Results 1 to 7 of 7
Thread: 2016 Audi Q7 4M rear brake pads replacement
    Mar 2020
    I got earlier warning for rear pads wear limit and I tried Sunday change brake pads for Q7. Problem is that parking brake module do not response. I maked everything according video instructions but parking brake module do not response. In use, the parking brake operates normally.
    I check auto scan results yesterday and noticed that there is no parking brake module in the auto scan results but you can find parking brake module in the chassis tab. Maybe that is the reason why the parking brake module won't response?
    I tried search find info yesterday in the forum and I found following instructions, do I have to make brake pad replacement work according these instructions? http://wiki.ross-tech.com/wiki/index...#Basic_Setting
    Sunday,01,March,2020,16:17:43:18659
    VIN: WAUZZZ4M6GD004441   License Plate:
    Chassis Type: 4M-AU73 (4M2)
    Scan: 01 02 03 06 08 09 0E 13 15 16 17 18 19 28 29 36 39 3C 42 44
              46 47 50 52 5F 69 6C 6D 74 81 82 84 8B A5 AC BB BC CB CF D6
              D7
    VIN: WAUZZZ4M6GD004441   Mileage: 137441km-85401miles
    50-Seat Adj. 3rd row -- Status: OK 0000
    84-Night Vision -- Status: Malfunction 0010
    BB-Door Rear Drv -- Status: Malfunction 0010
    CB-Rear Axle Steering -- Status: OK 0000
    Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
       Part No SW: 4M0 907 401     HW: 059 907 309 B
       Component: 3.0TDI EDC17  H45 0009
       Revision: 91H45---
       Coding: 2A2A403A057E050335380000000000000000000000000000
       Shop #: WSC 44606 002 1048576
       ASAM Dataset: EV_ECM30TDI0114M0907401 001013
       ROD: EV_ECM30TDI0114M0907401.rod
       VCID: 6695B12C38E34307539-8032
    Address 02: Auto Trans        Labels:| 0BK-927-156.clb
       Part No SW: 4M0 927 158 J    HW: 0D5 927 156 H
       Component: 0D5  30TDIRdW H03 1013
       Revision: --H03---
       Coding: 100000
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 3B23305813E12EEFDC7-806E
    Address 03: ABS Brakes (J104)       Labels: 4M0-907-379-PRE-V1.clb
       Part No SW: 4M0 907 379 K    HW: 4M0 907 379 K
       Component: ESP9 Premium  H08 0521
       Coding: 249830B230A20A9AD6A25895187E56AEE6A6DA240C0C506B1A186A7567655B
       Shop #: WSC 30445 001 1048576
       ASAM Dataset: EV_ESP9BOSCHAU736 011006
       ROD: EV_ESP9BOSCHAU736_AU73.rod
       VCID: 3FDB444807F932CFF0F-806A
       Part No SW: 4M0 959 760 E    HW: 4M0 959 760 E
       Component: MEM-BFS       008 0014
       Serial number: 00000145847085
       Coding: 000010000000B0410000210101010000110000313100000000000000000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007
       ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
       VCID: 3A2D355C1CDB17E7C71-806E
       Part No SW: 4M0 820 043 K    HW: 4M0 820 043 K
       Component: Klima Zone 4  H52 0060
       Coding: 6618401C5548411102620180800000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
       ROD: EV_AirCondiFrontBHTCAU736.rod
       VCID: 2D070E00DD95B05F523-8078
       Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000000332492
       Component: AQ_Hum_Sensor  H01 0003
       Serial number: A618C9A7000000000001
       Part No SW: 8W0 907 063 G    HW: 8W0 907 063 G
       Component: BCM1 MLBevo   H12 0215
       Coding: 07501943C12900CD010D8715583F04F9130331019000000000000000E20016810A4502AB32B706
       ASAM Dataset: EV_BCM1BOSCHAU736 014003
       ROD: EV_BCM1BOSCHAU736_014.rod
       Subsystem 1 - Part No SW: 4M1 955 119 A    HW: 4H2 955 119 C  Labels: 1KX-955-119.CLB
       Component: WWS536 150326  042 0792
       Serial number:         150415193120
       Coding: 1BC7F7
       Serial number: 20297724
       Coding: 02006E
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 R    HW: 4M0 941 531 R
       Component: E1 - LDS  H05 0007
       Serial number: 16 05 2015  00023256
       Subsystem 4 - Part No SW: 4M0 857 511 A    HW: 4M0 857 511 A
       Component: Y7_Innenspieg  H08 0002
       Serial number: GX1CE113051511520584
       Coding: 030000
       Interior Light Module:
       Subsystem 5 - Part No SW: 4M0 947 135 BE    HW: 4M0 947 135
       Component: J528-Dachele  H13 0080
       Serial number: Q00011711
       Electrically Adjustable Steering Column:
       Subsystem 6 - Part No SW: 4M0 907 705     HW: 4M0 907 705
       Component: J866-EVLS-SG  H03 0040
       Serial number: WA120302000011889155
