Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Passat B8 BiTDI retrofited to front RS3 370mm BREMBO brakes .
  1. #21
    Verified VCDS User @DRI@N's Avatar
    Nov 2017
    Romania
    Yes, original code have on BYTE 4 binary code 01010100 and on the BYTE 17 is binary code 00101010 !!!
    But I don't tried to change directly the binary codes in each Byte separately (04 and 17) !!!
    I have modification directly in LONGCODING !!!
  2. #22
    May 2017
    Sorry, now I don't follow?
    Did you change both at the same time and then tried to write the coding to the ABS? You can do the modification directly to long coding. No need to change the binary codes. Hex values work fine.
  3. Likes dnoermann liked this post
  4. #23
    Nov 2017
    Romania
    Yes, I change both Bytes at the same time directly in long coding !!
    But I tried to make the change separately Byte 4 firs and after Byte 17 !!
    But didn't work !!
  5. #24
    May 2017
    Yes, separate change does not work. You need to do them at the same time and then write the new coding. They have to match.
    So did it go if you changed them at the same time?
  6. #25
    Nov 2017
    Romania
    Yes, I changed both Bytes at the same time directly in long coding .
    But didn't work !!
  7. #26
    Quote Originally Posted by @DRI@N View Post
    But didn't work !!
    Do you mean the coding change wasn't accepted, or that it was accepted but made no difference?
  8. #27
    Nov 2017
    Romania
    I said on page 2 of the thread that the coding change wasn't accepted !!!
  9. #28
    May 2017
    D4 as brake type is not accepted by your ABS unit then. It might be undoable to code your current ABS unit to support the RS3 brakes. I know it's not something you would like to hear but it seems so.
  10. Likes PetrolDave liked this post
  11. #29
    Nov 2017
    Romania
    I suspected this thing .
    But now I'm interested if anybody maked the change of ABS unit on MQB platform with an RS3 ABS unit ?
  12. #30
    May 2017
    Good question. There's a difference in many of the other modules as well in A3 platform vs. Golf/Passat etc. So it might be that changing ABS will cause a plethora of changes needed to other modules as well.
