HI everyone, looking for a help with my vw jetta abs long coding. posting the log here. coding was lost when the cluster was removed. thank you in advance
Monday,02,March,2020,12:05:45:50448
VCDS Version: 19.6.2.2 HEX-NET CB: 0.4508.4
VIN: 3VWDZ7AJ4BM082996 License Plate: VW.JETTA.AM
Mileage: 164750km-102370mi Repair Order: vw
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 56 77
VIN: 3VWDZ7AJ4BM082996 Mileage: 164750km-102370miles
17-Instruments -- Status: Malfunction 1010
25-Immobilizer -- Status: Malfunction 1010
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 G HW: 07K 906 055
Component: 2,5l R5/4V G01 8757
Revision: T4H04--- Serial number:
Coding: 0000075
Shop #: WSC 06718 004 1048576
VCID: 3228E48FADEA71DF63-8066
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 000 - - Intermittent
Mileage: 164755 km
Date: 2014.07.22
Time: 00:05:14
RPM: 866 /min
Load: 31.8 %
Temperature: 24.0°C
Temperature: 27.0°C
Absolute Pres.: 990.0 mbar
049493 - No Communication with Instrument Cluster
U0155 - 000 - - Intermittent
Mileage: 164755 km
Date: 2014.07.22
Time: 00:10:08
Temperature: 34.0°C
Temperature: 28.0°C
Readiness: 1110 1101
Part No SW: 09G 927 750 LF HW: 09G 927 750 LF
Component: AQ 250 6F 1741
Revision: 00H90000 Serial number:
Coding: 0000840
VCID: 004C7E4753C6134FA5-8054
7 Faults Found:
01312 - Powertrain Data Bus
Fault Status: 00101101
Reset counter: 125
Reset counter: 125
Reset counter: 125
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
Reset counter: 125
Reset counter: 125
Reset counter: 125
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
VCID: 7BB609ABFA207097F0-802E
10 Faults Found:
Fault Status: 00100001
Reset counter: 22
Mileage: 263942 km
Date: 2002.04.02
Time: 16:40:10
Count: 259
Count: 158
Count: 5632
Count: 129
Count: 320
Count: 1537
Count: 195
Count: 5633
Reset counter: 22
Mileage: 164755 km
Date: 2014.07.22
Time: 01:56:17
Count: 7
Count: 15
Count: 4608
Count: 128
Count: 28416
Count: 59136
Count: 511
Reset counter: 22
Date: 2005.08.00
Time: 16:05:12
Count: 257
Count: 5910
Count: 256
Count: 8211
Count: 279
Count: 257
Count: 8982
Count: 257
Reset counter: 22
Mileage: 164755 km
Date: 2014.07.22
Time: 21:48:10
Count: 3
Count: 14
Count: 12288
Count: 16390
Count: 48896
Count: 256
Fault Status: 00100101
Reset counter: 22
Mileage: 78439 km
Date: 2011.10.08
Time: 00:00:03
Count: 16391
Count: 24832
Count: 212
Count: 50432
Count: 256
Reset counter: 22
Mileage: 78439 km
Date: 2011.10.08
Time: 00:00:05
Count: 16391
Count: 24832
Count: 166
Count: 50432
Count: 256
Reset counter: 22
Mileage: 78439 km
Date: 2011.10.08
Time: 00:00:05
Count: 16391
Count: 24832
Count: 195
Count: 50432
Count: 256
Fault Status: 01100101
Reset counter: 22
Mileage: 78439 km
Date: 2011.10.08
Time: 00:00:03
Count: 16391
Count: 24832
Count: 279
Count: 50432
Count: 256
Reset counter: 22
Mileage: 78439 km
Date: 2011.10.08
Time: 00:00:03
Count: 16391
Count: 24832
Count: 295
Count: 50432
Count: 256
Reset counter: 22
Mileage: 78439 km
Date: 2011.10.08
Time: 00:00:03
Count: 16391
Count: 24832
Count: 270
Count: 50432
Count: 256
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 Q HW: 5C0 820 047 Q
Component: J301 Klimaanlage 0103
Revision: 2000908S Serial number: 00000000274493
VCID: 2E10F0FFB9D2553F07-807A
6 Faults Found:
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 23:12:10
Fault Frequency: 15
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 01:07:13
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 00:02:35
00532 - Supply Voltage B+
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 00:02:35
00447 - Function Limitation due to Over-Voltage
Fault Frequency: 10
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 00:00:51
Reset counter: 62
Date: 2011.05.16
Time: 00:03:16
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 C HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0226
Revision: B2066001 Serial number: 03311017111309
Coding: 7B994B9A08AB0B0008382000240884C500C2502E60000000300000000000
VCID: 2D12F7F374D42E273E-8078
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3464
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.019 H08 0006
Serial number: WRH0001G4XO
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H07 0013
Serial number: 0085103
