Hi all!
(Apologies if this is in the wrong section. Wasnt sure fi it belonged in Repairs or Retrofits).
My car was recently at the dealer for a service and they found an implausible signal fault with the drivers door controller. Having then scanned, cleared and then scanned again the following day I have a few faults showing on the Autoscan.
Firstly, even though the CAN Install list doesn't include them, VCDS is reporting that the rear door controllers are missing (My car is a coupe). Secondly its reporting a fault with the Rear Lid Control Module (under Central Convenience). HVAC system is reporting a fault which apparently is common and may be genuine.
Although I can't tell if the HVAC re-circ flap is working or not, everything else is working fine. So I have some faults but no symptoms.
Audi want to get the car back in to investigate the Drivers Door issue but why hasn't their scan picked anything else up?
I'm nervous as I have retrofitted PLA and also installed a CETE exhaust valve controller - both of which are connected to the cables on the connector that goes to the Central Convenience module and both of which are working fine (both installed some time ago without problems).
My understanding of the CAN network and how controllers affect each other is extremely limited, but before I take it back to them, is there anything that I could have done re. above that may have caused this? . Could I have caused this?
Thanks in advance for your help.
AUTOSCAN:
AUTOSCAN:
Monday,02,March,2020,18:52:38:41457
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WUAZZZF55JA901450 License Plate:
Mileage: 22189km-13787mi Repair Order:
Chassis Type: F5-AU49 (8W7)
Scan: 01 02 03 06 08 09 15 16 17 19 29 2B 32 36 39 3C 42 44 46 47
52 5F 6C 74 81 A5 A9 BB BC CA CF D6 D7
VIN: WUAZZZF55JA901450 Mileage: 22189km-13787miles
BB-Door Rear Drv -- Status: Not registered 0001
BC-Door Rear Pass -- Status: Not registered 0001
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DECA) Labels: None
Part No SW: 8W0 907 551 HW: 06M 907 309 H
Component: V6 2.9l TFSI H11 0005
Revision: B9H11000
Coding: 1A2A003225260D0B34280000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM29TFS0118W0907551 001007
ROD: EV_ECM29TFS0118W0907551.rod
VCID: 7AADF1039C5546C7873-802E
Readiness: 0010 0001
Address 02: Auto Trans (J217) Labels:* Redir Fail!
Part No SW: 8W0 927 158 K HW: 0D5 927 156 H
Component: 0D5 29TSIRdW H05 1002
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002013
ROD: EV_TCMALX52011.rod
VCID: 4ACD61C38C351647573-801E
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PRE-V1.clb
Part No SW: 8W0 907 379 AA HW: 8W0 907 379 AA
Component: ESP9 Premium H13 0200
Coding: 50AA6C9A30A28A9711A24896407D5292E6A5DA0A360C518812024A4967A55B
Shop #: WSC 06324 790 00001
ASAM Dataset: EV_ESP9BOSCHCMP 001001
ROD: EV_ESP9BOSCHCMP_001.rod
VCID: 04518FFBEE910037EDF-8050
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M0 959 760 A HW: 4M0 959 760 A
Component: MEM-BFS 008 0031
Serial number: 00000266651184
Coding: 00323004000CB2010003010141010000000000000000000000000000802002
Shop #: WSC 06325 790 00001
ROD: EV_SCMPasseSideCONTIAU736_AU49.rod
VCID: 36352533E8CD62A723B-8062
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H55 0210
Coding: 4608040D5544040D02020100880000000000000000000000000000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44D14FFBAE11C037ADF-8010
Subsystem 1 - Part No SW: 4M2 820 021 A HW: 4M2 820 021 A
Component: J126 FLuftV H08 0003
Serial number: 00000000000001758474
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: A091D1C800PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
327971 - Motor for Fresh Air / Recirculated Air Flap
B11AF 07 [009] - Mechanical Failure
Reset counter: 59
Mileage: 22163 km
Date: 2020.03.01
Time: 12:01:15
Fresh-air door motor / specified value: 9699
Fresh air flap motor: actual value: 11208
System run time-Engine running time: 645 s
System run time-Terminal 15 on: 855 s
