Results 1 to 8 of 8
Thread: Audi C7 A6 DRL White to Orange conversion on full LED headlights.
    Feb 2020
    Hey guys,
    I posted about this a while back and couldn't find any info on it. I have the full LED headlights. The DRL is a solid white line. The indicator is a solid orange line.
    I spent about 3 hours with my Ross-Tech going through but I couldn't figure out where to code it in so I then pulled the headlight plug and ran a voltimeter to the pins
    Purple/Green - Constant 9v always
    Black/Blue - 10v when hazard indicator is on.
    Solid Purple - 10v when hazard indicator is on.
    blue/white - 7v when headlight switch is turned to running.
    blue/red - 10v when headlight switch is turned to running.
    My thinking was the LED strips have two sections so I spliced and tied the wires to be reversed:
    Blue/Black -> Blue/White
    Purple -> Blue Red
    Blue/White -> Blue Black
    Blue/Red -> Purple
    When reversed the white LED strip lights up when hazards are on, however when the running lights are turned on (The dimmed setting by headlight switch), it only lights up half the orange strip. I thought for a while that there must be another circuit I'm missing so I went back to my voltimeter and retested everything. Then I realized, that the white bulbs are dimmable and are simply dimmed when there's a lower voltage. The orange bulbs do not dimm so on lower voltage only half the strip lights up.
    I soldered the wires back to their original position and heat shrink wrapped them so I could do more research on the best method here. Maybe someone with more VCDS experience than me can assist. Open to any suggestions.
    Please refrain from posting your opinion about whether you think this is cool or not. I've also confirmed it is legal in my state to run a solid orange indicator up front.
    hmm..... certainly an innovative approach to solving your problem (based predominantly on the fundamental assumption that the turn-signal LED fittings are EXACTLY the same as the DRL LED fittings - except for colour!!!)
    Perhaps it might help if you posted-up a current UNEDITED auto-scan so forum folk can see how the car is equipped - it's always a good starting point for discussion!!
  3. Likes Uwe liked this post
    Feb 2020
    Here ya go
    Friday,13,March,2020,16:34:30:42847
    VCDS Version: 19.6.2.2  HEX-V2 CB: 0.4508.4
    VIN: WAUHMAFC3EN122101   License Plate:
    Chassis Type: FC-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 36 3B 3C 42 44 46 47
              52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90 AC
    VIN: WAUHMAFC3EN122101   Mileage: 61495km-38211miles
    Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 N    HW: 4G0 907 401 E
       Component: 3.0TDI FSA    H14 0013
       Revision: 58H14---
       Coding: 0A2A4012056601050000
       Shop #: WSC 63778 002 1048576
       ASAM Dataset: EV_ECM30TDI0114G0907401N 002013
       ROD: EV_ECM30TDI0114G0907401N_002.rod
       VCID: 2E05082BD09D30876B9-807A
       Part No SW: 4G0 927 158 Q    HW: 0BK 927 156 AM
       Component: 0BK 30 TDIUSA H16 1008
       Revision: --H16---
       Coding: 000001
       VCID: 3C21326316E1D217D5D-8068
       Part No SW: 4G0 907 379 M    HW: 4G0 907 379 M
       Coding: 27A79701E4E5E9804B00
       VCID: 3B23317F13EFD52FDC7-806E
    0478 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [SCL_Gateway_05_BCM1_01_alt]
                        Reset counter: 81
                        Time: 00:00:00
                        VzRef: 00
                        Bit Info 1: 80
                        Bit Info 2: 0F
                        Bit Info 3: 02
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: FD
                        Uz: 7F
       Part No SW: 4H0 907 064 ER    HW: 4H0 907 064 ER
       Component: BCM2 2.0      H36 0521
       Coding: 0DA82046000000000000
       VCID: 7DA7FF674DFB1B1FA23-8028
       Serial number: 0214000023613014
    00956 - Key 2
