2016 VW GOLF MK7 Sensor for Automatic Distance Regulation FAULT
nazdaq100
London, United Kingdom
C?ID=314050
I was wondering someone who has expertise in this area who can help us narrow it down, front bumper was slightly damaged and now repaired!
0790 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
[FAULT_MISALIGNMENT_HORIZONTAL]
Reset counter: 163
Mileage: 6738 km
Date: 2020.03.07
Time: 14:59:01
Control Module temperature: 38 °C
Voltage terminal 15: 14.3 V
Velocity_vehicle_reference: 11.12 m/s
Longitudinal_acceleration_vehicle_reference: -0.08 m/s²
Option 1 : Fix the fault
Option 2 : Remove the fault from Ecu or gateway or which ever is convenient via unticking options in long coding or adaptation? so the fault does not show in the car display or instrument
I am happy with option 2 if its simple
Saturday,07,March,2020,15:24:49:42869
VIN: WVWZZZAUZHW059947   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZAUZHW059947   Mileage: 6743km-4189miles
Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HF    HW: 04E 907 309 BJ
   Component: R4 1.4l TFS   H23 3545
   Revision: R6H23---
   Coding: 0125003223641D083000
   ASAM Dataset: EV_ECM14TFS01104E906027HF 001006
   ROD: EV_ECM14TFS01104E906027HF.rod
   VCID: 6FBA221EE7177B2F20F-803A
   CAN Converter 01:
15 Faults Found:
4527 - Coolant Fan Control Circuit 1
          P0480 00 [032] - Electrical Malfunction
                    Mileage: 6730 km
                    Date: 2020.02.19
                    Time: 15:44:19
                    Coolant temperature: 11 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 10.248 V
                    Outside air temperature: 215 °C
                    Absolute intake pressure: 101 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 30.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Intake camshaft bank1 active operating mode-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
5453 - Starter Relay
          P3088 00 [096] - Electrical Malfunction
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:15:39
                    Coolant temperature: 111 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 6.384 V
                    Unlearning counter according OBD: 34
                    Starter control: terminal 50 acknowledgment-Bits 0-7: 0
                    Starter control: relay 1-Bits 0-7: 3
                    Starter control: release conditions-Bits 0-7: 98
                    Starter control: release conditions-Bits 0-7: 90
                    Starter control: shut-off conditions 1-Bits 0-7: 0
                    Number of manual engine starts-Bits 0-7: 0
                    Number of manual engine starts-Bits 0-7: 9
                    Target torque for combustion engine crankshaft level: -38.3 Nm
5456 - Starter Will Not Turn
          P3054 00 [101] - Jammed or Electrical Malfunction
                    Mileage: 6730 km
                    Date: 2020.02.12
                    Time: 08:27:29
                    Coolant temperature: 101 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 6.408 V
                    Starter control: terminal 50 acknowledgment-Bits 0-7: 32
                    Starter control: release conditions-Bits 0-7: 102
17158 - Databus
          U1123 00 [040] - Received Error Message
                    Fault Frequency: 17
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:01
                    Coolant temperature: 38 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 12.274 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 130
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
14643 - Coolant Pump for Intercooler
          P16BA 00 [040] - Running Dry
                    Fault Frequency: 12
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:00:17
                    Engine speed: 988.50 /min
                    Normed load value: 34.5 %
                    Coolant temperature: 5 °C
                    Intake air temperature: 4 °C
                    Voltage terminal 30: 14.536 V
                    Unlearning counter according OBD: 36
                    Outside air temperature: 3 °C
                    Absolute intake pressure: 50 kPa abs
                    Engine torque: 41.0 Nm
                    Fuel level: 32.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 0.9854
          U0428 00 [040] - -
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:02
                    Engine speed: 1211.50 /min
                    Normed load value: 10.2 %
                    Coolant temperature: 10 °C
                    Voltage terminal 30: 12.062 V
                    Absolute intake pressure: 25 kPa abs
                    Engine torque: 9.3 Nm
                    Fuel level: 20.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 0.9792
5595 - Crash Shut-Down Activated
          P1609 00 [032] - -
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:04
4787 - Crash Shut-Down Activated
          P1609 00 [032] - -
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:04
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:11:48
                    Intake air temperature: 12 °C
                    Voltage terminal 30: 11.803 V
                    Absolute intake pressure: 99 kPa abs
                    Fuel level: 23.00 l
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [040] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 6730 km
                    Date: 2020.02.12
                    Time: 11:03:10
                    Coolant temperature: 24 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 10.931 V
                    Outside air temperature: 6 °C
                    Fuel level: 31.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 15.9998
