VW Transporter T5.1 with Mirror Fold Key Fob / Remote
nazdaq100
London, United Kingdom
C?ID=314050
I have an auto scan now after a very long time could you please look into this and let us know what is required
Subsystem 2 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 003 3311
Coding: 050000
Subsystem 3 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 003 3311
Coding: 040000
I tried to change
Coding: 0400A3
Coding: 1400A3
Coding Rejected:
I have noticed my driver and passenger side modules end with "C" does this makes a difference?
Saturday,07,March,2020,20:22:16:42869
VIN: WV2ZZZ7HZBH021367   License Plate:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 0D 10 15 17 19 25 37 56 69 77 78 0B
VIN: WV2ZZZ7HZBH021367   Mileage: 293370km-182291miles
0D-Slide Door, Left -- Status: OK 0000
77-Telephone -- Status: Not registered 0011
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 022 JF    HW: 03L 907 309 H
   Component: R4 2,0L EDC   H28 9108
   Revision: 22H28---    Serial number: 00000000000000
   Coding: 01194012233400080000
   Shop #: WSC 00379 210 87177
   ASAM Dataset: EV_ECM20BTD01103L906022JF 002011
   ROD: EV_ECM20BTD01103L906022JB.rod
   VCID: 72BC2B6AF42556C7CF1-8026
8187 - Exhaust Gas Temp Bank 1 Sensor 1 (G235)
          P2080 00 [101] - Implausible Signal
                    Mileage: 293200 km
                    Time: 00:00:00
                    Coolant temperature: 3 °C
                    Intake air temperature: 3 °C
                    Voltage terminal 30: 12.220 V
                    Exh.gas temp.sen 1: 67.1 °C
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: 4.7 °C
                    Exh.gas temp.sen 4: 4.7 °C
                    Shut-off timer: last engine shut-off time: 41209 s
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0105
   Revision: 00H43001
   Coding: 208764AD09A6049626A59077AA6510
   Shop #: WSC 02756 790 49152
   VCID: 3634D77AD84D0AE7239-8062
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 7E5 907 040 E    HW: 7E5 907 040 E
   Component: ClimatronicT5 H10 0101
   Coding: 0004000102
   Shop #: WSC 20270 000 1048576
   ASAM Dataset: EV_ClimatronicT5 A01002
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 2A0CF30A1C755E07B71-807E
   Slave 1:
   Subsystem 1 - Part No SW: 7E5 907 049 B    HW: 7E5 907 049 B
   Component: Heckbedienung  H10 0202
   Serial number: BHB-0011607130015012
9473650 - Motor for Rear Temperature Flap
          B108E 54 [008] - Missing Calibration / Basic Setting
                    Fault Frequency: 12
                    Reset counter: 58
                    Mileage: 291458 km
                    Date: 2019.04.27
                    Time: 18:14:44
9474930 - Motor for Rear Air Distribution
          B1093 54 [008] - Missing Calibration / Basic Setting
                    Fault Frequency: 14
                    Reset counter: 58
                    Mileage: 291458 km
                    Date: 2019.04.27
                    Time: 18:14:44
9582164 - Positioning Motor for Rear Air Disrtibution Flap 2
          B1236 54 [008] - Missing Calibration / Basic Setting
                    Fault Frequency: 14
                    Reset counter: 58
                    Mileage: 291458 km
                    Date: 2019.04.27
                    Time: 18:14:44
9479189 - Signal Line for Air Quality Sensor
          B10A4 15 [009] - Open or Short to Plus
                    Fault Frequency: 230
                    Reset counter: 21
                    Mileage: 291116 km
                    Date: 2019.03.12
                    Time: 11:27:07
   Part No SW: 7H0 937 087 D    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0221
   Revision: BO047001    Serial number: 0347 207100100
   Coding: B8B2793A0E73241393288600742B8FD50080410F60844000300003000000
   Shop #: WSC 02756 790 00000
   VCID: 3536D076C54B01FF2A3-8060
   Component: RLS 020810 05  54  0403
   Coding: 03302E
   Coding: 050000
   Coding: 040000
   Subsystem 4 - Part No: 7E1 951 171
   Subsystem 5 - Part No: 1K0 951 605 C
   Subsystem 6 - Part No: 7E1 951 171
   Subsystem 7 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0037
   Serial number: 0012568
   Coding: 820000
03303 - Response Closing Status of Rear Left Door
                    Fault Frequency: 14
                    Reset counter: 59
                    Mileage: 292556 km
                    Date: 2014.03.18
                    Time: 20:45:55
03304 - Response Closing Status of Rear Right Door
                    Fault Frequency: 15
                    Reset counter: 49
                    Mileage: 292556 km
                    Date: 2014.03.18
                    Time: 20:45:55
00975 - Heated Rear Window (Z1)
                    Fault Frequency: 32
                    Reset counter: 11
                    Mileage: 291116 km
                    Date: 2013.08.02
                    Time: 11:27:17
Address 0D: Slide Door, Left        Labels: Redir Fail!
