Results 1 to 5 of 5
Thread: Hello all
    Feb 2020
    Hello all
    I bought the scanner, the audi manual and still having problems. My s6 has been jet roaring the passenger side cooling fan when the car is turned on and for 10 min after shut down. i have checked the fuses under the ecm's and the relay box under the cowl. i pulled the radiator and the fans to see if i could put power to them and they do work but pull a ton of amps. i checked resistance and they are both the same. the fan running killed my battery that's why i have low voltage. the car runs fine otherwise no overheating it is winter though. if anyone has any ideas of what to check next i would appreciate it. i did clear codes because there was a billion from having the ground on the engine pulled off to cut off the fans. thank you
    Thursday,27,February,2020,17:30:54:32286
                    Address 01: Engine       Labels:
    Control Module Part Number:
      Component and/or Version:
               Software Coding:
                Work Shop Code:
                          VCID: 55F787DBAC06B74FCA3-FFFE
    Fault Codes have been Erased
    006435 - Please Check DTC Memory of ECU Number 2
                   P1923 - 008 -
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1137 /min
                        Load: 44.7 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 13.589 V
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 008 -
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1130 /min
                        Load: 46.6 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Voltage: 13.589 V
    001152 - Coolant Fan Control Circuit 1
                   P0480 - 004 - Electrical Malfunction
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1132 /min
                        Load: 46.3 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Voltage: 13.589 V
    Readiness: N/A
               Software Coding:
                Work Shop Code:
                   P1923 - 008 -
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1137 /min
                        Load: 44.7 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Voltage: 13.589 V
                   P1653 - 008 -
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1130 /min
                        Load: 46.6 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Voltage: 13.589 V
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1132 /min
                        Load: 46.3 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Voltage: 13.589 V
    Readiness: N/A
               Software Coding:
                Work Shop Code:
                   P1923 - 008 -
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1137 /min
                        Load: 44.7 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Voltage: 13.589 V
                   P1653 - 008 -
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1130 /min
                        Load: 46.6 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Voltage: 13.589 V
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1132 /min
                        Load: 46.3 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Voltage: 13.589 V
    Readiness: N/A
               Software Coding:
                Work Shop Code:
                   P1923 - 008 -
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1137 /min
                        Load: 44.7 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Voltage: 13.589 V
                   P1653 - 008 -
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1130 /min
                        Load: 46.6 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Voltage: 13.589 V
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1132 /min
                        Load: 46.3 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Voltage: 13.589 V
    Readiness: N/A
    I reckon this is what you need to debug:
    Quote Originally Posted by 2K8S6 View Post
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 12:21:52
                        RPM: 1132 /min
                        Load: 46.3 %
                        Temperature: 11.0C
                        Temperature: 10.0C
                        Voltage: 13.589 V
    BTW it would be a great help if you could post a full unedited VCDS Auto-Scan rather than just that small edited section.
    Feb 2020
    Thursday,27,February,2020,17:10:31:32286
    VIN: WAUDN74F98N087466   License Plate:
    Mileage: 149550km-92926mi   Repair Order:
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 07 08 09 0E 0F 11 31 15 16 17 19 1E 36 37 42 46
              47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
    VIN: WAUDN74F98N087466   Mileage: 149550km-92926miles
    0E-Media Player 1 -- Status: Malfunction 0010
    11-Engine II -- Status: Malfunction 0010
    31-Engine other -- Status: Malfunction 0010
    1E-Media Player 2 -- Status: Malfunction 0010
    67-Voice Control -- Status: Malfunction 0010
    Address 01: Engine (BXA)       Labels: Redir Fail!