4714 - Steering Column Control Module
          U0212 00 [032] - No Communications
                    Mileage: 6730 km
                    Time: 00:00:00
                    Coolant temperature: 9 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 11.921 V
                    Fuel level: 19.00 l
2736 - Throttle Valve Actuator Module (J338)
          P2106 00 [096] - Power Limited due to Malfunction
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:17:13
                    Coolant temperature: 105 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 6.832 V
                    Absolute intake pressure: 100 kPa abs
                    Fuel level: 31.00 l
2748 - Throttle Valve Controller
          P1545 00 [096] - Malfunction
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:17:13
                    Fuel level: 31.00 l
11628 - ROD - Unknown Error Code
          - 00 [096]
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:17:08
                    Voltage terminal 30: 6.337 V
                    Fuel level: 31.00 l
4633 - Internal Control Module
          P0606 00 [032] - Processor Fault
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:17:08
                    Voltage terminal 30: 6.007 V
                    Fuel level: 31.00 l
   Part No SW: 0CW 300 049 K    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0904
   Revision: 00005026    Serial number: CU501607096908
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 45D6A0B6952B917FBA3-8010
21193 - No Communication with Cruise Control Module
          U0104 00 [040] - -
                    Fault Frequency: 54
                    Mileage: 6730 km
                    Date: 2020.02.12
                    Time: 11:03:11
                    Engine speed: 3.50 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 55 km/h
                    Control Module temperature: 9 °C
                    CURRENT pressure: -9.5 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_7
                    Driving position: N
                    Accelerator position: 0.0 %
                    DTC memory status: 45568
10810 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:14:11
                    Engine speed: 3.75 /min
                    Vehicle speed: 52 km/h
                    Control Module temperature: 47 °C
                    Driving position: N
                    DTC memory status: 45824
10821 - System Voltage
          P0562 00 [008] - Too Low
                    Mileage: 6730 km
                    Date: 2020.02.19
                    Time: 12:17:04
                    Engine speed: 18.75 /min
                    Vehicle speed: 47 km/h
                    Control Module temperature: 32 °C
                    CURRENT pressure: -10.0 bar
                    Driving position: N
                    DTC memory status: 48640
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 62106000000875
   Coding: 01FA8AA1242511754780060441CA2980512488E26082947318225078C20203
   VCID: 7BA2064EA36F178F9C7-802E
9 Faults Found:
0128 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [undervoltage]
                    Reset counter: 203
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:14:22
0294 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 203
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:02
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Fault Frequency: 7
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:00:05
8192 - Databus
          [FCAN: ACC_07 message is not received]
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.02.12
                    Time: 11:03:10
8196 - Databus
          [FCAN : ACC_10 message is not received]
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.02.12
                    Time: 11:03:10
8291 - Databus
          [FCAN: MO_QBit_Motormomente signal is invalid]
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:11:49
16412 - Display for Tire Pressure Monitoring
                    Reset counter: 203
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 17:31:39
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 203
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 17:31:39
32928 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [IPB: Supply Voltage below undervoltage threshold]
                    Reset counter: 198
                    Mileage: 6730 km
                    Time: 00:00:00
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Revision: 00021000    Serial number: 0411404780
   Coding: 032C0C
   VCID: 3B22C64EE3EFD78FDC7-806E
          U1400 00 [008] - -
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:15:37
65813 - Supply voltage
                    Fault Frequency: 9
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 03:10:58
1052939 - Touch Sensor on Exterior Door Grip; Driver Side
          B116B 13 [008] - Open Circuit
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.03.06
                    Time: 09:09:49
1057035 - Antenna for Keyless Entry System; Drivers Side
          B116F 13 [008] - Open Circuit
                    Reset counter: 198
                    Time: 00:00:00
1057803 - Antenna for Keyless Entry System in Trunk
          B1173 13 [009] - Open Circuit
                    Reset counter: 160
                    Mileage: 6730 km
                    Date: 2020.03.06
                    Time: 17:29:33
   Part No SW: 5G0 907 426 AK    HW: 5G0 907 426 AK
   Component: AC Manuell    H03 1601
   Revision: 00001K06
   Coding: 00120004200110001000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004132
   ROD: EV_ACManueBHBVW37X_004.rod
   VCID: 74B02D728E3158F7DDD-8020
197890 - Temperature Sensor for Evaporator Vent
