Results 1 to 3 of 3
Thread: Central locking not locking after new bcm replacement
    Aug 2014
    uk
    Hi
    Had this Vw caddy come in with lots of faults after flat battery EG no horn,lights,dash lights, no charging.
    I have replaced the BCM with new part from Vw which has fixed the problem, I copied the orignal soft code and everything works except the central locking wont lock on remote, inside toggle switch or key barrel. check MVB and BCM is seeing signal for lock but nothing. My Guess is this new BCM needs to be recoded via VW or can anyone else help before I get my pants pulled down and shafted by VW.
    Old part number 5k0937085R
    new part number supplied by Vw 5k0937087-ac-z12
    Monday,09,March,2020,14:47:08:52053
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    Dealer/Shop Name: Wagenworx LTD
    VIN: WV1ZZZ2KZCX109469   License Plate:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56 61
    VIN: WV1ZZZ2KZCX109469   Mileage: 56630km-35188miles
    Address 01: Engine (J623-CAYE)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 TD    HW: 03L 907 425 C
       Component: R4 1.6l TDI   H43 9979
       Revision: --H43---    Serial number: 00000000000000
       Coding: 00114010032501080000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM16TDI02103L906023TD 003003
       ROD: EV_ECM16TDI02103L997557R.rod
       VCID: FBB6AAEB722EB59770-80AE
       Revision: 00H31001
       Coding: 433C200D09220303C20F04EA9022C091310000
       Shop #: WSC 35110 377 00144
       VCID: FBB6AAEB7A2EB59770-80AE
       Part No SW: 5K0 937 087 AC    HW: 5K0 937 087 AC
       Component: BCM PQ35 H+   122 0174
       Revision: BF122001
       Coding: 401A583A8025006A008000828000006403007288424F0160648087000041
       Shop #: WSC 18752 008 00032
       VCID: F6A0BBDF410CE8FF0F-80A2
       Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 11011  26  0512
       Coding: 009795
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag02B H06 0013
       Revision: --------    Serial number: 003HL00A166L
       Coding: 000000000000000000000000000000003242
       VCID: B5227CD3148AA3E7C6-80E0
       Part No SW: 5K0 953 507 AT    HW: 5K0 953 549 C
       Revision: --------    Serial number:  90440LA20000X
       Coding: 1080160000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 8248D70F15C4C45F33-80D6
       Part No SW: 2K0 920 965 E    HW: 2K0 920 965 E
       Component: KOMBI         H03 0606
       Coding: 480201
       VCID: B12A48C3E0E28FC79A-80E4
       Part No SW: 7N0 907 530 N    HW: 1K0 907 951
       Component: J533  Gateway H43 1623
       Revision:   H43       Serial number: 220112F2001940
       Coding: 357401
       VCID: BB366AEB3AAE759730-80EE
       Component: IMMO          H03 0606
       VCID: EA989FAF0DB43C1F9B-80BE
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2110
       Coding: 0000560
       Shop #: WSC 35110 377 08192
       VCID: C8DC0527BB782E0FAD-809C
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 140    3305
       Revision: 00H22000
       VCID: B73E76DBC68651F7D4-80E2
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0131632
       VCID: C7DE061BB6662177A4-8092
       Part No SW: 5K0 035 156 A    HW: 5K0 035 156 A
       Component: Radio         553 0555
       Revision: R0553007    Serial number: VWZ5Z1M0644166
       Coding: 0500020001
       VCID: A502AC93AC2AD36776-80F0
       Component: Batt.regelung H43 1623
       Coding: 030F1859
       VCID: F1AA88C32862CFC7DA-80A4
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900383304
    End----------(Elapsed Time: 00:48, VBatt start/end: 12.3V/12.3V)-----------
    Adaptation Channel 019 in BCM, see wiki.
  3. Likes Uwe liked this post
    Aug 2014
    uk
    Of course yes now working correctly thank you.
  5. Likes Uwe liked this post
