Results 1 to 10 of 16
Thread: Audi A6 C6 (facelift) heated seats... boost?
    Mar 2020
    Hi guys,
    I've noticed how the heated seats in my Audi C6.5 are feeble at best. Via my VCDS I'm able to read all the values and in Module 8, measuring blocks 27 and 28 it gives me the information on the seats. In my car it's possible to set it to 6 levels, most of which are apparently far below body temperature
    Only settings 5 and 6 seems vaguely useful, where setting 6 sets the seats to 38 degrees (celcius, to be clear, that's only just above body temperature), and setting 5 sets them to 33 degrees, already below. I'm sorry, but how is that heated? It's more like lukewarm
    Apparently this is simply the way they're programmed. If I briefly turn down the seats to let's say setting 3 (programmed to 17 degrees ), and then turn it back up to 6 it feels hotter for a bit, although it doesn't really ever display more than 39 degrees on VCDS.
    So the question is simple: is it possible to adjust the target temperatures for these settings? I'd really be looking for something 10 degrees higher at least, I can always turn it down if it's too hot. But six settings, of which 5 are pointless... I don't get that. I know that in the pre-facelift models the heated seats were much better, but in mine they're very disappointing. I haven't been able to find anything simply browsing around...
    Thanks in advance!
    Edit: added the auto-scan
    Mittwoch,11,März,2020,08:30:28:24747
    VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x64
    VCDS Version: AIB 18.9.1.0  HEX-V2 CB: 0.4508.4
    Datenstand: 20190215 DS296.0
    www.vcds.de
    Fahrzeug-Ident.-Nr.: WAUZZZ4F8AN073201   KFZ-Kennzeichen:
    Fahrzeugtyp: 4F-AU56 (4F0)
    Scan: 01 02 03 05 08 09 0E 13 15 16 17 19 34 42 46 47 4F 52 53 55
              56 5F 62 69 72 76
    Fahrzeug-Ident.-Nr.: WAUZZZ4F8AN073201   Kilometerstand: 269670km
    01-Motorelektronik -- Status: i.O. 0000
    02-Getriebe -- Status: i.O. 0000
    03-Bremsenelektronik -- Status: i.O. 0000
    04-Lenkwinkelsensor -- Status: i.O. 0000
    05-Zugangs-/Startber. -- Status: i.O. 0000
    08-Klima-/Heizungsel. -- Status: i.O. 0000
    09-Zentralelektrik -- Status: i.O. 0000
    0E-Media Player 1 -- Status: i.O. 0000
    13-Distanzregelung -- Status: i.O. 0000
    15-Airbag -- Status: i.O. 0000
    16-Lenkradelektronik -- Status: i.O. 0000
    17-Schalttafeleinsatz -- Status: i.O. 0000
    19-Diagnoseinterface -- Status: i.O. 0000
    34-Niveauregelung -- Status: i.O. 0000
    42-Türelektr. Fahrer -- Status: i.O. 0000
    46-Komfortsystem -- Status: Fehler 0010
    47-Soundsystem -- Status: i.O. 0000
    4F-Zentralelektrik II -- Status: i.O. 0000
    52-Türelektr. Beifahr. -- Status: i.O. 0000
    53-Feststellbremse -- Status: i.O. 0000
    55-Leuchtweitenreg. -- Status: i.O. 0000
    56-Radio -- Status: Fehler 0010
    5F-Informationselek. I -- Status: i.O. 0000
    62-Türelektr. hi. li. -- Status: i.O. 0000
    69-Anhänger -- Status: i.O. 0000
    72-Türelektr. hi. re. -- Status: i.O. 0000
    76-Einparkhilfe -- Status: i.O. 0000
    Adresse 01: Motorelektronik (J623-CAHB)       Labeldatei:* Keine
       Teilenummer SW: 03L 906 019 M    HW: 03L 906 022 FG
       Bauteil: R4 2,0L EDC   X03 6417
       Revision: 11X03---    Seriennummer:
       Codierung: 010D002C02072220
       Betriebsnr.: WSC 92521 052 00000
       ASAM Datensatz: EV_ECM20TDI03L906019M A01003
       ROD: EV_ECM20TDI03L906019AF.rod
       VCID: 3536DAF225C77C1F7DB-8060
    1 Fehler gefunden:
    4799 - Luftmassenmesser (G70)
              P0102 00 [032] - Signal zu klein