          B108A 15 [008] - Open or Short to Plus
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:15:13
                    Voltage terminal 30: 11.5 V
                    Outside air temperature: 11.5 °C
                    Refrigerant pressure: 0.0 bar
                    Compressor current: specified value: 0.000 A
262914 - Refrigerant Pressure
          B10AB F0 [008] - Too Low
                    Reset counter: 203
                    Mileage: 6730 km
                    Date: 2020.02.21
                    Time: 14:44:37
                    Outside air temperature: 12.5 °C
                    Engine speed: 800 /min
                    Temperature after evaporator: 15.7 °C
                    System run time-Engine running time: 5 s
                    System run time-Terminal 15 on: 5 s
          B10CD 00 [008] - -
                    Fault Frequency: 18
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 21:48:12
                    Voltage terminal 30: 10.9 V
1048839 - Function limitation due to crash signal
          B1397 00 [008] - -
                    Reset counter: 193
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:24
   Part No SW: 5Q0 937 084 CK    HW: 5Q0 937 084 AM
   Component: BCM MQBAB M+  H24 0175
   Serial number: 01061620700079
   Coding: 03111846C241027B0BA44080B10403281800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 03527EAEDB9F6F4FD47-8056
   Component: WWS    160714  042 0551
   Serial number:         160727025536
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y16M08D08H15M14S55
   Coding: 90A8DD
   Serial number: 000000000ZY161870KQ5
   Serial number: 00000000000036089206
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST0013Z3QW00000
   Coding: 181901
14 Faults Found:
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [009] - Open or Short to Plus
                    Reset counter: 153
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:00:57
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [009] - Open or Short to Plus
                    Reset counter: 154
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 15:36:33
8714 - Bulb for Left Fog Lamp
          B121F 15 [008] - Open or Short to Plus
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 15:36:46
8970 - Bulb for Right Fog Lamp
          B1220 15 [008] - Open or Short to Plus
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 15:36:46
14602 - Bulb for Left Brake Lamp / Tail Lamp
          B133A 15 [008] - Open or Short to Plus
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.03.04
                    Time: 17:14:44
14858 - Bulb for Right Brake Lamp / Tail Lamp
          B133C 15 [008] - Open or Short to Plus
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.03.04
                    Time: 17:14:45
17162 - Bulb for Left DRL and Parking Lamp
          B12EA 15 [008] - Open or Short to Plus
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.02.20
                    Time: 03:12:44
17418 - Bulb for Right DRL and Parking Lamp
          B12EB 15 [008] - Open or Short to Plus
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:00:04
131330 - Supply voltage
          [VersorgungsspannungSpannung zu niedrig]
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 03:04:09
131586 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:17:23
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 158
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [008] - Alert Emergency Activation Stage 1
                    Reset counter: 200
                    Time: 00:00:00
550420 - Databus
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.02.26
                    Time: 08:29:44
919560 - Light Switch
          B126A 29 [008] - Signal Implausible
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 15:14:31
   Revision: --------    Serial number: 39331621810989
   Coding: 0071051011
   VCID: 43D2BEAE9B1FAF4F947-8016
12 Faults Found:
1080083 - Rear Parking Aid Sensor(s)
          B107B 13 [008] - Open Circuit
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.03.04
                    Time: 17:15:00
1111828 - Front Left Parking Aid Sensor
          B10F7 14 [008] - Open or Short to Ground
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.02.21
                    Time: 14:44:40
1112596 - Front Right Parking Aid Sensor
          B10FA 14 [008] - Open or Short to Ground
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:06
1112084 - Front Left Center Parking Aid Sensor
          B10F8 14 [008] - Open or Short to Ground
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.02.12
                    Time: 11:04:05
1112340 - Front Right Center Parking Aid Sensor
          B10F9 14 [008] - Open or Short to Ground
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:06
1112594 - Front Right Parking Aid Sensor
          B10FA 12 [008] - Short to Plus
                    Fault Frequency: 15
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:02:37
1112338 - Front Right Center Parking Aid Sensor
          B10F9 12 [008] - Short to Plus
                    Fault Frequency: 15
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:02:37
1112625 - Front Right Parking Aid Sensor
          B10FA 31 [008] - No Signal
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.02.19
                    Time: 12:08:22
1079828 - Supply Voltage for Parking Aid Sensor(s)
          B107A 14 [008] - Open or Short to Ground
                    Fault Frequency: 49
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:01:37
13635840 - Supply voltage
          [Versorgungsspannung - zu niedrig]
                    Reset counter: 196
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                    Reset counter: 197
