Results 1 to 4 of 4
Thread: ABS problem VW jetta 2012
    Jan 2020
    Israel
    hello all
    i replaced an abs and have these problem
    Monday,02,March,2020,11:05:46:04619
    VIN: WVWZZZ16ZCM048745   License Plate:
    Chassis Type: 16-VW32 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ16ZCM048745   Mileage: 505780km-314277miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 MP    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 9970
       Revision: --H43---    Serial number: 00000000000000
       Coding: 10254016030400080000
       Shop #: WSC 00066 123 00081
       ASAM Dataset: EV_ECM16TDI02103L906023MP 003010
       ROD: EV_ECM16TDI02103L906023ML_003.rod
       VCID: 0059863BEA8223B7C95-8054
    7402 - Throttle Actuator Control System
              P2111 00 [167] - Stuck Open
                        Mileage: 505781 km
                        Date: 2020.03.02
                        Time: 01:20:16
                        Engine speed: 985.25 /min
                        Normed load value: 23.9 %
                        Coolant temperature: 52 °C
                        Intake air temperature: 19 °C
                        Voltage terminal 30: 11.746 V
                        Throttle valve adapter: offset closed-V_THR_BOL[0]: 0.708 V
                        Throttle_actuator_commanded_value-ANG_SP_THR[0]: 86.899 %
                        Throttle valve adapter: actual value-ANG_THR[0]: 99.121 %
                        Air mass: actual value (mg/stroke)-MAF_MES: 423.79 mg/stroke
                        Sensor for temp after charge air cooler: raw value-TBA_MES: 20 °C
    6086 - No Communication with ABS Brake Control Module
              U0121 00 [036] - -
                        Mileage: 505781 km
                        Date: 2020.03.02
                        Time: 01:51:25
                        Vehicle speed: 255 km/h
                        Coolant temperature: 49 °C
                        Intake air temperature: 21 °C
                        Voltage terminal 30: 11.520 V
                        Driver request torque-TQI_DRIV_SUB: 0.00 Nm
                        Control Module temperature-TECU: 32 °C
    Readiness: 1010 1000
       Part No SW: 0AM 300 058 S    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 5220
       Revision: 00043014    Serial number: CU501401305399
       Shop #: WSC 00824 002 1048576
       VCID: 41DF433FAD88EABF86B-8014
    7 Faults Found:
    006247 - Powertrain Data Bus
                   P1867 - 000 - Missing Message from Steering Wheel (J527)
                        Fault Frequency: 110
                        Reset counter: 10
                        Mileage: 505277 km
                        Date: 2014.07.10
                        Time: 10:49:10
    006012 - Clutch 2
                   P177C - 003 - Tolerance Limit Reached - Intermittent
                        Fault Status: 00100011
                        Fault Frequency: 9
                        Reset counter: 10
                        Mileage: 505277 km
                        Date: 2014.07.10
                        Time: 10:55:37
    006272 - Powertrain Data Bus
                   P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
                        Fault Frequency: 43
                        Reset counter: 6
                        Mileage: 505526 km
    006242 - Powertrain Data Bus
                   P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
                        Fault Frequency: 61
                        Reset counter: 10
                        Mileage: 505526 km
                        Fault Frequency: 43
                        Reset counter: 6
                        Mileage: 505526 km
    006225 - Powertrain Data Bus
                   P1851 - 000 - Missing Message from ABS Controller - Intermittent
                        Reset counter: 10
                        Mileage: 505781 km
                        Date: 2014.07.24
                        Time: 00:28:58
    054272 - Function Restricted due to Insufficient Voltage
                   U1400 - 000 -  - Intermittent
                        Reset counter: 8
                        Mileage: 505681 km
                        Date: 2014.07.20
                        Time: 00:07:29
       Revision: 00H31001
       Coding: A13B20F809260002851204E8901E0041250000
       Shop #: WSC 00066 123 12345
       VCID: 7BA3F1D783E4406F9C7-802E
                        Fault Status: 01100101
                        Reset counter: 68
                        Mileage: 505781 km
                        Date: 2014.07.24
                        Time: 01:56:11
                        Count: 3
                        Count: 29184
                        Count: 279
                        Count: 40704
                        Count: 1
                        Count: 9216
                        Reset counter: 68
                        Mileage: 505781 km
                        Date: 2014.07.24
                        Time: 01:56:11
                        Count: 3
                        Count: 29184
                        Count: 295
                        Count: 40704
                        Count: 1
                        Count: 9216
                        Reset counter: 68
                        Mileage: 505781 km
                        Date: 2014.07.24
                        Time: 01:56:11
                        Count: 3
                        Count: 29184
                        Count: 270
                        Count: 40704
                        Count: 1
