Helping a friend with his RS3, not sure what he did but lost the ABS coding. I found a similar scan online and tried applied the coding but it errors out.
Any ideas? I know my VCDS needs to be updated but hoping it will work for this ABS controller until i get the new one.
Here is scan:
Here is scan:
Wednesday,04,March,2020,19:16:38:29920
VCDS Version: 19.6.2.2 (x64)
VIN: WUABWGFF8J1907136 License Plate:
Chassis Type FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 47 4B 52 5F
6C BB BC CF
VIN: WUABWGFF8J1907136 Mileage: 24720km-15360miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (------DAZA) Labels:. 07K-907-309-V1.clb
Part No SW: 8V0 907 404 G HW: 07K 907 309 E
Component: R5 2.5l TFSI H22 0004
Revision: 53H22000
Coding: 0A250032242608053620
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM25TFS0118V0907404G 001004
ROD: EV_ECM25TFS0118V0907404G.rod
VCID: 3D7B22A1AC054EA78E-8068
17158 - Implausible Data Received from ESP Control Module
U0416 00 [047] - -
Mileage: 24720 km
Time: 00:00:00
Coolant temperature: 15 °C
Intake air temperature: 16 °C
Voltage terminal 30: 13.480 V
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
4716 - No Communications with Parking Brake Control Module
U0128 00 [047] - -
Mileage: 24720 km
Date: 2020.03.01
Time: 18:51:50
Intake air temperature: 15 °C
Voltage terminal 30: 13.220 V
selected gear-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 0
Cruise control switch actuation-Bits 0-7: 49
Readiness: 1110 0101
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DL 300 012 H HW: 0GC 927 711 G
Component: GSG DQ500 H06 2112
Revision: 00H06V07
VCID: 2E5915ED7163A53F07-807A
21221 - No Communications with Parking Brake Control Module
U0128 00 [047] - -
Mileage: 24720 km
Date: 2020.03.01
Time: 18:51:51
Clutch: primary stat: New
selected gear: GANG_R
Driving position: P
Engine torque: -48 Nm
Control Module temperature: 11 °C
Accelerator position: 16.0 %
DTC memory status: 73
Part No SW: 8V0 614 517 E HW: 8V0 614 517 C
Component: ESC H25 0625
Revision: 00000000 Serial number: 61018000000038
Coding: 00000000000000000000000000000000000000000000000000000000000000
ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
VCID: 3B7F2CB9B2114097B0-806E
12 Faults Found:
0195 - Control module not coded
U1013 00 [137] - -
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 19:43:21
0212 - Longitudinal Acceleration Sensor
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 19:43:21
0270 - Lateral Acceleration Sensor
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 19:43:21
0295 - Steering angle sensor
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 19:43:21
4161 - Coding invalid
U10DA 00 [008] - -
Reset counter: 225
Mileage: 24720 km
Date: 2020.03.01
Time: 19:43:29
8279 - Engine Control Module Incorrectly Coded
P1612 00 [137] - -
Fault Frequency: 7
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 19:43:21
8280 - Engine Control Module Incorrectly Coded
P1612 00 [137] - -
Fault Frequency: 7
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 19:43:21
8292 - Control Module Incorrectly Coded
U1014 00 [137] - -
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 19:43:21
8299 - Databus
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 19:43:21
8306 - Databus
U1122 00 [137] - Implausible Message
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 19:43:23
8314 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [009] - -
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 19:43:21
32848 - Control Module for Electric Parking Brake
C10E2 F1 [137] - Switches/Motors Detected
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 19:43:21
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0476943010
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
VCID: 3C7D2FA5B71F47AFB9-8068
Part No SW: 8V0 820 043 AF HW: 8V0 820 043 AF
Component: AC Automat H03 0150
Revision: 20003000 Serial number: 00000001529018
Coding: 03000015010000000000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
VCID: 76E9FD8DC9B3DDFF8F-8022
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 2E51532900PAG0MUFU03
Part No SW: 5Q0 937 085 BN HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H36 0253
Serial number: 01001808700157
ROD: EV_BCMBOSCH_018.rod
VCID: 06098D4DB953CD7F9F-8052
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 180316 043 0585
Serial number: 180323002915
Coding: 0A47F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21312970X81A955547A0
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 13 01 2018 00000428
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099667233
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H04 0005
Serial number: 0000FST0021291F00000
Coding: 101F00
204546 - Remote key 2
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 15:42:14
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418018086
Coding: 0470155011
VCID: 4B9F7C79E2B1F01700-801E
12658704 - Databus
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 18:51:50
13637426 - Databus
Reset counter: 184
Mileage: 24709 km
Date: 2020.02.29
Time: 11:37:06
Component: AirbagVW20 010 0830
Serial number: 003GCR0A0C82
Coding: 9DCCFCC0008000005000001AC24800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47974049FED9147724-8012