13637426 - Databus
                    Fault Frequency: 7
                    Reset counter: 203
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:02
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 3500478151FFC428949C8045000006
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
10 Faults Found:
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Reset counter: 194
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:02
                    Control Module temperature: 15 °C
                    Voltage terminal 15: 14.5 V
                    Velocity_vehicle_reference: 5.46 m/s
                    Longitudinal_acceleration_vehicle_reference: 2.57 m/s²
                    Status_ACC_System: ACC_irreversible error
2109 - Databus
          [FAULT_AWV_CONSISTENCY_FAIL]
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.03.06
                    Time: 12:09:06
                    Control Module temperature: 13 °C
                    Voltage terminal 15: 14.6 V
0822 - Databus
          [FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
                    Reset counter: 193
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:19:56
                    Velocity_vehicle_reference: -4.46 m/s
                    Longitudinal_acceleration_vehicle_reference: -1.49 m/s²
2111 - Databus
          [FAULT_ESP_CONS_ACC]
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.03.06
                    Time: 12:09:06
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 203
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:01
                    Voltage terminal 15: 14.7 V
                    Velocity_vehicle_reference: 3.40 m/s
                    Longitudinal_acceleration_vehicle_reference: 4.84 m/s²
          C1103 00 [009] - -
                    Reset counter: 163
                    Mileage: 6738 km
                    Date: 2020.03.07
                    Time: 14:59:01
0928 - Databus
          [FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
                    Reset counter: 196
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:00:06
                    Control Module temperature: 6 °C
                    Voltage terminal 15: 13.3 V
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 203
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:02
                    Velocity_vehicle_reference: 3.61 m/s
                    Longitudinal_acceleration_vehicle_reference: 2.32 m/s²
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VBAT_BUSMON_LOW]
                    Fault Frequency: 57
                    Reset counter: 196
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:14:05
                    Control Module temperature: 27 °C
                    Voltage terminal 15: 7.6 V
                    Status_ACC_System: ACC_Init
1387 - Supply voltage
          [FAULT_VBAT_LOW]
                    Reset counter: 196
                    Mileage: 6730 km
                    Date: 2020.02.12
                    Time: 08:34:51
                    Voltage terminal 15: 8.5 V
   Serial number: 003MLR1Y3TT/
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5AF25EB7770BAFB0F-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677A14011340085
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676A12011350218
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 003 007 16
   Serial number: 35767000000F7554EC15
   Subsystem 4 - Part No SW: -----------    HW: 480 000 108 16
   Serial number: 358670000006D5116D1W
   Subsystem 5 - Part No SW: -----------    HW: 480 402 607 16
   Serial number: 3516502B72095073C30
   Subsystem 6 - Part No SW: -----------    HW: 480 402 607 16
   Serial number: 35265029F211FA3240CB
   Subsystem 7 - Part No SW: -----------    HW: 480 401 807 16
   Serial number: 3556502BF211FA34838L
22 Faults Found:
          B1000 1B [136] - Resistance Too High
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:10
9437723 - Igniter for Passenger's Airbag
          B1002 1B [136] - Resistance Too High
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:10
          B1006 1B [136] - Resistance Too High
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:10
          B1007 1B [136] - Resistance Too High
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:10
9440283 - Driver side knee airbag igniter
          B100C 1B [136] - Resistance Too High
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:10
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [136] - Open or Short to Plus
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:11:49
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [136] - Open or Short to Plus
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:11:49
9629972 - Indicator Lamp for Passenger Airbag Enabled
          B12F1 14 [136] - Open or Short to Ground
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:11:48
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [136] - Open or Short to Ground
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:11:48
9466352 - Crash Data from Belt Tensioner Stored
          B1071 F0 [137] - Unknown Error Elaboration
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:04
9447424 - Front crash data stored
          B1028 00 [137] - -
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:04
9682160 - Multiple collision brake
          B13BC F0 [009] - Crash data stored
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:04
9682161 - Multiple collision brake
          B13BC F1 [008] - triggered
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:04
9634820 - Control Module for Front Left Belt Tensioner
          B1304 04 [009] - Internal System Fault
