Results 1 to 4 of 4
Thread: Steering angle sensor
    Jan 2020
    Israel
    hello all
    i have this car with problem with steering sensor
    i keep doing intializing but no use
    I don't know what the problem with abs
    As for airbag errors, could someone help me locate where are igniters.
    Sunday,08,March,2020,13:31:05:04619
    VIN: TMBAG7NE9D0019598   License Plate:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
    VIN: TMBAG7NE9D0019598   Mileage: 186302km-115762miles
       Part No SW: 04L 906 021 N    HW: 04L 907 309 B
       Component: R4 1,6L EDC   H22 4946
       Revision: 84H22---
       Coding: 01250012032401090000
       Shop #: WSC 73430 031 00207
       ASAM Dataset: EV_ECM16TDI01104L906021N 002007
       ROD: EV_ECM16TDI01104L906021N_002.rod
       VCID: 303916FB1AA27337795-8064
    4814 - System Voltage
              P0562 00 [032] - Too Low
                        Mileage: 185227 km
                        Date: 2020.02.08
                        Time: 06:55:01
                        Engine speed: 105.50 /min
                        Normed load value: 100.0 %
                        Coolant temperature: 34 °C
                        Intake air temperature: 27 °C
                        Voltage terminal 30: 5.560 V
                        Unlearning counter according OBD: 11
                        Limitation: torque: 13.1 Nm
                        Limitation: accelerator pedal: 91.8 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 0
                        Accelerator pedal travel: raw value: 0.00 %
                        Engine torque: 120.0 Nm
                        Generator: load signal: 0.02 %
    17158 - Databus
              U1123 00 [047] - Received Error Message
                        Mileage: 185000 km
                        Date: 2020.02.07
                        Time: 00:01:36
                        Coolant temperature: 82 °C
                        Intake air temperature: 64 °C
                        Voltage terminal 30: 12.440 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 4
                        Drivetrain coordinator: brake function status-Bits 0-7: 0
                        Acceleration: 0.000 m/s²
    21125 - Implausible Data Received from Airbag Control Module
              U0452 00 [032] - -
                        Mileage: 185891 km
                        Date: 2020.02.14
                        Time: 23:59:23
                        Engine speed: 2072.00 /min
                        Normed load value: 46.3 %
                        Vehicle speed: 37 km/h
                        Coolant temperature: 88 °C
                        Intake air temperature: 47 °C
                        Voltage terminal 30: 13.340 V
                        Unlearning counter according OBD: 31
                        Limitation: accelerator pedal: 78.4 Nm
                        selected gear-Bits 0-7: 3
    4710 - No Communications with Airbag Control Module
              U0151 00 [040] - -
                        Mileage: 186281 km
                        Date: 2020.02.17
                        Time: 23:35:47
                        Coolant temperature: 65 °C
                        Intake air temperature: 49 °C
                        Voltage terminal 30: 12.240 V
                        Limitation: accelerator pedal: 111.0 Nm
                        selected gear-Bits 0-7: 0
    Readiness: 0 0 0 0 X
       Part No SW: 0CW 300 047 R    HW: 0AM 927 769 G
       Component: GSG DQ200-MQB H43 5210
       Revision: 00043014    Serial number: CU501411085892
       Shop #: WSC 04940 001 00001
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 4ACD64139C3E29E7571-801E
       Part No SW: 5Q0 907 379 A    HW: 5Q0 907 379 A
       Component: ESC           H75 0333
       Coding: 1A07629120210A75007C060901CB245846045000608024F00048000040
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 008020
       ROD: EV_Brake1UDSContiMK100ESP_008_SK37.rod
       VCID: 3A2D34D3CCDEB967C71-806E
    0295 - Steering angle sensor
                        Reset counter: 70
                        Mileage: 186302 km
                        Date: 2020.02.18
                        Time: 01:19:16
    8277 - Databus
              U1122 00 [009] - Implausible Message
              [FCAN: EPS_DSR_Status signal is invalid]
                        Reset counter: 70
                        Mileage: 186302 km
                        Date: 2020.02.18
                        Time: 01:19:16
    8299 - Databus
              [FCAN: Anhaenger_01_alt veraltet bit is set]
                        Reset counter: 70
                        Mileage: 186302 km
                        Date: 2020.02.18
                        Time: 01:19:16
       Part No SW: 5E0 907 044     HW: 5E0 907 044
       Component: Climatronic   H02 0604
       Revision: 00001K06
       Coding: 00010104000100011005000000100000
       ROD: EV_ACClimaBHBVW37X_002_VW37.rod
       VCID: 629DACB304CE91A7BF1-8036
    459009 - Databus
