Results 1 to 10 of 10
Thread: Passat B8: Composition Media to Discover Media upgrade
    Aug 2014
    Norway
    My father has a 2015 Passat B8 with a factory fitted Composition Media and he would like to upgrade to a Discover Media to get navigation (and also DAB digital radio). I have already sourced and bought the parts, and hoping to avoid compatibility issues I made sure they were the same as would have been fitted on this car had it been ordered with the Discover Media when it was new.
    3Q0035874 - Control unit
    3G0919605D - Screen
    3G9035577B - DAB antenna amplifier
    Now I'm starting to get a little worried that I may have missed something. I know Component Protection has to be taken care of, but I see there may be additional activations required as well (FeC) and it wasn't clear to me whether or not this would be a problem for this particular upgrade in this particular car. Maybe there are other things as well that could a potential challenge?
    Sunday,01,March,2020,13:08:54:22644
    VCDS Version: 19.6.2.2 (x64)
    VIN: WVWZZZ3CZFE431825   License Plate:
    Mileage: 86486km-53739mi   Repair Order:
    Chassis Type  3C-VW48 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 42 44 52 55 5F
              69 6C 6D BB BC CA
    VIN: WVWZZZ3CZFE431825   Mileage: 86486km-53739miles
    CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-DDAA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 DS    HW: 04L 907 309 M
       Component: R4 2.0l TDI   H22 1934
       Revision: B4H22---
       Coding: 011D001A047605083000
       Shop #: WSC 00010 218 00000
       ASAM Dataset: EV_ECM20TDI01104L906026DS 004005
       ROD: EV_ECM20TDI01104L906026DQ_004_VW48.rod
       VCID: 7EDD1797E1AF01BFD7-802A
    17156 - Databus
    17159 - Databus
              U0428 00 [032] - -
    4113 - Camshaft Position Sensor (G40)
              P0341 00 [096] - Implausible Signal
    5923 - Exhaust Pressure Control Valve
              P047F 00 [096] - Stuck Open
       Part No SW: 0D9 300 011 T    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H53 4801
       Revision: 03253104    Serial number: TFK01411191636
       Shop #: WSC 05311 115 00085
       ROD: EV_TCMDQ250021.rod
       VCID: 266D1FF759BF797FFF-8072
       Part No SW: 3Q0 907 379 N    HW: 3Q0 907 379 G
       Component: ESC           H42 0710
       Revision: 00000000    Serial number: 63314000000083
       Coding: 0FEC6A8F34230B6D077F070241C849F0562CD0E0E08292F118625078C209
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
       VCID: 45AFB87BC4F99267D6-8010
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 182
                        Mileage: 82029 km
                        Date: 2019.10.21
                        Time: 08:11:44
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0522
       Revision: 00023000    Serial number: 0355078936
       Coding: 000F0F0703
       Shop #: WSC 05311 115 00314
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       VCID: 77D302B3CE9530F794-8022
       Part No SW: 5G1 907 044 A    HW: 5G1 907 044 A
       Revision: 00001K10
       Coding: 12020124204101012015500C00101802
       Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
       Component: BCM PQ37BOSCH 028 0146
       Revision: --------    Serial number: 86580112140798
       Coding: 00971A46C24102FF13844084B11C57281C80000000000000000000000000
       ROD: EV_BCMBOSCH_014.rod
       VCID: 7DDF109BECA91AA7CE-8028
       Component: WWS    141118  042 0607
       Serial number:         141126123418
       Component: RLHS  037 0059
       Serial number: S4Y14M12D05H20M11S31
       Coding: 00A8DD
       Light switch:
       Serial number: 15 11 2014  00000078
       Serial number: 000000000ZY143140E9Y
       Serial number: 00000000000061135553
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 0
                        Mileage: 83489 km
                        Date: 2019.12.06
                        Time: 16:31:44
    204546 - Remote key 2
              B147A 18 [008] - Current Too Low
                        Reset counter: 40
                        Mileage: 83529 km
                        Date: 2019.12.09
                        Time: 19:01:57
