Results 1 to 3 of 3
Thread: AUDI A8 2015
    Feb 2020
    Saudi Arabia
    AUDI A8 2015
    hi
    i nhave this audi a8 with very rough ideal to the point the car will not start the auto scan will show fuil rail B1 and B2 lean
    Monday,17,February,2020,19:35:32:48412
    VCDS Version: 19.6.2.2  HEX-NET CB: 0.4508.4
    VIN: WAUR2BFD4EN000825   License Plate:
    Chassis Type: FD-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 0E 10 15 16 17 19 20 28 34 36 3B 42 46
              47 48 52 53 56 57 5B 5F 62 6C 6D 6F 72 7F 81 88 8A 8D 8F 90
              BA
    VIN: WAUR2BFD4EN000825   Mileage: 78738km-48925miles
    48-Seat, Rear, DS -- Status: OK 0000
    5B-Seat,Rear,PS -- Status: Malfunction 0010
    7F-Inform. Electr. II -- Status: Malfunction 0010
    8A-Multicont. Seat Rear,DS -- Status: OK 0000
    8D-Multicont. Seat Rear,PS -- Status: OK 0000
    BA-Motor Mounts -- Status: OK 0000
    Address 01: Engine (------CEUA)       Labels: None
       Part No SW: 4H0 906 014 H    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H62 0006
       Revision: NCH62---
       Coding: 022A00326526010A1000
       Shop #: WSC 11061 002 1048576
       ASAM Dataset: EV_ECM40TFS0114H0906014H 001006
       ROD: EV_ECM40TFS0114H0906014H.rod
       VCID: 281CDE3A534E070FCD-807C
    15489 - Fuel Trim; Bank 2
              P0175 00 [096] - System Too Rich
                        Mileage: 78558 km
                        Date: 2020.02.15
                        Time: 21:41:09
                        Engine speed: 1304.00 /min
                        Normed load value: 21.2 %
                        Vehicle speed: 40 km/h
                        Coolant temperature: 99 °C
                        Intake air temperature: 56 °C
                        Ambient air pressure: 940 mbar
                        Voltage terminal 30: 13.499 V
                        AFS dm: 53.7 kg/h
                        Median injection timing: 1.401 ms
                        Engine operating condition: Part. load
                        Engine operating condition-Test_Program_Channel 87: 6
    16463 - Fuel Trim; Bank 1
              P0172 00 [096] - System Too Rich
                        Mileage: 78558 km
                        Date: 2020.02.15
                        Time: 21:41:09
                        Engine speed: 1308.50 /min
                        Voltage terminal 30: 13.428 V
                        AFS dm: 54.2 kg/h
                        Median injection timing: 1.466 ms
    16475 - Fuel Trim; Bank 2
                        Mileage: 76692 km
                        Date: 2020.01.30
                        Time: 22:37:30
                        Engine speed: 542.00 /min
                        Normed load value: 8.6 %
                        Coolant temperature: 93 °C
                        Intake air temperature: 37 °C
                        Voltage terminal 30: 13.617 V
                        Unlearning counter according OBD: 4
                        AFS dm: 18.9 kg/h
                        Median injection timing: 0.585 ms
                        A/C compressor: load current: act. value: -471.44 A
    16497 - Fuel Trim; Bank 1
       Part No SW: 4H1 927 158 EE    HW: 0BK 927 156 AG
       Component: 0BK 40TFSIUSA H16 1002
       Revision: --H16---
       Coding: 000001
       ASAM Dataset: EV_TCMALX51011 002022
       ROD: EV_TCMALX51011_002_AU64.rod
       VCID: 77BECD46CE7058F794-8022
       Part No SW: 4H0 907 379 D    HW: 4H0 907 379 D
       Component: ESP PREMIUM   H10 0352
       Coding: C4E5E30023A7C700E300
       ASAM Dataset: EV_ESPPremi 005013
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 332639569A8874D768-8066
       Part No SW: 4H0 907 064 CF    HW: 4H0 907 064 CF
       Component: BCM2 2.0      H33 0433
       Coding: 05A72F46000000000000
       Shop #: WSC 02313 785 00200
       VCID: 6FAEF526BE2010374C-803A
    Address 06: Seat Mem. Pass
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 L    HW: 4H0 820 043 L
       Component: Klima 4 Zonen H20 0130
       Coding: 680122FE38
       VCID: 291ADB3E48443E07D2-807C
    0137 - Motor for  Right Side Window Defrost Flap
              B10D8 22 [009] - Signal Amplitude Too High
                        Fault Frequency: 68
                        Reset counter: 206
                        Mileage: 77803 km
                        Date: 2020.02.07
                        Time: 23:42:04
       Revision: 11012002    Serial number: 00000001499515
       Coding: 0907201009749FE18B810004A0001800009CC3080E000101800108546F01
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 121120  H35 0080
       Serial number:         121214225223
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 10309556
       Coding: 025523
       Component: E1 - LDS  H07 0044
       Serial number: 15 01 2013  00001413
       Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
       Serial number: 00000023011300010965
       Coding: 100000
       Serial number: 00000022011300010383
       Coding: 100000
       Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA104974000002578183
       Coding: 020300
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 9AA98B86000000000001
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 F    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0200
       Revision: AA001001
       Coding: 020000
       VCID: 2306C9162268E45798-8076
    03230 - Video Input for Rear Seat Entertainment
                        Fault Status: 00101010
                        Fault Frequency: 99
                        Reset counter: 246
                        Mileage: 75936 km
                        Date: 2020.01.25
                        Time: 18:11:45
       Revision: 11001001    Serial number: 61061302001215
       Coding: A8030E
       VCID: 71AAF35EA01406C75A-8024
       Revision: --------    Serial number: 003JG00BEZY3
       Coding: 30314246323430303034554A304C34483053
       VCID: 3620004289FA61FF4F-8062
       Serial number: 3575HRB40611PU9478HF
       Serial number: 3585HRB405J1SJR2DP26
       Serial number: 3515JRB400O50D62K1K.
       Serial number: 3525JRB400O50D629A2I
       Serial number: 3554VRB400S4UPLCL0M
       Serial number: 3564VRB400S4UPLCDQ7%
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90815MAH0004W
       Coding: 000034
       VCID: 373E0D4686F098F754-8062
       Subsystem 1 - Part No SW: 4H0 951 528 J    HW: 4H0 951 528 J
       Component: E221 - MFL  H09 0009
       Serial number: 14 06 2012  33245065
       Part No SW: 4H0 920 900 L    HW: 4H0 920 900 L
       Component: TBenRDW------ H50 0515
       Revision: 34081076    Serial number: 658110113592004
       Coding: 53A6080013400008010000
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K_AU64.rod
       VCID: 2C14222A47B62B2F29-8078
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0225
       Serial number: 2121206006856
       Part No SW: 4H0 907 468 AC    HW: 4H0 907 468 AC
       Component: J533--Gateway H12 0037
       Revision: --------    Serial number: 00000000793367
       Coding: 00ED074800
       ASAM Dataset: EV_GatewPkoUDS 001018
       VCID: 72A8FC52A5123DDFA3-8026
       Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
       Component: J367-BDM  H08 0181
       Serial number: 00000000001910925715
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 A    HW: 8K0 959 663 A
       Serial number: 13015003256021200181
       Part No SW: 8K0 857 511 F    HW: 8K0 857 511 A
       Component: FLA           H04 0020
       Revision: AA001002
       Coding: 04018B6B74745D545420363E00
       VCID: 34243A4A978673EF71-8060
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 L    HW: 4H0 919 158 L
       Component: Klima Fond    H16 0121
       Coding: 2600000000
       ROD: EV_AirCondiHeck_AU64.rod
       VCID: 393A0B7EB8E48E87A2-806C
       Part No SW: 4H0 907 553 E    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0099
       Coding: 008000
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2E10282271AA593F07-807A
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Revision: AA000000    Serial number: 00000050239624
       Coding: C018BF8085857201070001010101112131313333203333
       VCID: 3522074E9CFC6AE746-8060
       Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
       Component: SARA 6D       H02 0056
       Revision: --------    Serial number: EJ1BPA7700FZ6L
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 373E0D468EF098F754-8062
       Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
       Component: TSG FA        H06 0273
       Revision: --------    Serial number: 0000049210354
       Coding: 011F1E005E0062C202083006
       Shop #: WSC 02312 785 00200
       VCID: 48DC7EBAFB0EE70F2D-801C
                        Fault Frequency: 126
                        Reset counter: 182
                        Mileage: 55684 km
                        Date: 2019.08.22
                        Time: 22:23:57
    01482 - Motors for Central Locking
                007 - Short to Ground
                        Fault Status: 01100111
                        Fault Frequency: 173
                        Reset counter: 182
                        Mileage: 55684 km
                        Date: 2019.08.22
                        Time: 22:23:57
                006 - Short to Plus
                        Fault Status: 01100110
                        Fault Frequency: 24
                        Reset counter: 183
                        Mileage: 57961 km
                        Date: 2019.09.10
                        Time: 19:26:31
       Revision: 00002001    Serial number: 0300223342
       Coding: 011A0E2000B9359FB330C7840A0301070000000000000000000000000000