                        Reset counter: 79
                        Mileage: 59444 km
                        Date: 2020.02.03
                        Time: 08:04:24
       Part No SW: 4G0 820 043 AN    HW: 4G0 820 043 AN
       Component: KLIMA 4 ZONEN H14 0093
       Serial number: 05021400041733
       Coding: 368120BA4D
       ASAM Dataset: EV_AirCondiComfoUDS 004003
       ROD: EV_AirCondiComfoUDS_004.rod
       VCID: 6B83C13F230F85AF0C7-803E
    0386 - Functional Limitation due to Energy Management
              B10CD 00 [008] - -
                        Reset counter: 75
                        Mileage: 61071 km
                        Date: 2020.02.28
                        Time: 15:43:14
                        Voltage terminal 30: 11.30 V
                        Outside air temperature: 11.5 °C
                        Energy management deactivation stage: 1
       Revision: 11012002    Serial number: 00000001697224
       Coding: 8907A091073C9FE281800084A0003800CF9CD208A60802258001085C7B00
       VCID: 6FBBD52F1797798F20F-803A
       Component: WWS57X 140201  H37 0080
       Serial number:         140204201113
       Coding: 0045F7
       Serial number: 22234636
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 31 01 2014  00000765
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555RA4WJ03
       Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0090184005
       Coding: 853000
       Serial number: 00000003021400010485
       Coding: 110000
       Subsystem 7 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Serial number: 00000005021400010491
       Coding: 110000
       Subsystem 8 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA107528000006088584
       Coding: 020300
       Subsystem 9 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 58388F07000000000001
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                        Fault Status: 00101100
                        Reset counter: 81
                        Mileage: 61361 km
                        Date: 2020.03.09
                        Time: 16:06:00
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                        Reset counter: 81
                        Mileage: 61361 km
                        Date: 2020.03.09
                        Time: 16:06:00
       Revision: 11001001    Serial number: 61031404900509
       Coding: A8EB06
       VCID: 71BFD35701236F7F36B-8024
       Part No SW: 4G0 907 561 A    HW: 4G0 907 561
       Component: ACC3          H19 0410
       Coding: 7E01010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002010
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 2809FE33F2796EB7A15-807C
    10240 - Sensor for Automatic Distance Control
              [FAULT_BLR_BLK8_31]
                        Reset counter: 82
                        Mileage: 61401 km
                        Date: 2020.03.09
                        Time: 19:34:09
                        Control Module temperature: 12 °C
                        Voltage terminal 15: 14.290 V
                        Velocity_vehicle_reference: 28.19 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.10 m/s²
    16640 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [FAULT_VMON_VZ_LOW1]
                        Reset counter: 81
                        Mileage: 61361 km
                        Date: 2020.03.09
                        Time: 17:34:06
                        Control Module temperature: 18 °C
                        Voltage terminal 15: 9.212 V
                        Velocity_vehicle_reference: -0.01 m/s
       Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
       Component: Airbag10.43   H33 0033
       Revision: --------    Serial number: 003D8003VW48
       Coding: 303234373131303030324A55304C34473053
       VCID: 3333195F3BBF1D6F047-8066
       Serial number: 6940000Y14000124AW0L
       Serial number: 3575HRB405L2ATKI9PDG
       Serial number: 3585HRB40572ANV45HKW
       Serial number: 3515JRB400E50REKKQ8.