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:04
9635076 - Control Module for Front Right Belt Tensioner
          B1305 04 [009] - Internal System Fault
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:04
9634838 - Control Module for Front Left Belt Tensioner
          B1304 16 [008] - Voltage Too Low
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:14:33
9635094 - Control Module for Front Right Belt Tensioner
          B1305 16 [008] - Voltage Too Low
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:14:33
9634901 - Control Module for Front Left Belt Tensioner
          B1304 55 [009] - Not configured
                    Reset counter: 158
                    Mileage: 6730 km
                    Date: 2020.03.02
                    Time: 14:06:40
9635157 - Control Module for Front Right Belt Tensioner
          B1305 55 [009] - Not configured
                    Reset counter: 158
                    Mileage: 6730 km
                    Date: 2020.03.02
                    Time: 14:06:40
1049093 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                    Reset counter: 193
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:19:56
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:01
1049094 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                    Reset counter: 193
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:19:56
   Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 03081608490806
   Coding: 0410
   VCID: 074A6ABEEFA7436F88F-8052
   Part No SW: 5G1 920 940 B    HW: 5G1 920 940 B
   Component: KOMBI         202 9630
   Coding: 27A419182780260001886B011400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009007
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 270A0A3E0F67636FA8F-8072
10 Faults Found:
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Fault Frequency: 10
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 17:29:15
12858139 - Databus
          [ACC_02 unplausibles Signal]
                    Reset counter: 193
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:00:04
          [Versorgungsspannung - unterer Grenzwert unterschritten Versorgungsspannung Spannung dauerhaft zu niedrig]
                    Fault Frequency: 7
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 03:16:02
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.02.12
                    Time: 11:03:10
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:00:04
16776993 - Databus
          [ESP_21 keine Kommunikation]
                    Reset counter: 193
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:00:03
16777018 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_Audio_0x31 keine Kommunikation]
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:16:53
16777020 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:16:53
16777022 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_NAV SD_0x32 keine Kommunikation]
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:16:53
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_AWV_0x1B keine Kommunikation]
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.02.12
                    Time: 11:03:17
   Revision: --------    Serial number: 23071610803340
   Coding: 030100043F085700FB00005C1C0F00010001050000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 7CA00552A66110B795D-8028
   Serial number: 29160001424510116291
   Coding: 2DFFFF
   Serial number: 0680290804
9 Faults Found:
131596 - Steering Column Control Module
          U0212 00 [008] - No Communications
          [Timeout Knoten 0x0C / 16 - Steuergerät für Lenksäulenelektronik]
                    Fault Frequency: 22
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 15:00:51
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: OFF
131604 - No Communication with Instrument Cluster
          U0155 00 [008] - -
          [Timeout Knoten 0x14 / 17 - Steuergerät für Schalttafeleinsatz]
                    Fault Frequency: 17
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 15:18:03
                    Terminal 15: OFF
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [008] - -
          [Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
                    Fault Frequency: 21
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 15:14:29
                    Terminal 15: OFF
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [008] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Fault Frequency: 41
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.02.20
                    Time: 03:12:45
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: On
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
          [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.02.19
                    Time: 12:07:47
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: OFF
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
          [Globaler Timeout CAN-Infotainment]
                    Fault Frequency: 11
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 16:16:03
                    Terminal 15: OFF
66054 - Extended CAN Bus (SAE Bus C)
          U0047 00 [008] - Performance
          [Globaler Timeout CAN-Extended]
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.02.12
                    Time: 11:03:34
                    Supply voltage: Terminal 30: 10.9 V
                    Terminal 15: On
1282 - Supply voltage
          [Versorgungsspannung - unterer Grenzwert unterschritten]
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:17:00
                    Supply voltage: Terminal 30: 7.5 V
                    Terminal 15: On
197169 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
