Results 1 to 10 of 10
Thread: Single-side parking lights on American 2019 Alltrack with LED head and tail lights
    Mar 2018
    I have found various guides online for enabling single-side parking lights on mk7 Golfs. However none fully work with my Alltrack. All the recipes I've found result in only the front parking lights to turn on with the turn signal. My LED tail lights don't illuminate.
    Can anyone point me at a guide for enabling single-side parking lights on a an American market mk7 with LED tail lights?
    Thanks!
    Dec 2016
    DE
    Please add an adpmap of your 09 module (BCM), so we can see, where the problem resides.
    Without that I can only provide these changes, which might work, as they are based on a Passat B8 as well:
    Module 09 > Login: 31347 > Adaption >
    > Leuchte23SL HLC10-Lichtfunktion B 23 -> Parking light left
    > Leuchte24SL HRA65-Lichtfunktion B 24 -> Parking light right
  3. Likes Uwe liked this post
    Apr 2018
    ITALY
    and maybe an autoscan, since it's your first post, we don't know your car at all
  5. Likes Uwe liked this post
    Mar 2018
    Thanks for the responses.
    Here an autoscan:
    Saturday,07,March,2020,02:05:15:06056
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VMWare)
    VCDS Version 19.6.2.2  HEX-NET CB: 0.4508.4
    VIN: 3VWM17AU1KM519550   License Plate:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 03 05 08 09 10 13 15 17 19 22 29 2B 39 3C 42 44 47 4B 52
              5F 75 A5 CA D6 D7
    VIN: 3VWM17AU1KM519550   Mileage: 2854km-1773miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 311900322446002F1000
       Shop #: WSC 00066 790 00072
       ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
       ROD: EV_ECM18TFS0208V0906264M.rod
       VCID: 46C07D5AF9B0457FDF-8013
       Part No SW: 5Q0 614 517 DR    HW: 5Q0 614 517 BM
       Component: ESC           H45 0108
       Revision: 00000000    Serial number: 52309000000406
       Coding: 43FA6AA130210975407C0305A0C329C2560C9002C005943434405050F0A94B0B0040010312121212B435351919323200
       Shop #: WSC 00066 790 00166
       VCID: 0444A7528F0CB76F81-8051
       Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
       Component: VWKESSYMQB    037 1307
       Revision: 00037000    Serial number: 0522201978
       Coding: 132C0C0623
       VCID: 45C27A56C4B64E67D6-8011
       Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
       Component: Climatronic   H04 2001
       Revision: 00001K05
       Coding: 02020024200118000104000012111008
       ASAM Dataset: EV_ACClimaBHBVW37X 006146
       VCID: 48DC7362F3A4530F2D-801D
              B10CD 00 [008] - -
                        Reset counter: 101
                        Mileage: 2795 km
                        Date: 2020.03.05
                        Time: 22:28:37
                        Voltage terminal 30: 11.9 V
                        CAN input signal(s) status-Back-up light: OFF
       Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
       Revision: --------    Serial number: C86413091902OS
       Shop #: WSC 00066 790 00075
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 7BB6DCAEF2F2C897F0-802F
       Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    190628  043 0551
       Serial number: 97022066190710215155
       Component: RLHS  051 0206
       Serial number: SAY19M07D17H09M09S24
       Coding: 0008DD
       Steering Column Switch:
       Subsystem 4 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
       Component: Lenks.Modul  H03 0170
       Serial number: 0300060920190C201062
    934149 - Rain/Light Recognition Sensor
              B1366 76 [008] - Wrong mounting position
    197904 - Central Locking
              B140A 4B [008] - Over temperature
       Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
       Component: PLA 3.0 12KH07 0050
       Serial number: 000137089R19231
       Coding: 0271167801
       ASAM Dataset: EV_EPHVA2CAU3700000 009041
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 51EA5E0600FE92C77A-8005
       Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
       Coding: 2D0000C141FFC728949C810510401600000000000000000004
       VCID: 44C46752CF8C776FC1-8011
       Serial number: 003GCR0CEMYB
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47DE705EFEBA5C7724-8013
       Occupant Detection:
       Component: BF-Gewichtss.  H14 0022
       Serial number: IBH00000000000C1U5V$
       Coding: 303137
       Subsystem 2 - Part No SW: -----------    HW: 480 002 007 19
       Serial number: 3570000000033071DD3F
       Subsystem 3 - Part No SW: -----------    HW: 480 002 007 19
       Serial number: 35800000000F3951DD3Z
       Subsystem 4 - Part No SW: -----------    HW: 480 402 007 19
       Component: SideSensor_Dr  005 6149
       Serial number: 351000198F11B857A83A
       Subsystem 5 - Part No SW: -----------    HW: 480 401 907 19
       Component: SideSensor_Pr  005 6149
       Serial number: 35200019AF11B85034D5
       Subsystem 6 - Part No SW: -----------    HW: 480 400 908 19
       Component: FrontSensor_D  005 6149
       Serial number: 3550001C4F08AF88472L
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 908 19
       Component: FrontSensor_P  005 6149
       Serial number: 3560001C8F08AF8162BP
       Part No SW: 5G1 920 840 D    HW: 5G1 920 840 D
       Component: KOMBI         252 2700
       Coding: 0BA41015ED88CF0502886A0B5001000080000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009068
       VCID: 281CD3E253E4B30FCD-807D
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5366
       Serial number: 14091900842152
       Coding: 0901000830085900FB00221A0A0F00000001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 6E90E5FAB180AD3F47-803B
       Component: 0-00-0d-00-04
       Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
       Component: E221__MFL-MDM  H18 0052
       Serial number: 33190001079920111439
       Coding: 2CFFFF
       Power Converter DC AC:
       Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
       Component: U13DCAC  H25 0780
       Serial number: 8000431
       Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H55 7084
       Serial number: HA1-00024.04.19
       Coding: 0001
       VCID: 4CD44F72E7DCBF2F09-8019
    Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH08 0014
       Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Component: ELV-MQBB      H08 0021
       Serial number: 19000208924016
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 312A3E86603EF2C71A-8065
    Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
       Component: HRE_Master    H12 0081
       Serial number: 0523419128
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D3212B6AC6606A78E-8069
       Component: HRE_Slave  H12 0081
       Serial number: 0525212449
       Coding: 020111
       Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
       Component: TSG FS        006 0247
       Serial number: 42038924601744
       Coding: 003A13200000040000000000
       Shop #: WSC 01383 790 50316
       VCID: 4FEE587E16CA84376C-801B
       Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000004067044
       Coding: 011000
       Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
       Component: EPS_MQB_ZFLS  172 1081
       Coding: 930A0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 50EC5B020BF49BCF75-8005
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
       Component: MIB2_lite_amp H40 0200
       Revision: 00000001    Serial number: VWZ8Z1KMD05QSGE
       VCID: 2E1025FA7100ED3F07-807B
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0345
       Serial number: 22081900842693
       Coding: 000000050900211200110F01030000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002006
       ROD: EV_MultiModulContiVW48X_002_VW37.rod
       VCID: 35220A969456DEE746-8061
       Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
       Component: TSG BFS       006 0247
       Serial number: 46038924501525
       VCID: 4ED0457A11C08D3F67-801B
       Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000004070274
       Coding: 091000
    196673 - Position Sensor for Mirror Adjustment
              B11FA 29 [008] - Signal Implausible
                        Reset counter: 102
                        Mileage: 2796 km
                        Date: 2020.03.06
                        Time: 02:43:05
       Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
       Component: MU-S-NS-US    853 0890
       Coding: 027312020000000041220002001808009F0508F401200505C6
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 3326348E9A22C0D768-8067
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  254 8130
       Serial number: VWZ6ZMW2625168
       Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
       Component: NAR 2018/19  --- 0810
       Component: OCULowMQBUS   009 0570
       Coding: 02730202C2823A017F1E06020000
       ROD: EV_OCULowMQB.rod
       VCID: 43C6644ECA827057F8-8017
       Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H12 0610
       Serial number: 17051915K11890
       Coding: 000307020002020100221354C150490084000E20012000
       ROD: EV_MFKBoschMQBB_002_VW37.rod
       VCID: 40CC6B42DB946B4FE5-8015
       Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
       Coding: 00804073720C
       ROD: EV_SunRoofCONTIAU736_009_VW37.rod
       VCID: 75A2CA96D4D69EE786-8021
       Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
       Component: LED1L         H06 0002
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 393A06A6B84E3A87A2-806D
       Component: LED1R         H06 0002
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxRKEBODVW481.rod
    End----------(Elapsed Time: 01:48, VBatt start/end: 12.5V/12.5V)-----------
    Here's the adpmap:
    ;SW:5Q0-937-087-BA   HW:5Q0-937-087-BA ---  Cent. Elect. --- SA: 31347
    ;Component:BCM PQ37BOSCH 036 0265, Coding:000000000000000000000000000000000000000000000000000000000000
    ;EV_BodyContrModul1UDSBosc,019001,EV_BCMBOSCH_019_VW37.rod
    ;Saturday,07,March,2020,01:54:43:06056
    ;VCDS Version: Release 19.6.2  Data version: 20200210 DS308.0
    ;VCID: 7BB6DCAEF2F2C897F0-802F
    IDE00002-Transport mode,not active ,1
    IDE01550-Service position,170.494336 ∞,2
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,active ,10
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 ∞,16
    IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 ∞C,16
    IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 ∞C,16
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 ∞,16
    IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 ∞C,16
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 ∞,16
    IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.0 ∞C,11
    IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.0 ∞C,11
    IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
    IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 ∞C,11
    IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
    IDE04927-ENG154810-Window heater-window heating front activation time pause,320 s,11
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active ,8
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,not active ,8
    IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
    IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung ,8
    IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 10 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 10 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224
    IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 ∞C,30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 ∞C,30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 ∞C,30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 ∞C,30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 ∞C,30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 ∞C,30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,34.00 ∞C,30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 ∞C,30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,34.00 ∞C,30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,50.00 ∞C,30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,49.00 ∞C,30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,50.00 ∞C,30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,49.00 ∞C,30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
