Results 1 to 5 of 5
Thread: Audi A8 D4 Gear Shift Module throwing codes
    Mar 2020
    Hi Everyone,
    Wondering if any of you can help shed some light on or point me in the direction of a solution to the following...
    I have just bought a 2011 A8 (D4) 3.0tdi with the 8sp ZF in it. A couple of days after purchase I got the warning on the dash 'Gearbox Malfunction, you may continue driving' - Terrifying!
    The car drives fine, no issues, so plugged in yesterday to pull the codes etc.
    The (hopefully) good news is there are no actual gearbox codes (02-Auto Trans) showing, the only thing I can see that seems relevant is in the (81-Gear Shift) shifter module which is showing a P17EC 00 [008] - Electrical Malfunction...
    Full Auto-Scan below:
    Monday,09,March,2020,12:12:44:38580
    VIN: WAUZZZ4H2BN005348   License Plate: VK11URY
    Mileage: 104366km-64850mi   Repair Order: 09-03-2020
    Chassis Type: 4H-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 10 15 16 17 19 20 28 30 34 36 3B 42 46
              47 52 53 56 5F 62 6C 6D 6F 72 81 88 89 8F 90
    VIN: WAUZZZ4H2BN005348   Mileage: 104366km-64850miles
    81-Gear Shift -- Status: Malfunction 0010
    Address 01: Engine (J623-CDTA)       Labels:. 059-907-401-V2.clb
       Part No SW: 4H0 907 401     HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0003
       Revision: 53H37---
       Coding: 0A2A4012052601020800
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TDI0114H0907401 001009
       ROD: EV_ECM30TDI0114H0907401.rod
       VCID: 619CAD3E61C0C14FA6B-8034
       Part No SW: 4H1 927 158 A    HW: 0BK 927 156 L
       Component: 0BK 30 TDIRdW H08 0003
       Revision: --H08---
       Coding: 001111
       ASAM Dataset: EV_TCMALX51011 001013
       ROD: EV_TCMALX51011_001.rod
       VCID: 2E060602609E2E376B9-807A
    Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
       Part No SW: 4H0 907 379 B    HW: 4H0 907 379 B
       Component: ESP PREMIUM   H09 0272
       Coding: 60E5A30006A7C500E300
       ASAM Dataset: EV_ESPPremi 005006
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 313C1D7E71A031CF76B-8064
       Part No SW: 4H0 907 064 DB    HW: 4H0 907 064 AB
       Component: BCM2 2.0      H23 0510
       Coding: 05B72F00000000000000
       Shop #: WSC 19196 000 1048576
       VCID: 6C82CC0A96829C2705D-8038
       Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
       Component: J764 ELV MLB  H38 0044
       Serial number: 0210000148991012
       Component: MEM-BFS       H08 0153
       Revision: AA000000    Serial number: 00001002099048
       Coding: 0038320000047201000001010101112131313333283333
       Shop #: WSC 02313 785 00200
       VCID: 3432146A8E3204E71DD-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 D    HW: 4H0 820 043 D
       Component: Klima 4 Zonen H14 0051
       Coding: 362100BE00
       ROD: EV_AirCondiFront_001_AU64.rod
       VCID: 211CED3E2140814FE6B-8074
    0132 - Motor for  Left Side Window Defrost Flap
              B10D7 31 [009] - No Signal
                        Reset counter: 138
                        Mileage: 104348 km
                        Date: 2020.03.07
                        Time: 13:06:00
       Part No SW: 4H0 907 063 G    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0092
       Revision: 11012002    Serial number: 00000000649196
       Coding: 0907201009749FE18B810007A0001800009DC30A0F000101800108542F00
       Shop #: WSC 00720 210 86430
       VCID: 2C020C0A56025C2745D-8078
       Subsystem 1 - Part No SW: 4H2 955 119 C    HW: 4H2 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 100218  H32 0040
       Serial number:         100223021751
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 10021459
       Coding: 025523
       Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
       Component: E1 - LDS  H07 0044
       Serial number: 14 09 2010  00000171
       Subsystem 4 - Part No SW: 4H0 907 472 A    HW: 4H0 907 472 A
       Component: A31 LED Mod1L  H01 0002
       Serial number: 000000-0000-0000
       Coding: 100000
       Subsystem 5 - Part No SW: 4H0 907 472 A    HW: 4H0 907 472 A
       Component: A27 LED Mod1R  H01 0002
       Coding: 100000
       Subsystem 6 - Part No SW: 4H0 907 705 H    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0275
       Serial number: WA100300000000072218
       Coding: 020300
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: D2180345000000000001
       Part No SW: 4H0 919 475 F    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0020
       Revision: 11001001    Serial number: 55931025102978
       Coding: 300302
       ASAM Dataset: EV_AU57XParkiAssis2 002005
       ROD: EV_AU57XParkiAssis2.rod
       VCID: 3534296E85C81DEF2A3-8060
       Part No SW: 4H0 959 655 B    HW: 4H0 959 655 B
       Component: Airbag10.43   H24 0028
       Revision: --------    Serial number: 003G10018W9R
       Coding: 30314246304230303038554A305234483053
       Serial number: 3575HRB406500Q2I81V4
