Hi Everyone,
Wondering if any of you can help shed some light on or point me in the direction of a solution to the following...
I have just bought a 2011 A8 (D4) 3.0tdi with the 8sp ZF in it. A couple of days after purchase I got the warning on the dash 'Gearbox Malfunction, you may continue driving' - Terrifying!
The car drives fine, no issues, so plugged in yesterday to pull the codes etc.
The (hopefully) good news is there are no actual gearbox codes (02-Auto Trans) showing, the only thing I can see that seems relevant is in the (81-Gear Shift) shifter module which is showing a P17EC 00 [008] - Electrical Malfunction...
Full Auto-Scan below:
Monday,09,March,2020,12:12:44:38580
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4H2BN005348 License Plate: VK11URY
Mileage: 104366km-64850mi Repair Order: 09-03-2020
Chassis Type: 4H-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 20 28 30 34 36 3B 42 46
47 52 53 56 5F 62 6C 6D 6F 72 81 88 89 8F 90
VIN: WAUZZZ4H2BN005348 Mileage: 104366km-64850miles
81-Gear Shift -- Status: Malfunction 0010
Address 01: Engine (J623-CDTA) Labels:. 059-907-401-V2.clb
Part No SW: 4H0 907 401 HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0003
Revision: 53H37---
Coding: 0A2A4012052601020800
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TDI0114H0907401 001009
ROD: EV_ECM30TDI0114H0907401.rod
VCID: 619CAD3E61C0C14FA6B-8034
Part No SW: 4H1 927 158 A HW: 0BK 927 156 L
Component: 0BK 30 TDIRdW H08 0003
Revision: --H08---
Coding: 001111
ASAM Dataset: EV_TCMALX51011 001013
ROD: EV_TCMALX51011_001.rod
VCID: 2E060602609E2E376B9-807A
Address 03: ABS Brakes (J104) Labels: 4H0-907-379.clb
Part No SW: 4H0 907 379 B HW: 4H0 907 379 B
Component: ESP PREMIUM H09 0272
Coding: 60E5A30006A7C500E300
ASAM Dataset: EV_ESPPremi 005006
ROD: EV_ESPPremi_005_AU64.rod
VCID: 313C1D7E71A031CF76B-8064
Part No SW: 4H0 907 064 DB HW: 4H0 907 064 AB
Component: BCM2 2.0 H23 0510
Coding: 05B72F00000000000000
Shop #: WSC 19196 000 1048576
VCID: 6C82CC0A96829C2705D-8038
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 0210000148991012
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-BFS H08 0153
Revision: AA000000 Serial number: 00001002099048
Coding: 0038320000047201000001010101112131313333283333
Shop #: WSC 02313 785 00200
VCID: 3432146A8E3204E71DD-8060
Address 08: Auto HVAC (J255) Labels:| 4H0-820-043.clb
Part No SW: 4H0 820 043 D HW: 4H0 820 043 D
Component: Klima 4 Zonen H14 0051
Coding: 362100BE00
ROD: EV_AirCondiFront_001_AU64.rod
VCID: 211CED3E2140814FE6B-8074
0132 - Motor for Left Side Window Defrost Flap
B10D7 31 [009] - No Signal
Reset counter: 138
Mileage: 104348 km
Date: 2020.03.07
Time: 13:06:00
Part No SW: 4H0 907 063 G HW: 4H0 907 063
Component: BCM1 2.0 H12 0092
Revision: 11012002 Serial number: 00000000649196
Coding: 0907201009749FE18B810007A0001800009DC30A0F000101800108542F00
Shop #: WSC 00720 210 86430
VCID: 2C020C0A56025C2745D-8078
Subsystem 1 - Part No SW: 4H2 955 119 C HW: 4H2 955 119 A Labels: 1KX-955-119.CLB
Component: WWS641 100218 H32 0040
Serial number: 100223021751
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 C Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10021459
Coding: 025523
Subsystem 3 - Part No SW: 4H0 941 531 B HW: 4H0 941 531 B
Component: E1 - LDS H07 0044
Serial number: 14 09 2010 00000171
Subsystem 4 - Part No SW: 4H0 907 472 A HW: 4H0 907 472 A
Component: A31 LED Mod1L H01 0002
Serial number: 000000-0000-0000
Coding: 100000
Subsystem 5 - Part No SW: 4H0 907 472 A HW: 4H0 907 472 A