    IDE06507-MAS13125-Button in center console-Function of button 1,not coded/not installed ,8
    IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
    IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
    IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
    IDE07356-Position during interval mode,31.494474 ∞,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,0 ,19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
    IDE10298-Alternating park position 1,7.494498 ∞,2
    IDE10299-Alternating park position 2,29.494476 ∞,2
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.20 ,256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,installed ,3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
    IDE11944-ENG246971-Keyless access and start authorization-Kessy Bewegungs¸berwachungIDGeber,not active ,3
    IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen,active ,3
    IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,3
    IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
    IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
    IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
    IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
    IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
    IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
    IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
    IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
    IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
    IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
    IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
    IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
    IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
    IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
    IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
    IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
    IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
    IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
    IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
    IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
    MAS01490-ENG141978-Energy management-Recuperation,not active ,5
    MAS05055-lower turn position,31.494474 ∞,2
    MAS05056-upper turn position,170.494336 ∞,2
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
    ENG141649-ENG122212-Auflenlicht_Blinker-ABBA_Blinken,not active ,10
    ENG141649-ENG133379-Auflenlicht_Blinker-Abbruch Komfortblinken,active ,10
    ENG141649-ENG116590-Auflenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger,separte ,10
    ENG141649-ENG121966-Auflenlicht_Blinker-Crash flashing,not active ,10
    ENG141649-ENG122207-Auflenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
    ENG141649-ENG122206-Auflenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
    ENG141649-ENG142194-Auflenlicht_Blinker-dynamisch_blinken_10,not active ,10
    ENG141649-ENG142195-Auflenlicht_Blinker-Dynamische_Blink_Delay,50 ms,10
    ENG141649-ENG126819-Auflenlicht_Blinker-Emergency_alert_blinken,not active ,10
    ENG141649-ENG154601-Auflenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10
    ENG141649-ENG115774-Auflenlicht_Blinker-Komfortblinken,active ,10
    ENG141649-ENG116587-Auflenlicht_Blinker-Komfortblinken Blinkzyklen,3 ,10
    ENG141649-ENG122208-Auflenlicht_Blinker-Multi_kollisions_Blinken,not active ,10
    ENG141649-ENG122209-Auflenlicht_Blinker-Notwarn_blinken_NBA_Phase_2,not active ,10
    ENG141649-ENG121967-Auflenlicht_Blinker-Panic flashing,not active ,10
    ENG141649-ENG154711-Auflenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
    ENG141649-ENG122211-Auflenlicht_Blinker-Richtungs_blinken_links,active ,10
    ENG141649-ENG122210-Auflenlicht_Blinker-Richtungs_blinken_rechts,active ,10
    ENG141649-ENG122201-Auflenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
    ENG141649-ENG121968-Auflenlicht_Blinker-Taxi alarm flashing,not active ,10
    ENG141649-ENG126629-Auflenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
    ENG141649-ENG122202-Auflenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
    ENG141649-ENG142029-Auflenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
    ENG141649-ENG246997-Auflenlicht_Blinker-Warnblinken_TP_max,120 min,10
    ENG141649-ENG122214-Auflenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
    ENG141649-ENG122213-Auflenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
    ENG141649-ENG122204-Auflenlicht_Blinker-ZV_Blinken_auf,not active ,10
    ENG141649-ENG122203-Auflenlicht_Blinker-ZV_Blinken_zu,not active ,10
    ENG141647-ENG141986-Auflenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
    ENG141647-ENG246962-Auflenlicht_Front-ABL Redundanz Check sperren,not active ,9
    ENG141647-ENG116705-Auflenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
    ENG141647-ENG116704-Auflenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
    ENG141647-ENG115833-Auflenlicht_Front-Fahrlicht bei Tag,Daytime running lights ,9
    ENG141647-ENG142193-Auflenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
    ENG141647-ENG115861-Auflenlicht_Front-Lichthupe bei Zuendung aus moeglich,not active ,9
    ENG141647-ENG115832-Auflenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
    ENG141647-ENG142191-Auflenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
    ENG141647-ENG142190-Auflenlicht_Front-Signaturlicht_verbaut,not installed ,9
    ENG141647-ENG116592-Auflenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
    ENG141647-ENG116594-Auflenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,9
    ENG141647-ENG122184-Auflenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,active ,9
    ENG141647-ENG115734-Auflenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
    ENG141647-ENG116593-Auflenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
