Results 1 to 7 of 7
Thread: No access to -10 Park/Steer assistis
    Mar 2020
    Question No access to -10 Park/Steer assistis
    Hi
    I am trying to access -10 Park/Steer Assist without luck. In fact it is not listed as installed under installation list in 19 Can Gateway.
    My car is equipped with PR code 7X7 - Park distance control rear with rear view camera. Doesn't that mean that I should have that gateway installed?
    Below is a full scan with some other issues as well.
    Sunday,08,March,2020,16:34:46:48066
    VIN: WAULFAFH6EN012787   License Plate:
    Mileage: 92280km-57340mi   Repair Order:
    Chassis Type: FH-AU48 (8R0)
    Scan: 01 02 03 05 06 08 09 15 16 17 19 26 36 42 44 46 47 52 53 56
              5F 62 6C 72
    VIN: WAULFAFH6EN012787   Mileage: 92280km-57340miles
    Address 01: Engine (DET-CPMB)       Labels:. 06H-907-115-CDN.clb
       Part No SW: 8K5 907 115 N    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 0005
       Revision: ECH09---
       Coding: 622A0013242600062000
       Shop #: WSC 28044 002 1048576
       ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
       ROD: EV_ECM20TFS0118K5907115N.rod
       VCID: 3D273FF0BDFA12CFE23-8068
    10203 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [096] - -
                        Mileage: 91684 km
                        Date: 2020.02.17
                        Time: 07:28:22
                        Engine speed: 1293.00 /min
                        Normed load value: 26.7 %
                        Coolant temperature: 11 °C
                        Intake air temperature: 12 °C
                        Voltage terminal 30: 12.180 V
                        Unlearning counter according OBD: 6
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    10591 - Cylinder 1
              P0301 00 [096] - Misfire Detected
                        Mileage: 91684 km
                        Date: 2020.02.17
                        Time: 07:29:10
       Part No SW: 8K0 927 158 T    HW: 0BK 927 156 AL
       Component: 0BK 20TFSIUSA H18 1006
       Revision: --H18---
       Coding: 000002
       VCID: 47CB5D18EF26481F48F-8012
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
       Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
       Component: ESP8 quattro  H09 0020
       Coding: 2D1D1801
       VCID: 094F9B20B932FE6F9EB-805C
       Part No SW: 8K0 907 064 JP    HW: 8K0 907 064 JP
       Component: BCM2 2.0      H14 0650
       Coding: 0D834040000000000000
       VCID: 074B9D18AF26881F88F-8052
       Serial number: 0214000051440005
       Part No SW: 8T0 959 760 F    HW: 8T0 959 760 F
       Component: MEM-BFS       H10 0077
       Revision: AA000000    Serial number: 00000090323372
       Coding: C80370250D2400001000
       VCID: 46D5501CE8AC5117B39-8012
       Part No SW: 8K1 820 043 AL    HW: 8K1 820 043 AL
       Revision: C3000000    Serial number: 01130320141969
       Coding: 6483208E00
       VCID: 72BDDCCCB4A49DB7CF1-8026
       Revision: 08016001    Serial number: 00000772938302
       Coding: 26000091873CAFC00000480000003D0D0F1C5288A209022100000B004000030100000070000000
       VCID: 78A9EEE4D2D8F7E7F15-802C
       Subsystem 1 - Part No SW: 8F1 955 119     HW: 8K1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 050314  H07 0080
       Serial number: SWF14033055349
       Coding: 00FD11
       Serial number: 22355953
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000803140685
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555RAJ5803
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 55498A17000000000001
    Address 15: Airbags (J234)       Labels:| 8F0-959-655.clb
       Part No SW: 8F0 959 655 E    HW: 8F0 959 655 E
       Component: AirbagVW-AU10 H15 0430
       Serial number: 003KKDB002XG
       Coding: 303741353731303030304A55304C38463053
       ASAM Dataset: EV_AirbaAU10SMEAU485 001004
       ROD: EV_AirbaECUVWAUDI010.rod
       VCID: 3A2D34ECACD425F7C71-806E
       Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
       Component: BF-Gewichtss.  H02 0060
       Serial number: 5810000R130000GLLD
       Serial number: 6334MSME450908313
       Serial number: 6344MSME4269560BH
       Serial number: 6352QSME453D415EQ
       Serial number: 6362QSME433D115AI
       Serial number: 63732SME3940417A.
