Results 1 to 3 of 3
Thread: VW Amarok - delete rear bass speakers
    Feb 2020
    I was hoping for some technical assistance. I work for a vehicle converter. We have at the moment a build of VW Amaroks which as part of the conversion require us to remove the rear door cards and speakers within the rear doors. When completing an autoscan on the finished vehicle the VCDS reports the error with rear bass speakers. I had a look at the coding but was unable to see if there is a way to code the car to ignore the rear bass speakers? Could anyone tell me if they have experience with this kind of coding or adaption?
    AutoScan results below.
    thanks in advance for any responses
    Jaymie
    Wednesday,11,March,2020,13:13:50:45835
    VCDS Version: 19.6.2.2  HEX-V2 CB: 0.4508.4
    VIN: WV1ZZZ2HZKH020552   License Plate:
    Chassis Type: 2H-VN81 (7E0)
    Scan: 01 02 03 04 08 09 10 15 17 19 25 5F 61 65 69 0B
    VIN: WV1ZZZ2HZKH020552   Mileage: 10km-6miles
    Address 01: Engine (J623-DDXE)       Labels: None
       Part No SW: 2H6 907 311 K    HW: 059 907 309 J
       Component: 3.0l V6 TDI   H23 0002
       Revision: 9AH23---
       Coding: 012A4032233601030000
       Shop #: WSC 02776 790 50316
       ASAM Dataset: EV_ECM30TDI0112H6907311K 001002
       ROD: EV_ECM30TDI0112H6907311K.rod
       VCID: 3039115A2AA86337795-8064
    Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
       Part No SW: 2H0 927 158 M    HW: 0DR 325 025 B
       Component: 0CM  30TDIRdW H22 1001
       Revision: --H22---
       Coding: 000001
       ASAM Dataset: EV_TCMAL450211 002011
       ROD: EV_TCMAL450211_002_VN81.rod
       VCID: 372B2A46CFC6B40F38F-8062
       Part No SW: 2H6 907 379 A    HW: 2H6 907 379
       Component: ESC           H06 0310
       Revision: 00000000    Serial number: 60769000000334
       Coding: 207364B64996B69504A726A892526D85390000
       ASAM Dataset: EV_Brake1ESCCONTIVN817GP 008001
       ROD: EV_Brake1ESCCONTIVN817GP_008.rod
       VCID: 34311D4ADEB05F171DD-8060
       Component: LENKW.SENSOR  H07 0070
       Serial number: 22011913470271
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EA5FF62A07C4547BB9-802A
    Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
       Part No SW: 2H6 907 040 B    HW: 2H6 907 040 B
       Component: ClimatronicT5 H04 0613
       Revision: 00001K05
       Coding: 0000000003
       ASAM Dataset: EV_ClimatronicT5 A01003
       ROD: EV_ClimaAutoT5Basis.rod
       VCID: 2615F702186C3D87939-8072
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 089 C    HW: 7E0 937 089 C
       Component: BCM PQ25 MMI4 H82 0762
       Revision: BB082001    Serial number: 8701 079190244
       Coding: 250002380C611400923809312C4B84D4B280654F60C25160310000030803
       Shop #: WSC 66305 000 1454502
       VCID: 33331E56DB3E582F047-8066
       Subsystem 1 - Part No SW: 6R0 959 802 CR    HW: 6R0 959 802 CR  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  022 1334
       Serial number: 13102700190326045506
       Subsystem 2 - Part No SW: 6R0 959 801 CQ    HW: 6R0 959 801 CQ  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  022 1334
       Serial number: 13102701190326040836
       Subsystem 3 - Part No: 5C0 951 171
       Component: Sensor, DWA 0  005 0502
       Subsystem 4 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0009
       Subsystem 5 - Part No: 5C0 951 171
       Subsystem 6 - Part No SW: 2H0 959 442     HW: 2H0 959 442
       Component: E221__MFL-DC1  H02 0103
