Results 1 to 2 of 2
Thread: Audi A3 8V US Side Marker Lights Coding?
    Mar 2019
    London, United Kingdom
    I am looking for US Side Marker Lights coding for Audi A3 8V. Please Help thanks
    Wednesday,21,August,2019,22:20:14:42869
    VIN: WAUZZZ8V8JA058657   License Plate:
    Chassis Type: 8V-AU37 (3Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F BB BC
    VIN: WAUZZZ8V8JA058657   Mileage: 4088km-2540miles
    Address 01: Engine (J623-CHZD)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04C 906 026 AB    HW: 04C 907 309 AE
       Component: R3 1.0l TFS   H26 3494
       Revision: W1H26---
       Coding: 02250032232401082000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM10TFS01104C906026AB 002006
       ROD: EV_ECM10TFS_VW37.rod
       VCID: 619E542621C3DD5FA57-8034
       CAN Converter 01:
    18951 - Leak in Air Intake System
              P2279 00 [101] - -
                        Mileage: 4075 km
                        Date: 2019.08.21
                        Time: 06:51:33
                        Engine speed: 1939.00 /min
                        Normed load value: 40.0 %
                        Vehicle speed: 45 km/h
                        Coolant temperature: 93 °C
                        Intake air temperature: 38 °C
                        Voltage terminal 30: 12.863 V
                        Charge air pressure: actual value: 1086.88 hPa
                        Charge air pressure specified value: 1692.73 hPa
                        Intake manifold pressure raw value: 1084.92 hPa
                        Charge pressure actuator: specified position: 140.00 %
                        Bypass valve f high press turboch turbine inlet: actual value: 39.78 %
                        Intake camshaft bank1 active operating mode-Bits 0-7: 0
                        Fuel level: 4.00 l
    18948 - Boost Pressure Regulation
              P0299 00 [101] - Control Range Not Reached
                        Mileage: 4015 km
                        Date: 2019.08.21
                        Time: 04:48:12
                        Engine speed: 2600.50 /min
                        Normed load value: 41.2 %
                        Vehicle speed: 118 km/h
                        Coolant temperature: 95 °C
                        Intake air temperature: 36 °C
                        Voltage terminal 30: 14.277 V
                        Charge air pressure: actual value: 1092.34 hPa
                        Charge air pressure specified value: 1647.42 hPa
                        Intake manifold pressure raw value: 1088.67 hPa
                        Bypass valve f high press turboch turbine inlet: actual value: 39.48 %
                        Fuel level: 8.00 l
    16434 - Charge Pressure Control Actuator
              P334B 00 [101] - Mechanical Malfunction
                        Mileage: 4088 km
                        Date: 2019.08.21
                        Time: 07:09:58
                        Engine speed: 1074.00 /min
                        Normed load value: 39.6 %
                        Coolant temperature: 96 °C
                        Intake air temperature: 43 °C
                        Voltage terminal 30: 13.028 V
                        Bypass valve f high press turboch turbine inlet: actual value: 69.23 %
                        Charge pressure actuator: adaptation for lower stop: 2650.8 mV
                        Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 0
                        Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 55
                        Bypass valve for high press turbocharger turbine inlet: status-Bits 0-7: 71
                        Bypass valve for high press turboch turbine inlet: uncond volt: 1793.4 mV
    16433 - Charge Pressure Control Actuator
              P334B 00 [172] - Mechanical Malfunction
                        Fault Frequency: 10
                        Mileage: 4002 km
                        Date: 2019.08.19
                        Time: 00:43:13
                        Engine speed: 855.00 /min
                        Normed load value: 20.4 %
                        Coolant temperature: 84 °C
                        Intake air temperature: 51 °C
                        Voltage terminal 30: 13.947 V
                        Charge pressure actuator: specified position: 22.89 %
                        Bypass valve f high press turboch turbine inlet: actual value: 27.27 %
                        Bypass valve for high press turboch turbine inlet: uncond volt: 622.4 mV
       Part No SW: 0CW 300 040 S    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1004
       Revision: 00005008    Serial number: CU501710157085
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 44D0BDB29E11A877AE1-8010
       Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
       Component: ESC           H62 0643
       Revision: 00000000    Serial number: 62867000002511
       Coding: 12F18AA224252274897D0E0560CA244851244491700624720221F0748208420000000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