    262912 - Sensor for Anti-Theft Alarm System
              B1330 F5 [008] - Alert Emergency Activation Stage 1
                        Reset counter: 171
                        Mileage: 85143 km
                        Date: 2019.12.31
                        Time: 16:06:48
       Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0053
       Revision: --------    Serial number: 39391433107761
       Coding: 0071151111
       VCID: 40A1A96FDBDBB74FE5-8014
       Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
       Component: ACC BOSCH MQB H04 0126
       Coding: 3260678910FFC428949C804C
       ASAM Dataset: EV_ACCBOSCHVW48X 001007
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 334BF6A39A6D1CD768-8066
    0862 - Databus
                        Fault Frequency: 9
                        Reset counter: 195
                        Mileage: 83578 km
                        Date: 2019.12.11
                        Time: 16:16:51
                        Control Module temperature: 21 °C
                        Voltage terminal 15: 14.1 V
       Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
       Component: Airbag VW20   012 0195
       Revision: --------    Serial number: 003R1PQY92LJ
       Coding: 88CCC000008000005C5400CC000800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 01276C6B90517E47AA-8054
       Belt Pretensioner left:
       Component: BeltPretRevFL  105 1032
       Serial number: 3G1857705E0336O00547
       Coding: 80000A
       Belt Pretensioner right:
       Component: BeltPretRevFR  105 1032
       Serial number: 3G1857706E0332O00893
       Coding: 80000A
       Subsystem 3 - Part No SW: -----------    HW: 454 002 611 14
       Serial number: 3576U000000C6999121E
       Subsystem 4 - Part No SW: -----------    HW: 454 002 911 14
       Serial number: 3586U000000BCA99121L
       Subsystem 5 - Part No SW: -----------    HW: 454 800 212 14
       Serial number: 3516RCBDA4605000000H
       Subsystem 6 - Part No SW: -----------    HW: 454 800 212 14
       Serial number: 3526R63B55105000000-
       Subsystem 7 - Part No SW: -----------    HW: 454 801 011 14
       Serial number: 3556V7DAA2E05000000P
       Part No SW: 3Q0 953 521 AM    HW: 5Q0 953 569 B
       Component: Lenks.Modul   100 0185
       Revision: FF033033    Serial number: 20141202500535
       Coding: 0410
       ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
       ROD: EV_SMLSVALEOMQBLRH.rod
       VCID: 7BDB1E83F2BD1497F0-802E
       Part No SW: 3G0 920 751     HW: 3G0 920 751
       Component: KOMBI         308 4311
       Coding: 07A40818AF80000800882A001000000000000000
       VCID: 62E543E77517C55FD3-8036
       Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
       Component: STH-MQB       006 0069
       Coding: 9309
       VCID: 364DCFB7891F09FF4F-8062
       Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
       Component: R149 T91-LIN  003 0301
       Serial number: 00000000000001031697
       Revision: --------    Serial number: 14111410802558
       Coding: 030300344F017300EF00025C1C0F00010001070000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72C533A7A5F755DFA3-8026
       Component: E221__MFL-DC1  H16 0040
       Serial number: 36140000332990044494
       Coding: 2FFFFF
       Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
       Serial number: 8472264703
       Analog clock:
       Component: Analoguhr  111 1004
       Serial number: 2711201400010659
       Serial number: HA1-00007.10.14
       Coding: 0301
       VCID: 46ADBF77F9FF997FDF-8012
       Serial number: 14000264001015
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71C73CABA0F16EC75A-8024
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 271114BKR05394
       Coding: 003F0A208000028000001000
       VCID: 42A5A367D5D7A55FF3-8016
       Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    203 2033
       Revision: 00000000    Serial number: 0000093964
       Coding: 01000010005001
       Shop #: WSC 00015 115 00314
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
       ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
       VCID: 3B5BDE83B23DD497B0-806E
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 241114BKM13739
