Results 1 to 1 of 1
Thread: T6.1 New model
    May 2016
    T6.1 New model
    Wednesday,01,January,2020,14:35:16:43540
    VIN: WV2ZZZ7HZLH032678   License Plate: T6.1
    Chassis Type: 7H-VN75 (3Q0)
    Scan: 01 02 03 08 09 10 13 15 17 18 19 22 3C 3D 44 55 5F 65 75 D6
              D7 810B
    3D-Special Function -- Status: OK 0000
    810B-Aux. Air Heat. 2 -- Status: OK 0000
    Address 01: Engine (J623-CXFA)       Labels: None
       Part No SW: 04L 906 056 QJ    HW: 04L 907 445 M
       Component: R4 2.0l TDI   H01 9696
       Revision: 23301001
       Coding: 0025401C4366050800000000000000000000000000000000
       Shop #: WSC 00012 790 00070
       ASAM Dataset: EV_ECM20TDI03004L906056QJ 004004
       ROD: EV_ECM20TDI03004L906056QF.rod
       VCID: 055667B165AB876FFA3-8050
    Readiness: N/A
       Part No SW: 0BT 300 012 E    HW: 0GC 927 711 H
       Component: GSG DQ500     H06 3105
       Revision: 00H06V09
       ROD: EV_TCMDQ500021_VW36.rod
       VCID: 313EE36181A3FBCF76B-8064
       Part No SW: 7LA 614 517 A    HW: 7LA 614 517
       Component: ESC_high      H01 0700
       Serial number: 08500618191205
       Coding: 40554452C84AEE87025A22AB136E7766382723B8
       ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
       ROD: EV_Brake1ESP90iBOSCHVN46X.rod
       VCID: 3D26CF514DFB0FAFE23-8068
       Part No SW: 7LA 907 040 C    HW: 7LA 907 040 C
       Component: Climatronic   H01 0502
       Coding: 9030100008102100010009005040010500000000000A1501A04000000000
       ASAM Dataset: EV_AirCondiBHTCT6PA 001004
       ROD: N/A
       VCID: 3B22C14953EF019FDC7-806E
       Subsystem 1 - Part No SW: 7LA 906 453     HW: 7LA 906 453
       Component: E857  H01 0106
       Serial number: 00002281119151629102
       Subsystem 2 - Part No SW: 7LA 907 049 F    HW: 7LA 907 049 F
       Component: E857  H02 0301
       Serial number: 00002231119091437603
    No ASAM data for: "EV_AirCondiBHTCT6PA" (VN75)
       Part No SW: 2Q5 937 090     HW: 2Q5 937 090
       Component: BCM T6PA Std+ H10 0935
       Serial number: 01101935101582
       Shop #: WSC 00012 790 00055
       ASAM Dataset: EV_BCMA0 205001
       ROD: EV_BCMA0_204.rod
       VCID: 74B02A753E318EE7DDD-8020
       Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  050 0105
       Serial number: S2Y19M12D08H23M06S31
       Coding: 02B8DD
       Drivers Door Control Module:
       Subsystem 2 - Part No SW: 7L2 959 405 B    HW: 7L2 959 163 B
       Component: FHSG_DRV  001 0002
       Serial number: 00000000000036915964
       Coding: 130007
       Subsystem 3 - Part No SW: 7L2 959 406 B    HW: 7L2 959 164 B
       Component: FHSG_PSG  001 0002
       Serial number: 00000000000036826818
       Coding: 090007
       Part No SW: 5QA 919 298 H    HW: 5QA 919 298 A
       Component: PLA 3.0 12K   H08 0061
       Serial number: 000150057319343
       Coding: 0251165851
       ASAM Dataset: EV_EPHVA2CAU3700000 009048
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 55F677F1D58BF7EFCA3-8000
    Address 13: Auto Dist. Reg (J428)       Labels:. 2Q0-907-572.clb
       Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H03 0372
       Coding: 3204670301FF8748949C815580508700000000000000000004
       ASAM Dataset: EV_ACCMRRCONTIVW376 003016
       VCID: 43D2B9A92B1F795F947-8016
       Part No SW: 2Q0 959 655 AE    HW: 2Q0 959 655 AE
       Component: VW22Airbag    013 0506
       Revision: --------
       Coding: 88CCC00000000000800000CF000C40000065
       ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
       ROD: EV_AirbaVW22BPAVW27X.rod
       VCID: 005876A57A89A247C95-8054
       Subsystem 1 - Part No SW: -----------    HW: 442 062 911 19
       Serial number: 3577Y51A3340E2C4227$
       Subsystem 2 - Part No SW: -----------    HW: 442 062 911 19
       Serial number: 3587Y51AF33FA1C2427I
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 7LA 920 751     HW: 7LA 920 751
       Component: KOMBI         305 6750
       Coding: 07A4098A2488000801882A0D1401000000200000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009069
       ROD: N/A
       VCID: 7CA002551661C6A795D-8028
    No ASAM data for: "EV_DashBoardVDDMQBAB" (VN75)
    Address 18: Aux. Heat (J364)       Labels: None
       Part No SW: 5WA 963 271 A    HW: 5WA 963 271 A
       Component: STH-VW37x     006 0010
       Serial number: 000000000000947
       Coding: 7143221854121512DCE519
       ASAM Dataset: EV_AuxilHeateWOSVW38X 001009
       ROD: N/A
       VCID: 4ACC948D0C35A817571-801E
    No ASAM data for: "EV_AuxilHeateWOSVW38X" (VN75)
       Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5388
       Serial number: 07121911601162
       Coding: 030100544F05730401100218100F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013026
       ROD: EV_GatewNF.rod
       VCID: 70B826654A29B2C7395-8024
       Component: 4-00-11-01-04
       Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F
       Component: E221__MFL-PR6  H06 0110
       Serial number: PR6-0440036345190749
       Coding: 2C1D00
       Subsystem 3 - Part No SW: 7E0 915 181 L    HW: 7E0 915 181 L