       Serial number: 3525JRB400G50S02FGM8
       Serial number: 3554VRB401E50SAMO98$
       Serial number: 3564VRB400A50TIMMGKI
       Revision: --------    Serial number: 90372NB5000GW
       Coding: 0004DC
       VCID: 38292E732259FE37315-806C
       Subsystem 1 - Part No SW: 4G0 951 528 F    HW: 4G0 951 528 F
       Component: E221 - MFL  H09 0010
       Serial number: 16 10 2013  B1250065
       Part No SW: 4G8 920 984 A    HW: 4G8 920 984 A
       Component: TDieUsaAccNv  H58 0621
       Revision: 29460235    Serial number: 658120214596006
       Coding: 0BCF0A040F51D705020000
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 34311A433EB11A571DD-8060
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001268944
       Coding: 00CD077D00
       VCID: 72BDDC5B04255467CF1-8026
       Serial number: 8076742403
       Voltage stabilizer:
       Serial number: 1310080000000000049F
    0267 - Optical data bus
              U1049 00 [008] - Open circuit
                        Reset counter: 81
                        Mileage: 61359 km
                        Date: 2020.03.08
                        Time: 22:00:45
                        Voltage terminal 30: 11.9 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 13 °C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 0
              U140B 00 [008] - -
              [Powermanagement active]
                        Fault Frequency: 14
                        Reset counter: 81
                        Mileage: 61071 km
                        Date: 2020.02.28
                        Time: 15:43:13
                        Voltage terminal 30: 11.2 V
                        Voltage terminal 15: 11.2 V
                        Control Module temperature: 22 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 1
       Part No SW: 4G0 919 158 N    HW: 4G0 919 158 N
       Component: KLIMA FOND    H08 0093
       Serial number: 06021400042063
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
       VCID: 3A2D347B1CD5EC27C71-806E
    0075 - Button or Switch in Operating Unit
              B10C7 07 [008] - Mechanical Failure
                        Reset counter: 79
                        Mileage: 61235 km
                        Date: 2020.03.07
                        Time: 14:56:17
                        Outside air temperature: 7.0 °C
                        Left rear vent temperature: 21.3 °C
       Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
       Revision: AA000000    Serial number: 00000089777525
       Coding: C0581B008F006001000001010101102030303232203232
       Component: SARA 6D       H03 0056
       Revision: --------    Serial number: EJ1BPA82069GE6
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3635204B28CD0847239-8062
       Part No SW: 4G0 907 566 D    HW: 4G0 907 566
       Component: J769  SWA MasterH03 0060
       Revision: 00H03000    Serial number: 6PZ 010 287-03
       VCID: 30391653C6292677795-8064
       Subsystem 1 - Part No: 4G0 907 568 D
       Component: J770  SWA Slave H03 0060
       Subsystem 2 - Serial number: 6PZ 010 287-23
       Subsystem 3 - Serial number: 5F14.02.1400H03000AMS14119˙
       Subsystem 4 - Serial number: S14119˙
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011F17005E00628002000013
       VCID: 45D7578765AB93DFBA3-8010
       Component: RCEPS         H40 0010
       Revision: 00001000    Serial number: 0002274758
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323D1C5BC4A514670F1-8066
       Revision: 00002001    Serial number: 0327071888
       Coding: 0106063A00FA408580A0088402070E470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000205085
       Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
       Component: J245 PS40.039  H01 0008
       Serial number:     WOO27056464
       Coding: 101F00
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00005883221
       Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 93165332
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 10
                        Reset counter: 41
                        Mileage: 60888 km
                        Date: 2020.02.25
                        Time: 19:56:31
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 41
                        Mileage: 60888 km
                        Date: 2020.02.26
                        Time: 06:35:55
       Part No SW: 4G0 035 465 C    HW: 4G0 035 465 B
       Component: BO G3 C7      H09 0160
       Revision: 11000000    Serial number: 0019033
       VCID: 2517F70785EB73DF9A3-8070
       Subsystem 1 - Part No SW: 4G0 035 466     HW: 4G0 035 466
       Component: BO C7 SLAVE  H51 0100
       Serial number: 01412130026332