Fresh air flap motor: diagnostic-Last operating state: No routine started
Fresh air flap motor: diagnostic-Operating condition: Blocking handling
Voltage terminal 30: 14.98 V
Outside air temperature: 7.00 °C
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07501343C13900CD050D79191BAD8CF9130B3104000000000000000060001C810A4502A202B706
Shop #: WSC 12345 123 61029
VCID: 025D89E3F4850E07DF3-8056
Subsystem 1 - Part No SW: 8W6 955 119 A HW: 8W6 955 119 A
Component: 494 RL 170705 036 0471
Serial number: 00000001707030303972
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 20649443X81A955555A0
Coding: 02005D
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 04 05 2017 00943833
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE112051723510110
Coding: 230000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 CN HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00469989
Subsystem 6 - Part No SW: 8W0 925 301 BF HW: 8W0 925 301 BF
Component: SL-B9/Q5NF H15 0010
Serial number: 2615000097097007
Subsystem 7 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J873 MKS_FSv H03 0034
Serial number: 7008174235B172754920
Coding: BF0500
Subsystem 8 - Part No SW: 8W0 907 182 HW: 8W0 907 182
Component: J872 MKS_BFSv H03 0034
Serial number: 7008174235B172754634
Coding: B30500
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 H HW: 8W0 959 655 H
Component: Airbag10.44 H04 0106
Serial number: 003UR0007HTR
Coding: AACCF0C000800000585000F3D0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006015
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 4EC56DD3705D3A670BB-801A
Subsystem 1 - Part No SW: ----------- HW: 442 062 407 17
Serial number: 3577Y009B24FCA3340CC
Subsystem 2 - Part No SW: ----------- HW: 442 062 407 17
Serial number: 3587Y00A124FCA3103A%
Subsystem 3 - Part No SW: ----------- HW: 442 0B0 408 17
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700C12772293813.
Subsystem 4 - Part No SW: ----------- HW: 442 0B0 408 17
Serial number: 3527700C12772292901Z
Subsystem 5 - Part No SW: ----------- HW: 442 0C2 206 17
Component: FrontSensor_D 1C5 014A
Serial number: 3557500992757BF3E45U
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 442 0C2 206 17
Component: FrontSensor_P 1C5 014A
Serial number: 3567500992757BF3937R
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76B5E533A84D22A7E3B-8022
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H18 0379
Coding: 252D21DE38B806000123ED601000401000000000
ASAM Dataset: EV_DashBoardAU736 001027
VCID: 43D34CE7AB1FC70F945-8016
Part No SW: 8W7 907 468 E HW: 8W7 907 468 E
Component: Gateway H42 0118
Revision: 6C020003 Serial number: 0386C502617818
Coding: 03010001000086405407000000590012E8180007900000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003092
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 4DC76ADF7D5B017F721-8018
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0002
Serial number: 20170721091724 21131
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 6892414604
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AD HW: 4M0 907 397 D
Component: LCM_MLBevoH05 0024
VCID: 79AFEE0F99534DDF8E9-802C
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 17000167986002
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 323D192304A57E870F3-8066
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H07 0040
Revision: 5WK12700 Serial number: 605727422251307
Coding: 0003
ASAM Dataset: EV_TVDCQSP22 001007
ROD: EV_TVDCQSP22.rod
Address 36: Seat Mem. Drvr (J136) Labels:* None
Component: MEM-FS 008 0031
Serial number: 00000270831833
Coding: 003A3B04000CB2010003010141010000000000000000000000000000802002
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 D HW: 4M0 907 566
Component: MRR1Rear H18 0410
Revision: --------
Coding: 4C8002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 H HW: 4M0 959 793 F
Component: TSG FS 005 0125
Serial number: 0000268170612
Coding: 005D5A425E010005000134B2
196665 - Switch for Central Locking
B122D 29 [009] - Signal Implausible