   Part No: 7E0 959 243 D
   Component: Schiebetuer-SG  407 0328
   VCID: 3038E162362924D7795-8064
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 A    HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0008
   Revision: --------    Serial number: 32741011907214
   Coding: 110001
   Shop #: WSC 02756 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K A01003
   ROD: EV_VW75XParkAssis8K_A01.rod
   VCID: 3038E1623AA924D7795-8064
1079060 - Center Rear Left Parking Aid Sensor
          B1077 14 [008] - Open or Short to Ground
                    Reset counter: 55
                    Mileage: 291916 km
                    Date: 2019.08.11
                    Time: 18:52:55
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag00P H05 0013
   Revision: --------    Serial number: 003HM0008SPH
   Coding: 000000000000000000000000000000003050
   Shop #: WSC 02754 790 50316
   VCID: 3634D77AD8CD0AE7239-8062
   Serial number: 3495ZRB40596JIHQ50A+
   Serial number: 3505ZRB405F6JIHQ5G79
   Part No SW: 7E0 920 970 C    HW: 7E0 920 970 C
   Component: KOMBI         H04 0204
   Coding: 160D00
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 0221
   Coding: 042300
   VCID: 70B82162FAA964D7395-8024
   Component: IMMO          H04 0204
   VCID: 6A8C330ADCF59E07771-803E
   Part No SW: 7F0 035 680 A    HW: 7F0 035 680
   Component: RNS-MID       H41 4026
   Revision: AB001001    Serial number: VWZ6Z7K8203039
   Coding: 06000402040000A00000
   Shop #: WSC 02754 790 00000
   VCID: 24101D327ED188778DD-8070
01523 - Microphone for Telephone (R38)
                    Fault Status: 00101011
                    Reset counter: 61
                    Mileage: 293163 km
                    Date: 2014.07.24
                    Time: 16:43:11
00862 - Antenna for GPS Navigation (R50/R52)
                    Reset counter: 61
                    Mileage: 291116 km
                    Date: 2013.08.02
                    Time: 11:27:46
                    Reset counter: 61
                    Mileage: 293163 km
                    Date: 2014.07.24
                    Time: 16:43:11
                    Reset counter: 61
                    Mileage: 291116 km
                    Date: 2013.08.02
                    Time: 11:27:46
   Component: Anhaenger     H07 0100
   Revision: 3A001001    Serial number: 00000132286424
   Coding: 410D000100000000
   VCID: 3038E1623A2924D7795-8064
   Part No SW: 7P6 035 730 E    HW: 7P6 035 730 E
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660063199
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA A01015
   ROD: UHVNA.rod
   VCID: 3430ED72CEB118F71DD-8060
9457171 - Right audio channel for speech/telephone
          B104E 13 [008] - Short to GND
                    Reset counter: 55
                    Mileage: 293163 km
                    Date: 2020.03.02
                    Time: 16:57:45
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
          [Bedieneinheit für Handyvorbereitung (Drei Tasten Module): Unterbrechung]
                    Reset counter: 240
                    Mileage: 361716 km
                    Date: 2015.05.31
                    Time: 16:01:28
0022 - Radio
          U1066 00 [000] - No Communication
          [Steuergerät Radio (RNS): kein Signal/Kommunikation]
Address 78: Slide Door, Right        Labels: Redir Fail!
End----------(Elapsed Time: 02:10, VBatt start/end: 12.3V/12.3V)-----------
dnoermann
C?ID=358118
This is not working with all combinations of BCM and Door Modules.
I have Door Modules with ending "J" with them it works for example ....
nazdaq100
C?ID=314050
Does anything else need to be flashed or upgraded?
dnoermann
C?ID=358118
I think you need to change the Door Modules and the BCM to get this running.