       Shop #: WSC 02311 785 00200
       Subsystem 1 - Part No: 4H0 951 177
       Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J245  007C  H06 0005
       Serial number: 251100019365
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 N    HW: 4H0 947 135 N
       Component: Dachelektroni  H11 0080
       Serial number: A2013000000000669785
       Coding: 070000
       Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J394  0014  H06 0005
       Serial number: 250700018581
       Coding: 020200
       Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J392  006A  H06 0005
       Serial number: 251100019361
       Coding: 020200
       Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Component: J867  00E0  H06 0005
       Serial number: 250700018589
       Coding: 020200
       Subsystem 8 - Part No SW: 3AA 962 243     HW: 3AA 962 243
       Component: GEB.F.Heckoef  H12 0719
       Serial number: 84338542
    03634 - Switch for Window Shade Illumination; Front
                        Fault Status: 00101100
                        Fault Frequency: 49
                        Reset counter: 243
                        Mileage: 56413 km
                        Date: 2019.08.29
                        Time: 21:52:06
       Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
       Component: BOSE-G3C7-ANC H02 0540
       Revision: CJ002700    Serial number: 00000000002740
       Coding: 030000
       VCID: 1C74F2EA1F16DBAF59-8048
    00529 - Engine Speed Signal Missing
                        Fault Status: 00110000
                        Reset counter: 245
                        Mileage: 74394 km
                        Date: 2020.01.16
                        Time: 22:04:50
    03994 - Noise reduction function limitation
                        Reset counter: 245
                        Mileage: 74394 km
                        Date: 2020.01.16
                        Time: 22:04:50
                        Bin. Bits: 00000001
    Address 48: Seat, Rear, DS (J876)       Labels: None
       Part No SW: 4H0 959 860 A    HW: 4H0 959 860 A
       Component: MEM-FS-Fond   H06 0155
       Revision: AA000000    Serial number: 00000042112090
       Coding: C01892808500700D0B00392038193A2039203B3B202020
       VCID: 32283C526D927DDF63-8066
       Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
       Component: TSG BF        H06 0273
       Revision: --------    Serial number: 0000049443126
       VCID: 3C34126ABFD6BBAFB9-8068
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000573945
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2B16213642B82C1720-807E
    67840 - Left Parking Brake Motor Voltage Supply
              C100D 01 [000] - Electrical Malfunction
    70912 - Left Parking Brake Motor Voltage Supply
              C100D 13 [008] - Electrical Malfunction
                        Reset counter: 139
                        Mileage: 76654 km
                        Date: 2020.01.30
                        Time: 16:14:25
                        Voltage terminal 30: 12.2 V
                        Internal Fault ID: 26
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: OFF
                        RWU: not active
                        DSD: not active
                        HTR: active
                        ECD: not active
                        Auto Adjust: not active
                        Internal Parking Brake state: No enabling
    71168 - Right Parking Brake Motor Voltage Supply
              C100E 13 [008] - Electrical Malfunction
                        Reset counter: 139
                        Mileage: 76654 km
                        Date: 2020.01.30
                        Time: 16:14:25
                        Internal Fault ID: 27
                        Yellow warning lamp: On
                        RWU: not active
                        DSD: not active
                        HTR: active
                        ECD: not active
    71424 - Left Parking Brake Motor Voltage Supply
              C100D 12 [000] - Electrical Malfunction
       Part No SW: 4H0 035 056 G    HW: 4H0 035 056
       Component: Radio U STD   H60 0121
       Revision: AB001007    Serial number: 231AN0D7523541
       Coding: 070003010003000001
       VCID: 2600D002515A117FFF-8072
    Address 57: TV Tuner (R78)       Labels: None
       Part No SW: 4F0 919 129 G    HW: 4F0 919 129
       Component: HybridTV-DVB  H07 0550
       Revision: R0070000    Serial number: 76301302893401
       Coding: 14010400
       VCID: 302C365A639E4FCF15-8064
    Address 5B: Seat,Rear,PS (J877)       Labels: None
       Component: MEM-BFS-Fond  H06 0155
       Revision: AA000000    Serial number: 00000042110915
       Coding: C01896808500700D0F00392038193A2039203B3B3B2020
    03785 - Remote Control for Rest-Seat
                        Reset counter: 236
                        Mileage: 78170 km
