You probably haven seen the same post hundreds of times, but I really need help. I purchased my second GTI an MK6 the first one was an MK4 25th anniversary. The car was involved in an accident and I've been working on it for some time now, from broken parts, to damaged harnesses. The car now runs but I have a few lights blinking on the dashboard TRACTION CONTROL, ABS AND BREAK LIGHTS. I've been doing some internet research and when I replaced the ABS PUMP I didn't know I had to save the long coding. If someone here can help me out I'd really appreciate it, I really don't want to end up at the dealer and pay a lot for the coding. I'm up for the challenge to get this fixed. Thank you in advance
2013 GTI
CBFA Engine, 6 speed manual , 2 door, no TPMS
2013 GTI
Tuesday,03,March,2020,18:05:46:37216
VCDS Version: 19.6.2.2 HEX-V2 CB: 0.4508.4
VIN: WVWED7AJ7DW046339 License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56
VIN: WVWED7AJ7DW046339 Mileage: 13710km-8518miles
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AT HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0020
Revision: E3H26--- Serial number:
Coding: 0403010818070160
VCID: 78A9EE704EDA5DC7F15-802C
Readiness: 1110 0101
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
VCID: 7DA7FF646DF878EFA23-8028
Reset counter: 83
Mileage: 13713 km
Date: 2020.02.27
Time: 01:46:21
Count: 3
Count: 2
Count: 29184
Count: 320
Count: 50944
Count: 512
Reset counter: 83
Date: 2020.02.27
Time: 01:46:22
Count: 7
Count: 2
Count: 29184
Count: 195
Count: 50688
Count: 256
Fault Status: 01100101
Reset counter: 83
Mileage: 13713 km
Date: 2020.02.27
Time: 01:46:21
Count: 3
Count: 2
Count: 29184
Count: 295
Count: 50944
Count: 512
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010002002
VCID: 7BA3F17C736C76DF9C7-802E
Part No SW: 1K0 937 086 T HW: 1K0 937 086 T
Component: BCM PQ35 M 111 0709
Revision: AB111709
Coding: 6F180A1A90272A04008800C170000D4448852086434D8D20E48420240040
VCID: 41DF43945180DC0F86B-8014
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 83
Mileage: 13713 km
Date: 2020.02.27
Time: 01:46:22
Voltage: 14.10 V
Term 50 On
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 83
Mileage: 13713 km
Date: 2020.02.27
Time: 01:46:21
Voltage: 14.10 V
Term 50 On
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R006XCK
Coding: 00004733
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C21326036E2B1E7D5D-8068
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00004F3N00
Serial number: 3572MSME4F321570ZZZU
Serial number: 3582MSME6E67346FZZZC
Serial number: 3512QSME50021812ZZZA
Serial number: 3522QSME5E35181BZZZ/
Component: F.Sens.Fahr --- ----
Serial number: 35527SME7371012EZZZB
Component: F.Sens.Beif --- ----
Serial number: 35627SME2C56012EZZZJ
Mileage: 13713 km
Date: 2020.02.27
Time: 01:46:26
9442075 - Driver's Belt Force Limiter Igniter
B1013 1B [137] - Resistance Too High
Mileage: 13713 km
Date: 2020.02.27
Time: 01:46:26
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90849LG1000EB
Coding: 108A140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 72BDDC5824263797CF1-8026
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0033
Serial number: 0145624
Coding: 820000
Part No SW: 5K6 920 973 C HW: 5K6 920 973 C
Component: KOMBI H05 0705
Coding: 270E01
Shop #: WSC 12345 123 61029
VCID: 372B2D4C0FC492BF38F-8062
Part No SW: 7N0 907 530 R HW: 7N0 907 530 H
Component: J533 Gateway H42 1632
Revision: H42 Serial number: 250612F1002144
Coding: 350000
VCID: 3FDB456C2774AAFFF0F-806A
Component: IMMO H05 0705
VCID: 6A8DC4380CF6FF57771-803E
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662979137
Coding: 020100
VCID: 2A0D0438CCF63F57B71-807E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H53 0319
Serial number: VWZAZ2M4251543
Coding: 04000401040005000000100A
ROD: EV_RNS315NARV2UDS.rod
VCID: 2517F704A568102F9A3-8070
Component: NAR_V3_(0037) 0037
1048669 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 83
Mileage: 13713 km
Date: 2020.02.27
Time: 01:46:25
Part No SW: 5K0 959 701 H HW: 5K0 959 701 H
Component: Tuer-SG 009 2103
Coding: 0001076
VCID: 372B2D4C034492BF38F-8062
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 74 3305
Revision: 00H22000
000 - - - MIL ON
Fault Status: 11100000
Mileage: 13713 km
Date: 2020.02.27
Time: 01:46:27
Battery Volts: 14.2 V
DU
Temperature: 31.0°C
Count: 8
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 5K0 959 702 H HW: 5K0 959 702 H
Coding: 0001076
VCID: 38292E700E5A9DC7315-806C
Component: AFS-Steuergeraet 0148
Coding: 1446940
VCID: 34311A40123279A71DD-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0005
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0005
Coding: 00000022
End----------(Elapsed Time: 01:07, VBatt start/end: 14.4V/14.3V)-----------