              Sporadisch - unbestätigt - geprüft seit letzter Löschung
    Adresse 02: Getriebe        Labeldatei: DRV\01J-927-156.lbl
       Teilenummer SW: 4F9 910 155 D    HW: 01J 927 156 JG
       Bauteil: V30 0AN 2.0l CR RdW 0020
       Revision: --H06---    Seriennummer: 00000000000474
       Codierung: 0000001
       Betriebsnr.: WSC 02325 785 00200
       VCID: 2C00FF96FA0D3DD7125-8078
    Adresse 03: Bremsenelektronik        Labeldatei: DRV\4F0-910-517.lbl
       Teilenummer SW: 4F0 910 517 AK    HW: 4F0 614 517 AT
       Bauteil: ESP8 front      H03 0060
       Revision: 00000000    Seriennummer: 00000000000000
       Codierung: 0000380
       VCID: 6D8632920197F4DF45B-8038
    Adresse 05: Zugangs-/Startber.        Labeldatei:. 4F0-910-852.clb
       Teilenummer SW: 4F0 910 852 B    HW: 4F0 905 852 D
       Bauteil: FBSAUDIC6 ELV   H05 0100
       Revision: 00H05000    Seriennummer: 10602601543296
       Codierung: 0000131
       Betriebsnr.: WSC 02323 785 00200
       VCID: 25160AB299E70C9FCDB-8070
       Subsystem 1 - Teilenummer: 4F0 910 132 E
       Bauteil: FBSAUDIC6 EZS   H03 0020
       Subsystem 2 - Teilenummer: 4F0 910 220 D
       Bauteil: FBSAUDIC6 IDG   H01 0054
    Adresse 08: Klima-/Heizungsel.        Labeldatei: 4F0-910-043.clb
       Teilenummer SW: 4F0 910 043 B    HW: 4F1 820 043 AL
       Bauteil: KLIMABETAETIGUNGH30 0080
       Revision: 00000076    Seriennummer: 00000000691520
       Codierung: 0000276
       VCID: 1D662252B1B7C45F95B-8048
    Adresse 09: Zentralelektrik        Labeldatei: DRV\4F0-910-279.lbl
       Teilenummer SW: 4F0 910 279 N    HW: 4F0 907 279
       Bauteil: ILM Fahrer      H22 0320
       Revision: 00000000    Seriennummer: 4F0907279
       Codierung: 0003122
       Betriebsnr.: WSC 02335 785 00200
       VCID: 3430E7F6223D65174A5-8060
       Subsystem 1 - Teilenummer: 4F1 910 113 D  Labeldatei: DRV\1KX-955-119.CLB
       Bauteil: Wischer AudiC6  H10 0040
       Codierung: 00056595
       Subsystem 2 - Teilenummer: 8K0 910 557   Labeldatei: DRV\8K0-955-559.CLB
       Bauteil: REGENLICHTSENSORH04 0003
       Codierung: 00211757
    Adresse 0E: Media Player 1 (R41)       Labeldatei: DRV\4E0-910-111.lbl
       Teilenummer SW: 4F0 035 110 A    HW: 4F0 035 110
       Bauteil: CDC-MP3-Alp   H44 0140
       Revision: AA001001
       VCID: 15763A7245879C1F5DB-8040
    Adresse 13: Distanzregelung        Labeldatei: DRV\4F0-910-561.clb
       Teilenummer SW: 4F0 910 561 C    HW: 4F0 907 561 B
       Bauteil: ABSTANDSREGELUNGH02 0020
       Revision: --------    Seriennummer: 00000000000000
       Codierung: 0061161
       Betriebsnr.: WSC 00046 000 00000
       VCID: 231214AA97D3F2AFA3F-8076
    Adresse 15: Airbag (J234)       Labeldatei:| DRV\4F0-910-655-10.clb
       Teilenummer SW: 4F0 910 655 Q    HW: 4F0 959 655 G
       Bauteil: Airbag AU1042 H07 0200
       Revision: --------    Seriennummer: 003F9002LUTN
       Codierung: 30314236303630303031554A304C34463053
       ASAM Datensatz: EV_Airba10AURB4 001001
       ROD: EV_Airba10AURB4.rod
       Crashsensor für Seitenairbag Fahrerseite:
       Seriennummer: 3574SRB40000AE19112+
       Crashsensor für Seitenairbag Beifahrerseite:
       Seriennummer: 3584SRB40000AE404979
       Crashsensor für Seitenairbag hinten Fahrerseite:
       Seriennummer: 3516HRB4035COCQ723PL
       Crashsensor für Seitenairbag hinten Beifahrerseite:
       Seriennummer: 3526HRB402HCTBFR4J95
       Crashsensor für Frontairbag Fahrerseite:
       Seriennummer: 3554NRB40000572DFEEN
       Crashsensor für Frontairbag Beifahrerseite:
       Seriennummer: 3564NRB4000056A3529.