          [MFL (LIN#2) Timeout]
                    Fault Frequency: 39
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 14:47:14
                    Terminal 15: OFF
   Revision: 00000000    Serial number: 16000130984006
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3430ED72CEB118F71DD-8060
          [Under voltage (continued)]
                    Reset counter: 195
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 03:16:27
                    ELV State: 04
                    Information Clamps: 00 08
                    CoCo State: E0 01
                    WFS State: 07 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 47
                    AD-Value H-bridge: 23
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 01
          U1400 00 [008] - -
          [Under voltage (temporary)]
                    Fault Frequency: 17
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 02:25:07
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 07 06
                    Voltage: 4B
                    AD-Value H-bridge: 25
                    CAN signals: 01
12670208 - Databus
          [Timeout Message WFS_01]
                    Reset counter: 198
                    Time: 00:00:00
                    ELV State: 04
                    Information Clamps: 00 00
                    CoCo State: 20 01
                    WFS State: 00 06
                    Voltage: 69
                    AD-Value H-bridge: 33
                    CAN signals: 00
12666373 - Databus
          [Timeout Message SMLS_01]
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 15:04:26
                    ELV State: 04
                    CoCo State: 20 01
                    WFS State: 07 06
                    Voltage: 67
                    CAN signals: 00
   Serial number: 060716EG502261
   Coding: 003B1220D001048000001000
   Serial number: 00000000000010960404
   Coding: 0D0000
8 Faults Found:
65548 - Supply voltage
                    Reset counter: 197
65654 - Motor for mirror fold-in
          B11F6 13 [008] - Open Circuit
                    Reset counter: 198
                    Date: 2020.02.24
                    Time: 14:58:31
65608 - Lamp for Ambient Speaker Illumination
          B13C8 01 [008] - Electrical Failure
                    Fault Frequency: 126
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.21
                    Time: 14:49:11
65649 - Lamp for Ambient Illumination
          B1325 13 [008] - Open Circuit
                    Fault Frequency: 27
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.21
                    Time: 14:49:11
65650 - Turn Signal in Exterior Mirror
          B11FD 13 [008] - Open Circuit
                    Reset counter: 199
                    Time: 00:00:00
589829 - Window Regulator; Rear Driver side
          B131F F5 [008] - Supply Voltage too Low
                    Fault Frequency: 173
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 03:24:27
589830 - Window Regulator; Rear Driver side
          B131F F4 [008] - Supply Voltage too High
                    Reset counter: 193
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:00:09
589839 - Window Regulator Motor; Front Driver Side
          B1321 02 [008] - Signal Failure
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:16:12
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
6 Faults Found:
16650 - Steering angle sensor
          B1168 29 [008] - Signal Implausible
                    Reset counter: 193
                    Mileage: 6730 km
                    Date: 2020.01.09
                    Time: 15:20:02
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 14.75 V
                    Temperature: 12.0 °C
                    KFC: 41
                    KFA: 00 0A
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 14.94 V
                    uAdSensI_SwitchedKl30_xdu16: 14.93 V
                    NoInitCause_RackPos_Rohwert: 00 08
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
12289 - Supply voltage
          [Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung (<5.5V für 3ms: KL50=0]
                    Fault Frequency: 51
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:00:03
                    Motor status: 01
                    Supply voltage: 8.75 V
                    Temperature: 5.0 °C
                    KFC: 30
                    KFA: 00 01
                    uioUdNotFilt_xdu16: 5.31 V
                    uAdSensI_SwitchedKl30_xdu16: 5.31 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 01 80
                    RP_VALCNTSAV: activated
                    RP_INDEXPLAUSI: not activated
                    RP_CNTERR: activated
26368 - Power Supply Terminal 30
          P1602 00 [008] - Voltage too Low
                    Reset counter: 195
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:16:22
                    Motor status: 00
                    Supply voltage: 6.00 V
                    Temperature: 16.0 °C
                    KFC: 67
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 6.34 V
                    uAdSensI_SwitchedKl30_xdu16: 6.36 V
26885 - Comfort limitation
          C10D7 00 [008] - -
          [Speicherinkonsistenz im Errorhandler]
                    Reset counter: 195
                    Motor status: 00
                    Supply voltage: 0.00 V
                    Temperature: 80.0 °C
                    KFC: 69
                    KFA: 00 05
11776 - Supply voltage
          [Warnung vor dauerhaft zu geringer Versorgungsspannung Anzeige von Unterspannung]
                    Reset counter: 196
                    Mileage: 6730 km
                    Date: 2020.02.12
                    Time: 08:27:03
