Golf MK5 Window Regulator, Enabling ??
paf
Romania
C?ID=358915
I have a golf 5 from 2009 with multiple retrofits and all 4 electric windows have in measuring block (002.2, Window Regulator, Enabling = No) the result is that no window works at the buttons, comfort closing and opening from the remote control works . otherwise everything works at the car. no error related to windows
so if you can please tell me more about measuring block 002.2, Window Regulator, Enabling 1K0-959-701-MAX3
what exactly can change the value in this group ??
paf
Romania
C?ID=358915
Monday,09,March,2020,09:02:05:36050
VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
VIN: WVWZZZ1KZ9W043355   License Plate:
Mileage: 246800km-153354mi   Repair Order:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 47 52 55 5F 62 69
          72
VIN: WVWZZZ1KZ9W043355   Mileage: 246800km-153354miles
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 021 PP    HW: 03G 906 021 AN
   Component: R4 2,0L EDC G000SG  1264
   Revision: --H08---    Serial number: XXXXXXXXXXXXXX
   Coding: 0000172
   Shop #: WSC 01269 785 00200
   VCID: 7CB4095E3F67B5AFFB-8028
   Part No SW: 1K0 907 379 CE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0120
   Revision: 00H35001
   Coding: 113B400D092600FD880E02E9901E00423400
   Shop #: WSC 24277 002 1048576
   VCID: 77BE1672C64196F796-8022
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Revision: 00001003
   Coding: 0000004002
   VCID: 004C7DAE9B8FD14FA7-8054
   Part No SW: 1K0 937 087 AE    HW: 1K0 937 087 AE
   Component: BCM PQ35  H+  111 0709
   Revision: AC111709
   Coding: 00000AB8E82108E000480081210089EC47F8008871618540640C00200000
   VCID: 74A4217ED737FDEFB3-8020
   Component: Wischer 10060  21  0501
   Coding: 009795
   Component: RLS 270608 05  54  0402
   Coding: 0F30AD
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 175
                    Mileage: 246805 km
                    Date: 2020.03.09
                    Time: 14:29:03
                    Voltage: 12.10 V
                        Term 50 Off
03189 - Bulb for Side Marker Light; Front Right
                    Reset counter: 175
                    Mileage: 246805 km
                    Date: 2020.03.09
                    Time: 14:29:03
                    Voltage: 12.10 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331908100588
   Coding: 0031091101
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: N/A
   VCID: 373ED6728EC156F756-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW35)
   Component: 37 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD23AFB4
   Coding: 0013111
   VCID: 3D32C45A64FD7CA78C-8068
   Subsystem 1 - Serial number: 6332MSME3D43232BC
   Subsystem 2 - Serial number: 6342MSME316258715
   Subsystem 3 - Serial number: 6352QSME723343212
   Subsystem 4 - Serial number: 6362QSME743A3C23M
00589 - Airbag Igniter 1; Passenger Side (N131)
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - MIL ON
   Part No SW: 1K0 953 549 CH    HW: 1K0 953 549 CH
   Component: J0527           056 0111
   Coding: 0000532
   Shop #: WSC 10202 599 96945
   VCID: 7AB80F4635538B9FE9-802E
   Subsystem 1 - Part No: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H31 0037
   Coding: 00000130
   Part No SW: 5N0 920 883 E    HW: 5N0 920 883 E
   Component: KOMBI         H03 0705
   Coding: 171F01
   Shop #: WSC 62919 001 104857
   VCID: 3620DB7689CBAFFF4D-8062
9459739 - Fuel Level Sensor 2
          B1058 1B [009] - Resistance Too High
                    Reset counter: 175
                    Mileage: 246805 km
                    Date: 2020.03.09
                    Time: 14:25:12
   Part No SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1673
   Revision:   H56       Serial number: 070316F1000860
   Coding: 350002
   VCID: 76A01B76C14BEFFF8D-8022
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 L
   Component: Haldex 4Motion      0116
   VCID: 3620DB7641CBAFFF4D-8062
Address 25: Immobilizer
   Part No SW: 5K0 959 701 G    HW: 5K0 959 701 G
   Component: Tuer-SG         009 2121
   Coding: 0007606
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 3522DC7A5CCDA4E744-8060
   Part No SW: 3C8 035 456 C    HW: 3C8 035 456 C
   Component: DSP 10 Kanal        0070
   Revision: 00H05001    Serial number: 75805000601304
   VCID: 281C050E9B7FC90FCF-807C
No Faults Found
   Part No SW: 5K0 959 702 G    HW: 5K0 959 702 G
   Coding: 0007606
   VCID: 373ED67246C156F756-8062
   Part No: 1T0 907 357
   Coding: 0000004
   Shop #: WSC 01279 785 00200
   VCID: 74A4217E1737FDEFB3-8020
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
01533 - Terminal 56 (High Beams)
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0449
   Serial number: --------------
   Coding: 027300010000000011111105000808001F0100C000008000CF
   Shop #: WSC 35110 790 50316
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 25020C3A246DD467F4-8070
   Subsystem 1 - Part No SW: 3G0 919 866 BC    HW: -----------
   Component: ECE1 2017/18  --- 0820
1564 - Microphone 1
          B129B 13 [009] - Open Circuit
                    Reset counter: 175
                    Mileage: 246805 km
                    Date: 2020.03.09
                    Time: 14:25:11
                    Voltage terminal 30: 12.1 V
6714 - Databus
          [VIN: no communication]