    Adresse 16: Lenkradelektronik        Labeldatei: DRV\4F0-910-549.lbl
       Teilenummer SW: 4F0 910 549 A    HW: 4F0 953 549 D
       Bauteil: J0527               0530
       Revision: 00H05000    Seriennummer: 90026100700040
       Codierung: 0002052
       VCID: 270A00BAE3EB1E8FFF7-8072
       Subsystem 1 - Teilenummer: XXXXXXXXXXX
       Bauteil: E0221           H02 0100
    Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:. DRV\4F0-920-xxx-17.clb
       Teilenummer SW: 4F0 920 934 A    HW: 4F0 920 934 A
       Bauteil: KOMBIINSTR.   H08 0147
       Revision: 00300000    Seriennummer: DH622CA3A
       Codierung: 0F5F11050601000C010100
       Betriebsnr.: WSC 02391 823 56573
       VCID: 26140DBEE8E10787C41-8072
    Adresse 19: Diagnoseinterface (J533)       Labeldatei:. 4F0-907-468.clb
       Teilenummer SW: 4F0 907 468 N    HW: 4F0 907 468 G
       Bauteil: GW-BEM 5CAN-M H06 0035
       Revision: MB200030    Seriennummer: 3000M103098034
       Codierung: 000B03
       VCID: 3A2CC9CE0C599367909-806E
       Subsystem 1 - Teilenummer SW: 8K0 915 181 C    HW: 8K0 915 181 C
       Bauteil: J367-BDM  H07 0125
       Seriennummer: 00000000002790145919
    Adresse 34: Niveauregelung        Labeldatei: DRV\4F0-910-553.clb
       Teilenummer SW: 4F0 910 553 C    HW: 4F0 907 553 A
       Bauteil: J197 LUFTFEDER  H17 0030
       Seriennummer: 00871001568800
       Codierung: 0000120
       Betriebsnr.: WSC 02895 202 82454
       VCID: 241017B692DDF597DA5-8070
    Adresse 42: Türelektr. Fahrer (J386)       Labeldatei:. 4F0-959-793.clb
       Teilenummer SW: 4F0 959 793 R    HW: 8K0 959 793 D
       Bauteil: TSG FA        H11 0250
       Revision:             Seriennummer: 0000103197575
       Codierung: 011C02205440410001
       VCID: 46D4AD3E48A1E787E41-8012
    Adresse 46: Komfortsystem        Labeldatei:. 4F0-910-289.lbl
       Teilenummer SW: 4F0 910 289 N    HW: 4F0 907 289 N
       Bauteil: Komfortgeraet   H29 0250
       Revision: 02500029    Seriennummer: 01283689760000
       Codierung: 2237169
       VCID: 3536DAF229477C1F7DB-8060
       Subsystem 1 - Teilenummer: 1K0 951 605 C
       Bauteil: LIN BACKUP HORN H05 1501
       Subsystem 2 - Teilenummer: 4F0 910 177
       Bauteil: Innenraumueberw.H01 0020
    3 Fehlercodes gefunden:
    00317 - Steuergerät für Heckklappe (J605)
                004 - kein Signal/Kommunikation
                 Umgebungsbedingungen:
                        Fehlerstatus: 01100100
                        Fehlerpriorität: 5
                        Fehlerhäufigkeit: 254
                        Verlernzähler: 27
                        Kilometerstand: 264740 km
                        Zeitangabe: 0
                        Datum: 2019.10.24
                        Zeit: 11:28:40
    01697 - Fußraumleuchte hinten rechts (W46)
                011 - Unterbrechung
                        Fehlerstatus: 01101011
                        Fehlerpriorität: 3
                        Verlernzähler: 24
                        Kilometerstand: 262108 km
                        Zeitangabe: 0
                        Datum: 2019.08.19
                        Zeit: 17:15:29
    01696 - Fußraumleuchte hinten links (W45)
                011 - Unterbrechung
                        Fehlerpriorität: 3
                        Verlernzähler: 24
                        Kilometerstand: 262510 km
                        Zeitangabe: 0
                        Datum: 2019.08.25
                        Zeit: 17:30:39
    Adresse 47: Soundsystem (J525)       Labeldatei:. DRV\4F0-035-223-BO.clb
       Teilenummer SW: 4F0 035 223 P    HW: 4F0 035 223 P
       Bauteil: BOSE G3 C6    H01 0100
       Revision: AG001300    Seriennummer: 00000000117348
       Codierung: 0D010000
       Betriebsnr.: WSC 09581 002 1048576
       VCID: 290E0682F9FF28FFE93-807C
