Results 1 to 10 of 10
Thread: 2007 VW Passat, [01]-Engine, security code needed
    Mar 2020
    Hello all,
    I am a long time time user; first time poster.
    I have a 3.6L BLV that lost a timing chain at 113k miles. I found 2 bent intake valves and 4 bent exhaust valves.
    I decided to purchase a used engine for replacement.
    I now have 5,000 miles on engine since installing, but the lifters are sometimes noisy at idle.
    In general, there is no noise upon starting, but once the engine is warm the lifters are ticking.
    It also seems that the noise is more pronounced when the ambient temperature is cold, but I am not confident about this as it is still winter in Northern Maine and thus still waiting for warmer weather to test that theory.
    Just barely pressing the gas pedal and lifting the idle speed, the ticking will go away. I have done multiple oil changes, but the ticking is still there.
    So I decided to see if bumping up the idle speed would help keep the ticking at bay.
    Unfortunately, I need a security access code for the engine module.
    Is there anyone that can provide this? Or is this not an option with the BLV engine?
    Many thanks in advance for any help and/or advice,
    Corey
    Sunday,08,March,2020,13:59:25:22024
    VCDS Version: 19.6.2.2 (x64)
    VIN: WVWVU73C77E002026   License Plate:
    Mileage: 189620km-117824mi   Repair Order: 2020.03.08
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 1C 22 25 36 42 44 46 52 53 56
              62 65 6D 72
    VIN: WVWVU73C77E002026   Mileage: 189620km-117824miles
    Address 01: Engine        Labels: 03H-906-032-BLV.clb
       Part No SW: 03H 997 033 M    HW: Hardware No
       Component: P3.6-FSI-LEV2   G00 2370
       Revision: --H08---    Serial number: VWZCZ000000000
       Coding: 0000175
       Shop #: WSC 05311 000 08193
       VCID: 37773B75461B8CF754-8062
       Part No SW: 09G 927 750 HK    HW: 09G 927 750 AJ
       Component: AQ 250 6F           1271
       Revision: 00H38000    Serial number:
       Coding: 0000072
       Shop #: WSC 05050 444 89168
       VCID: 010395AD585F0247AA-8054
    Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 Q    HW: 3C0 614 095 Q
       Component: ESP 440 C2     H015 0003
       Revision:  H015       Serial number: 0658498744
       Coding: 0046544
       Shop #: WSC 05311 000 00000
       VCID: 30650069A3755BCF15-8064
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 AC    HW: 3C0 907 044 AC
       Component: ClimatronicPQ46 050 0404
       Revision: 00050005    Serial number: 00000000000000
       VCID: 62C1BA21BD19B95FD3-8036
    00710 - Defroster Flap Positioning Motor (V107)
                        Fault Frequency: 120
                        Reset counter: 226
                        Mileage: 184422 km
                        Date: 2019.11.24
                        Time: 11:18:18
    00229 - Refrigerant Pressure
                        Fault Status: 00100001
                        Reset counter: 218
                        Mileage: 188834 km
                        Date: 2020.02.24
                        Time: 13:01:54
       Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
       Revision: 00H46000    Serial number: 00000002289050
       Coding: F58C8F0340041A00400A00000F00000000285D435C0000
       Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
       Component: Wischer 201006 003  0205
       Coding: 00046997
       Shop #: WSC 05311
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
       Shop #: WSC 05311
       Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
       Component: SDAR XM         H03 0080
       Revision: 00000000    Serial number: AUZ4Z7E0037794
       VCID: 2B5F17058A53381720-807E
       Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
       Component: 0P AIRBAG VW8R  029 2521
       Revision: 10029000    Serial number: 003A3PR12ERQ
       Coding: 0012368
       VCID: 2E591E11B9414D3F07-807A
       Subsystem 1 - Part No: 3C0 959 339 A
       Component: BF-Gewichtsens. 006 0002
       Subsystem 2 - Serial number: 00000000031SU9
       Subsystem 3 - Serial number: 0001.01.00000060000000000063
       Subsystem 4 - Serial number: 0000006332MSME0D2D625EQ63
       Subsystem 5 - Serial number: D625EQ6342MSME0D2D671FT63
       Subsystem 6 - Serial number: D671FT6351HTS63IK60AJ2163
       Subsystem 7 - Serial number: 60AJ216361HTS6I2I6B243V63
       Subsystem 8 - Serial number: 6B243V63727TS6I2IIMNJ2 63
       Subsystem 9 - Serial number: IMNJ2 63827TS61IKULHI21
       Subsystem 10 - Serial number: ULHI21
       Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
       Component: J0527               0015
       Revision: 00005000    Serial number: 3C9953507P
       Coding: 0002112
       Component: E0221           006 0080
    01426 - Controls in Steering Wheel (E221)
       Part No SW: 3C0 920 970 R    HW: 3C0 920 970 R
       Component: KOMBIINSTRUMENT VD1 4240
       Revision: X0033000    Serial number: 00000000000000
       Coding: 0007205
       VCID: 336F0F65526360D768-8066
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C05C0507C2
       Coding: BFFD0F0CD32002
