Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 5F 6C 8C
          BB BC C6
VIN: WAUUPBFFXHAxxxxxx   Mileage: 91440km-56818miles
C6-Batt. Chrg. -- Status: OK 0000
Address 01: Engine (J623-CXUA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AN    HW: 04E 907 309 F
   Component: R4 1.4l TFS   H22 3695
   Revision: X3H22---
   Coding: 021D0012632401083000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM14TFS01104E906023AN 008005
   ROD: EV_ECM14TFS01104E906023AN_008.rod
   VCID: 6C941AB4878B992F6B-8038
32045 - Engine Coolant Bypass Valve 1
          P26AB 00 [096] - Stuck Open
25358 - Fuel Tank Door
          P04B6 00 [096] - Stuck Closed
                    Mileage: 89375 km
                    Date: 2019.11.28
                    Time: 12:01:33
                    Coolant temperature: 86 °C
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 13.060 V
                    Unlearning counter according OBD: 16
                    Gasoline tank pressure sensor: offset corrected: 0.00 hPa
                    Ambient air pressure: 99 kPa abs
                    Outside air temperature: -2 °C
                    Fuel pump: specified value: 3.999 %
                    High fuel pressure: control deviation: 1.0545 MPa
                    Fuel level: 9.00 l
                    State of shut-off valve to the gasoline pressure tank: true
                    State of shut-off valve to the gasoline pressure tank-Test_Program_B TRUE UBYTE: 1
   Part No SW: 0DD 300 046 G    HW: 0DD 927 770 C
   Component: GSG DQ400E    H32 1601
   Revision: 00032056    Serial number: TFK01809060012
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDQ400021 001001
   ROD: EV_TCMDQ400021_VW41.rod
   VCID: 2C14DAB4470B592F2B-8078
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 60707000000102
   Coding: 12FF40923822226D897F0A0881C72948021C44915081947202A15054820802
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003_AU37.rod
   VCID: 7CB42AF4F7EB09AFFB-8028
8400 - Databus
          [FCAN: AB_Gurt_FA signal is invalid]
16401 - Tire Pressure Warning
          C102D 00 [032] - -
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Revision: 00021000    Serial number: 0434636458
   Coding: 030C0C
   VCID: 3B36E9E8B265CE97B2-806E
   Part No SW: 8V0 820 043 S    HW: 8V0 820 043 S
   Component: AC Automat    H03 0610
   Revision: 20001000    Serial number: 00000001162873
   Coding: 0300001001000000080000000000140001000000
   ASAM Dataset: EV_AirCondiFrontNARAU37X 001019
   ROD: EV_AirCondiFrontNARAU37X.rod
   VCID: 42C8940CD58FBF5FF1-8016
   Subsystem 1 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G395 pT-Sens1  H61 0006
   Subsystem 2 - Part No SW: 3Q0 963 231 D    HW: 3Q0 963 231 D
   Component: J848 HV-PTC  200 0204
   Serial number: -00100.7U.2A20340381
   Subsystem 3 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
   Serial number: 5869C59880PAG0MUFU02
   Subsystem 4 - Part No SW: 5QE 816 803 C    HW: 5QE 816 803 C
   Component: J842 eKK  H02 0006
   Serial number: IABB00000K0000000115
   Part No SW: 5Q0 937 085 BF    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H34 0236
   Serial number: 02001706100536
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EB020FCE1F71BBFD5-802A
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 170129  043 0580
   Serial number:         170210171955
   Coding: 0A47F7
   Serial number: 62684515
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 30 12 2016  00001698
   Serial number: 00000000000068902469
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST001HTXW400000
   Coding: 101F00
   Part No SW: 5QA 919 294 A    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0038
   Serial number: 000308418617063
   Coding: 0470151011
   ASAM Dataset: EV_EPHVA18AU3700000 009031
   VCID: 4AD8BC2CEDBF671F39-801E
   Serial number: 003GCR07FJ0D
   Coding: 9DFCFCC0002000009000001AC24800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47DE8518FEAD9A7726-8012
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34230167A01031740661
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34230168A28021750153
   Coding: 333135
   Occupant Detection:
   Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
   Serial number: 694000000000001KPESL
   Coding: 303333
   Subsystem 4 - Part No SW: -----------    HW: 480 000 903 17
   Serial number: 35700000000283D4F12K
   Subsystem 5 - Part No SW: -----------    HW: 480 000 903 17
   Serial number: 35800000000F73D4F12X
   Subsystem 6 - Part No SW: -----------    HW: 480 401 003 17
   Serial number: 3510001C125187C1C3F3
   Subsystem 7 - Part No SW: -----------    HW: 480 401 003 17
   Serial number: 3520001C524CDB15040.