       Coding: 020100
       Subsystem 7 - Part No SW: 4M0 925 301 B    HW: 4M0 925 301 B
       Component: SL-Q7NF/AU736  H09 0006
       Serial number: 00000000000000004420
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4M1 035 108 A    HW: 4M1 035 108
       Component: DVD Changer   H30 0100
       ASAM Dataset: EV_DVDCALPI 001010
       ROD: EV_DVDCALPI.rod
       VCID: 2411EB248E5F71178DD-8070
    Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
       Part No SW: 4M0 907 561 C    HW: 4M0 907 561
       Component: LRR4          H08 0160
       Coding: 3477FFFB78FFEC08949880A4
       ASAM Dataset: EV_ACCBOSCHAU736 001016
       ROD: EV_ACCBOSCHAU736.rod
       VCID: 30391774CAA7DDB7795-8064
       Part No SW: 4M0 959 655     HW: 4M0 959 655
       Component: Airbag10.44   H50 0084
       Serial number: 003L100043SH
       Coding: AAFCF0D80C80000098F650F3C00C00000000
       Shop #: WSC 03536 002 1048576
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
       VCID: 78A9EF546257C5F7F15-802C
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 4M0857705D0136P00411
       Coding: 88001B
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 4M0857706D0136P00510
       Coding: 88001B
       Subsystem 3 - Part No SW: -----------    HW: 442 061 105 15
       Serial number: 3577Y00C9193B8533292
       Subsystem 4 - Part No SW: -----------    HW: 442 061 105 15
       Serial number: 3587Y00C3193B85253E4
       Subsystem 5 - Part No SW: -----------    HW: 442 0B2 005 15
       Serial number: 35177002A2934409071V
       Subsystem 6 - Part No SW: -----------    HW: 442 0B0 905 15
       Serial number: 35277009D1A482445198
       Subsystem 7 - Part No SW: -----------    HW: 442 0C1 205 15
       Serial number: 3557500B11984756E28F
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 442 0C1 205 15
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500AF1984755114A
       Pedestrian Protection Center:
       Subsystem 9 - Part No SW: -----------    HW: 442 0C1 205 15
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500B11984752732Y
       Subsystem 10 - Part No SW: -----------    HW: 442 420 705 15
       Component: PedPSensor_D2  21E 0887
       Serial number: I0M8U00B9193B853D3F/
       Subsystem 11 - Part No SW: -----------    HW: 442 420 705 15
       Component: PedPSensor_P2  21E 0887
       Serial number: I0N8U00B9193B853306J
       Central Sensor XY:
       Subsystem 12 - Part No SW: -----------    HW: 410 201 505 15
       Component: CentrSensorXY  1C8 0108
       Serial number: I0O7800AB165692190F3
       Part No SW: 4M0 907 129 JE    HW: 4M0 907 129 JE
       Component: Lenks.Modul   H11 0008
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 7CA1F344566FE9D795D-8028
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 4M0 920 790     HW: 4M0 920 790
       Component: FBenRDW       H12 0280
       Coding: 040400E07C98000800A369603000600000000000
       ASAM Dataset: EV_DashBoardAU736 001020
       VCID: 6C81C304260F795705D-8038
    Address 18: Aux. Heat (J364)       Labels:* None
       Part No SW: 4M0 265 105 E    HW: 4M0 265 105 E
       Component: HSG           H09 0060
       Coding: 0D0F01
       ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
       ROD: EV_AuxilParkHeateEBEAU736.rod
       VCID: 290FFA10E97DAC7FBEB-807C
       Part No SW: 4M2 907 468 A    HW: 4M2 907 468 A
       Component: Gateway       H13 4079
       Revision: 3C010050    Serial number: 5043C006B15418
       Coding: 0301000100000F407F070000005900325C9200071C0000000100000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002040
       ROD: EV_GatewCONTIAU736_002_AU73.rod
       VCID: 3635216C28C3F387239-8062
       Subsystem 1 - Part No SW: 4M0 951 523 A    HW: 4M0 951 523 A
       Component: J453 MFL  H06 0002
       Serial number: 20150513033621 RD340
       Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
       Component: J367-BDMHella  H10 9041
       Serial number: 3845706503
    16646149 - predictive route data
              B1630 02 [008] - Signal Failure
                        Reset counter: 148
                        Mileage: 137199 km
                        Date: 2020.02.21
                        Time: 12:55:44
    Address 28: HVAC, Rear (E265)       Labels:* None
       Part No SW: 4M0 919 158 D    HW: 4M0 919 158 D
       Component: Klima Zone 2  H52 0060
       Coding: 000040000000000100820080000000000000000000000000000000000000