       Part No SW: 4F1 910 562 A    HW: 4F1 907 552 B
       Component: 5.2L V10/4V FSI    0010
       Revision: 5HH02---    Serial number:
       Coding: 01050009190F0160
       Shop #: WSC 23435 444 11744
       VCID: 2313E903B7D219FFF47-8076
    6 Faults Found:
    009523 - Ignition Switch; Run/Start Position Circuit
                   P2533 - 002 - Open or Short to Ground - Intermittent
                        Fault Status: 00110010
                        Mileage: 148392 km
                        Temperature: 16.0C
                        Temperature: 20.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 12.446 V
                   P1653 - 008 -
                        Mileage: 148392 km
                        Date: 2019.12.15
                        Time: 09:22:22
                        Temperature: 7.0C
                        Temperature: 12.0C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 11.176 V
    012423 - Voltage Supply Relay for Engine Components
                   P3087 - 004 - Electrical Malfunction - Intermittent
                        Mileage: 148392 km
                        RPM: 40 /min
                        Load: 100.0 %
                        Temperature: 16.0C
                        Temperature: 20.0C
                        Voltage: 11.684 V
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    001669 - ECM Power Relay Control Circuit
                   P0685 - 004 - Open Circuit - Intermittent
                        Mileage: 149557 km
                        Date: 2007.05.16
                        Time: 12:41:34
                        Temperature: 9.0C
                        Temperature: 13.0C
                        Voltage: 5.588 V
                   P1923 - 008 -
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 11:58:22
                        Temperature: 3.0C
                        Temperature: 6.0C
                        Voltage: 11.938 V
    Readiness: 0110 1101
       Part No SW: 4F5 910 156 F    HW: 09E 927 156 C
       Component: AG6 09E 5,2 FSI USA 0020
       Revision: --H04---    Serial number:        0116291
       Shop #: WSC 02325 785 00200
       VCID: 2B030123DF02D1BF4C7-807E
    006246 - Powertrain Data Bus
                   P1866 - 000 - Missing Messages - Intermittent
                        Mileage: 148393 km
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 P    HW: 4F0 614 517 P
       Component: ESP 8.0 quattro H05 0070
       Coding: 0020920
       VCID: 313F134BFD2EBB6F76B-8064
                        Fault Frequency: 17
                        Reset counter: 198
                        Mileage: 148392 km
                        Date: 2019.12.15
                        Time: 09:22:23
                        Hex Value: 0x0000
                        Hex Value: 0x4282
                        Hex Value: 0x0024
                        Hex Value: 0x01B8
                        Hex Value: 0x00FF
    01418 - Switch Valve 1 for Electronic Stability Program (N225)
                        Reset counter: 236
                        Mileage: 149075 km
                        Date: 2020.01.03
                        Time: 12:20:54
                        Hex Value: 0x0000
                        Hex Value: 0x4082
                        Hex Value: 0x0016
                        Hex Value: 0xC0B4
                        Hex Value: 0x00FF
       Part No SW: 4F0 910 852 A    HW: 4F0 905 852 C
       Component: FBSAUDIC6 ELVSG H01 0040
       Revision: 09010701    Serial number: 10601600939581
       Coding: 0000007
       Shop #: WSC 23436 444 11307
       VCID: 2411EA1FB2DC1EC78DD-8070
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 KSG   H27 0080
    00532 - Supply Voltage B+
                        Reset counter: 211
                        Mileage: 148393 km
                        Date: 2019.12.17
                        Time: 11:51:25
                        Fault Frequency: 7
                        Reset counter: 238
    00447 - Function Limitation due to Over-Voltage
                        Fault Status: 00100001
                        Reset counter: 210
                        Mileage: 148392 km
                        Date: 2019.12.15
                        Time: 09:22:06
       Part No SW: 4F0 910 732 D    HW: 4E0 035 729 A
       Component: Interfacebox    H43 4140
       Revision: 00000000    Serial number: 361KU077519071
       Coding: 0010003
       Shop #: WSC 02335 785 00200
       Subsystem 2 - Serial number: 00000000938442
       Subsystem 3 - Serial number: 0128.11.070000000100010282
       Subsystem 4 - Serial number: 010282
    01964 - Control Module for Seat & Steering Column Memory (J136)
                        Reset counter: 238
                        Mileage: 148391 km
                        Date: 2019.12.12
                        Time: 13:18:27
                        Reset counter: 210
                        Time Indication: 15
       Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
       Component: KLIMABETAETIGUNGH30 0020