    ENG141647-ENG115733-Auflenlicht_Front-Tagfahrlichtkontrollleuchte,not active ,9
    ENG141647-ENG142192-Auflenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit,not active ,9
    ENG141647-ENG116591-Auflenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,9
    ENG141647-ENG115860-Auflenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,limitieren ,9
    ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,Yes ,5
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,not active ,5
    ENG141656-ENG142020-Auflenlicht_uebergreifend-All-weather lights,not installed ,18
    ENG141656-ENG133381-Auflenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,begrenzen auf Mindestverf¸gbarkeit ,18
    ENG141656-ENG133380-Auflenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,begrenzen auf Mindestverf¸gbarkeit ,18
    ENG141656-ENG142188-Auflenlicht_uebergreifend-bewusstes Standlicht,Aktive Begrenzung ,18
    ENG141656-ENG246968-Auflenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
    ENG141656-ENG115656-Auflenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
    ENG141656-ENG116601-Auflenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18
    ENG141656-ENG116604-Auflenlicht_uebergreifend-Coming-home Einschaltereignis,Driver door ,18
    ENG141656-ENG130581-Auflenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,not active ,18
    ENG141656-ENG126818-Auflenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis ,18
    ENG141656-ENG137034-Auflenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
    ENG141656-ENG154619-Auflenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG154177-Auflenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG116608-Auflenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
    ENG141656-ENG116605-Auflenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
    ENG141656-ENG142189-Auflenlicht_uebergreifend-HVLM_Ladezustandsanzeige,No ,18
    ENG141656-ENG115858-Auflenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
    ENG141656-ENG142185-Auflenlicht_uebergreifend-LCM_blinker,false ,18
    ENG141656-ENG141992-Auflenlicht_uebergreifend-LDS_mit_AFL,Yes ,18
    ENG141656-ENG141991-Auflenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,No ,18
    ENG141656-ENG141990-Auflenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
    ENG141656-ENG141993-Auflenlicht_uebergreifend-LDS_mit_Standlichtstellung,Yes ,18
    ENG141656-ENG115657-Auflenlicht_uebergreifend-Leaving-Home Verbausstatus,Enabled ,18
    ENG141656-ENG141989-Auflenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
    ENG141656-ENG115862-Auflenlicht_uebergreifend-Lichtwarnungsverhalten,klemmenabhaengig ,18
    ENG141656-ENG142034-Auflenlicht_uebergreifend-Light_Control_Module,installed ,18
    ENG141656-ENG98354-Auflenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG115863-Auflenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
    ENG141656-ENG116603-Auflenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
    ENG141656-ENG116607-Auflenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
    ENG141656-ENG116602-Auflenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung,active ,18
    ENG141656-ENG116606-Auflenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP,active ,18
    ENG141656-ENG115859-Auflenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
    ENG141656-ENG126816-Auflenlicht_uebergreifend-Standlicht aus,active ,18
    ENG141656-ENG115829-Auflenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,not active ,18
    ENG141656-ENG133383-Auflenlicht_uebergreifend-Standlicht-Verf¸gbarkeit,6 s,18
    ENG141656-ENG154174-Auflenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG126817-Auflenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte,not active ,18
    ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
    ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
    ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
    ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
    ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
    ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
    ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,active ,6
    ENG141645-MAS00214-HW_Verbau-Brake pad wear,not installed ,8
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,58.5 %,30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,58.5 %,30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,58.5 %,30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,58.5 %,30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,54.5 %,30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,49.5 %,30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,46.5 %,30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,35.5 %,30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,31.5 %,30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
    ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,36 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,35 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,0 ,16
    ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,00 ,16
    ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,not active ,16
    ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,0 ,16
    ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,00 ,16
    ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,not active ,16
    ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,not active ,16
    ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,minimize ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,3D ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,13 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,35 - kombinierte LED Blink-Bremsleuchten ,16
    ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,Blinken links Hellphase ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,Blinken links Dunkelphase ,16
    ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,minimize ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3E ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,23 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,35 - kombinierte LED Blink-Bremsleuchten ,16
    ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,Blinken rechts Hellphase ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,Blinken rechts Dunkelphase ,16
    ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,Parking light right ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,127 ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,not active ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,not active ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,54 ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,00 ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,53 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,43 - allgemeine LED ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe bei bereits aktivem Abblendlicht oder bereits aktivem Dauerfahrlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe bei bereits aktivem Abblendlicht oder bereits aktivem Dauerfahrlicht ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 23 13 00 3D 18 02 64 03 00 80 00 09 00 00 00 00 23 23 00 3E 18 04 64 05 00 80 00 0A 00 00 00 00 2A 29 00 2C 18 24 7F 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 00 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 00 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 54 08 00 7F 00 00 00 00 00 00 00 00 00 2B 00 00 53 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
    ENG141662-Leuchtenkonfiguration_Sonstiges,2B 00 00 36 08 00 FF 00 00 00 00 00 00 00 00 00 2B 00 00 35 08 00 FF 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
    ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
    ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
    ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
    ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
    ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
    ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
    ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
    ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
    ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
    ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
    ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabh‰ngig,not active ,7
    ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabh‰ngig_Parameter,active ,7
    ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabh‰ngig,active ,7
    ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabh‰ngig,not active ,7
    ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabh‰ngig_Parameter,active ,7
    ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabh‰ngig,active ,7
    ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Z¸ndungsabh‰ngig,not active ,7
    ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
    ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
    ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
    ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
    ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
    ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
    ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
    ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
    ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
    ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.50 ,27
    ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 ∞C,27
    ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,13.0 %,27
    ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
    ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
    ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
    ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
    ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,39 ∞C,27
    ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,43 ∞C,27
    ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,47 ∞C,27
    ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
    ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 ∞C,27
    ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
    ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
    ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
    ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
    ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
    ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
    ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
    ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
    ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper,installed ,2
    ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock,not installed ,2
    ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
    ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
    ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
    ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
    ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
    ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
    ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
    ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
    ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
    ENG122979-ENG141953-Networking-Getriebesteuergeraet,not installed ,8
    ENG124714-ENG142044-OCU-DWA_push,active ,8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
    ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
    ENG124714-OCU-,installed ,8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via ZV-Absicherung Light ,8
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
    ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,not active ,10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,0 ms,10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,0 ms,10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,0 ms,10
    ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
    ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
    ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
    ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
    ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
    ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
    ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
    ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
    ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
    ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
    ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
    ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
    ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
    ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
    ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
    ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
    ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
    ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
    ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
    ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
    ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
    ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
    ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
    ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
    ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
    ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
    ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
    ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
    ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
    ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
    ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
    ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
    ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
    ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
    ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
    ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
    ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
    ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
    ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
    ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,not active ,5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by convenience operation via remote control key ,5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,not active ,5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,not active ,5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,not active ,5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,not active ,5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,not active ,5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,not active ,5
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_f¸r_P_plausibel,1000 ms,10
    ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,Potentiometer ,21
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,active ,4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,installed ,4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,installed ,4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
    ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,not active ,9
    ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,not active ,9
    ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,not active ,9
    ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schlieflen,not active ,9
    ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,not active ,9
    ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active ,9
    ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,not active ,9
    ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schlieflen via Funkfernbedienung,not active ,9
    ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schlieflen via Kessy,not active ,9
    ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schlieflen via Schlieflzylinder,not active ,9
    ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
    ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
    ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,not active ,7
    ENG141651-ENG115755-ZV allgemein-Notschlieflfunktion,active ,7
    ENG141651-ENG141957-ZV allgemein-Radio freq.,315MHz ,7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Einzeltuerentriegelung ,7
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR,active ,3
    ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,not active ,7
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,active ,7
    ENG141681-IDE02022-ZV Komfort-Comfort opening,active ,8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,not active ,8
    ENG141681-ENG246991-ZV Komfort-pa_Two_Keys,not active ,8
    ENG141652-ENG141999-ZV T¸rkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
    ENG141652-ENG142043-ZV T¸rkonfiguration-HFT_Invertierung_Drehfallensignal,nicht invertiert ,5
    ENG141652-ENG142039-ZV T¸rkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite,not installed ,5
    ENG141652-ENG142038-ZV T¸rkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite,not installed ,5
    ENG141652-ENG142001-ZV T¸rkonfiguration-Schiebetuer_links,No ,5
    ENG141652-ENG142002-ZV T¸rkonfiguration-Schiebetuer_rechts,No ,5
    ENG141652-ENG142041-ZV T¸rkonfiguration-Schiebetueren_Crafter,not installed ,5
    ENG141652-ENG142244-ZV T¸rkonfiguration-Schiebetuerschloss_direkt_BCM,Driver side ,5
    ENG141652-ENG116631-ZV T¸rkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,5
    ENG141652-ENG142000-ZV T¸rkonfiguration-Schlosstyp_NAR,Yes ,5
    ENG141652-ENG141959-ZV T¸rkonfiguration-Viertuerer,Yes ,5
    Elapsed Time: 02:11
    Dec 2016
    DE
    Looking at the adaption channel map I guess my advice in post #2 could be the solution you are looking for.
    Mar 2018
    Is the meaning of these tags 23SL, HLC10, B 23 etc. documented anywhere in the service literature? Or is the only reference available the adaptation maps that come from other cars?
    Mar 2018
    Thanks for your input.
    Based on your suggestion, I was able to get things working somewhat better. For Leuchte23SL I found no "Parking light left" option; it's necessary to select "Parklicht links (beidseitiges Parklicht aktiviert li & re)" instead.