       VCID: 2143F52DF89FE2478A-8074
       Part No SW: 3C0 919 965 A    HW: 3C0 919 965 A
       Component: Kompass         001 0002
       Revision: 00001000    Serial number: 1339817TPYVY02
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 E
       Component: HALDEX 4Motion      0110
       Coding: 0000001
       VCID: 2F670315BE4B44370C-807A
       Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
       Component:    IMMO         041 0364
       Revision: 00041000    Serial number: VWZCZ000000000
       Shop #: WSC 22607 444 05200
       VCID: 2A51120185A9211FDB-807E
    02811 - Control Module for Electronic Steering Column Lock (J764)
                        Fault Status: 00101110
                        Reset counter: 212
                        Mileage: 188704 km
                        Date: 2020.02.20
                        Time: 19:40:52
    Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
       Part No SW: 3C0 959 760 B    HW: 3C0 959 760 B
       Component: Sitzverstellung     0701
       Revision: 00003000    Serial number: 00000000000000
       VCID: 2C5D14198F5D3F2F29-8078
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1K0 959 701 L
       Component: Tuer-SG         024 2461
       Coding: 0001463
       Part No: 3C1 909 144 B
       Component: EPS_ZFLS Kl.5   D04 1607
       VCID: 244DFC39E78DF76FE1-8070
       Component:    KSG PQ46 RDK 041 0213
       Coding: 13900E88D103067F1C04141FF00A8F0E081800
       Shop #: WSC 05311 123 12345
    00896 - Trunk Lock Unit (F256)
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 81
                        Mileage: 185627 km
                        Date: 2019.12.18
                        Time: 09:59:35
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1K0 959 702 L
       Coding: 0001462
       VCID: 387538494B05838F5D-806C
       Revision:   013
       Coding: 0000013
    01487 - System Function Test
                        Reset counter: 230
                        Voltage: 11.90 V
                        Count: 100
       Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
       Component: Radio PM6       016 0018
       Revision: 00016000    Serial number: VWZ5Z7E2029631
       Coding: 0000010
       Shop #: WSC 00028 028 00001
       VCID: 2045F029F395EB4F85-8074
       Part No: 3C9 959 703 A
       Component: Tuer-SG         021 2505
       Coding: 0000144
       VCID: 3163056DA87F52C71A-8064
       Component:    RDK              0391
       Coding: 0100101
    Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
       Part No SW: 3C9 827 383 B    HW: 3C9 827 383 H
       Component: J605  HECKDECKEL    0405
       Revision: 00H21001
       Shop #: WSC 23250 384 715754
       Subsystem 1 - Part No: 3C9 827 384 B
       Component: J756  HECKDECKEL    0405
       Subsystem 2 - Serial number: 0800H21001001A0095
       Part No: 3C9 959 704 A
       Coding: 0000144
       VCID: 32610A61AD7969DF63-8066
    End-------------------------(Elapsed Time: 02:19)--------------------------
    Dec 2016
    DE
    What action exactly requires you to enter a security code?
    Mar 2020
    I am trying to adjust the idle speed.
    Using adaptation channel 1
    Dec 2016
    DE
    Maybe the value you want to set is out of bounds?
    There is however a widely accepted login code 12233, that often works in Engine modules and you could try.
  5. Likes nazdaq100 liked this post
    12233 is pretty much a 4-cylinder TDI thing. I don't recall it ever working on any gasoline engine.
    PS: There's another 3.6 guy asking more-or less the same question here.
  7. Likes TBAx liked this post
    Dec 2016
    DE
    Thanks for the heads-up Uwe
    Mar 2020
    Yes, i can confirm that code does not work; I have tried twice.
    I will look in the other thread.
    Thank you!
  10. Likes Dana liked this post
  11. #8
    Mar 2020
    Czech Republic
    Hey Corey,
    i have the same problem with idle speed adjustment , you can try other code :
    27971
    79153
    26281
    45678
    the code not help to me .
    TOP priority , when you try enter code and not accepted , you must wait a 10 minits with open drivers door and ignition on , when you meny times wrong tries the time it will be extended to max 4 hours
    when you find another security acces code, pls send me .
    Thank you and good luck
    koda Superb 3.6 FSI combi, 2010
  12. Likes Dana liked this post
  13. #9
    Verified VCDS User Dietrich's Avatar
    Jul 2017
    South Africa
    Hi
    I saw another thread where they used code 26262. Maybe try this code and I hope you are lucky. I have the same issue with my 2007 VW Touareg 3.0 V6 TDi. All codes that I have tried does not work.
    Let me know if this code works.
    Good luck
  14. #10
    Dallas (McKinney) ,TX ,USA
    Why not try with ATF fluid and see what happens.
    When engine hot put 100ml of regular ATF fluid , after that start car , get up to 1800prm and hold like that for 20 min(I usually stuck someting in gas pedal because your leg will be numb after 5 min).
    After that drive car around the block and see do you have any lifter noise.
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