       Revision: 00000053    Serial number: 00000000472085
       Coding: 0524330
       VCID: 1C61D2FF8AAC260735D-8048
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
                        Fault Status: 00101010
                        Reset counter: 225
                        Mileage: 147685 km
                        Date: 2019.11.06
                        Time: 06:26:24
                        Voltage: 14.10 V
                        (no units): 218.0
                        (no units): 255.0
       Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
       Component: ILM Fahrer      H18 0250
       Coding: 0115121
       Shop #: WSC 23436 444 13621
       VCID: 3039164FF624B267795-8064
       Subsystem 1 - Part No: 4F1 910 113 C  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0210
       Coding: 00064784
       Shop #: WSC 23436
       Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0100
       Coding: 00146221
       Shop #: WSC 23436
                        Fault Status: 00100111
                        Reset counter: 212
                        Mileage: 148392 km
                        Date: 2019.12.15
                        Time: 09:24:00
                        Reset counter: 210
                        Mileage: 148392 km
                        Date: 2019.12.17
                        Time: 11:41:00
                        Reset counter: 210
                        Mileage: 148392 km
                        Date: 2019.12.17
                        Time: 11:41:00
       Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
       Component: MP3-Changer     H46 0350
       Revision: 00046007    Serial number: AUZ5ZBG3517104
       VCID: 1869CEEF7E944A27115-804C
                        Reset counter: 210
                        Mileage: 148393 km
                        Date: 2019.12.17
                        Time: 11:50:51
                        Reset counter: 210
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
       Component: SDAR SIRIUS     H07 0140
       Revision: 00000000    Serial number: AUZ4Z7G0215244
       Coding: 0000100
       VCID: 2F3B1533EB1AAD9F60F-807A
                        Reset counter: 210
                        Mileage: 148393 km
                        Date: 2019.12.17
                        Time: 11:51:10
                        Voltage: 8.00 V
                        Reset counter: 210
                        Mileage: 148393 km
                        Date: 2019.12.17
                        Time: 11:51:02
                        Voltage: 8.00 V
                        Reset counter: 86
                        Mileage: 144939 km
                        Date: 2019.09.18
                        Time: 18:15:24
    Address 11: Engine II        Labels: Redir Fail!
    005491 - Left Engine Mount Solenoid Valve (N144)
                   P1573 - 004 - Open Circuit - Intermittent
                        Fault Status: 00110100
                        Mileage: 145129 km
                        Date: 2019.09.30
                        Time: 06:30:48
                        RPM: 707 /min
                        Load: 27.4 %
                        Speed: 3.0 km/h
                        Temperature: 49.0C
                        Temperature: 21.0C
                        Voltage: 14.224 V
                   P1653 - 008 -
                        Mileage: 148392 km
                        Date: 2019.12.15
                        Time: 09:22:22
                        Temperature: 7.0C
                        Temperature: 12.0C
                        Voltage: 11.176 V
                        Temperature: -40.0C
                        Temperature: -40.0C
                        Voltage: 0.000 V
       Part No SW: 4F0 910 655 K    HW: 4F0 959 655 D
       Component: 7Q AIRBAG AUDI8RH30 0400
       Revision: 02H30000    Serial number: 003BMD020H6V
       Coding: 0014161
       Subsystem 1 - Part No: 4F0 910 339 B
       Component: BF-Gewichtsens. H03 0060
       Subsystem 2 - Serial number: 6332CSME34310520M
       Subsystem 3 - Serial number: 6342CSME3431564D1
       Subsystem 4 - Serial number: 6352QSME497B3B77-
       Subsystem 5 - Serial number: 6362QSME49560B13H
       Subsystem 6 - Serial number: 63734SME3E7A097FN
       Subsystem 7 - Serial number: 63834SME424B1B7DC
       Revision: 00H03000    Serial number: 90026073200210
       Coding: 0012141
       Shop #: WSC 02323 785 00200
       VCID: 270BFD13C3EAF5DFA8F-8072
                        Reset counter: 238
                        Date: 2063.15.31
                        Time: 31:63:52
                        Reset counter: 238
                        Mileage: 148392 km
                        Date: 2019.12.15
                        Time: 09:22:20
                        Reset counter: 238
                        Mileage: 148393 km
                        Date: 2019.12.17
                        Time: 11:51:36
       Part No SW: 4F0 910 930 C    HW: 4F0 920 981 Q
       Component: KOMBIINSTR. M73 H22 0240