       ASAM Dataset: EV_AirCondiFondBHTCAU736 001013
       ROD: EV_AirCondiFondBHTCAU736.rod
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 B    HW: 4M0 907 397 B
       Component: LCM_MLBevoH05 0011
       ASAM Dataset: EV_LCMLeftHELLAAU736 001006
       Component: MEM-FS        008 0014
       Serial number: 00000145846731
       ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
       ASAM Dataset: EV_LCMRightHELLAAU736 001006
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 4M0 907 566     HW: 4M0 907 566
       Component: MRR1Rear      H13 0160
       Revision: --------
       Coding: 1EE002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001015
       ROD: EV_RearRadarS1BoschAU736.rod
       VCID: 72BDDD7C042BAFA7CF1-8026
    1311234 - Control Module for Lane-Change Assist
              C1114 F3 [008] - Limited Visibility
                        Fault Frequency: 13
                        Reset counter: 151
                        Mileage: 134996 km
                        Date: 2020.01.08
                        Time: 12:07:33
                        Control Module temperature: 22 °C
                        Voltage terminal 30: 14.80 V
                        Vehicle speed: 76.59 km/h
                        Terminal 15 status: OFF
                        Voltage terminal 15: Measured value not available
       Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
       Component: TSG FS        009 0052
       Serial number: 0000150302999
       Coding: 005F9B0050000080000130B0
       VCID: 42DD4DBC740B5F279F1-8016
       Part No SW: 4M0 909 144 G    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H17 0004
       Serial number: 0000812549
       Coding: B0150101000101
       ASAM Dataset: EV_EPSVWBSAU736 008020
       ROD: EV_EPSVWBSAU736_008.rod
       VCID: 333318783BB1E6AF047-8066
       Part No SW: 8W0 907 064 CD    HW: 4M0 907 064 D
       Component: BCM2 MLBevo   015 0344
       Coding: 01341E00000000E0630980000E00580203004000004F02502F0400000504803F001F0001000000
       Shop #: WSC 56464 001 1048576
       ASAM Dataset: EV_BCM2HellaAU736 012013
       ROD: EV_BCM2HellaAU736_012_AU49.rod
       VCID: 005987B43A878D37C95-8054
    65617 - Local Data Bus 3
              U10DB 00 [009] - Electrical Malfunction
              [Local data bus 3: electrical fault]
                        Reset counter: 113
                        Mileage: 137405 km
                        Date: 2020.02.26
                        Time: 08:23:22
                        Supply voltages-Supply voltage: Terminal 30: 11.209 V
                        Supply voltages-Supply voltage Terminal 30 - 2: 11.128 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 11.087 V
                        general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
                        general_additional_freeze_frame-coprocessor_spi_status: 00000000
                        general_additional_freeze_frame-dataflash_status: 00000000
                        general_additional_freeze_frame-interior_temperature: -50.0 °C
                        general_additional_freeze_frame-Operating_Status: 00000000 00000000
                        general_additional_freeze_frame-production_mode: not active
                        general_additional_freeze_frame-reset_cause: 00000000
                        general_additional_freeze_frame-Reset_counter: 0
                        general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                        general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                        general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                        general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 16 04 F8
                        general_additional_freeze_frame-Transport_Mode: not active
                        general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                        can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
    65758 - Voltage Supply for Control Module for Rear Lid Opening
              B1690 11 [009] - Short to Ground
                        Fault Frequency: 7
                        Reset counter: 113
                        Mileage: 134953 km
                        Date: 2020.01.07
                        Time: 13:52:46
                        Supply voltages-Supply voltage: Terminal 30: 12.120 V
                        Supply voltages-Supply voltage Terminal 30 - 2: 12.038 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 11.984 V