                        Count: 9216
       Part No SW: 5K0 907 044 ER    HW: 5K0 907 044 ER
       Revision: 00001003
       Coding: 0000001002
       Shop #: WSC 00066 000 00121
       ROD: EV_ClimaAutoBasis_VW32.rod
       VCID: 7F5B05C7977C5C4FB0F-802A
              U1111 00 [008] - -
              [Motorsteuergerät - kein Signal/Kommunikation]
                        Fault Frequency: 28
                        Reset counter: 107
                        Time: 00:00:00
    13701392 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Bremsensteuergerät - kein Signal/Kommunikation]
                        Fault Frequency: 32
                        Reset counter: 108
                        Time: 00:00:00
    13701408 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Diagnoseinterface für Datenbus - kein Signal/Kommunikation]
                        Fault Frequency: 85
                        Reset counter: 107
              U1111 00 [008] - -
              [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                        Fault Frequency: 89
                        Reset counter: 108
       Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
       Component: BCM PQ35 B    011 0048
       Revision: BA011001
       Coding: 00000A3A902D02C040080080000000E403000088508081605C8000000040
       VCID: 353727EFE540561F2A3-8060
    10 Faults Found:
                        Reset counter: 106
                        Mileage: 505681 km
                        Date: 2014.07.20
                        Time: 00:00:49
                        Voltage: 8.70 V
                        Reset counter: 104
                        Voltage: 14.00 V
                        Fault Frequency: 52
                        Reset counter: 107
                        Voltage: 11.60 V
                        Reset counter: 68
                        Mileage: 505781 km
                        Date: 2014.07.24
                        Time: 01:18:56
                            Term 15 Off
                        Voltage: 11.80 V
                        Fault Frequency: 106
                        Reset counter: 107
                            Term 15 Off
                        Voltage: 12.70 V
                        Fault Frequency: 37
                        Reset counter: 107
                        Voltage: 11.65 V
                        Reset counter: 104
                        Voltage: 12.00 V
                        Fault Frequency: 10
                        Reset counter: 108
                        Voltage: 12.00 V
                        Fault Frequency: 108
                        Reset counter: 108
                        Voltage: 11.65 V
                        Fault Frequency: 52
                        Reset counter: 107
                        Voltage: 11.60 V
       Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
       Serial number: 003G6M00SDUW
       Coding: 00003242
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 323D1CF314AE41270F1-8066
       Serial number: 3572MSME2B460562ZZZT
       Serial number: 3582MSME01460562ZZZI
       Serial number: 3516KSME66114E12ZZZO
       Serial number: 3526KSME68065712ZZZP
    12656896 - No Communication with ABS Brake Control Module
              U0121 00 [008] - -
              [Lost Communication With Vehicle Dynamics Control Module]
                        Reset counter: 108
                        Mileage: 505781 km
                        Date: 2020.03.02
                        Time: 01:51:25
       Part No SW: 1K5 953 521 AE    HW: 5K0 953 569
       Revision: FF010040    Serial number: 20110722200490
       Coding: 4080040000
       Shop #: WSC 00066 000 00187
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 70B9D6FBDA223337395-8024
    114178 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 106
                        Mileage: 505681 km
                        Date: 2020.02.27
                        Time: 00:07:39
    332564 - Databus
                        Fault Frequency: 84
                        Reset counter: 107
       Part No SW: 5C6 920 871 A    HW: 5C6 920 871 A
       Coding: 171A00
       VCID: 2A0D04933C7E09E7B71-807E
    9 Faults Found:
    12604928 - Combination / Chassis CAN Bus (SAE Bus D)
              U0056 00 [008] - Performance
              [Datenbus Kombi/Fahrwerk: keine Kommunikation]
                        Fault Frequency: 50
                        Reset counter: 108
    12648448 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Motor: keine Kommunikation]
                        Fault Frequency: 7
                        Reset counter: 107
                        Time: 00:00:00
    12648704 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Getriebe: keine Kommunikation]
                        Fault Frequency: 7
                        Reset counter: 107
                        Time: 00:00:00
    12656896 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Bremse: keine Kommunikation]
                        Fault Frequency: 9
                        Reset counter: 108
                        Time: 00:00:00
    12664832 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
                        Fault Frequency: 69
                        Reset counter: 107
                        Time: 00:00:00
    12669184 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Airbag: keine Kommunikation]
                        Fault Frequency: 7
                        Reset counter: 107
                        Time: 00:00:00
