How is that helpful?Absolutely living up to your username Dr. Distortion..........
A peak of 205 g/s seems reasonable for a tuned R32, I guess.Any thoughts on the log?
Looking back at your original faults, I wonder if you don't have an intake air leak somewhere past the MAF.
My name is from years reverse engineering vintage guitar effects.
I've been chasing what I thought was a post MAF air leak.
The two large breather tubes were cracked. I covered them with heat shrink, didn't like it and replaced the tubes.
I removed and cleaned the throttle body so I thought I might have a bad O ring. so I replaced it.
I sprayed all the hose junctions with Berryman's looking for an increase in RPM. Nothing.
New fuel pump about 5000 miles ago.
There is Regain fuel additive in the fuel but I had put several hundred miles on it after the additive.
The reason I was looking for a vacuum leak was it would hunt at idle. This had happened before and I found and fixed the leak...
MAF was replaced with PN 0280218073 with the Bosch "check at" seal on it. Purchased from Autohaus AZ. Had the same fault so I went back to the MAF that was on the cat for 40K+ miles.
Hi Jack,
I'm very much a novice at using this tool. Can I get guidance on:
"OP log CF for timing in all Zyl's please and post them in a pull.
Let's have a look at how deep knock control is going okay?"
Thanks,
I have been running this tune for MANY years without problem. Got a problem and have been chasing ghosts /poor behavior since...Steinberger Sound was right around corner from my first auto-parts store in 1994 on 9W Newburgh NY.
https://en.wikipedia.org/wiki/Steinberger
Cool, I'm familiar with Steinberger. I worked as a test engineer on a medical imaging devise that used 96 channels of very high speed A to D converters. I used the same test systems to study effect pedals guitars and amps.
I setup an employees Digifant 2 Vanagon Wasser on the VAG 1767 when it was new and he was the first vehicle I hooked it up too, when putting my VAG 1367 on shelf.
I got a personal tour of the molds and assemblies.
Nice!
What about fuel filter?
Changed with pump
What about booster circuit adaptive values and secondary Aux brake vacuum pump if supported down to rack area lines?
Haven't checked them I will locate and do so. Will the Berryman's trick work?
0x01-04-103-4 & 108 report please.
0x01-08-020/021 ME7.1.1 can be fickle in action ........
https://forums.ross-tech.com/showthread.php?3147-What-is-Jack-talking-about-0x01-08-000
In regards to bad MAF or new MAF out of box being bad it happens often!
Just an FYI I have owned and worked on many R32's ones with mods and stock or with tuning.
I can tell you that ME7.1.1 if tuned will learn to not run proper on a MAF & that is even in good condition if another issue is present and the ADP fails to clear in eeprom on tuned cars.
Don't understand this...
In some cases the MOD cars had to be defaulted to accept the old or new MAF if car was in proper order & to not always pend a DTC due to tuners neglect!
Thursday 4 June 2020 17:29:00:63675-VCID:54A9703EF403F4EF51-5178 VCDS Version: Release 19.6.2 (x64) Data version: 20200210 DS308.0
022 906 032 EG United R32 G 6411
Group A: '020 Group B: '021 Group C: Not Running
Timing Retardation Timing Retardation Timing Retardation Timing Retardation Timing Retardation Timing Retardation
TIME Cylinder 1 Cylinder 2 Cylinder 3 Cylinder 4 TIME Cylinder 5 Cylinder 6 TIME
Marker STAMP °KW °KW °KW °KW STAMP °KW °KW STAMP
0 0 0 0 0 0.17 0 0
0.35 0 0 0 0.8 0.52 0 0
0.69 0 0 0 0 0.86 0 0
1.03 2.3 0 2.3 2.3 1.2 4.5 4.5
1.37 1.5 0 1.5 1.5 1.53 3.8 4.5
1.7 3.8 0 1.5 1.5 1.87 3.8 4.5
2.04 3.8 0 1.5 1.5 2.2 3.8 4.5
2.38 3.8 0 1.5 1.5 2.54 3 3.8
2.71 3 0 0.8 0 2.89 3 3.8
3.07 3 0 0 0 3.23 2.3 3.8
3.41 3 3.8 0 0 3.57 2.3 3
3.74 2.3 3.8 0 0 3.92 1.5 1.5
4.09 0 0 0 0 4.26 0 0
4.43 0 0 0 0 4.6 0 0
4.77 0 0 0 0 4.94 0 0
5.12 0 0 0 0 5.29 0 0
5.46 0 0 0 0 5.63 0 0
5.8 0 0 0 0 5.97 0 0
6.14 0 0 0 0 6.3 0 0
6.47 0 0 0 0 6.64 0 0
6.82 0 0 0 0 6.99 0 0
7.16 0 0 0 0 7.33 0 0
7.5 0 0 0 0 7.67 0 0
7.84 0 0 0 0 8 0 0
Yep, but tuned ECUs are often more sensitive and apt to misbehave when something that's just a bit out of kilter than stock ECUs are. I've seen this first hand when I was involved in this sort of thing back in the day of 12V VR6s.I have been running this tune for MANY years without problem. Got a problem and have been chasing ghosts /poor behavior since...
CODE tags fixed it right up.Sorry, This still looks like ASS...
I've been looking for leaks using Berryman's B12. Is there a better way to find leaks?
Manifold leak is unlikely, never been off...
Is there a better way to find leaks than spraying with B12?