              [Airbagsteuergerät - kein Signal/Kommunikation]
                        Reset counter: 110
                        Mileage: 186281 km
                        Date: 2020.02.17
                        Time: 23:35:53
    263425 - Air Quality Sensor
              B10AF 04 [008] - Internal System Fault
                        Fault Frequency: 132
                        Reset counter: 110
                        Mileage: 185000 km
                        Date: 2020.02.07
                        Time: 00:06:40
              B10CD 00 [008] - -
                        Reset counter: 86
                        Mileage: 185262 km
                        Date: 2020.02.09
                        Time: 21:06:38
       Part No SW: 5Q0 937 084 N    HW: 5Q0 937 084 N
       Component: BCM MQBAB M   H14 0106
       Serial number: 00011306600594
       Coding: 0C001842424702FB07A04000000407080000000000000000000000000000
       Shop #: WSC 73430 790 00207
       ROD: EV_BCMBOSCH_010.rod
       VCID: 43D34937BB14F8AF947-8016
       Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 130302  041 0570
       Serial number:         130307002938
       Coding: 065DDD
       Component: RLFS  024 0042
       Serial number: Y13M03D16H21M00S00S4
       Coding: 02805D
    10506 - Bulb for Left Tail Light
              B12BE 15 [008] - Open or Short to Plus
                        Reset counter: 88
                        Mileage: 185227 km
                        Date: 2020.02.08
                        Time: 06:59:08
    10515 - Bulb for Left Tail Light
              B12BE 01 [008] - Electrical Failure
                        Fault Frequency: 15
                        Reset counter: 107
                        Mileage: 185028 km
                        Date: 2020.02.07
                        Time: 05:28:59
    12810 - Bulb for Right Back-up Light
              B12CC 15 [009] - Open or Short to Plus
                        Reset counter: 55
                        Mileage: 185559 km
                        Date: 2020.02.12
                        Time: 03:10:05
    558101 - Databus
              [Airbag_02 Datenbus fehlende Botschaft]
                        Reset counter: 110
                        Mileage: 186281 km
                        Date: 2020.02.17
                        Time: 23:35:52
       Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
       Component: PARKHILFE 4K  009 0026
       Revision: --------    Serial number: 60831306500776
       Coding: 0001050011
       ASAM Dataset: EV_EPHVA14AU3700000 002015
       VCID: 372B2DE7FFCCA40F38F-8062
    1079060 - Center Rear Left Parking Aid Sensor
              B1077 14 [008] - Open or Short to Ground
                        Reset counter: 39
                        Mileage: 185000 km
                        Date: 2020.02.07
                        Time: 00:03:05
    1079316 - Center Rear Right Parking Aid Sensor
              B1078 14 [008] - Open or Short to Ground
                        Reset counter: 39
                        Mileage: 185000 km
                        Date: 2020.02.07
                        Time: 00:03:05
    13637426 - Databus
                        Reset counter: 40
                        Mileage: 185000 km
                        Date: 2020.02.07
                        Time: 00:01:37
       Part No SW: 3Q0 959 655 AB    HW: 3Q0 959 655 AB
       Component: Airbag VW20   011 0188
       Revision: --------    Serial number: 003P3P53SCBT
       Coding: 98CCC0000C0000005C5400CC000800000065
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7EA5F8C390765547BB9-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 000 403 13
       Serial number: 3576U000000BCBF43C0X
       Subsystem 2 - Part No SW: -----------    HW: 454 000 503 13
       Serial number: 3586U00000030D3DBC0L
       Subsystem 3 - Part No SW: -----------    HW: 454 800 503 13
       Serial number: 3516R15A73201000000S
       Subsystem 4 - Part No SW: -----------    HW: 454 800 603 13
       Serial number: 3526RA7372101000000V
       Subsystem 5 - Part No SW: -----------    HW: 454 800 503 13
       Serial number: 3556V43B20E01000000%
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 454 801 602 13
       Component: PedP_Sensor_D  114 0149
       Serial number: 2286VD822CD00000000D
       Subsystem 7 - Part No SW: -----------    HW: 454 801 502 13
       Component: PedP_Sensor_P  114 0149
       Serial number: 2296VE433CD00000000D
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 454 801 502 13
       Component: PedP_Sensor_C  114 0149
       Serial number: 2306VCD3AF900000000I
    9498451 - Igniter for Pedestrian Protection
              B10EF 53 [009] - Deactivated
                        Mileage: 186295 km
                        Date: 2020.02.18
                        Time: 00:22:14
       Part No SW: 5Q0 953 507 AJ    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 18031304221317
       Coding: 1400
       Part No SW: 5E0 920 860 D    HW: 5E0 920 860 D
       Component: KOMBI         227 0555