                    Reset counter: 175
                    Mileage: 246805 km
                    Date: 2020.03.09
                    Time: 14:25:16
                    Voltage terminal 30: 12.0 V
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 175
                    Mileage: 246805 km
                    Date: 2020.03.09
                    Time: 14:25:14
                    BAP-BAP_Function_ID: 02
0011 - Digital Radio Antenna
          B1103 13 [009] - Open Circuit
                    Reset counter: 175
                    Mileage: 246805 km
                    Date: 2020.03.09
                    Time: 14:25:11
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
   Part No SW: 5K0 959 703 E    HW: 5K0 959 703 E
   Coding: 0003280
   Shop #: WSC 01357 011 1012551
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H08 0080
   Revision: 3A002002    Serial number: 00000122918755
   Coding: 4100000100000000
   VCID: 2F2EEE127E919E370E-807A
   Part No SW: 5K0 959 704 E    HW: 5K0 959 704 E
   Coding: 0003280
End----------(Elapsed Time: 01:10, VBatt start/end: 12.1V/12.1V)-----------
paf
Romania
C?ID=358915
all the current errors are due to the fact that the headlights, glove compartment, dome lighting with microphone and radio trim are currently removed from the car. g85 error is due to battery disconnection. and 5F: Information Electr has a filter can because of element protection
Since this car has "multiple retrofits", please tell us what parts have been retrofit and what parts are original.
I don't see anything obvious that's causing this.
paf
Romania
C?ID=358915
I know but the question remains, what value or condition influences the value on the measuring block 002.2 Window Regulator, Enabling = Yes or No my personal car which is also a golf mk5 and has almost the same retrofits including bcm and the value is yes. I tried modules from one car to the other and mine works perfectly and the other does not the only visible difference is that group
If I knew the answer, I would happily tell you. Unfortunately, many things are not well-documented by VW.
Dana
Western PA, USA
Although I doubt there's a power window disable type of MFA menu it couldn't hurt to go through the instrument cluster menus to see if tick box changes modify the behavior. You may even want to use any Factory Reset (or Factory Settings) menus that are available in the MFA.
paf
Romania
C?ID=358915
I have checked all the settings / adaptations and codes several times. I did not see anything that could change the activation or deactivation of the electric windows. The electric windows work if I use the comfort function: from the remote control, key lock, lock unlock button on the door, even rain closing. I checked the value groups for the electric window knobs and they all work perfectly. the only value group that is not ok is windows enable which is no instead of yes.
the problem appeared after the bcm retrofit. bcm retrofit is made with adaptive plugs. I took the bcm and the adapter jacks and tested them on another car and everything works correctly. I tested in this way almost all the modules: door modules, instrument, bcm, can gateway. and all work perfectly on the test car
MartinsX
Riga, Latvia
C?ID=268515
Please explain here: Your door controllers does not work on that car or door controllers from that car does not work on Your car, too?
What type of CAN filter? How it is programmed/configured? If You disconnect the filter and 5F from CAN bus, any changes to power windows behavior?
paf
Romania
C?ID=358915
my personal car = test car . the second car is the car with problem ( car of very good friend ) I tried to test modules from the car with problems on the test car every module I tested on the test car works perfectly and window enable group is yes and windows works I tried and vice versa but the car with problems no matter what I tried, refuses to change windows enable to yes both cars are vw golf mk5 (test car 2007) (car problem 2009)
CAN filter is filter only for security component protection the rest of the communication is not affected. but 5f errors appear and I specified the part with CAN filter so people can understand what is with those errors
MartinsX
Riga, Latvia
C?ID=268515
What exactly modules from problem car has been tested on the test car?
Just disconnect 5F and CAN filter completely for test time. If You are not designed this CAN filter Yourself or at least designed SW for it Yourself, You can not be sure may this device make any side effects or not...
paf
Romania
C?ID=358915
please forget about 5f and the can filter ,is disconnected from the car, it was connected at the time of the scan and I explained so people don't ask what's wrong with that
I tested door modules, bcm + adapter, can gateway, cluster instrument, climatronic panel, steering column module. all at the same time and everything works perfectly
MartinsX
Riga, Latvia
C?ID=268515
Some children interlock switch wire/pin shorted, maybe?
paf
Romania
C?ID=358915
yes but children interlock switch is only for the rear windows and not for the front ones
wire / pin shorted is possible but where ?? car with problems is the latest generation of golf mk5, and the electrical installation I noticed is not 100% the same as in 2007 or with the one from elsa database.