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34230167A12041820225
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34230168A12041820470
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 694000000000001R080C
Coding: 303337
Subsystem 4 - Part No SW: ----------- HW: 480 001 204 18
Serial number: 35700000000AB95D7C2+
Subsystem 5 - Part No SW: ----------- HW: 480 001 204 18
Serial number: 35800000000C6D4D7C2%
Subsystem 6 - Part No SW: ----------- HW: 480 400 904 18
Serial number: 3510001A32968244941T
Subsystem 7 - Part No SW: ----------- HW: 480 403 103 18
Serial number: 3520001B92968244814-
Subsystem 8 - Part No SW: ----------- HW: 480 402 003 18
Serial number: 3550002B3252D863119-
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 402 003 18
Serial number: 3560002B3252D861F130
9682162 - Multiple collision brake
B13BC F2 [137] - No function
Mileage: 24720 km
Date: 2020.03.01
Time: 19:16:59
1049093 - Databus
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 18:58:11
1049094 - Databus
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 18:58:11
1049095 - Databus
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 18:58:11
Part No SW: 8V0 953 521 KK HW: 5Q0 953 549 E
Revision: -------- Serial number: 12041804220591
Coding: 2018
VCID: 0D1BB261DC25BE27DE-8058
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 790 A HW: 8V0 920 790 A
Component: FBenRDW H16 0066
Coding: 082D18532B8800080204EC041800001000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001027
ROD: EV_DashBoardFPKAU37X.rod
VCID: 3A7129BDBD2B799FAB-806E
16777014 - Tire Pressure Monitoring Module
U0127 00 [009] - No Communications
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 18:58:13
16776973 - Databus
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 18:51:54
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 31031810520829
Coding: 03010004340860005B00802E380B00000001010000000000000000000000
ROD: EV_GatewNF.rod
VCID: 387533B583276B8F5D-806C
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20180406154716 31314
Subsystem 3 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 1755497204
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H52 7762
Serial number: HA1-00012.03.18
Coding: 0601
VCID: 4D9B72611CA5FE271E-8018
17505 - Databus
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 18:51:50
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 18000107835004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 346D07859F4F8FEF71-8060
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 F HW: 3Q0 907 566
Component: MRR1Rear H21 0610
Revision: --------
Coding: 040002
1192062 - Databus
Reset counter: 225
Mileage: 24709 km
Date: 2020.03.01
Time: 15:22:58
Control Module temperature: 24 °C
Voltage terminal 30: Measured value not available
Vehicle speed: 0.00 km/h
Terminal 15 status: Measured value not available
Voltage terminal 15: 14.10 V
Component: TSG FS 020 0041
Serial number: 200318ECJ19549
Coding: 005D1B205C00048000000002
VCID: 438F5459CAE13857F8-8016
Part No SW: 3Q0 909 144 L HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5081
Coding: 811E0000
ROD: EV_SteerAssisMQB_015.rod
19204 - Databus
Reset counter: 225
Mileage: 24720 km
Date: 2020.03.02
Time: 18:37:57
Motor status: 01
System status: Driving mode
Supply voltage: 12.00 V
Temperature: 23.0 °C
KFC: 4B
KFA: 00 04
Environmental conditions: 21
uioUdNotFilt_xdu16: 12.22 V
uAdSensI_SwitchedKl30_xdu16: 12.14 V
RP_VALCNTSAV: not activated
RP_DIAGJOB: not activated
RP_RPS: not activated
RP_STARTUP: not activated
RP_L2PLAUSI: not activated
RP_INDEXPLAUSI: not activated
RP_RUKUCNTR: not activated
RP_UNDERVOLT: not activated
RP_CNTERR: not activated
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 B HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0440
Revision: 00000001 Serial number: AUZ8ZAJ5F01H6GZ
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
VCID: 244DF7C52FAF1F6FE1-8070
Address 4B: Multifunc. Module
Interface not compatible.
Component: TSG BFS 020 0041
Serial number: 210318ECK25738
Coding: 005D13205E00048000000002
VCID: 4281515DD5FB315FF3-8016
Part No SW: 8V1 035 880 D HW: 8V1 035 880
Component: MU-P-LNS-US 054 1196
Serial number: A702C0JS007918
Coding: 017361020000000011220002041A00002F0028E4017001047E
Subsystem 1 - Part No SW: V03 959 801 GH HW: -----------
Component: NAR 2017/2018 --- 0060
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9J1Y09TKV
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BK HW: 8V0 919 614 BK
Component: ControlUnit_H H85 0855
Serial number: ALJAL130011800050025
Component: Gracenote2 --- 3012
6919 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 18:58:12
Voltage terminal 30: 13.4 V
7175 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 185
Mileage: 24720 km
Date: 2020.03.01
Time: 18:58:15
BAP-BAP_Function_ID: 02
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0273010102002001400040
VCID: 397336B1B82D7287A2-806C
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 240318ECO01219
Coding: 000C13204000048000000002
Component: TSG HBFS 020 0041
Serial number: 240318ECO01258
Address CF: Lane Chge Asst 2
End-------------------------(Elapsed Time: 05:20)--------------------------