   Subsystem 8 - Part No SW: -----------    HW: 480 402 912 16
   Serial number: 3550002BB23C4E518213
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 402 912 16
   Serial number: 3560002B523C4E5580A9
   Part No SW: 8V0 953 521 JR    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 10031704401664
   Coding: A418
   VCID: 13666148FA75E6D70A-8046
   Part No SW: 8V0 920 873 G    HW: 8V0 920 873 G
   Component: KOMBI         H05 8316
   Coding: 0B240C19238000080203E8101A00000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009054
   Part No SW: 3Q0 907 530 D    HW: 3Q0 907 530 D
   Component: GW MQB EV     615 6286
   Serial number: 27021710522414
   Coding: 0201001726F200005B00120C581000000001010100010000000300000000
   ROD: EV_GatewNF.rod
   VCID: 302CCEC46B233DCF17-8064
   Subsystem 1 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
   Component: J453 MFL  H04 0003
   Serial number: 20170217024146 20360
   Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
   Serial number: 9234112704
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 E    HW: 5QE 909 059 B
   Component: EBKV          H14 0200
   Serial number:   085460010687
   Coding: 03720100331A02030002050500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
   ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
   VCID: 50ECAE440BE35DCF77-8004
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861090317065124
   Revision: 00000000    Serial number: 17000067935007
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424C2D49F3B01EF73-8060
   Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
   Serial number: 050217EB43193A
   Coding: 001C1F204000048000000002
   VCID: 41CA9B00D089A447E8-8014
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 100
                    Mileage: 91003 km
                    Date: 2019.12.15
                    Time: 07:11:16
   Component: EPS_MQB_ZFLS  128 1072
   Coding: C106
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45C28F10C4A18867D4-8010
Address 51: Electric Drive (J841)       Labels: None
   Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
   Component: LE Gen 3.3H11 1032
   Revision: 00H11000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM08530115G0907080E 001008
   ROD: EV_DMCM08530115G0907080E.rod
   VCID: 291A23A048F94C07D0-807C
   Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
   Serial number: 120217EBB23435
   Coding: 001C17204000048000000002
   VCID: 40CC9E04DB83AD4FE7-8014
                    Reset counter: 96
                    Mileage: 88456 km
                    Date: 2019.11.21
                    Time: 08:29:28
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 8V1 035 880 A    HW: 8V1 035 880
   Component: MU-P-LNS-US   053 0906
   Serial number: A702B0HS002313
   Coding: 01739302FF0A000011220001041A00002F0029C4017001047E
   VCID: 383CF6E48353E58F5F-806C
   Subsystem 1 - Part No SW: V03 959 801 GG    HW: -----------
   Component: NAR 2017  --- 0057
   Component: DU High  H49 0014
   Serial number: AUZ8Z9H1Y01UJU
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL120021700010401
   Component: Gracenote2---  --- 3011
   Coding: 0273100102002001400040
   VCID: 393AF3E0B859FC87A0-806C
Address 8C: Hybrid Battery (J840)       Labels: None
   Part No SW: 5Q0 915 182 E    HW: 5Q0 915 182 C
   Component: BECM          H05 1101
   Serial number: U8040054
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006042
   ROD: EV_BECM09620115Q0915182.rod
   VCID: 3522FFD0944118E744-8060
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
   Component: BJB  H28 0240
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D1  H14 0481
   Serial number: V013C1673030181
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D2  H14 0481
   Serial number: V013C1673030137
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D3  H14 0481
   Serial number: V013C1673030196
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D4  H14 0481
   Serial number: V013C1673030183
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D5  H14 0481
   Serial number: V013C1673030045
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D6  H14 0481
   Serial number: V013C1673030032
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D7  H14 0481
   Serial number: V013C1673030046
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
   Component: 6D8  H14 0481
   Serial number: V013C1673030031
29005 - Battery Energy Control Module
          P0A1F 00 [096] - -
          [Diag_H_BECM_Clock]
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Serial number: 070217EB617193
   Coding: 000C17204000048000000002
   VCID: 43C69108CA95B657FA-8016
   Serial number: 070217EB619241
Address C6: Batt. Chrg. (J1050)       Labels:* None
   Part No SW: 5QE 915 682 AP    HW: 5QE 915 682 AG
   Component: OBC KOSTAL    H31 4114
   Revision: --------    Serial number: 2001170AK0000L
   Coding: 105168023000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
   ROD: EV_OBCSinglPhaseKLOMQB12P.rod
   VCID: 1B76096812A5AE9752-804E
End----------(Elapsed Time: 01:43, VBatt start/end: 13.2V/13.2V)-----------
