Results 1 to 2 of 2
Thread: 2006 phaeton , level control
    Nov 2019
    In June 2019 I had a problem with the passenger front air suspension module leaking down and I ordered a replacement module on ebay for $350. I noticed that the control arm bushings were worn and replaced them all at this point the car had been on the lift for several months and when I lowered the lift the front suspension bottomed out. I filled the front, rear and reservoir with air and attempted to learn the level ride height. When the level ride calibration began the rear went up then down as expected but the front only moved slightly and never rose over 360 mm and the factory set height is 417mm. After several minutes it asked for the height of the left front and I entered the value but when I went to the 002 setting for the right front the screen showed security code required and the test shut down. My observation is that all of the problem started with the front passenger side loosing air and that is where I am still having a problem. I have studied this ride height issue in great detail but have not been able to diagnose the problem, I am hoping that some one may have encountered this problem and can offer some suggestions. Thanks, Jeff
    Tuesday,10,March,2020,11:56:14:19084
    VCDS Version: 19.6.2.2 (x64)
    VIN: WVWAK03D268002792   License Plate:
    Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
    Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
              34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
    VIN: WVWAK03D268002792   Mileage: 125350km-77888miles
    Address 01: Engine        Labels: 07C-906-018-BAP1.lbl
       Part No SW: 07C 906 018 AJ    HW: 000 000 000 00
       Component: D1-6.0L-AT-LEV2 G  ª6722
       Revision: --H01---    Serial number: VWZ3Z0E7396418
       Coding: 0000173
       Shop #: WSC 01065 000 00000
       VCID: 6DDA078677DB72277E-513C
    Readiness: 0010 0001
    Address 02: Auto Trans        Labels: 3D0-927-156.lbl
       Part No: 3D0 927 156 AB
       Component: AG5 01L 6.0lW12 USA 1010
       VCID: 68D476925839570F0D-513C
    Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
       Part No: 3D0 614 517 AK
       Component: ESP 5.7 allrad  H33 0047
       Coding: 0008397
       VCID: 6BDE099E49CF7C1760-513C
       Part No SW: 3D0 909 137 A    HW: 5WK 470 26
       Component:    Kessy            6700
       Revision: 67005614    Serial number: VWZ3Z0E7396418
       Coding: 0133356
       VCID: 254A3FA6EFAB8A67F6-513C
    Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
       Part No: 3D0 959 759 C
       Component: Sitzmemory D1 BF    1720
       Coding: 0000003
       VCID: 3668E8EA420DF1FF4F-513C
    Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
       Part No: 3D0 035 008 QX
       Component:    ZAB COCKPIT      0223
       Coding: 0500205
       Shop #: WSC 94302 999 84567
       VCID: 00044E3250498F4FA5-513C
    Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
       Part No: 3D0 907 040 J
       Component: Climatronic D1      2031
    Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
       Part No: 3D0 937 049 H
       Component: STG.Bordnetz        5101
       VCID: 2F66DD8EBD57C0370C-513C
    Address 11: Engine II        Labels: 07C-906-018-BAP2.lbl
       Coding: 0000173
       Part No: 3D0 909 601 H
       Component: 04 Airbag 8.4E++H01 0554
       Revision: BB38727     Serial number: 0005148<
       Coding: 0012340
       VCID: 2854369298B9970FCD-513C
       Subsystem 1 - Part No: 3D0 959 339
       Component: BF-Gewichtsens. 006 0005
    Address 16: Steering wheel        Labels: 3D0-953-549.lbl
       Part No: 3D0 953 549 E
       Component: Lenksäulenmodul     3401
       Coding: 0000232
    Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
       Part No: 3D0 920 882 P
       Component: KOMBIINSTRUMENT RB8 0521
       Coding: 0007321
       VCID: 346CD2E25471E3EF71-513C
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70E41EF260E99FCF55-513C
    Address 28: HVAC, Rear        Labels: 3D0-919-158.lbl
       Part No: 3D0 919 158 F
       Component: Klima-Bedienteil D1 0117
       VCID: 2E58C08ABA5DC93F07-513C
    Address 29: Left Light        Labels: 3D0-909-157.lbl
       Part No: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  X012
       VCID: 66C878AA522D417F3F-5120
    Address 34: Level Control        Labels: 3D0-907-553-V2.clb
       Part No: 3D0 907 553 C
       Component: LUFTFDR.-CDC- 3C3V0 1122
       Coding: 0007732
       Shop #: WSC 35376 002 104857
       VCID: 275635AE95A79877C4-513C
    01437 - Control Position not Learned
    Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
       Part No: 3D0 959 760 C
       Component: Sitzmemory D1 F     1720
       Coding: 0000004
    Address 37: Navigation        Labels: 3D0-919-887.lbl
       Part No: 3D0 919 887 F
       Component:    NAVIGATION       0168
       Coding: 0400000
       VCID: 3776E5EE450708F754-513C
    Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
       Part No: 3D0 907 135 B
       Component: Dachmodul           0605
       Coding: 0000015
       VCID: 224024BAFE857D5F93-513C
    00220 - Connection to Sunroof
       Part No: 3D0 909 158
       VCID: 67D675AE5527587704-5120
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 F
       Component:    HSG              0101
       Coding: 0000040
       VCID: 336ED1FE517FE4D768-4B18
       Subsystem 1 - Part No: 3D1 959 701 K
       Component: Tuersteuergeraet FS 5616
       Subsystem 2 - Part No: 3D1 959 702 K
       Component: Tuersteuergeraet BF 5616
       Subsystem 3 - Part No: 3D0 959 703 J
       Component: Tuersteuergeraet HL 5616
       Subsystem 4 - Part No: 3D0 959 704 J
       Component: Tuersteuergeraet HR 5616
       Subsystem 5 - Part No: 3D0 909 610 C
       Component: 3L HDSG             2330
       Subsystem 6 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 3D0 035 466 A
       Component: 12K-AUDIOVERST      0118
       VCID: 20442EB2F0896F4F85-513C
    Address 65: Tire Pressure        Labels: Redir Fail!
       Part No: 3D0 907 273 G
       Component: Reifendruckueberw.  0026
       Coding: 0410224
       VCID: 2A50CC9A86B5A51FDB-513C
    Address 66: Seat, Rear        Labels: None
       Part No: 3D0 959 860 C
       Component: Sitzmemory D1 H     1724
    Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V1.clb
       Part No: 3D1 955 119 A
       Component: Front Wiper         2005
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 C
       Component: Batteriemanagement  2700
       VCID: 234E21BEE19F745798-513C
    Address 76: Park Assist        Labels: None
       Part No: 3D0 919 283 D
       Component: 03 Einparkhilfe     0907
       VCID: 2B5EC99E894FBC1720-513C
    End-------------------------(Elapsed Time: 08:56)--------------------------
    HQ
    A common mistake people make when doing the suspension relearn is to submit the "default values", not an actual value using a metric tape measure.
    Are you submitting the actual mm measurement from the center cap to fender arch?
    Jef
  3. Likes Uwe, DV52 liked this post