       Coding: 011F17005E00628002000002
       VCID: 46D5508B58AD98C7B39-8012
       Component: EPB-4         H03 0015
       Revision: --------    Serial number: 00000000959061
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D070F27DD9B4B9F523-8078
       Serial number: 140207-0002-129
       Coding: 1221A6601002A500
       ROD: EV_HeadlRegulBasic.rod
    392711 - Positioning Motor for Headlight Range Left
              C1085 11 [008] - Short to Ground
                        Reset counter: 72
                        Mileage: 61071 km
                        Date: 2020.02.28
                        Time: 15:53:58
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156B%0E7966262
       Coding: 020007010000000001
       VCID: 2411EA038ED18AD78DD-8070
       Part No SW: 4G0 035 746 F    HW: 4G0 035 746 E
       Component: H-BNT-NA      H41 0757
       Revision: --------    Serial number: 194BX0E7601904
       Coding: 050200000003E9EF7D12CB1E00000003100001000000000000
       VCID: 2A0D043BECF55CA7B71-807E
       Subsystem 1 - Part No: 8R0 060 884 BL
       Component: NAR 2014  0902
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDDD003RCXH
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
       Serial number: 90349NBD00092
       Component: CD-Database  5571
    02067 - Optical Databus; Unpermitted Wake-Up Request
                        Reset counter: 81
                        Mileage: 61359 km
                        Date: 2020.03.08
                        Time: 21:10:01
                        Voltage: 11.90 V
       VCID: 49CF5BB749B377BF5EB-801C
       Part No SW: 4H0 907 428 B    HW: 7P6 907 441 D
       Component: TopView       H05 0220
       Revision: 11001001    Serial number: 82330JF0133842
       Coding: 0200000001010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 007026
       ROD: EV_CamerSysteTopViewAUDI_007_AU57.rod
       VCID: 2C010223E681429745D-8078
    9617697 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [Functional limitation by undervoltage]
                        Mileage: 61361 km
                        Date: 2020.03.09
                        Time: 17:59:09
                        Voltage terminal 30: 8.3 V
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H26 0038
       Coding: 6A060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2615F00BF86D78C7939-8072
       Part No SW: 4G0 907 541 A    HW: 4G0 907 541
       Component: ACC3          H19 0400
       Coding: 7E01010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H32 0041
       Serial number: 005000121102147
       Coding: 04C198180111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 313F1357C1A32F7F76B-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H09 0010
       Revision: 00000000    Serial number: 133330161
       ROD: EV_RDCMA00100_008.rod
       VCID: 2B03013FE38F45AF4C7-807E
    End----(Elapsed Time: 02:57, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
    Feb 2020
    Thoughts?
    ^^^hmm........ nothing obvious to me - perhaps someone else here has insights?
    I've had a read of the SSP for the A6 here and it mentions on page 46 that the DRL and turn-signal LED strips share the same power supply module (A32 is the Left-side "Module 2" for parking/DRL and turn signal)
    The SSP also confirms that the headlight assemblies on the car are controlled by the BCM via separate wiring for the various lamps - which is not incompatible with your objective (I'm guessing of course). At least these 2 x lighting functions don't appear to be enabled via a CAN message. However, it's not clear whether the design of the orange LEDs permit dimming (i.e. whereas the DRLs permit variable states of illumination via Pulse Width Modulation, turn-signals have a binary ON/OFF state as factory designed). If dimming is not permitted, it might be necessary to disable this function - I'm not sure how, or even if it's possible.
    Perhaps reference to the WD will shed further light (pun intended) on the potential success of your venture? The WD should identify which BCM pins are dedicated to each of the DRL and Turn-signal functions - it may be as simple as swapping these wires (or not).
    Now that we know that the BCM is the lighting controller, the other option that might be worth pursuing is investigation of the adaptation channels in the hex09 module. Perhaps make an admap- maybe?
    Feb 2020
    Jesus, you're a beast!
    I'll take a stab at it tomorrow.
    Quote Originally Posted by nthusiastt View Post
    An oxymoron perhaps? But yes (about the latter-part), and my number is 666!!!
  9. Likes Uwe, PetrolDave liked this post
  10. #8
    Feb 2020
    Jesus was a beast. Dude was money