                        general_additional_freeze_frame-terminal_control_intern_status: 1B 01 0A 10 04 E0
       Part No SW: 4M0 035 223 A    HW: 4M0 035 223
       Component: MIB2_amp_PD   H02 0420
       Serial number: 00000000002975
       Coding: 01350608008AF53AAF0000010000
       ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
       ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod
       VCID: 211FE230914D643FE6B-8074
    Address 50: Seat Adj. 3rd row (J857)       Labels:* None
       Part No SW: 4M0 959 760 G    HW: 4M0 959 760 G
       Component: MEM-SR3       008 0014
       Serial number: 00000150158670
       Coding: FF001020F1000000000F000000000900000021210900000000000000440000
       ASAM Dataset: EV_SCM3rdRowCONTIAU736 005007
       ROD: EV_SCM3rdRowCONTIAU736.rod
       VCID: 3C21334416EF29D7D5D-8068
       Part No SW: 4M0 959 792 D    HW: 4M0 959 792 C
       Component: TSG BFS       009 0036
       Serial number: 0000150306512
       Coding: 005F9B005C000480000130B0
       VCID: 3E25394C00F33BC7FB9-806A
       Part No SW: 4M0 035 035 R    HW: 4M0 035 035
       Component: MU-P-LND-EU   041 0358
       Serial number: A270E0FB004410
       Coding: 013706010000000013111102000A00332F001BE5017001009E
       Subsystem 1 - Part No SW: V03 959 801 FA    HW: -----------
       Component: ECE 2016  --- 0134
       Subsystem 2 - Part No SW: 4M0 919 605     HW: 4M0 919 605
       Component: AU536_DU_HIGH  H43 0008
       Serial number: AUZ8Z9FJ400A4Y
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 4M0 919 615 D    HW: 4M0 919 615 D
       Component: ControlUnit_P  H14 0165
       Serial number: 15051500000000000063
       Component: Gracenote2  --- 1010
    3086 - Antenna for Telephone Mount
              B1564 01 [008] - Electrical Failure
                        Fault Frequency: 12
                        Reset counter: 153
                        Mileage: 134987 km
                        Date: 2020.01.08
                        Time: 12:00:41
                        Voltage terminal 30: 14.8 V
                        Status of telephone-Antenna diagnostic: OK
                        Status of telephone-Telephone baseplate diagnostic: not connected
                        Status of telephone-Handset in handset holder (cradle): selected
                        Status of telephone-Handset holder (cradle): connected
       Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
       Component: Anhaenger     H18 0208
       Revision: 9A001002    Serial number: 0368188938
       Coding: 0110000202010000
       Trailer Articulation Angle Sensor:
       Subsystem 1 - Part No SW: 4M0 907 811     HW: 4M0 907 811
       Component: G820 KNWINSEN  H18 0019
       Serial number: 6082
    Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
       Part No SW: 4M0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0130
       Coding: 0237060113002025000044
       ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
       ROD: EV_CamSysRVRVCPANAMLBEv_004_AU73.rod
       Part No SW: 4M0 959 107     HW: 4M0 959 107
       Component: HDSG-Modul    H12 0143
       Revision: --------    Serial number: 30009644700000
       Coding: 00F0
       ASAM Dataset: EV_DeckLidCONTIAU736 001010
       ROD: EV_DeckLidCONTIAU736_AU73.rod
       VCID: 70B9D7740A279DB7395-8024
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 4M0 907 777     HW: 4M0 907 777
       Component: Fahrwerk-SG   H10 0102
       Serial number: 2205150176
       Coding: B8505050F8
       ASAM Dataset: EV_ChassContrContiAU736 002013
       ROD: EV_ChassContrContiAU736.rod
       VCID: 76B5E16C6843B387E39-8022
       Air Suspension Compressor:
       Subsystem 1 - Part No SW: 4M0 907 589 B    HW: 4M0 907 589 B
       Component: V66LFKompOLV  H06 0012
       Serial number: 00000000004130009833
       Coding: 303030
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 4M1 713 041 D    HW: 4M1 713 041 D
       Component: GSM-LL        H07 0066
       Revision: 0L0D5012    Serial number: 20150422000426
       ASAM Dataset: EV_GSMWaehlZFAU736 001013
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 2615F12CF8638307939-8072
       Part No SW: 4M0 919 617     HW: 4M0 919 617
       Component: HeadUpDisplay H25 1507
       Coding: 5F00C0
       ASAM Dataset: EV_HudNSEIKAU736 001012
       ROD: EV_HudNSEIKAU736.rod
    Address 84: Night Vision (J853)       Labels:* Redir Fail!