                    Motor status: 00
                    Supply voltage: 10.00 V
                    Temperature: 17.0 °C
                    KFC: 2E
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 10.09 V
                    uAdSensI_SwitchedKl30_xdu16: 10.10 V
16897 - Function Limitation due to Missing Initialization
          B2020 00 [008] - -
          [Rutschkupplungerkennung.  Allgemein]
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.21
                    Time: 14:46:22
                    Motor status: 01
                    Supply voltage: 12.75 V
                    Temperature: 21.0 °C
                    KFC: 42
                    KFA: 00 01
                    nApplI_RotorSpeedFilt_xds16: 389 /min
                    mApplI_LimitedMotorTorque_xds16: 4.200 Nm
                    icuCurrentPhase_U_IRQ_xds16: -100.63 A
                    icuCurrentPhase_W_IRQ_xds16: 36.13 A
                    mApplI_TorsionBarTorque_xds16: 9.75 Nm
                    wrsCurrRotorPosIRQ_xdu16: 152.2 °
   Serial number: 020716EG210507
   Coding: 003B1020DE01048000801000
   VCID: 42DCBBAA8405A6479F1-8016
   Serial number: 00000000000010929455
   Coding: 150000
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 03:23:14
                    Reset counter: 196
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:14:17
589845 - Window Regulator; Front Passenger side
          B1320 F5 [008] - Supply Voltage too Low
                    Fault Frequency: 179
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 03:24:20
589846 - Window Regulator; Front Passenger side
          B1320 F4 [008] - Supply Voltage too High
                    Reset counter: 193
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 00:00:09
589855 - Window regulator motor; front passenger side
          B1322 02 [008] - Signal Failure
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:16:12
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0751
   Coding: 02730001FF00000051110101008808001F0100C601200100CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 313EE46631A32DDF76B-8064
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJU02SNH
   Subsystem 2 - Part No SW: 3G0 919 866 S    HW: -----------
   Component: ECE1 2016/17  --- 0635
12 Faults Found:
1537 - Supply voltage
          [Supply voltage - lower limit value not reached]
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.02.19
                    Time: 12:15:29
                    Voltage terminal 30: 6.2 V
1539 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Function restriction due to insufficient voltage - lower limit value not reached]
                    Reset counter: 197
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:14:20
                    Voltage terminal 30: 7.3 V
2571 - Navigation system
          B126C F2 [008] - Navigation database not enabled
                    Reset counter: 195
                    Mileage: 6730 km
                    Date: 2020.01.10
                    Time: 16:15:38
                    Voltage terminal 30: 6.3 V
0517 - Front Right Bass Speaker
          B1062 13 [008] - Open Circuit
          [Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.21
                    Time: 14:59:13
                    Voltage terminal 30: 12.3 V
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [008] - Open Circuit
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:44:45
                    Voltage terminal 30: 11.7 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 214 dBµV
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [008] - Open Circuit
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:44:45
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 214 dBµV
0013 - Antenna Amplifier 1 for Digital Radio
          B1270 13 [008] - Open Circuit
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:44:45
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 14.033536
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
2565 - GPS Antenna
          B1054 13 [008] - Open Circuit
          [GPS aerial - open circuit]
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:44:45
6179 - Display Module 1 for Multimedia System
          B1297 F6 [008] - Cable for Video Signal; Open Circuit
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:44:45
          U1111 00 [008] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.02.19
                    Time: 12:08:11
                    Voltage terminal 30: 14.7 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 199
                    Mileage: 6730 km
                    Date: 2020.02.19
                    Time: 12:08:15
                    Voltage terminal 30: 14.8 V
          U11B8 00 [008] - No Communications
          [USB - communication error]
                    Reset counter: 198
                    Mileage: 6730 km
                    Date: 2020.02.28
                    Time: 00:44:48
                    Interface for external media: status-Status: Open circuit
End----------(Elapsed Time: 01:48, VBatt start/end: 12.5V/12.5V)-----------
darkchina811
ITALY
C?ID=333184
if the car is repaired and driving please clear all errors and let's see what stays.
anyway, the ACC radar sensor is misaligned on the horizontal axis. it requires calibration. can be done by dealer or ask any glass/windows center.
you COULD pull the radar out and code down the ACC to a standard cruise control, but why would you? ACC is cool, and you should also replace the steering wheel buttons, and taking apart the steering wheel is a big PITA.
IMHO get it fixed...
nazdaq100
C?ID=314050
Are you suggesting calibration cannot be done via VCDS? could you please elaborate about glass/window center?