    Adresse 4F: Zentralelektrik II        Labeldatei: DRV\4F0-910-280.lbl
       Teilenummer SW: 4F0 910 280     HW: 4F0 907 280 A
       Bauteil: ILM Beifahrer   H13 0100
       Revision:             Seriennummer: 00000000697775
       Codierung: 0001104
       VCID: 5EE4655EFC319F47CC1-800A
    Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei:. 4F0-959-792.clb
       Teilenummer SW: 4F0 959 792 R    HW: 8K0 959 792 D
       Bauteil: TSG BF        H11 0250
       Revision:             Seriennummer: 0000103221619
       Codierung: 011C02205C40410001
       VCID: 45D6AA3275A7EC9FEDB-8010
    Adresse 53: Feststellbremse        Labeldatei: DRV\4F0-910-801.clb
       Teilenummer SW: 4F0 910 801 D    HW: 4F0 907 801 B
       Bauteil: EPB  CEFC0090   H05 0090
       Revision: --H05---
       Codierung: 0000131
       Betriebsnr.: WSC 02145 785 00200
       VCID: 211E1EA28DCFE0BFB13-8074
    Adresse 55: Leuchtweitenreg.        Labeldatei: DRV\8P0-907-357.lbl
       Teilenummer: 8P0 907 357 H
       Bauteil: Dynamische LWR  H02 0010
       Revision: 00000001    Seriennummer:
       Codierung: 0000004
       VCID: 3FDAB8DA1B7BB64FA77-806A
    Adresse 56: Radio (R)       Labeldatei:. DRV\4F0-035-0xx-56.clb
       Teilenummer SW: 4F0 035 053 K    HW: 4F0 035 053
       Bauteil: Radio U Basic H45 0074
       Revision: AB001007    Seriennummer: 341C-0A7718746
       Codierung: 010003010000000000
       VCID: 25160AB295E70C9FCDB-8070
    1 Fehler gefunden:
    02984 - Verbindung zwischen Impedanzwandler 2 und Scheibenantenne
                011 - Unterbrechung
                        Fehlerpriorität: 5
                        Fehlerhäufigkeit: 44
                        Verlernzähler: 174
                        Kilometerstand: 259845 km
                        Zeitangabe: 0
                        Datum: 2019.06.06
                        Zeit: 20:59:50
                        Spannung: 14.10 V
    Adresse 5F: Informationselek. I (J794)       Labeldatei:. DRV\4E0-035-6xx-5F.clb
       Teilenummer SW: 4E0 035 666 K    HW: 4E0 035 666 C
       Bauteil: H-BN-EU       H47 0187
       Revision: --------    Seriennummer: 454CV0A7544370
       Codierung: 010100010002DBFD01000F15EF6300030001
       VCID: 2E04F59EC0114FC73C1-807A
       Subsystem 1 - Teilenummer: 8R0 060 884 FC
       Bauteil: EUR 2018  2601
       Subsystem 2 - Teilenummer SW: 4F0 919 604     HW: 4F0 919 604
       Bauteil: DU7 High  H43 0306
       Seriennummer: 9356CP0A1223960
       Subsystem 3 - Teilenummer SW: 4F0 910 609 E    HW: 4F1 919 611 S
       Bauteil: Bedienteil MM  H01 0060
       Seriennummer: 00000001540309
       Subsystem 4 - Teilenummer: 8R0 906 961 A
       Bauteil: CD-Database  1293
    Adresse 62: Türelektr. hi. li. (J388)       Labeldatei:. 4F0-959-795.clb
       Teilenummer SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Bauteil: TSG HL        H10 0251
       Revision:             Seriennummer: 0000010191910
       Codierung: 010800204040220001
       VCID: 44D0B7367E9DD597FA5-8010
    Adresse 69: Anhänger        Labeldatei:. DRV\4F0-907-383.clb
       Teilenummer SW: 4F0 907 383 D    HW: 4F0 907 383 D
       Bauteil: J345  Towbar module 0040
       Revision: 00H06000    Seriennummer: 4F0907383D
       Codierung: 0065536
       Betriebsnr.: WSC 00000 000 00000
    Adresse 72: Türelektr. hi. re. (J389)       Labeldatei:. 4F0-959-795.clb
       Bauteil: TSG HR        H10 0251
       Revision:             Seriennummer: 0000010193759
    Adresse 76: Einparkhilfe        Labeldatei: DRV\4Fx-910-283.lbl
       Teilenummer SW: 4L0 910 283 B    HW: 4L0 919 283 B
       Bauteil: Parkhilfe 4-Kan H02 0500
       Revision: 00H02000    Seriennummer: 12331007702218
       Codierung: 0211016
       VCID: 290E0682F5FF28FFE93-807C
    Ende--------(Dauer: 01:59, Batt.-Spannung Start/Ende: 14.3V/14.4V)---------
    Hi and welcome.