Component: A27 LED Mod1R H01 0002
Coding: 100000
Subsystem 6 - Part No SW: 4H0 907 705 H HW: 4H0 907 705 C
Component: EVLS-SG H08 0275
Serial number: WA100300000000072218
Coding: 020300
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: D2180345000000000001
Part No SW: 4H0 919 475 F HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0020
Revision: 11001001 Serial number: 55931025102978
Coding: 300302
ASAM Dataset: EV_AU57XParkiAssis2 002005
ROD: EV_AU57XParkiAssis2.rod
VCID: 3534296E85C81DEF2A3-8060
Part No SW: 4H0 959 655 B HW: 4H0 959 655 B
Component: Airbag10.43 H24 0028
Revision: -------- Serial number: 003G10018W9R
Coding: 30314246304230303038554A305234483053
Serial number: 3575HRB406500Q2I81V4
Serial number: 3585HRB40516RSSQDPR8
Serial number: 3515JRB405L6T8MI60FX
Serial number: 3525JRB405H6T8MI897X
Serial number: 3554VRB40536UBV89P69
Serial number: 3564VRB40536UBV8PGS$
Part No SW: 4H0 953 568 A HW: 4H0 953 568 A
Component: Lenks.Modul H08 0007
Revision: -------- Serial number: 90815JIE0000M
Coding: 000034
VCID: 313C1D7E712031CF76B-8064
Subsystem 1 - Part No SW: 4H0 951 528 A HW: 4H0 951 528 A
Component: E221 - MFL H06 0009
Serial number: 29 04 2010 11010222
Part No SW: 4H0 920 910 D HW: 4H0 920 910 A
Component: TDieGB------- H30 0297
Revision: 26110011 Serial number: 658260810593027
Coding: 33A6080013002600010000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU64.rod
VCID: 2514F92E35686D6F9A3-8070
Analog_clock:
Subsystem 1 - Part No SW: 4H0 919 204 H HW: 4H0 919 204 H
Component: Analoguhr D4 H04 0210
Serial number: 1100902004396
Part No SW: 4H0 907 468 F HW: 4H0 907 468 C
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000040503
Coding: 00CD077D00
ROD: EV_GatewUDS_AU57.rod
VCID: 3432146A8EB204E71DD-8060
Subsystem 1 - Part No SW: 4H0 915 181 HW: 4H0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650020170
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 C HW: 8K0 959 663 C
Component: J532_DCDCStab H04 0003
Serial number: 10238001678021200410
Part No SW: 8K0 857 511 E HW: 8K0 857 511 E
Component: FLA H04 0004
Revision: AA001002
Coding: 04028B6B74745D545420363E
VCID: 333017768B3C03DF047-8066
Address 28: HVAC, Rear (E265) Labels:| 4H0-919-158.clb
Part No SW: 4H0 919 158 D HW: 4H0 919 158 D
Component: Klima Fond H14 0050
Coding: 0800000000
ROD: EV_AirCondiHeck_AU64.rod
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000005434
Coding: 01010101000000000000000202
VCID: 6492A42A7E52D4674DD-8030
Part No SW: 4H0 907 553 B HW: 4H0 907 553
Component: LUFE-DAEMPFER H16 0095
Coding: 008000
ASAM Dataset: EV_AirSuspe 003017
ROD: EV_AirSuspe_VW51.rod
VCID: 2B000F16538C5B1F4C7-807E
Component: MEM-FS H08 0153
Revision: AA000000 Serial number: 00001002099102
Coding: 00383B0000057201000001010101112131313333203333
Address 3B: Sensor Elect. (J849) Labels: None
Part No SW: 4H0 907 637 HW: 4H0 907 637
Component: SARA 6D H02 0015
Revision: -------- Serial number: EJ1BPA31004HH-0
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 6C82CC0A96029C2705D-8038
Part No SW: 4H0 959 793 E HW: 4H0 959 793 E
Component: TSG FA H02 0162
Revision: -------- Serial number: 0000107831626
Coding: 011F12205E2162C202080006
VCID: 3B203F56A36CCB9FDC7-806E
Revision: 00002001 Serial number: 0134909325
Coding: 011B0E2200B93D81B320C784080100000000000000000000000000000000
Subsystem 1 - Part No: 4H0 951 177
Subsystem 3 - Part No SW: 4H0 947 135 A HW: 4H0 947 135 A
Component: Dachelektroni H11 0080
Serial number: A2010000000000154655