       VCID: 78A8194292593C97F29-802C
    Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
       Part No SW: 8V0 820 047 F    HW: 8V0 820 047 F
       Component: AC Manuell el H03 0130
       Revision: 20002000    Serial number: 00000000359535
       Coding: 03100003000000001000000000000000
       ASAM Dataset: EV_AirCondiFrontManAU37X 008018
       ROD: EV_AirCondiFrontManAU37X.rod
       VCID: 392EDC46E9D3E59FCD7-806C
       Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
       Component: BCM MQBAB H   H36 0253
       Serial number: 01001729402934
       ROD: EV_BCMBOSCH_018.rod
       VCID: 094E6C86F9B3351F9D7-805C
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 170909  043 0580
       Serial number:         170915193255
       Coding: 0A47F7
       Subsystem 2 - Part No SW: 8U0 955 559 D    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
       Component: G397_RLS  H06 0004
       Serial number: 50166208
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06 0032
       Serial number: 01 06 2017  00000011
       Serial number: 000000000ZY172630G66
       Serial number: 00000000000071046474
       Part No SW: 5QA 919 283 B    HW: 5QA 919 283
       Component: PDC 4 KanalH07 0044
       Serial number: 000308419617285
       Coding: 0600040011
       ASAM Dataset: EV_EPHVA14AU3700000 009033
       ROD: EV_EPHVA14AU3700000_009.rod
       VCID: 49CEAC86B933751F5D7-801C
       Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
       Serial number: 003VWR3HRYFH
       Coding: 98CCC0000C0000005C5400CA00C8000000C5
       ROD: EV_AirbaVW20SMEVW37X.rod
       Subsystem 1 - Part No SW: -----------    HW: 480 002 010 17
       Serial number: 357000000008C921E82S
       Subsystem 2 - Part No SW: -----------    HW: 480 001 202 18
       Serial number: 35800000000747DC6B2Z
       Subsystem 3 - Part No SW: -----------    HW: 480 402 310 17
       Serial number: 3510001B527E0435C6D6
       Subsystem 4 - Part No SW: -----------    HW: 480 402 310 17
       Serial number: 3520001B327E0431836U
       Subsystem 5 - Part No SW: -----------    HW: 480 402 709 17
       Serial number: 3550002A525629A2023S
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 410 17
       Component: PedP_Sensor_D  000 6149
       Serial number: 2280001AF275C8A12368
       Subsystem 7 - Part No SW: -----------    HW: 480 402 410 17
       Component: PedP_Sensor_P  000 6149
       Serial number: 2290001B3275C8A5C1CG
       Subsystem 8 - Part No SW: -----------    HW: 480 002 409 17
       Serial number: I0M00000000C2744D624
       Subsystem 9 - Part No SW: -----------    HW: 480 002 409 17
       Serial number: I0N00000000C0744D623
                        Mileage: 4002 km
                        Date: 2019.08.19
                        Time: 00:38:18
              B1007 1B [137] - Resistance Too High
                        Mileage: 4002 km
                        Date: 2019.08.19
                        Time: 00:38:18
       Part No SW: 8V0 953 521 HB    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 23101704401385
       Coding: 2418
       VCID: 015E74A6C1837D5FC57-8054
       Part No SW: 8V0 920 973 F    HW: 8V0 920 973 F
       Component: KOMBI         H01 0311
       Coding: 27A40A082B8006000100A8001000000000000000
       VCID: 42DCBBAA8405A6479CD-8016
       Part No SW: 3Q0 907 530 F    HW: 3Q0 907 530 B
       Component: GW MQB Mid    517 5304
       Serial number: 12101710804660
       Coding: 030100043F0857005B000048100B00000001010000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 323CEB6A34A516C70CD-8066
       Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
       Component: J453 MFL  H04 0003
       Serial number: 20171013002821 20066
       Serial number: 75886000001710170AB4
       Serial number: 021017EJ211749
       Coding: 00108A204001040000001002
       VCID: 43D2BEAE9B1FAF4F97B-8016
       Component: EPS_MQB_ZFLS  128 1072
       Coding: 0107
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 45D6A0B6952B917FB9F-8010
       Serial number: 300917EIT20449
       Coding: 001082204001040000001002
       Part No SW: 81A 035 188 E    HW: 81A 035 188
       Component: MU-HS-ND-EU   050 0213
       Coding: 01730300FF00000011111101000A00002F002AC601F001000E
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP.rod
       VCID: 2808090202796C17A29-807C
       Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
       Component: DU High  H49 0014
       Serial number: AUZ8Z9H1Y066VJ
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 BE    HW: 8V0 919 614 BE
       Component: ControlUnit_B  H50 0103
       Serial number: ALJAL129081700051123
       Serial number: 041017EJ32545C
       Coding: 000082204001040000001002
       Serial number: 041017EJ325534
    End----------(Elapsed Time: 01:12, VBatt start/end: 12.2V/12.2V)-----------
    Dec 2016
    DE
    Aren’t the side markers hardwired to the license plate lights? I am pretty sure I’ve read something like that here a while ago.