       Coding: 003F00208000028000001000
       VCID: 41A7AC6BD0D1BE47EA-8014
       Coding: 03EA000009000000
       Shop #: WSC 05311 000 00001
       VCID: 75CF08BBD49942E786-8020
       Part No SW: 3Q0 035 824     HW: 3Q0 035 824
       Component: MU-S--ER      H04 0135
       Serial number: VWZAZ2P4651517
       Coding: 02840200FF00000011110001000808001F0100840120010000
       ASAM Dataset: EV_MUStd4CTSAT 001018
       ROD: EV_MUStd4CTSAT_VW48.rod
       VCID: 6AF52BC78D279D1F1B-803E
       Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
       Component: ABT_Std-2  H42 1015
       Serial number: VWZ8Z9PD7000ZK
              B201A 00 [009] - -
                        Reset counter: 133
                        Mileage: 76689 km
                        Date: 2019.06.27
                        Time: 11:51:45
                        Voltage terminal 30: 14.0 V
       Part No SW: 5Q0 907 383 D    HW: 5Q0 907 383 D
       Component: Anhaenger     H14 0137
       Revision: 8A001001    Serial number: 0353979400
       Coding: 0100000202000000
       VCID: 3851C18F830BFF8F5D-806C
       Part No SW: 5Q0 980 556     HW: 5Q0 980 556
       Component: RVC Compact   H07 0100
       Coding: 0184020163002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
       Part No SW: 5Q0 959 107 A    HW: 5Q0 959 107 A
       Component: HDSG-Modul    H11 0224
       Revision: --------    Serial number: 29703519600000
       Coding: 0280
       ASAM Dataset: EV_DeckLidCONTIAU736 001008
       Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
       Component: TSG HFS       020 0028
       Serial number: 081214BL701141
       Coding: 000E00200100028000001000
       VCID: 44A9A57FCFC3AB6FC1-8010
       Component: TSG HBFS      020 0028
       Serial number: 081214BL618841
    Address CA: Sunroof
    Interface not compatible.
    End-------------------------(Elapsed Time: 05:21)--------------------------
    Apr 2018
    ITALY
    yeah, you don't have the FeC for navigation so it will never work, not officially. you need to buy a hacked head unit with all FeC codes activated. hope you can send this one back :P
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
    Aug 2014
    Norway
    Well, that's a bummer! And this cannot be solved at the VW dealer? Is this "hack" a hardware change or is it possible to get it unlocked remotely? Will the digital radio work or do you need a FeC for that as well?
    May 2017
    VW dealer won’t lift a finger for this because there’s nothing they can do.
    APG Poland and VAG navisystems can hack the system but you need to send the media unit to them. And to make things more fun, not all systems are hackable. They will ask you to provide pictures from the unit before sending it to them for confirmation.
    Price for the hack is roughly 600€ but you get everything, APP connect, mapcare etc.
    And digital radio is behind FeC as well. So no go if you don’t have it from factory.
    Isn’t retrofits fun on MQB cars
    Aug 2014
    Norway
    Delightful
  6. Likes PetrolDave liked this post
    The time may come when we regard these as the days of the good old cars when we could actually still do some things.
  8. Likes PetrolDave, downtime, Somnus liked this post
    May 2016
    I can unlock all delphi and harman unit no problem. Send me pm
  10. #8
    Aug 2014
    Norway
    Quote Originally Posted by vastechnics View Post
    I believe this unit is made by TechniSat.
  11. #9
    May 2016
    Ok Techinsat i can not sorry
  12. #10
    Mar 2014
    Europe
    Yeah, "eagerly" waiting for SFD introduction in latest MQB cars
    @Bjornix:
    Your unit is made by Technisat, this has to be opened for hacking and test points have to be soldered to connect the unit to computer and hack it. Easiest way is to buy a 2nd hand Delphi unit, let VW service perform the component protection online and then enable the FECs. 600 bucks for a hacked Disco/Compo Media? Guys in our city are doing it much cheaper But we're discussing not legal stuff here.
    It's a shame that VW is unable to support people who want legal retrofit and are surprised people are hacking their units
  13. Likes Uwe, downtime, m87a liked this post