       Coding: 07A402082080000801082A00040000
       VCID: 270BFDA72F6C348FA8F-8072
    16776962 - Databus
              [Airbag_01 keine Kommunikation]
                        Reset counter: 110
                        Mileage: 186281 km
                        Date: 2020.02.17
                        Time: 23:35:47
       Part No SW: 5Q0 907 530 E    HW: 5Q0 907 530 E
       Component: GW MQB Mid    124 1109
       Revision: --------    Serial number: 0000452288
       Coding: 030100040B087300EF0002481C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_006.rod
       VCID: 333319F7EBB4482F047-8066
       Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
       Component: E221__MFL-PR6  H04 0100
       Serial number: 000000000A0333270213
       Serial number: 5434670103
    131605 - No Communications with Airbag Control Module
              U0151 00 [008] - -
              [Timeout Knoten 0x15 / 15 - Steuergerät für Airbag]
                        Reset counter: 110
                        Mileage: 186281 km
                        Date: 2020.02.17
                        Time: 23:35:53
                        Supply voltage: Terminal 30: 12.0 V
                        Terminal 15: On
       Part No SW: 5Q4 959 393     HW: 5Q4 959 393
       Component: TSG FS        007 0006
       Serial number: 0000055770042
       Coding: 005000209000020000001100
       VCID: 55F7876F4580761FCA3-8000
       Component: FOND_FHSG_DRV  005 0004
       Serial number: 00000000000000119081
       Coding: 010200
    458752 - Databus
              [Airbag_01 Datenbus fehlende Botschaft]
                        Reset counter: 110
                        Mileage: 186281 km
                        Date: 2020.02.17
                        Time: 23:35:55
    589833 - Window Regulator Switch; Rear Driver Side
              B1323 29 [009] - Signal Implausible
                        Fault Frequency: 191
                        Reset counter: 70
                        Mileage: 185000 km
                        Date: 2020.02.07
                        Time: 00:01:37
       Component: EPS_MQB_ZFLS  126 1063
       Coding: 0002
       Shop #: WSC 73430 790 12345
       VCID: 44D14A2BBE1AFF97ADD-8010
       Part No SW: 5Q4 959 392     HW: 5Q4 959 392
       Component: TSG BFS       007 0006
       Serial number: 0000055311973
       VCID: 7F5B05C7977C5C4FB0F-802A
       Component: FOND_FHSG_PSG  005 0004
       Serial number: 00000000000000133953
       Coding: 190200
              B122D 29 [008] - Signal Implausible
                        Reset counter: 110
                        Mileage: 185262 km
                        Date: 2020.02.09
                        Time: 21:06:29
    458752 - Databus
                        Reset counter: 110
                        Mileage: 186281 km
                        Date: 2020.02.17
                        Time: 23:35:55
    Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-ENT1.clb
       Part No SW: 5E0 035 875     HW: 5E0 035 875
       Component: MU-E--ER      164 0141
       Revision: --------    Serial number: 000031094114000
       Coding: 03730100FF00000011110001000000002F0000840000010000
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_MUEnt4CCONT 004052
       ROD: EV_MUEnt4CCONT.rod
       VCID: 6695B0A3E8E6ED87539-8032
    6697 - Databus
              [Airbag: no communication]
                        Reset counter: 110
                        Mileage: 186281 km
                        Date: 2020.02.17
                        Time: 23:35:50
                        Voltage terminal 30: 9.9 V
    7175 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 39
                        Mileage: 185000 km
                        Date: 2020.02.07
                        Time: 00:01:41
                        Voltage terminal 30: 12.3 V
                        BAP-BAP_Function_ID: 02
    End----------(Elapsed Time: 01:07, VBatt start/end: 14.2V/13.7V)-----------
    Oct 2018
    skoda A7 2013
    mmm....are you not better starting with the basics ?
    check battery voltage fuses etc..loose plugs ..wires...
    has this car been in an accident ?
    ^^^hmm..... good question(about car being in an accident)! I assume that the car is in general use and not sitting in a workshop during the month of February - the difference between the mileage reading @ auto-scan date and the mileage on the DTC s suggests this is the case.
    So, lots of DTC s happening in February together with Fault Frequency=1 (which means that the underlying fault hasn't reappeared in any subsequent ignition cycle) - the "Igniter for Pedestrian Protection" DTC is in this category. Maybe try clearing DTC s and re-posting a new auto-scan to establish a clean starting point for your investigation.
    Steering Angle problems appear to be a not uncommon problem with MQB platform vehicle - there's an informed forum chat about this matter HERE - perhaps this is helpful.
  4. Likes Uwe liked this post
    Jan 2020
    Israel
    Thanks a lot