                        Date: 2020.02.14
                        Time: 15:02:27
       Part No SW: 4H0 035 764 L    HW: 4H0 035 764 N
       Component: H-BNT-RW      H45 0637
       Revision: --------    Serial number: 181AV0D7503178
       Coding: 020D00000001F1EF45D08B0E00000003740001020000000000
       VCID: 312A335E689446C71A-8064
       Subsystem 1 - Part No: 8R0 060 884 AS
       Component: ROW 2013  0506
       Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
       Component: DU8 D4 SV NB  H48 0021
       Serial number: AUZ8ZDCC90008SS
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0065
       Serial number: 00000000101538
       Component: CD-Database  4949
    03787 - Rotation Mechanism for Display Module Front
                003 - Mechanical Failure
                        Fault Status: 01100011
                        Reset counter: 206
                        Mileage: 55684 km
                        Date: 2019.08.22
                        Time: 21:35:53
                        Voltage: 12.60 V
       Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
       Component: TSG HL        H06 0273
       Revision: --------    Serial number: 0000049808147
       Coding: 010F1E00420062C202083006
       Part No SW: 4H0 907 428 A    HW: 7P6 907 441 D
       Component: TopView       H05 0150
       Revision: 11001001    Serial number: 82330JF0068921
       Coding: 020A000001010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 006025
       ROD: EV_CamerSysteTopViewAUDI_005_AU57.rod
    9617434 - Supply Voltage for Left Surroundings Camera
              B1286 14 [008] - Open or Short to Ground
                        Mileage: 57958 km
                        Date: 2019.09.08
                        Time: 18:51:20
                        Voltage terminal 30: 11.7 V
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 AB    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0043
       Revision: 10011001    Serial number: 015301021
       Coding: 0210044000
       ASAM Dataset: EV_DeckLidContrUnit 001032
       ROD: EV_DeckLidContrUnit.rod
       VCID: 6E90E822B12A193F47-803A
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000094095
       Coding: 600000
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 638689166AE8A457D8-8036
       Component: TSG HR        H06 0273
       Revision: --------    Serial number: 0000049808146
    Address 7F: Inform. Electr. II (J829)       Labels: None
       Part No SW: 4H0 035 778 G    HW: 4H0 035 778 J
       Component: H-BN-RW       H45 0638
       Revision: --------    Serial number: 186AW0D7502832
       Coding: 020D0000000100400140000400001300600000000000000000
       Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
       Component: DU10 RSE  H41 0021
       Serial number: AUZ8ZDC1200XJ8Y
       Subsystem 2 - Part No SW: 4H4 919 607     HW: 4H4 919 607
       Serial number: AUZ8ZDC27007KLS
       Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
       Component: E499 BDT 2  H07 0019
       Serial number: 90238MAF0000S
       Subsystem 5 - Part No: 8R0 060 884 AS
    00658 - Control Head
                        Reset counter: 216
                        Mileage: 77927 km
                        Date: 2020.02.09
                        Time: 18:45:41
                        Voltage: 12.50 V
                        Bin. Bits:      001
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H08 0083
       Revision: 0L0D5015    Serial number: SN121107  0266
       ROD: EV_GSM2x3Mono.rod
       Serial number: 00009256156801
       Coding: 766FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F2E352676A050370C-807A
    Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
       Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
       Component: IVB           H08 0042
       Serial number: 00009475071302
       Coding: 306F00
       ASAM Dataset: EV_IVBDriveSideRear 001003
    Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
       Serial number: 00009475061502
       Coding: 306F00
       ASAM Dataset: EV_IVBPasseSideRear 001003
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 312A335E609446C71A-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 32283C5265927DDF63-8066
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145     HW: 4H0 907 145
       Component: AEM - LEAR    H05 0006
       Revision: 00001001    Serial number: 97804001280604
       ASAM Dataset: EV_AEMLearAU64X 002014
       ROD: EV_AEMLearAU64X_AU57.rod
       VCID: 6680900299DAD17F3F-8032
    End----------(Elapsed Time: 03:41, VBatt start/end: 12.2V/12.2V)-----------
    16.4905 S, 151.7375 W
    hi
    - Sounds like you may want to check the N80-Canister Purge Valve and make sure you do not have raw fuel or too much fuel vapor entering into the intake manifold causing a 'rich/flooding' condition.
