Results 1 to 10 of 13
Thread: VA EOS Roof troubleshooting
    Nov 2017
    Here
    Hello RossTech,
    I need your help please with troubleshooting this EOS roof. Currently the trunk is stuck as the two latches on both sides (right & left inside) are in close position preventing the trunk to open. The roof is close and everything else but those two latches do not go back to Open position to let the trunk to open from outside.
    I am aware of the rest of the errors for engine and airbag, I will fix those once I am done with the roof. Thanks in advance!
    here is a full scan
    Sunday,08,March,2020,18:45:46:15095
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
    VCDS Version 19.6.2.2
    VIN: WVWAA71F67V020165   License Plate: EOS 2007
    Mileage: 168590km-104756mi   Repair Order:
    Chassis Type: 1F (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 52 56 62 65 72
    VIN: WVWAA71F67V020165   Mileage: 168590km-104756miles
    26-Auto Roof -- Status: Malfunction 1010
       Part No SW: 1Q0 907 115 E    HW: 1Q0 907 115 B
       Revision: 5BH15---    Serial number: VWX7Z0F83NR97O
       Coding: 041C010A18070160
       Shop #: WSC 09148 444 00518
       VCID: 2E7DE714B92DB23F07-807B
    001092 - EVAP Purge Control Valve (N80)
                   P0444 - 004 - Circuit Open - MIL ON
                        Fault Status: 11100100
                        Mileage: 168597 km
                        Time: 00:08:03
                        RPM: 696 /min
                        Load: 20.0 %
                        Temperature: 57.0∞C
                        Temperature: 18.0∞C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 14.224 V
    000051 - Turbocharger Bypass Valve Control Circuit
                   P0033 - 004 - Malfunction / Open Circuit
                        Mileage: 168597 km
                        Time: 00:08:03
                        RPM: 696 /min
                        Load: 20.0 %
                        Temperature: 57.0∞C
                        Temperature: 18.0∞C
                        Voltage: 14.605 V
    000579 - Solenoid Valve  for Boost Pressure Control (N75)
                   P0243 - 004 - Malfunction - MIL ON
                        Mileage: 168597 km
                        Time: 00:08:03
                        RPM: 696 /min
                        Load: 20.0 %
                        Temperature: 57.0∞C
                        Temperature: 18.0∞C
                        Voltage: 14.605 V
    Readiness: 0110 0101
       Revision: 00H11001
       Coding: 0021218
       Shop #: WSC 00020 000 00000
       VCID: 73CB3660128FDFD7A8-8027
       Part No SW: 1Q0 907 044     HW: 1Q0 907 044
       Component: ClimatronicPQ35 093 0101
       Revision: 00093002    Serial number: 00000000000000
       VCID: 6AF52B0445451E1F1B-803F
    00830 - Convertible Top Control Module (J256)
       Revision: 00H46000    Serial number: 00000006128806
       Coding: 118C0F0340041500470000000F00000000285D035C0000
       VCID: 3753C270467773F754-8063
       Component: Wischer 181006 020  0501
       Coding: 00038805
       Shop #: WSC 00020
    9 Faults Found:
                        Fault Status: 00101100
                        Reset counter: 22
                        Mileage: 168597 km
                        Voltage: 12.10 V
                        Reset counter: 22
                        Mileage: 168597 km
                        Voltage: 12.10 V
                        Fault Status: 00101010
                        Reset counter: 22
                        Mileage: 168597 km
                        Voltage: 12.10 V
                        Reset counter: 22
                        Mileage: 168597 km
                        Voltage: 12.10 V
                        Reset counter: 22
                        Mileage: 168597 km
                        Voltage: 12.10 V
                        Reset counter: 22
                        Mileage: 168597 km
                        Voltage: 12.10 V
                        Reset counter: 22
                        Mileage: 168597 km
                        Voltage: 12.10 V
                        Reset counter: 22
                        Mileage: 168597 km
                        Voltage: 12.10 V
                        Reset counter: 22
                        Mileage: 168597 km
                        Voltage: 12.00 V
    Address 15: Airbags        Labels: 1Q0-959-655.lbl
       Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
       Component: 13 Airbag VW8C      0180
       Revision: 92009018    Serial number: 003B30011PZ-
       Coding: 0012595
       VCID: 3A55DB4475656E9FAB-806F
       Subsystem 1 - Part No: 1Q0 959 339 A
       Component: BF-Gewichtsens. 007 0003
       Subsystem 2 - Serial number: 3ECX7
       Subsystem 3 - Serial number: 0001.01.000000700000000000ˇ63
       Subsystem 4 - Serial number: 000000ˇ6332SRB40419D49A5ˇ63
       Subsystem 5 - Serial number: 9D49A5ˇ6342SRB403CC52ACCˇ63
       Subsystem 6 - Serial number: C52ACCˇ6372URB4017D47C49ˇ63
       Subsystem 7 - Serial number: D47C49ˇ6382URB4017D47824ˇ
       Subsystem 8 - Serial number: D47824ˇ
                        Fault Status: 11100001
                        Mileage: 168597 km
                        Time: 00:08:49
       Part No SW: 1K0 953 549 AR    HW: 1K0 953 549 AR
       Component: J0527           036 0070
       Coding: 0000021
       VCID: 022563A45D35E65FB3-8057
       Part No SW: 1Q0 920 953 D    HW: 1Q0 920 953 D
       Component: KOMBIINSTRUMENT VDD 1610
       Revision: V0003000    Serial number: VWX7Z0F83NR97O
       Coding: 0023207
       Shop #: WSC 09150 444 58449
       VCID: 3245F364AD1596DF63-8067
                        Reset counter: 22
                        Mileage: 168597 km
                        Time: 00:29:41
       Part No SW: 1K0 907 530 H    HW: 1K0 907 951
