Results 1 to 5 of 5
Thread: Cold diagnosis front parking light/DRL Octavia2 RS 1K0937049N
    Feb 2018
    Czech Republic
    can someone please help me to switch off the cold diagnosis in this BCM? At least front parking lights/DRL or at all.
    Ive tried so far (untickle) these:
    Byte2 bit2 - "Cold lamp diagnosis active" - NOT WORKING
    Byte19 bit1 - "C.D. Front parking lights active" - NOT WORKING
    Byte18 and 19 no bit tickled - NOT WORKING
    Why?
    Is there any sw solution?
    Adress 09: Central electronics        Labels:. 3C0-937-049-23-H.lbl
       Control unit SW: 1K0 937 049 N    HW: 1K0 937 049 N*
       Part: Bordnetz-SG     H34 0803
       Revision: 00H34000    Serial number: 00000001245642
       Coding: 01880F020004140000110D000000000000087F075C
       Workshop #: WSC 22616 074 17237
       VCID: 3A38DEE77570059FA8-806E
       Subsystem 1 - Control unit: 1Z1 955 119 A  Labels: SVO\1KX-955-119.CLB
       Part: Wischer SK351  012  0401
       Coding: 00065525
    2 faults found.
    02395 - parking light front right (M3)
                012 - electric circuit fault
    02394 - parking light front left (M1)
    as well as:
       Coding: 01880B020004140000110D0000000000000800005C
       Coding: 00065525
    2 faults found.
    Jun 2017
    You need VCP for this.
    Not possible with VCDS.
    I still hope that some day there will be any magic keystroke in VCDS to dowload and upload the PQ lighting configuration as raw hex values..
    Feb 2018
    Czech Republic
    Thanks for the answer. I have VCP(original, but used just few times), is it there described well(in coding, adp,guided functions...)? Maybe doing adpmaps with vcds before and after can reveal it?(if it is in coding, a scan might be enough)
    Jun 2014
    Poland
    For bordnetz - I never heard that VCP can do any trick
    For BCM - yes ...but not bordnetz
    for Bordnetz I only know people play with resistors inside
    Jun 2017
    Quote Originally Posted by Spacewalker View Post
    You're right, sorry. I was too fast associating Octavia 2 with BCM......