       Serial number: 39190000513540079102
       Coding: A4FFFF
       Subsystem 7 - Part No SW: 6R0 959 811 P    HW: 6R0 959 811 P
       Component: J388__TSG_HL  022 1334
       Serial number: 13102709190327022042
       Subsystem 8 - Part No SW: 6R0 959 812 P    HW: 6R0 959 812 P
       Component: J389__TSG_HR  022 1334
       Serial number: 13202708190322003005
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0212
       Revision: --------    Serial number: 28231907203514
       Coding: 31810E
       ASAM Dataset: EV_VW75XParkAssis8K 001012
       ROD: EV_VW75XParkAssis8K_001_VN75.rod
       VCID: 71BFD45EE1222A3F36B-8024
       Part No SW: 2K5 959 655 D    HW: 2K5 959 655 D
       Component: VW10Airbag01S 010 0018
       Revision: --------    Serial number: 003EL005YVVA
       Coding: 000000000000000000000000000000003153
       Shop #: WSC 02774 790 50316
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       VCID: 3D27386EEDFA9E5FE23-8068
       Serial number: 3495RRB405560VK2E0FG
       Serial number: 3505RRB40535RVOGI8MQ
       Serial number: 3555YRB405P5SME2K8GO
       Serial number: 3565YRB40145I160GPHG
       Part No SW: 2H6 920 973 A    HW: 2H6 920 973 A
       Component: KOMBI         H02 2030
       Coding: 431E000300
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
       VCID: 2F3B122637967CCF60F-807A
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 089 C
       Component: GW-K-CAN TP20 H82 0762
       Revision: BB082001
       Coding: 742301
       VCID: 6889B93AD278EBF7615-803C
       Component: IMMO          H02 2030
       Coding: 000002
       VCID: 6A8DC332CCF4D9E7771-803E
       Part No SW: 5K7 035 200 K    HW: 5K7 035 200 K
       Component: MU-S-D-ER     H41 0475
       Serial number: VWZAZ2W0800208
       Coding: 06180700BE00000011111101008808001F0100D60020010003
       ROD: EV_MUStd4CTSAT_SK25.rod
       VCID: 2C01052A068007D745D-8078
    0512 - Rear Right Bass Speaker
              B1067 13 [009] - Open Circuit
              [Tieftonlautsprecher Kanal 1: Unterbrechung (DC-Diagnose)]
                        Reset counter: 1
                        Mileage: 14 km
                        Date: 2020.03.04
                        Time: 18:01:06
                        Voltage terminal 30: 11.9 V
    0527 - Rear Left Bass Speaker
              B1065 13 [009] - Open Circuit
              [Tieftonlautsprecher Kanal 4: Unterbrechung (DC-Diagnose)]
                        Reset counter: 1
                        Mileage: 14 km
                        Date: 2020.03.04
                        Time: 18:01:06
       Part No SW: 7E0 907 534     HW: 7E0 937 089 C
       Component: Batt.regelung H82 0762
       Coding: 330B18AF
       Shop #: WSC 02776 790 00000
       Subsystem 1 - Part No SW: 2H6 915 181     HW: 2H6 915 181
       Component: J367-BDMConti  H03 1051
       Serial number: 7497540900190312008E
       Part No SW: 2H6 907 273     HW: 5Q0 907 273
       Component: RDKBERU30     H04 0003
       Serial number: 40000000037713
       ASAM Dataset: EV_RDKBERU30 006003
       ROD: EV_RDKBERU30_006_VW48.rod
       VCID: 6C81C52AC600C7D705D-8038
       Component: Anhaenger     H12 0100
       Revision: 3A001001    Serial number: 00000511635374
       Coding: 010D000100000000
       VCID: 3039115A2A286337795-8064
    End----(Elapsed Time: 02:02, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Sometimes a picture is worth many words:
    Feb 2020
    thanks for the quick reply! Looks good