       Part No SW: 4M0 907 547 A    HW: 4M0 907 547
       Component: NV-ECU-Gen3   H08 0025
       Serial number: 629228400201520
       Coding: 200111
       ASAM Dataset: EV_NightVisioG3AUTOLAU736 001001
       ROD: EV_NightVisioG3AUTOLAU736_AU73.rod
       VCID: 323D1D7CC4ABEFA70F1-8066
       Camera For Night Vision System:
       Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
       Component: NV-CAM-Gen3  H03 0006
       Serial number: 623466500F1506300306
    16389 - predictive route data
                        Reset counter: 128
                        Mileage: 135027 km
                        Date: 2020.01.08
                        Time: 16:24:04
    Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
       Part No SW: 4M0 907 541 C    HW: 4M0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU736 001016
       ROD: EV_ACC2BOSCHAU49X_001.rod
       VCID: 2E05090CD093CB476B9-807A
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 4M0 907 217 D    HW: 4M0 907 217 B
       Component: BVS           H11 0042
       Coding: 0407030600000404032023B7CD0000B4B0F0C020F280
       ROD: EV_BVSMLBevKOSTAAU736_AU73.rod
       VCID: 2F3B1408D799C24F60F-807A
    1123600 - predictive route data
                        Reset counter: 148
                        Mileage: 137199 km
                        Date: 2020.02.21
                        Time: 12:57:27
                        Control Module temperature: 11 °C
                        Voltage terminal 15: 14.90 V
    1123601 - predictive route data
                        Reset counter: 148
                        Mileage: 135222 km
                        Date: 2020.01.11
                        Time: 20:03:13
                        Control Module temperature: 15 °C
                        Voltage terminal 15: 15.00 V
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355     HW: 4M0 907 355
       Component: SCR-Stg-G3H10 0003
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736_AU49.rod
       VCID: 6E85C90C10138B472B9-803A
       Part No SW: 4M0 959 795 D    HW: 4M0 959 795 C
       Component: TSG HFS       009 0036
       Serial number: 0000150323548
       Coding: 004F990000000480000030A0
       VCID: 41DF42B0710D443F86B-8014
    196663 - Motor for Window Regulator
              B1487 4B [008] - Over temperature
                        Reset counter: 122
                        Mileage: 136142 km
                        Date: 2020.01.26
                        Time: 19:33:13
       Component: TSG HBFS      009 0036
       Serial number: 0000150322329
    Address CB: Rear Axle Steering (J1019)       Labels:* None
       Part No SW: 4M0 909 145 G    HW: 4M0 909 145 D
       Component: HAL_MLBevoH07 0607
       Revision: --------    Serial number: CCC_007_D_07_03
       Coding: 00852C
       ASAM Dataset: EV_RearAxleSteerZFAU736 005010
       ROD: EV_RearAxleSteerZFAU736_005_AU73.rod
       VCID: 34311B643EBFE1971DD-8060
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 4M0 907 590     HW: 4M0 907 590
       Component: MRR1Rear      H13 0161
       Revision: --------
       Coding: 1EE002
       ASAM Dataset: EV_RearRadarS2BoschAU736 001015
       ROD: EV_RearRadarS2BoschAU736.rod
       VCID: 6FBBD4081719824F20F-803A
    Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-592.clb
       Part No SW: 7PP 941 592 CA    HW: 7PP 941 592 C
       Component: LED1L         H09 2002
       VCID: 196FCAD0B91D3CFF2EB-804C
    Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-592.clb
       Component: LED1R         H09 2002
    End----(Elapsed Time: 02:36, VBatt start/end: 11.9V/11.6V. VIgn 11.6V)-----
    Quote Originally Posted by MattiHarju View Post
    Yes, I think that should be correct for this model also.
  3. Likes Uwe, Dana liked this post
    Jan 2020
    Germany (Auto-Intern)
    Hi, if you only want to change the brake pads, not the handbrake pads or the brake discs, then definitely do not use vcds to remove the brake. It leads to the fact that you have to carry out a basic setting that is very extensive and costs nerves. The handbrake shoes act as a drum brake in the brake disc from the inside. The brake pads that you can see from the outside are pushed back like a brake caliper at the front.
    Mar 2020
    Quote Originally Posted by ai_Ingo View Post
    Hi, I think you mean older Q7 (4L)? New one (4M) do not have separate parking brake shoes.
  6. Likes Dana liked this post
    Jan 2020
    Thank you, you're absolutely right. I just checked that. I really still thought about the old model.
  8. Likes Uwe, Dana liked this post
  9. #6
    Administrator Andy's Avatar
    Sector 7G
    You would use the instructions you linked, going into ABS Brakes.
  10. Likes Uwe, Dana liked this post
  11. #7
    Mar 2020
    Andy, thank you for the help.
    These istructions works: http://wiki.ross-tech.com/wiki/index...#Basic_Setting