    Please post an Auto-Scan so people can see exactly what HVAC module you've got.
    Apr 2018
    ITALY
    we'll also need admaps of modules 08, 09 (and/or 46).
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
    Mar 2020
    Hi there,
    Sorry for forgetting the auto-scan, here it is.
    www.vcds.de
              56 5F 62 69 72 76
    1 Fehler gefunden:
       Codierung: 0000001
       Codierung: 0000380
       Codierung: 0000131
       Codierung: 0000276
       Codierung: 0003122
       Codierung: 00056595
       Codierung: 00211757
       Revision: AA001001
       Codierung: 0061161
       Bauteil: J0527               0530
       Codierung: 0002052
       Codierung: 000B03
       Codierung: 0000120
       Codierung: 2237169
                        Fehlerpriorität: 5
                        Verlernzähler: 27
                        Zeitangabe: 0
                        Datum: 2019.10.24
                        Zeit: 11:28:40
                011 - Unterbrechung
                        Fehlerpriorität: 3
                        Verlernzähler: 24
                        Zeitangabe: 0
                        Datum: 2019.08.19
                        Zeit: 17:15:29
                011 - Unterbrechung
                        Fehlerpriorität: 3
                        Verlernzähler: 24
                        Zeitangabe: 0
                        Datum: 2019.08.25
                        Zeit: 17:30:39
       Codierung: 0D010000
       Codierung: 0001104
       Revision: --H05---
       Codierung: 0000131
       Codierung: 0000004
    1 Fehler gefunden:
                011 - Unterbrechung
                        Fehlerpriorität: 5
                        Verlernzähler: 174
                        Zeitangabe: 0
                        Datum: 2019.06.06
                        Zeit: 20:59:50
                        Spannung: 14.10 V
       Codierung: 0065536
       Codierung: 0211016
    Hmm that didn't hurt, apparently there's a fault with the air mass meter. I'll clear that and see if it returns. I'm not sure why there are faults with the tailgate, I don't have an electric one and the release does work. The lights for the rear seats is probably because I programmed them in, I guess they're not there in the rear. None of it has much to do with the heated seats though, so the question stands
    Mar 2020
    I'm happy to look into that, but I'm not sure what you mean. How do I do that? Do I need security codes for that?
    You should have both actual and specified seat temperatures in MVBs 027 and 028. Do actual temperatures match specified?
    I don't see any documented way to change the specified temperatures.
    PS: Since this is an English language forum, in the future, please post data from the English version of VCDS. You can download it from this page and it will happily coexist with the German translation you are currently using (which should also be updated!).
  7. #7
    Mar 2020
    The specified and actual temperatures in measuring blocks 027 and 028 do match, yes. It's just that the specified temperature is very unambitious... I'm sorry to hear that's apparently simply what it is...
    Sorry about the german software, that's what came with my VCDS. I wasn't aware that the English version will also work with it... My German is fine but I do prefer English, so I'll switch, thanks To be honest I didn't think updating it would be very useful as my car isn't that new either...
  8. #8
    Quote Originally Posted by Unruled View Post
    It's not about how new your car is, updating VCDS gets all the bug fixes, updated label files and other enhancements - which IMHO are always worth having, even on an older car
  9. Likes Uwe liked this post
  10. #9
    Mar 2020
    A little bump here... I have since updated, and am now using the English version of VCDS.
    I'm wondering if there is a security code known for the 08 HVAC controller? It does seem to have a bunch of adaptation values I can access, but require a code for. Is there any way to get it? Otherwise my options are more hard-ware related I think, fooling the temperature sensor into thinking it's a bit colder than it actually is. That should be doable but it's a last resort
    I've included the admaps for 08 and 09 since you asked for those
    EDIT: Never mind the links, here they are in plain text.