       Component: J367-BDMConti  H03 1051
       Serial number: 77197200001911250921
       Part No SW: 0CQ 907 554 L    HW: 0CQ 525 130 C
       Component: Haldex4Motion H56 7822
       Serial number: HA1-00008.11.19
       Coding: 0001
       Shop #: WSC 00012 790 00047
       VCID: 4EC4989DF05D84370B9-801A
    Address 3C: Lane Change (J1086)       Labels:* None
       Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
       Component: HRE3_Kl15_Mst H06 0149
       Serial number: 00000533054068
       Coding: 52954640
       ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
       ROD: EV_HREntryHellaGen3Kl15.rod
       VCID: 392EDB4159D3338FCEB-806C
    Address 3D: Special Function (J608)       Labels:* None
       Part No SW: 2N0 907 427 P    HW: 2N0 907 427 H
       Component: KFG       H24 0306
       Serial number: GB24194842058
       Coding: 04002000000000200200000860B8135EB8000000
       ASAM Dataset: EV_SpeciFunctFlextVN54X 007029
       ROD: EV_SpeciFunctFlextVN54X.rod
       Subsystem 5 - Part No SW: 7C0 907 155     HW: 7C0 907 155
       Component: U13DCAC  H05 0870
       Serial number: A016891
       Subsystem 6 - Part No SW: 7E0 915 181 M    HW: 7E0 915 181 M
       Serial number: 7719450100191125014E
    Address 44: Steering Assist (J500)       Labels:. 2N0-909-143.clb
       Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
       Component: EPS_MQB_ZFLS  751 7150
       Coding: 0306
       ASAM Dataset: EV_SteerAssisMNB 002012
       ROD: N/A
       VCID: 45D6A7B1252B476FBA3-8010
    No ASAM data for: "EV_SteerAssisMNB" (VN75)
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Coding: 0C8A020009200003
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: N/A
       VCID: 41DEB3A131036B4F86B-8014
    No ASAM data for: "EV_HeadlRegulAFSMQBMAX" (VN75)
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 3G0 035 869 B    HW: 3G0 035 869 B
       Component: MU-E-D-ER     720 0740
       Serial number: 04121900020797
       Coding: 06640500FF00000041110101008000001F0000D40000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001044
       ROD: EV_MUEnt4CGen2LGE_VW12.rod
       VCID: 2B02F109A38F911F4C7-807E
       Part No SW: 5Q0 907 273 D    HW: 5Q0 907 273
       Component: RDKBERU30     H05 0010
       Serial number: 40000000365324
       ROD: EV_RDKBERU30_005.rod
       VCID: 3634D07D68CDDCF7239-8062
    8397058 - Front Left TPMS Sensor
              C1050 31 [009] - No Signal
                        Reset counter: 2
                        Mileage: 29 km
                        Date: 2020.02.19
                        Time: 17:22:44
                        Vehicle speed: 84 km/h
                        Outside air temperature: 7.0 C
                        Reception level antenna 1: 420 mV
                        Offset level antenna 1: 220 mV
    8397314 - Front Right TPMS Sensor
              C1051 31 [009] - No Signal
                        Reset counter: 2
                        Mileage: 29 km
                        Date: 2020.02.19
                        Time: 17:22:44
                        Reception level antenna 1: 440 mV
    8397570 - Rear Left TPMS Sensor
              C1052 31 [009] - No Signal
                        Reset counter: 2
                        Mileage: 29 km
                        Date: 2020.02.19
                        Time: 17:22:44
    8397826 - Rear Right TPMS Sensor
              C1053 31 [009] - No Signal
                        Reset counter: 2
                        Mileage: 29 km
                        Date: 2020.02.19
                        Time: 17:22:44
                        Reception level antenna 1: 430 mV
    Address 75: Telematics (J949)       Labels: None
       Part No SW: 5WA 035 282     HW: 5WA 035 282
       Component: OCUGen3Low    H14 0083
       Serial number: 0000000909NVCL4
       Coding: 06462000196818208005460160500607
       ASAM Dataset: EV_OCUGen3Low 002036
       ROD: N/A
       VCID: 015E73A17183AB4FC6B-8054
    No ASAM data for: "EV_OCUGen3Low" (VN75)
    7170 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 40
                        Mileage: 2226 km
                        Date: 2020.03.04
                        Time: 14:32:47
       Part No SW: 992 941 571 AA    HW: 992 941 571 A
       Component: LED1L         H08 9002
       ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
       ROD: EV_LLPGen3LKEBODPO68X.rod
       VCID: 619E532191C30B4FA6B-8034
       Component: LED1R         H08 9002
       ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
    Address 810B: Aux. Air Heat. 2 (J604)       Labels:* None
       Part No SW: 7C0 963 273 B    HW: 7C0 963 273 B
       Component: LSH_DIESEL    006 0026
       Coding: 3200
       ASAM Dataset: EV_LSHECCSMNB 002018
       ROD: EV_LSHECCSMNB_002.rod
       VCID: 2A0CF40DAC758817B71-807E
       Component: R64 D208L  004 0402
       Serial number: 00000000000000924743
    End----------(Elapsed Time: 01:28, VBatt start/end: 12.7V/12.6V)-----------
  2. Likes Uwe liked this post