    The N80 valve is located in the right rear area of the engine compartment. You can 'Pinch' the hose closed and see if the vehicle will start. If you remove the N80, there should be no raw fuel in the line (failed charcoal canister) and the N80 valve should be closed.
    The other thing to check is fuel dilution in the engine oil, caused by a failed High Pressure Fuel Pump (HPFP) leaking fuel into the crankcase and also causing a rich/flooding air/fuel mixture. Check the Oil Level, if the oil level is too high, check for fuel in the oil and do NOT start/run the engine, gasoline is not a good lubricant!
    We recommend to use the Official Factory Repair Information when attempting to diagnose and repair these vehicles,
    Hope this helps,
    drpeter
  3. Likes Uwe liked this post
    Feb 2020
    Saudi Arabia
    than you for replying Drpeter
    i will check the charcoal canister because i did have the same problem with a BMW and i had to change the canister.
    the same car came back with check engine light and this codes cam up
    Sunday,08,March,2020,14:35:00:48412
    VCDS Version: Release 19.6.2 Running on Windows 7 x64
                    Address 01: Engine       Labels: None
    Control Module Part Number: 4H0 906 014 H    HW: 4H0 906 014
      Component and/or Version: 4.0l V8TFSI / H62 0006
               Software Coding: 022A00326526010A1000
                Work Shop Code: WSC 11061 002 1048576
                  ASAM Dataset: EV_ECM40TFS0114H0906014H 001006 (AU64)
    7 Faults Found:
    7690 - Oxygen (Lambda) Sensor B2 S1
              P2240 00 [096] - Pump Current Open Circuit
    7676 - Oxygen (Lambda) Sensor B1 S1
              P2237 00 [096] - Pump Current Open Circuit
    10203 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [237] - -
                        Mileage: 80795 km
                        Date: 2020.03.08
                        Time: 00:05:18
                        Engine speed: 1273.00 /min
                        Normed load value: 21.6 %
                        Vehicle speed: 59 km/h
                        Coolant temperature: 96 C
                        Intake air temperature: 51 C
                        Voltage terminal 30: 13.405 V
                        AFS dm: 107.2 kg/h
                        Median injection timing: 1.949 ms
    10593 - Cylinder 3
              P0303 00 [237] - Misfire Detected
                        Mileage: 80795 km
                        Date: 2020.03.08
                        Time: 00:05:18
                        AFS dm: 107.2 kg/h
    10205 - Cylinder Disabling
              P130A 00 [044] - -
                        Mileage: 80795 km
                        Date: 2020.03.08
                        Time: 00:05:37
                        Engine speed: 523.50 /min
                        Normed load value: 7.8 %
                        Coolant temperature: 93 C
                        Intake air temperature: 58 C
                        AFS dm: 16.5 kg/h
                        Median injection timing: 1.882 ms
                        A/C compressor: load current: act. value: 904.56 A
                        Mileage: 79607 km
                        Date: 2020.02.27
                        Time: 16:59:31
                        Engine speed: 783.00 /min
                        Normed load value: 9.0 %
                        Vehicle speed: 9 km/h
                        Coolant temperature: 95 C
                        Intake air temperature: 48 C
                        Voltage terminal 30: 13.853 V
                        Unlearning counter according OBD: 13
                        AFS dm: 28.9 kg/h
                        Median injection timing: 1.153 ms
                        A/C compressor: load current: act. value: -47.44 A
                        Mileage: 79607 km
                        Date: 2020.02.27
                        Time: 16:59:31
                        AFS dm: 28.9 kg/h
