Results 1 to 4 of 4
Thread: VW Polo abs coding (ESP8.2i)
    Oct 2016
    62 reg polo. full scan attached, can someone help with abs coding. lost due to flat battery. thanks
    Wednesday,04,March,2020,17:00:01:35588
    VCDS Version: 19.6.2.2 (x64)
    VIN: WVWZZZ6RZDU014395   License Plate:
    Mileage: 129440km-80430mi   Repair Order: trade centre
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 2E 44 56
    VIN: WVWZZZ6RZDU014395   Mileage: 129440km-80430miles
    Address 01: Engine        Labels: 03C-906-024-BXW.lbl
       Part No SW: 03C 906 024 CN    HW: 03C 906 024 BH
       Component:       CGGB  MM4HV   8994
       Revision: --H09---    Serial number:
       Coding: 0000071
       Shop #: WSC 31414 790 31414
       VCID: 6CD392F94C00F32F69-5120
    Readiness: 0110 0001
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0001
       Revision: --------
       VCID: 020FDC419984155FB3-8056
                        Fault Frequency: 13
                        Reset counter: 60
                        Mileage: 129445 km
                        Date: 2014.07.26
                        Time: 00:26:55
                        Hex Value: 0x0007
                        Hex Value: 0x0002
                        Hex Value: 0x3013
                        Hex Value: 0x14A8
                        Hex Value: 0x00FF
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
    03306 - Coding Not Valid
                        Reset counter: 60
                        Mileage: 129445 km
                        Date: 2014.07.26
                        Time: 00:14:46
                        Hex Value: 0x0007
                        Hex Value: 0x0002
                        Hex Value: 0x3009
                        Hex Value: 0x149A
                        Hex Value: 0x007F
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
    00493 - ESP-Sensor Unit (G419)
                        Fault Status: 01100101
                        Fault Frequency: 13
                        Reset counter: 60
                        Mileage: 129445 km
                        Date: 2014.07.26
                        Time: 00:26:55
                        Hex Value: 0x0007
                        Hex Value: 0x0002
                        Hex Value: 0x30E1
                        Hex Value: 0x20A8
                        Hex Value: 0x00FF
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
       Component: LENKW.SENSOR  H06 0060
       Serial number: 090465LH4000E7
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EF7A8B1E17C71BFD7-802A
    1140738 - Steering angle sensor
              B1168 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 100
                        Mileage: 129445 km
                        Date: 2020.03.04
                        Time: 00:29:33
                        Voltage terminal 15: 12.10 V
                        Voltage terminal 30: 12.35 V
                        Terminal 15 status: On
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
       Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
       Component: Man AC        H02 0202
       Revision: 0003SH02
       VCID: 397D7BADB0D29687A2-806C
       Part No SW: 6R0 937 087 K    HW: 6R0 937 087
       Component: BCM PQ25 H+4  H46 0254
       Revision: BF046001    Serial number: 0434 201120535
       Coding: 24B02BBF08A10000003008002D2B0CD00040410F60060000200000000000
       VCID: 4585075DCC2AE267D6-8010
       Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  008 1611
       Serial number: KU0KU025071200011785
       Coding: 18BC30
       Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  008 1611
       Serial number: KU0KU030071200010395
       Coding: 18BC30
       Subsystem 3 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
       Component: J388__TSG_HL  008 1611
       Serial number: KU0KU013071200010802
       Coding: 18BC32
       Subsystem 4 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
       Component: J389__TSG_HR  008 1611
       Serial number: KU0KU031071200011226
       Coding: 18BC32
    Address 15: Airbags (J23)       Labels:| 5K0-959-655.clb
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10Airbag027 H10 0020
       Revision: --------    Serial number: 003GX01BVNK9
       Coding: 003237
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4A9F3461ED340D1F3B-801E
       Serial number: 3575HRB404V1HAR2B8P0
       Serial number: 3585HRB405H1G0QM69OY
       Serial number: 3515RRB40064UJ4SFAA.
       Serial number: 3525RRB40044UJ4SP25X
    9437779 - Igniter for Passenger's Airbag
              B1002 53 [009] - Deactivated
                        Mileage: 129445 km
                        Date: 2020.03.04
                        Time: 00:29:37
       Part No SW: 6R0 920 960 K    HW: 6R0 920 960 K
       Component: KOMBI         H04 0605
       Coding: 440A01
       Shop #: WSC 31414 790 50316
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
       VCID: 3D756FBDACFAAAA78E-8068
       Part No SW: 6N0 909 901     HW: 6R0 937 087
       Component: GW-K-CAN TP20 H46 0254
       Revision: BF046001
       Coding: 002300
       VCID: 70EB8689A32817CF55-8024
       Component: IMMO          H04 0605
       VCID: 6ADF94E18DF4ED1F1B-803E
       Component: SG EXT.PLAYER H18 0546
       Revision: A1001003    Serial number: 7663202810
       Coding: 010100
       VCID: 2A5F54E145742D1FDB-807E
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 11250
       Shop #: WSC 31414
       VCID: 2F6945F5EA9648370C-807A
       Part No SW: 5M0 035 186 L    HW: 5M0 035 186 L
       Component: Radio RCD310  004 0119
       Revision: 01000001    Serial number: VWZ1Z2M2181369
       Coding: 01000400020001
       VCID: 3565779D9CCA72E746-8060
    End-------------------------(Elapsed Time: 02:21)--------------------------
    Aug 2016
    The Hague, NL
    Can you please give this a try? 230224E3216E00B6C42824EB84D600801700
  3. Likes Uwe, Radiosolutions liked this post
    Oct 2016
    perfect thankyou
  5. Likes Uwe liked this post
  6. #4
    Aug 2016
    The Hague, NL
    Did it work?
