Saturday,07,March,2020,21:27:48:20475
VCDS Version: 19.6.2.0 (x64)
VIN: WAUEF78E96A043443 License Plate: DARE1
Mileage: broke Repair Order:
67 69 75 76 77
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8E0 910 115 M HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0080
Revision: --H10--- Serial number:
Coding: 0104010A180F0120
Shop #: WSC 09110 444 11712
VCID: 2B5F01278A4ACB1722-807E
049493 - No Communication with Instrument Cluster
U0155 - 008 -
Fault Status: 01101000
Load: 0.0 %
Temperature: 3.0°C
Temperature: 5.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 11.176 V
049412 - No Communication with Cruise Control Module
U0104 - 008 -
Load: 0.0 %
Temperature: 3.0°C
Temperature: 5.0°C
Voltage: 11.176 V
049508 - No Communications with HVAC Control Module (J301)
U0164 - 008 -
Load: 0.0 %
Temperature: 3.0°C
Temperature: 5.0°C
Voltage: 11.176 V
001299 - Incorrect Immobilizer Key
P0513 - 008 -
RPM: 521 /min
Load: 60.0 %
Temperature: 3.0°C
Temperature: 5.0°C
Voltage: 10.287 V
Load: 0.0 %
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0110 0101
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
Component: ESP8 quattro H04 0120
Coding: 0004526
Shop #: WSC 06335 000 00000
VCID: 2953FB2F80B6D907D0-807C
Reset counter: 40
Hex Value: 0x0000
Hex Value: 0x4202
Hex Value: 0x0013
Hex Value: 0x2994
Hex Value: 0x0001
Fault Frequency: 6
Reset counter: 40
Hex Value: 0x0000
Hex Value: 0x4202
Hex Value: 0x0024
Hex Value: 0x0187
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AM
Component: A4 Klimaautomat 2831
Coding: 00000
VCID: 6CDDC23B1CC40C2F6B-513C
49-00 - No Communications
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul USA 0504
Coding: 01003
Shop #: WSC 65536
VCID: 3B7F3167292A5B97B2-4B18
01312 - Powertrain Data Bus
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H11 3540
Revision: 91H1135 Serial number: 0036N000P1P/
Coding: 0032607
VCID: 3C7D327B7F245CAFBB-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 33WJJ
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB401C0C620Gÿ†63
Subsystem 5 - Serial number: 0C620Gÿ†6342DRB401C2CB9D1ÿ†63
Subsystem 6 - Serial number: 2CB9D1ÿ†6352ARB400710E70Bÿ†63
Subsystem 7 - Serial number: 10E70Bÿ†6362ARB4006F3323Fÿ†63
Subsystem 8 - Serial number: F3323Fÿ†63729RB4008CED41Zÿ†63
Subsystem 9 - Serial number: CED41Zÿ†63829RB4008CEE830ÿ
Subsystem 10 - Serial number: CEE830ÿ
Fault Status: 11100100
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 R
Component: Lenksáulenmodul 0501
Coding: 04041
Shop #: WSC 08213
VCID: 42814C834EC02A5FF1-4B18
00888 - Wiper Switch for Intermittent Operation (E22)
37-00 - Faulty
01301 - Control Module for Voice Recognition (J507)
01304 - Radio
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BT
Component: Komfortgerát T7B 3332
Coding: 11896
Shop #: WSC 06335
VCID: 040D8A9B1454E46F83-4B32
Component: Tõrsteuer.FS BRM 0406
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0205
00962 - Alarm via. Tilt Sensor
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
35-00 - -
End-------------------------(Elapsed Time: 07:00)--------------------------
Address 09: DTCs cleared
The car will start and shut off. I have no power to the instrument cluster or radio. The windows work. The alarm worked until I did a capacitor discharge. I am not able to reach module 17 instruments I believe it is. Please help.