    Channel 08
    ;SW:4F0-910-043-B   HW:4F1-820-043-AL ---  Auto HVAC
    ;Component:KLIMABETAETIGUNGH30 0080, Coding:0000276
    ;Wednesday,22,April,2020,14:45:18:24747
    ;VCDS Version: Release 20.4.1 (x64)  Data version: 20200331 DS317.0
    ;VCID: 1D662252B1B7C45358D-8048
    Channel,,Field 1,Field 2,Field 3,Field 4,
    01,,ERROR:,Channel 01,Not,Available,
    02,,ERROR:,Channel 02,Not,Available,
    03,1,N/A,N/A,N/A,N/A,
    04,0,N/A,N/A,N/A,N/A,
    05,0,N/A,N/A,N/A,N/A,
    06,0,N/A,N/A,N/A,N/A,
    07,0,N/A,N/A,N/A,N/A,
    08,,ERROR:,Channel 08,Not,Available,
    09,0,N/A,N/A,N/A,N/A,
    10,10,N/A,N/A,N/A,N/A,
    11,1,N/A,N/A,N/A,N/A,
    12,,ERROR:,Security,access,required,
    13,,ERROR:,Security,access,required,
    14,0,N/A,N/A,N/A,N/A,
    15,60,N/A,N/A,N/A,N/A,
    16,0,N/A,N/A,N/A,N/A,
    17,0,N/A,N/A,N/A,N/A,
    18,,ERROR:,Security,access,required,
    19,0,N/A,N/A,N/A,N/A,
    20,1,N/A,N/A,N/A,N/A,
    21,1,N/A,N/A,N/A,N/A,
    22,0,N/A,N/A,N/A,N/A,
    23,0,N/A,N/A,N/A,N/A,
    24,,ERROR:,Security,access,required,
    25,,ERROR:,Security,access,required,
    26,,ERROR:,Security,access,required,
    27,2,N/A,N/A,N/A,N/A,
    28,5,N/A,N/A,N/A,N/A,
    29,,ERROR:,Security,access,required,
    30,,ERROR:,Security,access,required,
    31,,ERROR:,Channel 31,Not,Available,
    32,,ERROR:,Security,access,required,
    33,60,N/A,N/A,N/A,N/A,
    34,0,N/A,N/A,N/A,N/A,
    35,,ERROR:,Security,access,required,
    36,,ERROR:,Channel 36,Not,Available,
    37,,ERROR:,Security,access,required,
    38,0,N/A,N/A,N/A,N/A,
    39,2,N/A,N/A,N/A,N/A,
    40,30,N/A,N/A,N/A,N/A,
    41,0,N/A,N/A,N/A,N/A,
    42,0,N/A,N/A,N/A,N/A,
    43,48,N/A,N/A,N/A,N/A,
    44,36,N/A,N/A,N/A,N/A,
    45,12,N/A,N/A,N/A,N/A,
    46,10,N/A,N/A,N/A,N/A,
    47,2,N/A,N/A,N/A,N/A,
    48,,ERROR:,Channel 48,Not,Available,
    49,,ERROR:,Channel 49,Not,Available,
    50,,ERROR:,Channel 50,Not,Available,
    51,,ERROR:,Channel 51,Not,Available,
    52,,ERROR:,Channel 52,Not,Available,
    53,,ERROR:,Channel 53,Not,Available,
    54,,ERROR:,Channel 54,Not,Available,
    55,,ERROR:,Channel 55,Not,Available,
    56,,ERROR:,Channel 56,Not,Available,
    57,,ERROR:,Channel 57,Not,Available,
    58,,ERROR:,Channel 58,Not,Available,
    59,,ERROR:,Channel 59,Not,Available,
    60,,ERROR:,Channel 60,Not,Available,
    Channel 09
    ;SW:4F0-910-279-N   HW:4F0-907-279 ---  Cent. Elect. --- SA: 12151
    ;Component:ILM Fahrer      H22 0320, Coding:0003122
    ;Wednesday,22,April,2020,14:47:43:24747
    ;VCID: 3430E7F6223D651B873-8060
    01,140,N/A,N/A,N/A,N/A,
    02,18,N/A,N/A,N/A,N/A,
    03,24,N/A,N/A,N/A,N/A,
    04,8,OFF,N/A,N/A,N/A,
    05,15,OFF,N/A,N/A,N/A,
    06,38,OFF,N/A,N/A,N/A,
    07,66,OFF,N/A,N/A,N/A,
    08,100,OFF,N/A,N/A,N/A,
    09,30,31.0 s,N/A,N/A,N/A,
    10,5,N/A,N/A,N/A,N/A,
    11,20,20.0 %,N/A,N/A,N/A,
    12,60,N/A,N/A,N/A,N/A,
    13,50,N/A,N/A,N/A,N/A,
    14,1,N/A,N/A,N/A,N/A,
    15,1,Enabled,N/A,N/A,N/A,
    16,1,N/A,N/A,N/A,N/A,
    17,3,N/A,N/A,N/A,N/A,
    18,50,N/A,N/A,N/A,N/A,
    20,6,N/A,N/A,N/A,N/A,
    21,0,N/A,N/A,N/A,N/A,
    22,40,N/A,N/A,N/A,N/A,