Part No SW: 4G0 035 223 A HW: 4G0 035 223 A
Component: BOSE G3 C7 H07 0070
Revision: CJ007000 Serial number: 00000000002511
VCID: 1B60DFD603ACAB9F3C7-804E
Part No SW: 4H0 959 792 E HW: 4H0 959 792 E
Component: TSG BF H02 0162
Revision: -------- Serial number: 0000107544843
VCID: 3A2E3A52AC56F297C71-806E
Reset counter: 178
Mileage: 104348 km
Date: 2020.03.07
Time: 13:25:26
01482 - Motors for Central Locking
Fault Status: 00100110
Reset counter: 178
Mileage: 104348 km
Date: 2020.03.07
Time: 13:25:26
Part No SW: 4H0 907 801 C HW: 4H0 907 801 A
Component: EPB-4 H03 0009
Revision: -------- Serial number: 00000000010127
ASAM Dataset: EV_ParkiBrake 001015
ROD: EV_ParkiBrake_VW51.rod
VCID: 280AF01A427A7007A15-807C
Part No SW: 4E0 035 061 H HW: 4E0 035 061
Component: Radio U DAB H46 0048
Revision: AB001007 Serial number: 014IL0A7510107
Coding: 010103010000000001
VCID: 201AE83A2ACA8847E95-8074
Part No SW: 4H0 035 666 C HW: 4H0 035 666 C
Component: H-BN-EU H41 0171
Revision: -------- Serial number: 028IU0A7502533
Coding: 020101000001F1EF45108B1E00000003E001010000000000
VCID: 290CF51E59F0490FBEB-807C
Subsystem 1 - Part No: 8R0 060 884 R
Component: EUR 2010 1107
Subsystem 2 - Part No SW: 4H0 919 604 C HW: 4H0 919 604 C
Component: DU8 D4 SV NB H46 0021
Serial number: AUZ8ZDA26006QKT
Subsystem 3 - Part No SW: 4H2 919 600 C HW: 4H2 919 600
Component: E380 BDT D4 H09 0062
Serial number: 00000000014430
Component: CD-Database 1886
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 A HW: 4H0 959 795 A
Component: TSG HL H04 0162
Revision: -------- Serial number: 0000107538901
Coding: 010F1220402162C202080006
VCID: 392C255EA950F98FCEB-806C
Part No SW: 4H0 907 441 HW: 4H0 907 441
Component: SG Rueckfahrkamera 0030
Revision: --H03--- Serial number: 525 PA8J08D0AR
Coding: 1022002
VCID: 6594B92E7968AD6F5A3-8030
Address 6D: Trunk Elect. (----) Labels:* None
Part No SW: 4H0 959 107 P HW: 4H0 959 107 M
Component: HDSG-Modul H11 0036
Revision: 10011001 Serial number: 254000034
Coding: 0210044000
ROD: EV_DeckLidContrUnit.rod
VCID: 3B203F56A3ECCB9FDC7-806E
Address 6F: Centr. Conv. II (J773) Labels:* None
Part No SW: 4H0 907 412 HW: 4H0 907 412
Component: ALM H05 0004
Revision: -------- Serial number: 000000010463
Coding: 220000
ASAM Dataset: EV_Ambie 001008
ROD: EV_Ambie.rod
VCID: 6390A7367BDCD35FB47-8036
Component: TSG HR H04 0162
Revision: -------- Serial number: 0000107538900
Address 81: Gear Shift (J587) Labels: 3Y0-927-731.clb
Part No SW: 4H2 927 731 HW: 4H2 927 731
Component: GSM-RL H04 0081
Revision: 0R0D4011 Serial number: SN100708 0057
ASAM Dataset: EV_GSM2x3Mono 001014
ROD: EV_GSM2x3Mono.rod
VCID: 6B80CF16930C9B1F0C7-803E
10022 - Unlock Button
Fault Frequency: 8
Reset counter: 179
Mileage: 104360 km
Date: 2020.03.09
Time: 08:34:37
Voltage terminal 15: 14.6 V
Voltage terminal 30: 14.6 V
Driving position: D/S
Selector lever position: drive lane (X)
Unlock button signal: 4.2 V
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 E HW: 4H0 907 182 E
Component: IVB H03 0027
Serial number: 00454004093001
Coding: 672FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2C020C0A56825C2745D-8078
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00453854179901
Coding: 272FF2
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 00060000031F030000030800424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FB8DB06A714673F20F-803A
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70BAD87ABA2A78C7395-8024
End----(Elapsed Time: 02:49, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
