Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: MKIV R32 P0103 and P1143
    Jun 2016
    Hi All...
    First post in a long time.
    I'm having problems with my R32.
    Started as a p0103, so I changed the MAF with part# 0 280 218 073 German Bosch part.
    Then got p1143. so I removed and cleaned the TB. I replaced the O ring behind the TB and I realigned the throttle.
    The car started hunting at idle and surging while driving. I disassembled rechecking everything looking for vacuum leaks and found a broken breather tube. I replaced it with a new one part# 022 103 474 L. I realigned the throttle.
    Still have hunting and surging. CEL and stability lights lit.
    Log below...
    Thank you for giving it a look.
    Sunday,08,March,2020,16:34:43:63675
    VCDS Version: 19.6.2.2 (x64)
    VIN: WVWKG61J04D127005   License Plate:
    Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
              76
    VIN: WVWKG61J04D127005   Mileage: 231000km-143536miles
    Address 01: Engine        Labels: 022-906-032-BJS.lbl
       Part No SW: 022 906 032 EG    HW: 144 03
       Component: United  R32     G   6411
       Coding: 0000132
       Shop #: WSC 31414 000 00000
       VCID: 54A9703EF403F4EF51-5178
    17551 - Load Calculation Cross Check
                P1143 - 001 - Upper Limit Exceeded - Intermittent
    16891 - Idle Control System RPM
                P0507 - 001 - Higher than Expected. - MIL ON
    16487 - Mass Air Flow Sensor (G70)
                P0103 - 001 - Signal too High
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
       Part No: 1C0 907 379 P
       Component: ESP ALLRAD MK60     0101
       Coding: 0023049
       VCID: 377327B245B53FF754-515A
                013 - Check DTC Memory
    Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
       Part No: 3B1 907 044 C
       Component: CLIMATRONIC     C 2.0.0
       Coding: 11200
       Shop #: WSC 31414
       VCID: 2147E9EAAB3151478A-51B2
                37-00 - Faulty
       Part No: 1C0 909 605 F
       Component: 17 AIRBAG VW61 0108 0003
       Coding: 12599
       Shop #: WSC 31414
       VCID: 2753F7F2C515AF77C4-513C
       Part No: 1J0 920 927 A
       Component: KOMBI+WEGFAHRSP VDO V03
       Coding: 15230
       Shop #: WSC 04997
       VCID: 2957F1CAD3019907D2-513C
       WVWKG61J04D127005     VWZ7Z0C8634417
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 31414
       VCID: 70E1DCAE305BA8CF55-513C
    Address 22: AWD        Labels: 02D-900-554.lbl
       Part No: 02D 900 554 C
       Component: HALDEX LSC  ECC     0010
       VCID: 2041ECEEA03B584F85-4B18
       Part No: 1C0 959 799 C
       Component: C7 Komfortgerát HLO 0003
       Coding: 00064
       Shop #: WSC 31414
       VCID: 377327B215B53FF754-4B18
       Component: C7 Tőrsteuer.FS KLO 0202
       Component: C7 Tőrsteuer.BF KLO 0202
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 3B7 035 180 G
       Component:    Radio NP2        0016
       Coding: 00031
       Shop #: WSC 31414
       VCID: 2449E0FEB423446FE1-515A
    End-------------------------(Elapsed Time: 04:09)--------------------------
    Sorry wrong forum
    Jun 2016
    I thought I posted in the wrong place, sorry for the duplicate.
    Any suggestions what next steps should be?
    Oct 2014
    Arandjelovac, Serbia
    Please wait for the administrator's decision and don't worry, everything will come in its place.
    Moving to Car Repair Support.
  5. Likes Boki Ar liked this post
    Jun 2016
    Help? I'm stuck. Any Ideas?
    I would start by checking MAF readings -- at idle, and log a full throttle run through 2nd or 3rd gear and let's see what you've got.
    HQ
    Also, what are the values in 01-08-032?
    MAF issues are not super common on 2004 and onward vehicles.... unless there is some sort of aftermarket intake/filter installed, then MAF failures are common.
    Jef
  9. Likes Uwe liked this post
  10. #8
    Jun 2016
    Thank you Uwe, will do, can you point me to the directions to do that? I'm a novice. Willing to read/study if you could point me in the right direction.
    Thank you Jef same as above. I haven't used VCDS much...
    Thank you both. I won't be back to the problem till Sunday next. pointers to what to read would be very helpful...
    Regards
    Don (Dr.Distortion) Williams
  11. #9
    HQ
    Fuel trim stuff, what I'm asking about for 01-08-032:
    Uwe is asking for the data from 01-08-003.
    Here's a good sanity check for the status of your MAF. Do a full-throttle run all the way to redline in a single gear (second works fine). Group 002 usually shows air mass in g/s (in many modern ECU's, consult your Factory Repair Manual for the specific group for your particular vehicle). Your peak airflow should be roughly 0.80 times your horsepower if you are close to sea level.
    MK4 R32 (the best one) has the BJS engine, rated at 177kW @ 6200rpm. 177kW = 237HP. 80% of 237 is 189. So you would hope to see somewhere around 189 g/s from the MAF on a 2nd or 3rd gear pull when hitting 6200rpms. I will outright tell you... you will not see 189 g/s, but you should be decently close to it. The value will vary based on several factors... but the big 3 factors are volumetric efficiency of the engine, location of test (altitude) and weather conditions. What we are looking for is a rather low number that implies the MAF is under reporting air flow... if that is the case, then the engine would run lean (too much air).
    Jef
  12. Likes Uwe liked this post
  13. #10
    Jun 2016
    Hello everybody
    Sorry for the large gap. I've been isolated for the last 3 months and had no chance to get to the shop. I will be proceeding where I left off...
    Thank you for understanding.