       Component: J533__Gateway   H12 0150
       Revision:   H12       Serial number: 3100106A048A3D
       Coding: 3DBF234007005000
       VCID: 2C79ED1C8F31C02F29-8079
                        Reset counter: 21
                        Mileage: 168597 km
                        Time: 00:29:42
       Component: IMMO            VDD 1610
    Address 26: Auto Roof        Labels: 1Q0-959-255.clb
       Part No SW: 1Q0 959 255 B    HW: 1Q0 959 255 B
       Component: Verdecksteuergeraet 0622
       Revision: 0032000K    Serial number: 062980126
       Coding: 0655360
    02805 - System Interference
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 237
                        Mileage: 168597 km
                        Time: 00:48:18
                        Voltage: 12.20 V
                        Voltage: 12.20 V
                        Voltage: 4.90 V
                        Error Code: 4
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1Q0 959 701 C
       Component: Tuer-SG         024 2737
       Coding: 0000247
       Shop #: WSC 21124 210 01865
       VCID: 3449F57C570198EF71-8061
    00120 - Outside Warning Light/Door exit Light Driver Side
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       Part No SW: 1K0 959 433 CT    HW: 1K0 959 433 CL
       Component:    KSG PQ35 RDK 051 0218
       Revision: 00051000    Serial number: 00000000000000
       Coding: 13908A800186281B0804040FB0080E0488DCA0
       VCID: 042965BC4721E86F81-8051
    00532 - Supply Voltage B+
                        Reset counter: 22
                        Mileage: 168597 km
                        Time: 21:51:35
                        Reset counter: 22
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1Q0 959 702 B
       Component: Tuer-SG         024 2729
       Coding: 0001206
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
       Component: Radio DE2       014 0016
       Revision: 00014000    Serial number: VWZ4Z7F6164335
       Coding: 0040401
       VCID: 1E1D37D4C98D22BFB7-804B
       Part No: 1Q0 959 703
       Component: Tuer-SG         021 2705
       Coding: 0000128
       Component:    RDK              0440
       Coding: 0100101
                        Fault Status: 00110100
                        Reset counter: 247
                        Mileage: 167867 km
                        Time: 12:21:52
    00667 - Ambient Temperature Signal
                        Fault Status: 00111000
                        Reset counter: 22
                        Mileage: 168597 km
    00625 - Vehicle Speed Signal
                        Fault Frequency: 9
                        Reset counter: 22
                        Mileage: 168597 km
                        Time: 00:00:06
       Part No: 1Q0 959 704
       Coding: 0000128
       VCID: 74C9357C1781D8EFB1-8021
    End-------------------------(Elapsed Time: 01:19)--------------------------
    Moving to Car Repair Support.
  3. Likes Pfaizulla liked this post
    HQ
    http://wiki.ross-tech.com/wiki/index.php/02805
    https://forums.ross-tech.com/showthread.php?9194
    http://wiki.ross-tech.com/wiki/index...onvertible_Top
    In the video, at about what time does it physically match up your car in terms of so far open or closed? What is the data from 26-08-002 show? Can you post a photo of your car in its current state?
    Also, DO NOT CLICK ON THIS LINK -----> For real, do not do this... bad things can happen.
    Jef
  5. Likes Uwe, Pfaizulla liked this post
  6. #4
    Nov 2017
    Here
    Hi Jef,
    The windows go down all 4 of them, then run roof all the way, then I heard the roof pump- that is all I heard. next when I closed everything again, and when I tried to open the trunk from Outside, it did not open because the two latches on left and right side holding the trunk are engaged and preventing the trunk to be opened. RIght now I need a process to set those two latches to set to unlock and let the trunk to be opened from outside (what basic setting perform this task?)
    here is photos of current roof status:
    finally, I honestly do not undrestand the last part of your reply
    I am sorry
    HQ
    Your photos don't show up. You can freely host photos on imgur.com
    https://forums.ross-tech.com/showthr...-Post-Pictures
    The final part has information that if used incorrectly can damage/destroy things. I've been keeping my eye open for a good working Eos to make a video on it. Anyway, get those photos up so we can see how things look.
    Jef
  8. Likes Uwe, Pfaizulla liked this post
  9. #6
    Nov 2017
    Here
    Hi Jeff,
    Please check and see if you can see below pictures.
    I am not sure why do not they show on the post even though they are between [IMG] URL [/IMG] tags.
    here is the URLs just in case the image did not show up here
    https://imgur.com/JrdgxK5
    https://imgur.com/7AbtLKQ
  10. #7
    Quote Originally Posted by Pfaizulla View Post
    Because the URL you put between the IMG tags was for an Imgur page, not an actual picture. An actual picture will generally end in .jpg or .png.
  11. Likes Pfaizulla liked this post
  12. #8
    HQ
    I would say based on my past experience with various Eoses... Eoss... how does one make Eos plural? Anyway, I would suspect you can do the Basic Settings steps to manually go through each step of top operation.
    DANGER DANGER DANGER ---> click here for dreadful information <--- DANGER DANGER DANGER
    I would say that after "BS 013, tailgate opening" is complete, normal top operation with the switch will occur an the fault code can be cleared out.
    Jef
  13. #9
    Nov 2017
    Here
    thank you for fixing it!
  14. #10
    Nov 2017
    Here
    Thank you Jeff.
    I Will take a look tomorrow, any special configuration if I install a new roof module?