    The only limitation now is that only the rear outer lights illuminate, and the front single orange "dot" side marker does not illuminate. Here's the recipe:
    Driving light and parking light-Parklicht ueber LSS aktiviert -> one-sided
    Leuchte20BR LA71-Lichtfunktion F 20 -> Parklicht links (beidseitiges Parklicht aktiviert li & re)
    Leuchte21BR RC8-Lichtfunktion F 21 -> Parking light right
    Leuchte23SL HLC10-Lichtfunktion B 23 -> Parklicht links (beidseitiges Parklicht aktiviert li & re)
    Leuchte24SL HRA65-Lichtfunktion B 24 -> Parking light right
  10. #8
    May 2014
    tphares: Hi - If I might add additional info to TBAx's excellent suggestion, his approach to enabling Single-Side-Parking-Light (SSPL) on the 2 x inner tail lights deftly uses the illumination level that was factory programmed for the general PL function. Said in "Leuchte-speak" TBAx's approach uses the illumination level on factory set :
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 > 127
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 >127
    This is full illumination for LED style lamps
    Now here's the interesting thing about your BCM admap:
    As you correctly observed:
    But oddly - on your admap, the "illuminators" for these 2 x channels are:
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 > 0
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 > 0
    So - these settings mean that for some strange reason the illumination level for SSPL on the 2 x outer tails is zero. I've seen stranger things, but it seems odd to go to the trouble of programming the SSPL function onto the Lichtfunktion F channels and then not illuminate the lamps
    Anyhow, depending on what you want to do - perhaps consider increasing the value of the 2 x Dimmwert EF channels, or maybe change the 2 x Lichtfunktion F channels to not active?
  11. #9
    Mar 2018
    Do you mean that B 21 and 24 are sufficient for both front and rear? And that setting F 20 and 21 is redundant?
    Regarding EF 20 and 21 being set to 0, I believe that's how they came from the factory. Your post is the first I've heard of them. Thanks for calling them to my attention.
    Is there any guide to the nomenclature for these things? E.g., what's the meaning of 20BR vs LA71 vs EF 20? I can't find any info in the service literature. Your explanation makes it sound like I'm missing something totally obvious. But I find these settings very unintuitive.
  12. #10
    May 2014
    Quote Originally Posted by tphares View Post
    hmm....... no - none of the "Leuchte" channels in the BCM are superfluous: they are each important and they each have a specific purpose
    "unituitive"? Perhaps true, nevertheless the lighting channels kind-of make sense when you look at the pattern in a Leuchte-set (a Leuchte-set is a bunch of 19 x channels in the BCM with the same "Primary Tag" number and containing the term "Leuchte" as the first word in the channel descriptor)
    Each of the 35 x exterior lamps on a MQB platform vehicle (like your Alltrack) has an associated Leuchte-set. And, each Leuchte-set in the BCM has exactly the same structure.
    If you strip-off the tag numbers and unpack the channels in a Leuchte-set and re-order them in a more sensible manner (no offense to the order that VCDS uses in the current software) - you get the pattern shown in my picture below:
    Notice how a Leuchte-set has 3 x set-up channels and 4 x banks of "Alpha-pairs" with each bank having a repeated set of channels like this:
    • 2 x Lichtfunktion channels - these define the Light functions for the lamp
    • 1 x Dimmwert channel - this determines the illumination level for the Lichtfunktion pair
    • 1 x dimming direction channel
    As for the meaning of the Leuchte-set names - consider the Leuchte-set Leuchte21BR RC8. Here's how to interpret the nomenclature in the channel name
    Label	Meaning
    Leuchte	German for "Light"
    "21"	This is a simple sequence-number (i.e.  range is  0-34). I think this number links "Leuchte" Channels to "Lighting configuration" channels
    BR	German abbreviation for the lamp position. In this case BR means "Bremslicht hinten Rechts", or in English, Brake-light, Rear right
    R	" Rechts ", or in English "Right". The Left Lamp will have the letter L (for "Links" in German)
    C8	The physical pin number and connector identifier for the light on the BCM. In this case: Socket "C", pin "8"
    So- perhaps not "unintuitive", but I agree somewhat vague nevertheless!!
  13. Likes Uwe, PetrolDave, D-Dub liked this post