    13638912 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Lenkhilfe: keine Kommunikation]
                        Fault Frequency: 7
                        Reset counter: 107
                        Time: 00:00:00
    12718592 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Lenksäulenelektronik: keine Kommunikation]
                        Fault Frequency: 52
                        Reset counter: 107
                        Time: 00:00:00
    13631488 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Komfortsysteme: keine Kommunikation]
                        Fault Frequency: 36
                        Reset counter: 107
                        Mileage: 505526 km
                        Time: 00:00:00
       Revision:   H42       Serial number: 22091101270472
       Coding: 351002
                        Reset counter: 108
                        Mileage: 505781 km
                        Date: 2014.07.24
                        Time: 00:28:59
                        Fault Status: 00101110
                        Mileage: 505527 km
                        Date: 2014.07.11
                        Time: 07:21:05
       VCID: 6A8DC493FCFEC9E7771-803E
       Revision: 13110009    Serial number: 0003310964
       Coding: 0000B5
       Shop #: WSC 01383 790 50316
       VCID: 5BE3915723A4A06FFC7-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1508
       Serial number: 00000006026830
       Coding: 000090
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 68
    68102 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN Kombi]
                        Fault Frequency: 70
                        Reset counter: 108
    68103 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN gateway]
                        Fault Frequency: 83
                        Reset counter: 107
    68107 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN AirBag]
                        Fault Frequency: 47
                        Reset counter: 107
    68108 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Front CAN MSG]
                        Fault Frequency: 44
                        Reset counter: 107
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 69     3201
       Revision: 00H20000
       VCID: 34311AEBE23A4F171DD-8060
                        Fault Frequency: 31
                        Reset counter: 107
                        Mileage: 505681 km
                        Voltage: 13.50 V
                            DU
                        Temperature: 16.0°C
                        RPM: 781 /min
                        Fault Frequency: 13
                        Reset counter: 108
                        Mileage: 505781 km
                        Date: 2014.07.24
                        Time: 00:36:39
                        Voltage: 12.13 V
                            DD
                        Temperature: 26.0°C
                        Reset counter: 108
                        Mileage: 505781 km
                        Date: 2014.07.24
                        Time: 01:51:25
                        Voltage: 11.50 V
                            DD
                        Temperature: 26.0°C
       Revision: 15110009    Serial number: 0003339668
       Coding: 0000B4
       VCID: 5CE1924B26AAA757F5D-8008
       Slave Passenger:
       Component: J389__TSG-HR  006 1508
       Serial number: 00000006048591
       Coding: 000090
    6 Faults Found:
                        Reset counter: 68
              U1111 00 [008] - -
              [Front CAN Kombi]
                        Fault Frequency: 70
                        Reset counter: 108
              U1111 00 [008] - -
              [Front CAN gateway]
                        Fault Frequency: 83
                        Reset counter: 107
              U1111 00 [008] - -
              [Front CAN AirBag]
                        Fault Frequency: 47
                        Reset counter: 107
              U1111 00 [008] - -
              [Front CAN MSG]
                        Fault Frequency: 44
                        Reset counter: 107
    132610 - Motors for Rear Central Locking
              B122C 01 [008] - Electrical Failure
                        Reset counter: 97
                        Mileage: 505282 km
                        Date: 2020.02.17
                        Time: 11:35:49
       Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
       Component: Radio RCD310  032 0079
       Revision: 01000001    Serial number: VWZ1Z2L3156661
       Coding: 05000400040006
       VCID: 72BDDCF3D4AE0127CF1-8026
    00625 - Vehicle Speed Signal
                        Reset counter: 108
                        Fault Frequency: 19
                        Reset counter: 108
                        Fault Frequency: 15
                        Reset counter: 107
                        Mileage: 505526 km
                        Reset counter: 106
                        Mileage: 505681 km
                        Date: 2014.07.20
                        Time: 00:07:38
                        Reset counter: 105
    End----(Elapsed Time: 01:00, VBatt start/end: 11.2V/11.2V. VIgn 11.3V)-----
    i done basic settings but still same problems
    Are you sure you have done them correctly?
    http://wiki.ross-tech.com/wiki/index..._%28MK60EC1%29
    Additionally OP has forgot to clear codes in other modules and also do adaptions possibly in 0x44 in same session too when doing adaptions in 0x03?
    Jan 2020
    Israel
    thanks
    its done correctly now
  5. Likes Jack@European_Parts, Uwe liked this post
