Results 1 to 2 of 2
Thread: 2007 audi a4q cabrio no reverse lights
    Aug 2019
    The issue is i dont have reverse lights. I can turn them on via the 519, but it never sees "reverse lights active via can" mvb 9 at the 519, i think mvb 9. it sees brake lights active via can. It sees reverse and all other prndl features in the cluster, trans, engine, abs. I tried a new 519 module and noticed this car has had new headlights put in that are not bi xenon when i went to code. I tried the different coding options, there is no coding option for no xenons and a us car. headlights and other lights work fine and i tried disconnecting them. I also noticed the cluster coding was questionable on the first coding option, its a 007 but seems it should be 001, that it wont accept. Im at a bit of a loss here, wiring diagram show one wire coming out gear position switch that seems the be the info line for postion that does not go directly to the 519. I feel its a coding problem but cant find an issue i can confirm and change. Thanks for any input.
    VIN: WAUDF48H27K029674   License Plate:
    Mileage: 140950km-87582mi   Repair Order:
    Chassis Type: 8H (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
              67 69 75 76 77
    VIN: WAUDF48H27K029674   Mileage: 140950km-87582miles
       Part No SW: 8E1 910 115     HW: 8E0 907 115 D
       Component: 2.0l R4/4V TFSI     0030
       Revision: 5EH15---    Serial number:
       Coding: 011C010A190F0120
       Shop #: WSC 00672 785 00200
       VCID: 5F8E580E8E7C92B7FC-800A
    Readiness: 0110 0101
       Part No SW: 8E1 910 156 K    HW: 09L 927 156 B
       Component: AG6 09L 2,0TFSI USA 0050
       Revision: --H01---    Serial number:        4287631
       VCID: 2F2EE8CEBE5C42370C-807A
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
       Component: ESP8 quattro    H06 0140
       Coding: 0004528
       VCID: 2E10F5CAB9564B3F07-807A
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   3233
       Coding: 00100
       Shop #: WSC 00672
       VCID: 6D9232C625D0F0277E-513C
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 N
       Component: int. Lastmodul  USA 0907
       Coding: 20013
       Shop #: WSC 00672
       VCID: 3D32C2863530A0A78E-4B00
    Address 15: Airbags        Labels: 8H0-959-655-94.lbl
       Part No SW: 8H0 959 655 F    HW: 8H0 959 655 F
       Component:    Airbag 9.42  H10 1830
       Revision: 92H10183    Serial number: 0037Z0006W0/
       Coding: 0132105
       VCID: 3D32C2866430A0A78E-8068
       Subsystem 1 - Part No: 8H0 910 339
       Component: BF-Gewichtsens. H01 0020
       Subsystem 2 - Serial number: 3HJ3X
       Subsystem 3 - Serial number: 0001.01.0000H0100000000000˙†63
       Subsystem 4 - Serial number: 000000˙†6332BRB401F3FEC86˙†63
       Subsystem 5 - Serial number: 3FEC86˙†6342BRB401F3FF21Y˙†63
       Subsystem 6 - Serial number: 3FF21Y˙†63729RB40221E266G˙†63
       Subsystem 7 - Serial number: 1E266G˙†63829RB40221E22BI˙
       Subsystem 8 - Serial number: 1E22BI˙
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0701
       Coding: 02041
       Shop #: WSC 00672
       VCID: 41CABE7649C8C447EA-4B00
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8H0 920 951 F    HW: 8H0 920 951 F
       Component: KOMBI+WFS 4     H14 0200
       Revision: 0200        Serial number: 00000000000000
       Coding: 0007261
       Shop #: WSC 08259 444 10256
       VCID: 302CEBB2A2625DCF15-5184
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0007261
       Part No: 8H0 959 433 C
       Component: Komfortgerát T7B    1311
       Coding: 11788
       Shop #: WSC 00672
       VCID: 3424E7A2067A61EF71-4B00
       Subsystem 1 - Part No: 8H1959801E
       Component: Tőrsteuer.FS BRM 0205
       Subsystem 2 - Part No: 8H1959802D
       Component: Tőrsteuer.BF BRM 0205
       Subsystem 3 - Part No: 8H0959801A
       Component: Tőrsteuer.HL BRM 0002
       Subsystem 4 - Part No: 8H0959802A
       Component: Tőrsteuer.HR BRM 0002
       Part No SW: 8E0 035 195 AC    HW: 8E0 035 195 AC
       Component: R Symphony2+    H06 0221
       Revision: 00H06000    Serial number: AUZ1Z4G4446673
       Coding: 0210132
       VCID: 689C43D25932D50F0D-5160
    End----(Elapsed Time: 05:55, VBatt start/end: 12.8V/12.8V. VIgn 0.0V)------
    16.4905° S, 151.7375° W
    The coding of the [09-Cent. Elect.] (J519) does not appear to be able to code out the reverse lights functions. The expected coding for this vehicle's (J519) seems to be [20003]. The coding for the J285- Instrument Cluster seems to be fine.
    The Measuring Value Block group [009], field (4) in the (J519), shows the "Reverse Gear, (via CAN)".
    - This field is not displaying the "activation'" of the actual reverse lights, instead this is the message that has come from the J217-Transmission controller on the Powertrain CAN-Bus via the Comfort CAN-Bus on the J285- Instrument Cluster.
    We had a customer with a 2009 A4 (w/09L trans) that had the same concern, "no reverse lights", no change in the MVB-009 and the obvious Reverse Signal coming from the J217-Transmission controller (see MVB-004, field 3 = Multi-Function Switch (F125)).
    The had informed us that they ended up replacing the (J519) and the concern was gone, Reverse Lights were functional.
    With that said, did you use the same exact part number when you tried a new (J519) controller? Was it 'New' or 'Used'? Part numbers do matter and not all J519s are created equal!
    If the (J519) is okay and the CAN-Bus message for reverse is never making it to the (J519), it is possible the J285-Instrument Cluster is not sending the "reverse" CAN-Bus message? It hard to tell for sure, since you can not really 'see' a CAN-Bus message without an oscilloscope for CAN-Analyzer.
    Before you condemn or replace any controller, I suggest to verify that all the powers, grounds and connections for that controller are 100% correct. The use of the Official Factory Repair Information is highly recommend.
    Hope this helps,
    drpeter
  3. Likes Uwe liked this post
