Hello.
Have a very strange problem with a Skoda Octavia.
Car came to me with an error on the Steering Assist .. I thought , easy peasy , callibrate the steering and all should be ok..
TO Note : Problem started when the owner changed himself the ignition lock as the old one was broken.
He changed the ignition lock and since then the problem started ... so he claims..
Can not perform adaptation on Steering Assist. I can feel the electric motor works as I get feedback (can also read torque from it) , I can read all channels and voltage and so long , but the angle is always 0.
Problem is that when I look to Measuring blocks, the steering angle will ALWAYS stay 0 degrees, no matter if I turn wheel all the way left or all the way right..
Engine started, car driving , car at idle ... no matter what.
Same 0 degree angle if seen in ABS module.
Questions :
1. Is the steering angle sensor G85 sending info directly to the Steering Assist module 44 or ALSO to the ABS block ?
Adaptation can be made only on ABS module in this car as far as I can see.
2. IF I have an error on the ABS module (in this case a front wheel bearing had let go) will it be impossible to calibrate steering assist ?
I have tried with 3 different G85 sensors (the one under the slip ring) and 2 different module 16: Steering wheel , results are always the same.
Even tried another slip ring as I was thinking some shorted wires might be the problem.
Attached full Autoscan, any ideas ?
Side Note : Owner said he did not play with any modules or coding on anything , but I can not be sure.
Questions :
Wednesday,26,February,2020,20:08:39:43630
VCDS Version: 18.9.1.0
VIN: TMBBE61Z282097230 License Plate:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72 76
VIN: TMBBE61Z282097230 Mileage: 276250km-171653miles
Address 01: Engine Labels: 03G-906-021-BMM.clb
Part No SW: 03G 906 021 JC HW: 03G 906 021 AB
Component: R4 2,0L EDC G000SG 2118
Revision: --H07--- Serial number: SKZ7Z0G4600336
Coding: 0000072
Shop #: WSC 00406 442 180685
VCID: 69D3A0F640D38C026A-803C
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0023170
Shop #: WSC 73430 790 00000
VCID: 73EFC29E121F46D2D0-8026
014 - Defective
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Part No SW: 1Z0 907 044 AC HW: 1Z0 907 044 AC
Component: ClimatronicPQ35 120 0600
Revision: 00120022 Serial number: 00000000000000
VCID: 77F7F68E06672AF2EC-8022
Revision: 00H54000 Serial number: 00000005365928
Coding: 09888F030004140040110D000000000000097F075C000000000000000000
VCID: 71E3C896680374C222-8024
Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 231107 022 0601
Coding: 00055223
Shop #: WSC 73430
Part No SW: 1K0 909 605 AA HW: 1K0 909 605 AA
Component: Q2 AIRBAG VW8 027 0900
Revision: 11027000 Serial number: 003B5D13LUGH
Coding: 0020786
VCID: 6BDFDAFE4A2F9E1218-803E
Subsystem 1 - Serial number: 6332MSME2B621747B
Subsystem 2 - Serial number: 6342MSME2A355437B
Subsystem 3 - Serial number: 6351HSME1247256C6
Subsystem 4 - Serial number: 6361HSME1245144E3
Part No SW: 1K0 953 549 BN HW: 1K0 953 549 BN
Component: J0527 051 0100
Coding: 0000042
VCID: 7F071EAE2E5712B2A4-802A
00888 - Wiper Switch for Intermittent Operation (E22)
Part No SW: 1Z0 920 812 D HW: 1Z0 920 812 D
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610056 Serial number: SKZ7Z0G4600336
Coding: 0003101
Shop #: WSC 00011 888 06946
VCID: 356B3C865CEB18E23E-8060
Part No SW: 1K0 907 530 P HW: 1K0 907 951
Component: J533__Gateway H16 0191
Revision: H16 Serial number: 2000K07A29805B
Coding: E9807F4E0002021302
Shop #: WSC 00098 204 71959
VCID: 346D0182579101EA09-8060
Component: IMMO VD1 1610
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1203
Coding: 0000246
VCID: 387535B24BF9E58A25-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Shop #: WSC 73430 000 90108
02546 - Steering Limit Stop
Mileage: 276200 km
Temperature: 11.0°C
Voltage: 14.40 V
Voltage: 14.20 V
014 - Defective
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 80801A08528300763F04850540084FD6907CA0
VCID: 030F925E42BF7652C0-8056
Subsystem 5 - Part No: 1Z0 951 171 A
Component: NeigungsSensor 009 5003
Coding: 00000000
Shop #: WSC 73430
Subsystem 6 - Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Subsystem 7 - Part No: 1Z0 951 171 A
Component: Innenraumueberw.009 5003
00323 - Vehicle Inclination Sensor (G384)
014 - Defective
Fault Status: 01101110
Reset counter: 159
Mileage: 276209 km
Time: 00:12:50
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000246
VCID: 397330B670F3FC82DA-806C
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 019 0040
Revision: 00019000 Serial number: SKZ7Z3G0084514
Coding: 0040400
VCID: 2E5913EAB9BD2B3A7F-807A
00625 - Vehicle Speed Signal
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 006 1201
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 3777368E46E7EAF22C-8062
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008030417217
Coding: 0100000100000000
VCID: 30650D9263893DCA6D-8064
02563 - Trailer; Right Tail Lamps (M61)
Fault Status: 11101010
Reset counter: 159
02565 - Trailer; Right Turn Signals (M63)
010 - Open or Short to Plus - Intermittent - MIL ON
Fault Status: 10101010
Reset counter: 199
Reset counter: 199
Mileage: 276209 km
Time: 00:12:42
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
Address 76: Park Assist Labels: 1Z0-919-283.lbl
Part No SW: 1Z0 919 283 C HW: 1Z0 919 283 C
Component: Parkhilfe 8-Kan H04 0020
Coding: 0010001
VCID: 3E7923AA69DDDBBAEF-806A
Fault Status: 00101001
Reset counter: 200
Mileage: 276026 km
Time: 20:05:44
006 - Short to Plus
Fault Status: 01100110
Reset counter: 160
Mileage: 276226 km
Time: 22:56:23
End-------------------------(Elapsed Time: 02:09)--------------------------