       Revision: 00000000    Serial number: 73033ZLC7
       Coding: 2129288
       Shop #: WSC 15622 003 1048576
       Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
       Component: J533__Gateway   H06 0060
       Revision: 00H06000    Serial number: 1100B07B23819D
       Coding: F5D5DEF7707A0600
       VCID: 2D070F3BE116DF8F523-8078
                        Reset counter: 210
                        Mileage: 148393 km
                        Date: 2019.12.17
                        Time: 11:51:25
    Address 1E: Media Player 2 (R192)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
       Component: SG ext.Player H15 0700
       Revision: 00000000
       VCID: 270BFD13CFEAF5DFA8F-8072
                        Reset counter: 210
       Coding: 0082954
       VCID: 619FA30BED4E4BEFA6B-8034
                        Reset counter: 211
                        Date: 2007.01.01
                        Time: 00:00:00
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 M
       Component: MNS US          H50 1100
       Revision: 00000000    Serial number: 395K2077505993
       Shop #: WSC 22133 444 58922
       VCID: 38292E6F1E546A27315-806C
                        Reset counter: 210
                        Mileage: 148393 km
                        Date: 2019.12.17
                        Time: 11:50:44
                        Hex Value: 0x5DF8
                        Hex Value: 0xC114
                        Hex Value: 0x004B
                        Reset counter: 210
                        Time Indication: 15
                        Hex Value: 0xFFFF
                        Hex Value: 0xFFFF
                        Hex Value: 0x00BC
       Component: TSG FA          H12 0210
       Revision: 00000000    Serial number: s1
       Coding: 0051947
       Shop #: WSC 02327 758 00200
       VCID: 2C01023FDA0CD68745D-8078
       Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
       Component: Komfortgeraet   H26 0210
       Revision: 02100026    Serial number: 01083303880000
       Coding: 4618269
    8 Faults Found:
    01134 - Alarm Horn (H12)
                        Reset counter: 198
                        Mileage: 115596 km
                        Date: 2018.02.18
                        Time: 13:42:05
    01506 - Bulb for Rear Fog; Right (L47)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 23
                        Reset counter: 198
                        Mileage: 147112 km
                        Date: 2019.10.26
                        Time: 15:50:36
    02743 - Bulb for Brake/Turn Signal Light; Right
                        Fault Status: 00101001
                        Reset counter: 216
                        Mileage: 147872 km
                        Date: 2019.11.25
                        Time: 05:59:08
                        Fault Frequency: 81
                        Reset counter: 198
                        Mileage: 141570 km
                        Date: 2019.08.01
                        Time: 08:13:52
    02199 - Bulb for Tail Light 2; Right (M50)
                        Fault Frequency: 102
                        Reset counter: 198
                        Mileage: 143122 km
                        Date: 2019.08.23
                        Time: 08:40:35
    01503 - Bulb for 3rd Brake Light (M25)
                        Fault Frequency: 13
                        Reset counter: 211
                        Mileage: 148391 km
                        Date: 2019.12.13
                        Time: 09:20:06
    02735 - Bulb for Tail Light 3; Right
                        Fault Frequency: 108
                        Reset counter: 198
                        Mileage: 143159 km
                        Date: 2019.08.23
                        Time: 17:46:25
                        Reset counter: 210
                        Mileage: 148393 km
       Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
       Component: DSP-High C6     H10 0240
       Revision: PROD_01     Serial number: 00000000062726
       Coding: 0000026
       VCID: 2517F71BB9E6E7CF9A3-8070
                        Reset counter: 236
                        Date: 2019.12.17
                        Time: 11:53:06
                        Voltage: 7.70 V
       Part No SW: 4F0 910 280     HW: 4F0 907 280 C
       Component: ILM Beifahrer   H12 0100
       Revision:             Serial number: 00000000106553
       Coding: 0012014
       VCID: 5EE598F7DC3074179B9-800A
                        Reset counter: 210
                        Voltage: 0.000 V
                        Temperature: 77.0C
                        Reset counter: 211
                        Mileage: 148392 km
                        Date: 2019.12.15
                        Time: 09:22:00
                        Voltage: 18.400 V
                        Temperature: 77.0C
       Component: TSG BF          H12 0210
       Revision: 00000000    Serial number: Y0
       Coding: 0051947
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
       Component: EPB  CDEC0080   H04 0080