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3464
Coding: 800000
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 00:00:27
Fault Frequency: 7
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 00:02:37
03587 - Control Circuit for Starter Lock Lock
Fault Status: 00100111
Reset counter: 62
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 013 0807
Serial number: 003GTD09U9XD
Coding: 00003935
ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3424E2979FFE7FEF71-8060
Subsystem 1 - Part No SW: 5C6 959 339 HW: 5C6 959 339
Component: BF-Gewichtss. H10 0027
Serial number: 6940000Y11000036320Q
Coding: 303241
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME2E60425AZZZ-
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME7F12415BZZZ/
Serial number: 3516KSME3908200EZZZP
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME0D28200EZZZT
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME75467D0EZZZ7
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME155D7D0EZZZA
6 Faults Found:
U0155 00 [008] - -
Fault Frequency: 23
Reset counter: 62
Mileage: 164755 km
Date: 2011.05.16
Time: 00:27:47
13635840 - Supply voltage
[Powersupply lower threshold fall short of]
Reset counter: 62
Mileage: 164755 km
Date: 2020.02.29
Time: 00:00:52
12583168 - Powertrain Databus
U0001 00 [008] - Unspecified Malfunction
[High Speed CAN Communication Bus defect]
Reset counter: 62
Mileage: 164755 km
Date: 2020.02.29
Time: 23:18:32
12674816 - Immobilizer Control Module
U0167 00 [008] - No Communications
[Lost Comminication with Immobilizer]
Reset counter: 62
Date: 2011.05.16
Time: 00:09:01
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
Reset counter: 62
Mileage: 164755 km
Date: 2020.02.29
Time: 00:00:08
9483008 - Seat Occupied Recognition
B10B3 00 [008] - Function Restriction due to Implausible Message(s)
Reset counter: 62
Mileage: 164755 km
Date: 2020.02.29
Time: 00:00:00
Part No SW: 5C6 920 950 D HW: 5C6 920 950 D
Component: KOMBI H07 0406
Coding: 270201
Shop #: WSC 00066 000 00146
VCID: 2B16F9EB42C0201720-807E
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Motor: keine Kommunikation]
Reset counter: 62
Mileage: 164755 km
Date: 2020.02.29
Time: 18:16:04
[Supply voltage too low]
Reset counter: 40
Mileage: 164755 km
Date: 2020.02.29
Time: 01:53:00
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 0226
Coding: 102200
VCID: 70AC2E87A36603CF55-8024
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 01:01:10
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 23:12:11
Reset counter: 62
Fault Frequency: 15
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 01:07:13
Component: IMMO H07 0406
VCID: 6A983CEF8DBAF91F1B-803E
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 164755 km
Date: 2020.02.29
Time: 00:00:02
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668855991
VCID: 271E05DB56280477C4-8072
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 00:01:39
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 00:02:26
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H05 0008
Revision: -----09S Serial number: VWZ4Z7N1107735
Coding: 0100040004000F
Shop #: WSC 05311 000 00000
VCID: 648452D7679EAF6F21-8030
6 Faults Found:
Fault Status: 00101011
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 21:48:13
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 21:48:13
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 21:48:14
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 21:48:14
Reset counter: 22
Mileage: 164755 km
Date: 2014.07.22
Time: 21:48:10
Reset counter: 62
Mileage: 164755 km
Date: 2014.07.22
Time: 00:02:19
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669308420
Coding: 0A00000000010100
Shop #: WSC 01383 790 50316
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 628854CF758AA15FD3-8036
[Klemme 30: unterer Grenzwert unterschritten]
Reset counter: 62
Mileage: 164755 km
Date: 2020.02.29
Time: 01:52:01
13636096 - Supply voltage
U1012 00 [008] - Voltage too High
[Klemme 30: oberer Grenzwert überschritten]
Reset counter: 62
U1400 00 [008] - -
Reset counter: 62
Mileage: 164755 km
Date: 2020.02.29
Time: 00:02:46
13893888 - Function Restricted due to Excessive Voltage
U1401 00 [008] - -
Reset counter: 62
End----------(Elapsed Time: 01:27, VBatt start/end: 14.2V/14.3V)-----------