    23,5,N/A,N/A,N/A,N/A,
    24,0,N/A,N/A,N/A,N/A,
    25,30,N/A,N/A,N/A,N/A,
    26,,ERROR:,Channel 26,Not,Available,
    27,,ERROR:,Channel 27,Not,Available,
    28,,ERROR:,Channel 28,Not,Available,
    29,,ERROR:,Channel 29,Not,Available,
    30,,ERROR:,Channel 30,Not,Available,
    32,,ERROR:,Channel 32,Not,Available,
    33,,ERROR:,Channel 33,Not,Available,
    34,,ERROR:,Channel 34,Not,Available,
    35,,ERROR:,Channel 35,Not,Available,
    37,,ERROR:,Channel 37,Not,Available,
    38,,ERROR:,Channel 38,Not,Available,
    39,,ERROR:,Channel 39,Not,Available,
    40,,ERROR:,Channel 40,Not,Available,
    41,,ERROR:,Channel 41,Not,Available,
    42,,ERROR:,Channel 42,Not,Available,
    43,,ERROR:,Channel 43,Not,Available,
    44,,ERROR:,Channel 44,Not,Available,
    45,,ERROR:,Channel 45,Not,Available,
    46,,ERROR:,Channel 46,Not,Available,
    47,,ERROR:,Channel 47,Not,Available,
    60,65535,Adapt Value,Learned,N/A,N/A,
    61,65535,Adapt Value,Learned,N/A,N/A,
    62,65535,Adapt Value,Learned,N/A,N/A,
    63,65535,Adapt Value,Learned,N/A,N/A,
    64,65535,Adapt Value,Learned,N/A,N/A,
    65,65535,Adapt Value,Learned,N/A,N/A,
    66,65535,Adapt Value,Learned,N/A,N/A,
    67,65535,Adapt Value,Learned,N/A,N/A,
    68,65535,Adapt Value,Learned,N/A,N/A,
    69,65535,Adapt Value,Learned,N/A,N/A,
    70,65535,Adapt Value,Learned,N/A,N/A,
    71,65535,Adapt Value,Learned,N/A,N/A,
    72,65535,Adapt Value,Learned,N/A,N/A,
    73,65535,Adapt Value,Learned,N/A,N/A,
    74,65535,Adapt Value,Learned,N/A,N/A,
    75,65535,Adapt Value,Learned,N/A,N/A,
    76,65535,Adapt Value,Learned,N/A,N/A,
    77,65535,Adapt Value,Learned,N/A,N/A,
    78,65535,Adapt Value,Learned,N/A,N/A,
    79,65535,Adapt Value,Learned,N/A,N/A,
    80,65535,Adapt Value,Learned,N/A,N/A,
    81,65535,Adapt Value,Learned,N/A,N/A,
    82,65535,Adapt Value,Learned,N/A,N/A,
    83,65535,Adapt Value,Learned,N/A,N/A,
    84,65535,Adapt Value,Learned,N/A,N/A,
    85,,ERROR:,Channel 85,Not,Available,
    86,,ERROR:,Channel 86,Not,Available,
    87,,ERROR:,Channel 87,Not,Available,
    88,,ERROR:,Channel 88,Not,Available,
    89,,ERROR:,Channel 89,Not,Available,
    90,,ERROR:,Channel 90,Not,Available,
    91,,ERROR:,Channel 91,Not,Available,
    92,,ERROR:,Channel 92,Not,Available,
    93,,ERROR:,Channel 93,Not,Available,
    94,,ERROR:,Channel 94,Not,Available,
    95,,ERROR:,Channel 95,Not,Available,
    96,,ERROR:,Channel 96,Not,Available,
    97,,ERROR:,Channel 97,Not,Available,
    98,,ERROR:,Channel 98,Not,Available,
    99,,ERROR:,Channel 99,Not,Available,
    100,,ERROR:,Channel 100,Not,Available,
    101,,ERROR:,Channel 101,Not,Available,
    102,,ERROR:,Channel 102,Not,Available,
    103,,ERROR:,Channel 103,Not,Available,
    104,,ERROR:,Channel 104,Not,Available,
    105,,ERROR:,Channel 105,Not,Available,
    106,,ERROR:,Channel 106,Not,Available,
    107,,ERROR:,Channel 107,Not,Available,
    108,,ERROR:,Channel 108,Not,Available,
    109,,ERROR:,Channel 109,Not,Available,
    110,,ERROR:,Channel 110,Not,Available,
    111,,ERROR:,Channel 111,Not,Available,
    112,,ERROR:,Channel 112,Not,Available,