       Revision: --H04---
       Coding: 0008022
       Shop #: WSC 02145 785 00200
       VCID: 2019E60FA6C402E7E95-8074
                        Fault Status: 00101101
                        Fault Frequency: 14
                        Reset counter: 236
                        Mileage: 149384 km
                        Date: 2020.01.09
                        Time: 06:19:06
                        Voltage: 13.46 V
                        Count: 236
    02443 - Control Head
                        Fault Status: 00111100
                        Reset counter: 211
                        Voltage: 5.18 V
                        Count: 40
    01487 - System Function Test
                        Reset counter: 210
                        Voltage: 0.00 V
                        Count: 184
       Coding: 0000016
       VCID: 290FFB2BD5FEC3AFBEB-807C
       Subsystem 1 - Part No: 4F0 941 329 D
       Component: AFS-Modul links H01 0010
       Subsystem 2 - Part No: 4F0 941 329 D
       Component: AFS-Modul rechtsH01 0010
                        Reset counter: 210
                        Mileage: 148392 km
                        Date: 2019.12.15
                        Time: 09:22:53
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
       Revision: 00000000    Serial number: 394KY077840270
       VCID: 2E050837EC10A4976B9-807A
                        Reset counter: 238
                        Mileage: 148393 km
                        Date: 2019.12.17
                        Time: 11:41:29
       Part No SW: 4F0 910 181 F    HW: 4F0 915 181 B
       Component: J0644 BEM       H12 0760
       Revision: 00000000    Serial number: 00000000046802
       Component: von VA0  33100881GF
       Coding: 344630393135313035442056413033333130303838314746
       Shop #: WSC 47212 000 1048576
    02272 - Quiescent Current Stage 1
                        Fault Frequency: 34
                        Mileage: 132741 km
                        Date: 2019.01.26
                        Time: 09:56:59
                        Fault Frequency: 20
                        Date: 2019.02.10
                        Time: 12:38:09
    02276 - Quiescent Current Stage 5
                        Fault Frequency: 17
                        Mileage: 133371 km
                        Date: 2019.02.19
                        Time: 07:40:09
                        Reset counter: 211
                        Mileage: 148393 km
                        Date: 2019.12.17
                        Time: 10:57:44
                        Mileage: 149558 km
                        Date: 2020.02.09
                        Time: 08:14:59
       Component: TSG HL          H21 0210
       Coding: 0051754
       Revision: 00050100    Serial number: 00000900061988
       Coding: 0062725
       VCID: 221DEC07A8C810F7FF1-8076
                        Fault Status: 10100010
                        Reset counter: 210
                        (no units): 0.0
                        Voltage: 7.20 V
                        (no units): 42.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
       Component: SDS 3501 US     H46 0630
       Revision: 00000000    Serial number: 00000711210175
       Shop #: WSC 12336 024 394758
       VCID: 34311A5F023C8E471DD-8060
                        Reset counter: 210
                        Mileage: 148393 km
                        Date: 2019.12.17
                        Time: 11:51:25
       Part No SW: 4F0 910 441     HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J7Y20L0
       Coding: 1000204
       VCID: 5DE79FFBD1366F0F823-8008
                        Reset counter: 211
                            Term 15 Off
                            Reverse OFF
                        Count: 3
                        Reset counter: 210
                            Term 15 Off
                            Reverse OFF
                        Count: 3
                        Fault Status: 01101101
                        Reset counter: 198
                        Mileage: 149557 km
                        Date: 2007.05.19
                        Time: 11:58:23
                            Reverse OFF
                        Count: 3
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Component: TSG HR          H21 0210
       Coding: 0051754
       Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
       Revision: 00H09000    Serial number: 06240733203523
       Coding: 0021306
       Part No SW: 4F0 910 336 E    HW: 4E0 862 335
       Component: Handyvorb2      H18 0950
       Revision: 00000000    Serial number: 00000005016868
       Coding: 0010900
                        Reset counter: 41
    End----(Elapsed Time: 02:16, VBatt start/end: 11.7V/11.3V. VIgn 11.3V)-----
    Thursday,27,February,2020,17:13:01:32286
  4. Likes PetrolDave liked this post
    Jun 2014
    Clear faultcodes and see which of them show up again in your next autoscan...
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
    Feb 2020
    the first scan is the cleared version.