       Serial number: 63832SME4E42284E9
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862NCD000RF
       Coding: 000016
       VCID: 48C95E24E2B84767415-801C
       Part No SW: 8T0 920 984 N    HW: 8T0 920 984 N
       Component: KOMBIINSTR.   H35 0564
       Revision: 00000000    Serial number: Z9F47P63F
       Coding: 8BB719000301D705020000
       VCID: 4ACD642CFCB4B577571-801E
       Component: GW-BEM 4CAN-M H11 0060
       Revision: 1Y080030    Serial number: 3041Y1430109C2
       Coding: 80C303FF00
       Serial number: 6865392703
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 241
                        Mileage: 91986 km
                        Date: 2020.03.01
                        Time: 13:04:08
                        Bin. Bits:    10000
                        Voltage: 12.20 V
                        Count: 9
                        Bin. Bits:    00000
    01327 - Control Module for Parking Aid (J446)
                        Reset counter: 254
                        Mileage: 92283 km
                        Date: 2020.03.08
                        Time: 16:25:44
                        Bin. Bits:    10111
                        Voltage: 12.20 V
                        Count: 6
                        Bin. Bits:    00000
                        Time: 25.40 s
    Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
       Part No SW: 8F0 959 255     HW: 8F0 959 255
       Component: VSG-AUDI-B8   H12 0190
       Coding: 030000
       ASAM Dataset: EV_ElectRoofContr 001008
       ROD: EV_ElectRoofContr.rod
       VCID: 71BFD3C0B122A6AF36B-8024
       Component: MEM-FS        H10 0077
       Revision: AA000000    Serial number: 00000093048783
       Coding: C81B7B250D2400001000
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H09 0305
       Coding: 011C53724E08332C03
       VCID: 56F5805C380CE197C39-8002
       Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
       Component: RCEPS         H40 0508
       Revision: 00001000    Serial number: 0016312790
       Coding: 100000000001
       ASAM Dataset: EV_RCEPSAU48X 008015
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 353727D085CACA8F2A3-8060
       Revision: 00002001    Serial number: 0330042461
       Coding: 010606BA00FA402180B0033200000000
       Subsystem 1 - Part No SW: 8F0 959 719 B    HW: 8K0 959 719
       Component: GTO BF  H01 0080
       Serial number: 00000000000000802315
    02615 - Fuel Tank Cap; Lock
                        Fault Status: 00101001
                        Reset counter: 226
                        Mileage: 91591 km
                        Date: 2020.02.11
                        Time: 08:53:25
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 218
                        Mileage: 91591 km
                        Date: 2020.02.11
                        Time: 08:53:51
       Part No SW: 8F1 035 223 A    HW: 8F1 035 223 A
       Revision: 00005001    Serial number: 94833027031503
       VCID: 1F1BE57817B660DFD0F-804A
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H09 0305
       Coding: 011C53324E08332C03
       VCID: 55F78750250AEA8FCA3-8000
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H01 0005
       Revision: --------    Serial number: 30000000180249
       ROD: EV_ParkiBrake_AU48.rod
       Part No SW: 4G0 035 082 H    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0138
       Revision: AB001007    Serial number: 156C10E7980870
       Coding: 020007010000000101
       VCID: 2517F79035EABA0F9A3-8070
       Part No SW: 8R1 035 746 K    HW: 8R1 035 746 D
       Component: H-BNT-NA      H41 1040
       Revision: --------    Serial number: 204C-0E7649038
       Coding: 130200030006A1EF41028B5E00000401150000000000000000
       VCID: 3FDB45F8B77600DFF0F-806A
       Subsystem 1 - Part No: 8R0 060 884 GB
       Component: NAR 2019  1901
       Component: DU7 High  H42 0104
       Serial number: A130CZ0E2967671
       Serial number: 00000001792287
       Component: CD-Database  5571
    03623 - Invalid Security/Release Code
                        Reset counter: 214
                        Mileage: 92283 km
                        Date: 2020.03.08
                        Time: 16:17:23
                        Hex Value: 0x0004
                        Hex Value: 0x0009
                        Count: 7
       Part No SW: 8T0 959 795 F    HW: 8T0 959 795 F
       Component: TSG HL        H08 0305
       Coding: 010C13304008372C03
       VCID: 4EC5683C00DC99570B9-801A
       Part No SW: 8F0 907 441     HW: 4L0 907 441 B
       Revision: --H09---    Serial number: 525PA8-J42B0CW
       Coding: 1000009
       VCID: 678BBD988366681F68F-8032
       Component: TSG HR        H08 0305
    End----------(Elapsed Time: 01:53, VBatt start/end: 12.2V/12.2V)-----------
    Jun 2014
    If Can Gateway is not able to communicate, you are also not able to communicate... You first have to fix it!
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
    Mar 2020
    Quote Originally Posted by Mari View Post
    Can this be related to the fault on the Optical Databus?
    Quote Originally Posted by janviden View Post
    The Parking Aid module doesn't connect to the Optical Databus, so it's not related - you have (at least) 2 separate faults.
  5. Likes Uwe liked this post
    Mar 2020
    Thank you for the answers. I will take it back to the dealer where i bought the car and ask them to investigate the faults.
    I hope for the best.
    Thanks again.
    May 2017
    Audi does not have separate park control module. It is integrated to the central electronics module so it is normal that it is not visible in the installation list.
    A3/A4 are different. A6,Q5 etc all have it in BCM.
  8. Likes ai_Ingo liked this post
    Mar 2020
    Thank you for that information. Thar was very helpfull.