    113,,ERROR:,Channel 113,Not,Available,
    114,,ERROR:,Channel 114,Not,Available,
    115,,ERROR:,Channel 115,Not,Available,
    116,,ERROR:,Channel 116,Not,Available,
    117,,ERROR:,Channel 117,Not,Available,
    118,,ERROR:,Channel 118,Not,Available,
    119,,ERROR:,Channel 119,Not,Available,
    120,,ERROR:,Channel 120,Not,Available,
    121,,ERROR:,Channel 121,Not,Available,
    122,,ERROR:,Channel 122,Not,Available,
    123,,ERROR:,Channel 123,Not,Available,
    124,,ERROR:,Channel 124,Not,Available,
    125,,ERROR:,Channel 125,Not,Available,
    126,,ERROR:,Channel 126,Not,Available,
    127,,ERROR:,Channel 127,Not,Available,
    128,,ERROR:,Channel 128,Not,Available,
    129,,ERROR:,Channel 129,Not,Available,
    130,,ERROR:,Channel 130,Not,Available,
    131,,ERROR:,Channel 131,Not,Available,
    132,,ERROR:,Channel 132,Not,Available,
    133,,ERROR:,Channel 133,Not,Available,
    134,,ERROR:,Channel 134,Not,Available,
    135,,ERROR:,Channel 135,Not,Available,
    136,,ERROR:,Channel 136,Not,Available,
    137,,ERROR:,Channel 137,Not,Available,
    138,,ERROR:,Channel 138,Not,Available,
    139,,ERROR:,Channel 139,Not,Available,
    140,,ERROR:,Channel 140,Not,Available,
    141,,ERROR:,Channel 141,Not,Available,
    142,,ERROR:,Channel 142,Not,Available,
    143,,ERROR:,Channel 143,Not,Available,
    144,,ERROR:,Channel 144,Not,Available,
    145,,ERROR:,Channel 145,Not,Available,
    146,,ERROR:,Channel 146,Not,Available,
    147,,ERROR:,Channel 147,Not,Available,
    148,,ERROR:,Channel 148,Not,Available,
    149,,ERROR:,Channel 149,Not,Available,
    150,,ERROR:,Channel 150,Not,Available,
    151,,ERROR:,Channel 151,Not,Available,
    152,,ERROR:,Channel 152,Not,Available,
    153,,ERROR:,Channel 153,Not,Available,
    154,,ERROR:,Channel 154,Not,Available,
    155,,ERROR:,Channel 155,Not,Available,
    156,,ERROR:,Channel 156,Not,Available,
    157,,ERROR:,Channel 157,Not,Available,
    158,,ERROR:,Channel 158,Not,Available,
    159,,ERROR:,Channel 159,Not,Available,
    160,,ERROR:,Channel 160,Not,Available,
    161,,ERROR:,Channel 161,Not,Available,
    162,,ERROR:,Channel 162,Not,Available,
    163,,ERROR:,Channel 163,Not,Available,
    164,,ERROR:,Channel 164,Not,Available,
    165,,ERROR:,Channel 165,Not,Available,
    166,,ERROR:,Channel 166,Not,Available,
    167,,ERROR:,Channel 167,Not,Available,
    168,,ERROR:,Channel 168,Not,Available,
    169,,ERROR:,Channel 169,Not,Available,
    170,,ERROR:,Channel 170,Not,Available,
    171,,ERROR:,Channel 171,Not,Available,
    172,,ERROR:,Channel 172,Not,Available,
    173,,ERROR:,Channel 173,Not,Available,
    174,,ERROR:,Channel 174,Not,Available,
    175,,ERROR:,Channel 175,Not,Available,
    176,,ERROR:,Channel 176,Not,Available,
    177,,ERROR:,Channel 177,Not,Available,
    178,,ERROR:,Channel 178,Not,Available,
    179,,ERROR:,Channel 179,Not,Available,
    180,,ERROR:,Channel 180,Not,Available,
  11. #10
    http://www.filehost.pt/bzqY (08)
    http://www.filehost.pt/bzqZ (09)
    Please post them in-line rather than making us click on some sketchy Portuguese language download site.