       Serial number: 3585HRB40516RSSQDPR8
       Serial number: 3515JRB405L6T8MI60FX
       Serial number: 3525JRB405H6T8MI897X
       Serial number: 3554VRB40536UBV89P69
       Serial number: 3564VRB40536UBV8PGS$
       Part No SW: 4H0 953 568 A    HW: 4H0 953 568 A
       Component: Lenks.Modul   H08 0007
       Revision: --------    Serial number: 90815JIE0000M
       Coding: 000034
       VCID: 313C1D7E712031CF76B-8064
       Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
       Component: E221 - MFL  H06 0009
       Serial number: 29 04 2010  11010222
       Part No SW: 4H0 920 910 D    HW: 4H0 920 910 A
       Component: TDieGB------- H30 0297
       Revision: 26110011    Serial number: 658260810593027
       Coding: 33A6080013002600010000
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K_AU64.rod
       VCID: 2514F92E35686D6F9A3-8070
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 H    HW: 4H0 919 204 H
       Component: Analoguhr D4  H04 0210
       Serial number: 1100902004396
       Part No SW: 4H0 907 468 F    HW: 4H0 907 468 C
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000040503
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 3432146A8EB204E71DD-8060
       Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650020170
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 C    HW: 8K0 959 663 C
       Component: J532_DCDCStab  H04 0003
       Serial number: 10238001678021200410
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 E
       Component: FLA           H04 0004
       Revision: AA001002
       Coding: 04028B6B74745D545420363E
       VCID: 333017768B3C03DF047-8066
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
       Component: Klima Fond    H14 0050
       Coding: 0800000000
       ROD: EV_AirCondiHeck_AU64.rod
       Part No SW: 4H0 907 440     HW: 4H0 907 440
       Component: STS           H06 0030
       Revision: S0H06000    Serial number: 00000000005434
       Coding: 01010101000000000000000202
       VCID: 6492A42A7E52D4674DD-8030
       Part No SW: 4H0 907 553 B    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H16 0095
       Coding: 008000
       ASAM Dataset: EV_AirSuspe 003017
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2B000F16538C5B1F4C7-807E
       Revision: AA000000    Serial number: 00001002099102
       Coding: 00383B0000057201000001010101112131313333203333
    Address 3B: Sensor Elect. (J849)       Labels: None
       Part No SW: 4H0 907 637     HW: 4H0 907 637
       Component: SARA 6D       H02 0015
       Revision: --------    Serial number: EJ1BPA31004HH-0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 6C82CC0A96029C2705D-8038
       Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Component: TSG FA        H02 0162
       Revision: --------    Serial number: 0000107831626
       Coding: 011F12205E2162C202080006
       VCID: 3B203F56A36CCB9FDC7-806E
       Revision: 00002001    Serial number: 0134909325
       Coding: 011B0E2200B93D81B320C784080100000000000000000000000000000000
       Subsystem 1 - Part No: 4H0 951 177
       Subsystem 3 - Part No SW: 4H0 947 135 A    HW: 4H0 947 135 A
       Component: Dachelektroni  H11 0080
       Serial number: A2010000000000154655
       Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0070
       Revision: CJ007000    Serial number: 00000000002511
       VCID: 1B60DFD603ACAB9F3C7-804E
       Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
       Component: TSG BF        H02 0162
       Revision: --------    Serial number: 0000107544843
       VCID: 3A2E3A52AC56F297C71-806E
                        Reset counter: 178
                        Mileage: 104348 km
                        Date: 2020.03.07
                        Time: 13:25:26
    01482 - Motors for Central Locking
                        Fault Status: 00100110
                        Reset counter: 178
                        Mileage: 104348 km
                        Date: 2020.03.07
                        Time: 13:25:26
       Part No SW: 4H0 907 801 C    HW: 4H0 907 801 A
       Component: EPB-4         H03 0009
       Revision: --------    Serial number: 00000000010127
       ASAM Dataset: EV_ParkiBrake 001015
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 280AF01A427A7007A15-807C
       Part No SW: 4E0 035 061 H    HW: 4E0 035 061
       Component: Radio U DAB   H46 0048
       Revision: AB001007    Serial number: 014IL0A7510107
       Coding: 010103010000000001
       VCID: 201AE83A2ACA8847E95-8074
       Part No SW: 4H0 035 666 C    HW: 4H0 035 666 C
       Component: H-BN-EU       H41 0171
       Revision: --------    Serial number: 028IU0A7502533
       Coding: 020101000001F1EF45108B1E00000003E001010000000000
       VCID: 290CF51E59F0490FBEB-807C
       Subsystem 1 - Part No: 8R0 060 884 R
       Component: EUR 2010  1107
       Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
       Component: DU8 D4 SV NB  H46 0021
       Serial number: AUZ8ZDA26006QKT