Reset counter: 61
Mileage: 22189 km
Date: 2020.03.02
Time: 18:04:55
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 8W0 909 144 G HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0409
Coding: 09880380008000
ASAM Dataset: EV_EPSZFAU49X 003018
ROD: EV_EPSZFAU49X_003.rod
VCID: 41DF46EFB103D51F869-8014
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 8W0 907 064 DC HW: 8W0 907 064 DC
Component: BCM2 MLBevo 019 0366
Coding: 013300006FB000006389A0006E00000233034010804306502F0400000104003D201F1001000000
ASAM Dataset: EV_BCM2HellaAU736 013013
ROD: EV_BCM2HellaAU736_013_AU49.rod
VCID: 005983EBFA891C17C97-8054
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1712411TL
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000038786448
Subsystem 3 - Part No SW: 3AA 962 243 H HW: 3AA 962 243 H
Component: GEB.F.Heckoef H16 0905
Serial number: >1131654
65669 - Control Module for Rear Lid Opening
U1152 00 [008] - No Communications
[Control module for tailgate spoiler opening: no communication]
Reset counter: 99
Mileage: 22163 km
Date: 2020.03.02
Time: 08:34:30
Supply voltages-Supply voltage: Terminal 30: 12.201 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.174 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.187 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 40 04 4A 12 04 98
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 0.00 km/h
can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
Address 47: Sound System (J525) Labels:* None
Part No SW: 8W0 035 465 HW: 8W0 035 465
Component: MIB2_amp_P_B9 H11 0420
Revision: 00000001 Serial number: AUZ8ZAHJA02DRDE
Coding: 0194040800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
Part No SW: 4M0 959 792 H HW: 4M0 959 792 F
Component: TSG BFS 005 0125
Serial number: 0000266411110
Coding: 005D5A425E010005000134B0
VCID: 42DD49E3B405CE079F3-8016
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 035 C HW: 8W5 035 035
Component: MU-P-LND-EU 034 1329
Serial number: A829H0HB033904
Coding: 019464010000000053111102000A00102F0013E701700100BE
VCID: 372B2837EFC79BAF38D-8062
Subsystem 1 - Part No SW: V03 959 802 TH HW: -----------
Component: ECE 2020 --- 0184
Subsystem 2 - Part No SW: 8W2 919 605 HW: 8W2 919 605
Component: AU49x_DU_HIGH H40 0008
Serial number: AUZ8Z9HBK00L2J
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 T HW: 8W0 919 614 T
Component: ControlUnit_H H30 0206
Serial number: APVAK117071700020491
Component: Gracenote2 --- 1016
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H12 0250
Coding: 0294040102002001400040
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
VCID: 33331C27FBBF778F045-8066
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 8W0 907 777 L HW: 8W0 907 777 B
Component: Fahrwerk-SG H34 1230
Serial number: 2706170171
Coding: 1460403112
ASAM Dataset: EV_ChassContrContiAU426 001004
ROD: EV_ChassContrContiAU426.rod
VCID: 50F973AB6A692C97197-8004
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W2 713 041 F HW: 4M2 713 041 F
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 17062943202271
ROD: EV_GSMWaehlZFAU736.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 8W6 907 217 A HW: 8W6 907 217 A
Component: BVS H16 0050
Coding: 0404090400000403024023A2A50000FC10F0C020C280
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 40D943EBBA09DC17897-8014
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 8W0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 170309201434
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 508000049401
VCID: 3D273A1FCDFBB1FFE21-8068
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 4M0 907 590 D HW: 4M0 907 590
Revision: --------
Coding: 4C8002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-592.clb
Part No SW: 7PP 941 592 CB HW: 7PP 941 592 C
Component: LED1L H10 2003
VCID: 1A6DD1837C15A6C7273-804E
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-592.clb
Component: LED1R H10 2003
End----(Elapsed Time: 02:04, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