Rollux
New Zealand
C?ID=380572
Calibration requires a specialised board and procedure to get the alignment right. VCDS may be able to access the settings, but you still need the other hardware.
Some glass replacement shops have the equipment as it is similar/same as the camera calibration boards for lane change camera (which is tied into the radar if fitted)
downtime
C?ID=280813
I'm afraid not that simple. ACC and normal CC are again different FeC's. So even pulling out the ACC and coding it out, you won't get normal cruise to work as the FeC is not enabled. You'll need to buy the official CC retrofit kit to enable normal cruise. And I'm not even sure if the activation ever goes through the factory as the car already has one form of cruise enabled.
darkchina811
ITALY
C?ID=333184
I had assumed that a car with a flat radar from the factory came out with both FeCs...
downtime
C?ID=280813
As far as I know no. Only FeCs which are needed are activated.
As you know VW does not allow you to revert to normal cruise in cases the ACC is unusable. Many many other car manufacturers allow this as you can change the cruise function from ACC to CC and vice versa with flick of a switch or from menu.
Now this is just pure guesswork but what if it's so that the VW FeC system is so idiotically programmed that there's only one FeC allowed to be activated at a time for the cruise system. This could be one of the reasons why it's not possible to change the functionality of CC.
If we look at the software mess VAG has made with the newer MIB3 systems especially in the new Superb, I would not be that surprised if this is the case. VAG has never been the front runner or the most innovative in software.
Rollux
New Zealand
C?ID=380572
My MK7 has the ability to turn off the distance regulation (front assist it's called) on the indicator stalk and the cruise reverts to a standard operation - is this not the case with every one? It probably deactivates other features too, but I would expect it makes it operate as the OP has asked.
downtime
C?ID=280813
Does it really? On mine it doesn’t. Not on 2013 Leon with round radar and not on 2017 Tiguan with flat radar. If I disable front assist, also cruise stops functioning and does not activate.
Same discussion was in finnish VW forum. Someone there claimed the same thing but when asked for proof the person disappeared like fart in Sahara.
darkchina811
ITALY
C?ID=333184
since I retrofitted the round radar my CC became ACC, period, although I never tried disabling Front Assist to see what happens.
Rollux
New Zealand
C?ID=380572
I’m sure it did - I remember the fright my wife got when she nearly ran up the back of a car when the CC didn’t back off speed and the ear bashing I got because of ‘fiddling’ with her car!
However, I will take it for a drive tomorrow and recheck, as I never turned it off again (why would you!?!) I may be mistaken, but I won’t forget that ear bashing in a long time :facepalm::facepalm:
PetrolDave
Westbury, UK
C?ID=1423
Nor on my 2015 Skoda Octavia with flat radar. Disabling front assist also disables ACC.
downtime
C?ID=280813
I tried it today. If you disable front assist from the menu, it allows you to activate cruise but it’s still ACC. I tested that. Car brakes if the car in front brakes.
People, front assist and ACC are different things. Front assist is like it says, assist system and ACC is active cruise. Both use same radar but for different purpose.
If you get front assist disabled by something blocking the radar it just says ACC Unavailable if you try to activate cruise.
And this is on Tiguan with flat radar.
With round radar if you disable front assist, it does not allow you to enable cruise either.
Rollux
New Zealand
C?ID=380572
Ok, I’ll eat humble pie as I was incorrect. Tried my wife’s MK7 and turned front assist off and activated cruise control - it is still Active. I’m sorry for any misinformation I may have given.
Back to OP tho, I would go to many lengths to fix the ACC fault as it is awesome &#55357;&#56846;
Morski
Cheshire UK
C?ID=90186
iirc Autoglass charge £250+vat to do an alignment and Audi charge £200+vat. There are others out there who might have the Hella system or Autel ADAS who can do it cheaper but worth ringing around.
mk77l6
Atlanta, GA, USA
C?ID=521054
How do you code down the ACC to regular cruise? Never heard of being able to do this
Yes, they changed it in later models, but those of us with early ACC models are sh&t out of luck if we accidentally misalign the ACC sensor. It’s a frustrating stupid design I wish there were a work around for.
downtime
C?ID=280813
Newer radars (mostly on MY2020 and later cars) can be coded to support standard cruise as well. It is then selectable from driver assist menu. Older ones don’t support this.
mk77l6
Atlanta, GA, USA
C?ID=521054
Yep, I noticed on a recent Tiguan rental. I envy it.