       Subsystem 3 - Part No SW: 4H2 919 600 C    HW: 4H2 919 600
       Component: E380 BDT D4  H09 0062
       Serial number: 00000000014430
       Component: CD-Database  1886
       Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
       Component: TSG HL        H04 0162
       Revision: --------    Serial number: 0000107538901
       Coding: 010F1220402162C202080006
       VCID: 392C255EA950F98FCEB-806C
       Part No SW: 4H0 907 441     HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0030
       Revision: --H03---    Serial number: 525 PA8J08D0AR
       Coding: 1022002
       VCID: 6594B92E7968AD6F5A3-8030
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0036
       Revision: 10011001    Serial number: 254000034
       Coding: 0210044000
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3B203F56A3ECCB9FDC7-806E
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Part No SW: 4H0 907 412     HW: 4H0 907 412
       Component: ALM           H05 0004
       Revision: --------    Serial number: 000000010463
       Coding: 220000
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 6390A7367BDCD35FB47-8036
       Component: TSG HR        H04 0162
       Revision: --------    Serial number: 0000107538900
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H2 927 731     HW: 4H2 927 731
       Component: GSM-RL        H04 0081
       Revision: 0R0D4011    Serial number: SN100708  0057
       ASAM Dataset: EV_GSM2x3Mono 001014
       ROD: EV_GSM2x3Mono.rod
       VCID: 6B80CF16930C9B1F0C7-803E
    10022 - Unlock Button
                        Fault Frequency: 8
                        Reset counter: 179
                        Mileage: 104360 km
                        Date: 2020.03.09
                        Time: 08:34:37
                        Voltage terminal 15: 14.6 V
                        Voltage terminal 30: 14.6 V
                        Driving position: D/S
                        Selector lever position: drive lane (X)
                        Unlock button signal: 4.2 V
    Address 88: Multicont. Seat Driver (J873)       Labels:* None
       Part No SW: 4H0 907 182 E    HW: 4H0 907 182 E
       Component: IVB           H03 0027
       Serial number: 00454004093001
       Coding: 672FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2C020C0A56825C2745D-8078
    Address 89: Multicont. Seat Pass. (J872)       Labels:* None
       Serial number: 00453854179901
       Coding: 272FF2
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 00060000031F030000030800424CDA010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 6FB8DB06A714673F20F-803A
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70BAD87ABA2A78C7395-8024
    End----(Elapsed Time: 02:49, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
    Near Philadelphia, PA, USA
    If I had to guess, it was the unlock button that caused that display. Note it is an intermittent fault and it occurred 8 times. Bumpy road when the cluster displayed that message? Seems something on the gear shift needs attention.
    The intermittent status means that at the moment of the scan, the unlock button was fine. You could try clearing the code on the shift unlock button, then drive the car, see if the fault gets set again. If it does, you have a problem there that needs attention.
    What I have written here is a guess on my part for I have never seen the cluster warning. Others may have a different/more correct view of your problem.
  3. Likes flat4matt liked this post
    Mar 2020
    Hi Bruce, firstly thanks for taking the time to reply, much appreciated.
    It's an odd one as it's come on at seemingly completely random times and frequency, not after any rough road or the likes. The first time was sub 10mph on a smooth as butter car park, the second time was slowing from 40mph to 30mph, then again straight after (within a minute) while cruising at around 30. I've been trying to watch out for it to try and correlate some sort of reasoning behind it but yesterday it happened twice on the way to work, today though, same road, same conditions, same driving style, no issue at all!.
    Agree it's seemingly likely to be something to do with the shifter assembly or the module itself.
    I did just find a TSB for a software update mentioning the code though (seems unlikely for it to have just reared its head now though!) https://static.nhtsa.gov/odi/tsbs/20...65993-2280.pdf
  5. Likes Bruce, Uwe liked this post
    The TSB does seem to indicate that there should be a software update available for that module, to version 0083, and you currently have 0081.
    If it were mine, I'd take it to the dealer and see if they can update it.
  7. Likes PetrolDave, flat4matt liked this post
  8. #5
    Mar 2020
    Hi Uwe, I literally came to the same conclusion just after posting, I'm booked in for the emissions related update and have asked them to perform the above too on Thursday of this week. I will update on the results
  9. Likes Uwe liked this post
