Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Advanced Measuring Values
    HQ
    With Advance Measuring Values, you can cherry pick what live data you wish to view/log. Without getting into too much detail here, on UDS Modules you have to use the [Adv. Meas. Values] function, and on non-UDS modules, if we (Ross Tech) have documentation in the form of a label file for a given control module, then the [Adv. Meas. Values] is a bonus feature.
    We often get asked by customers how can they see what all data a given control module can display. If there is a label file for a non-USD module, then you can click on the [Adv. Meas. Values] button and get a list of the documented data Ross Tech has. Now this will be the same data as with [Meas. Blocks - 08], but as noted, you can cherry pick what data you view. You can create lists and save them for later use as well.
    From the Open Controller screen, click on the [Adv. Meas. Values] button.
    You will have 2 windows opened up:
    In the example above, I've gone ahead and cherry picked the live data I wish to view/log. This is the same data as in Measuring Blocks. Notice on the smaller window on the right, the "Loc." column, the 001, 003, 004, ect, those are Measuring Block Groups numbers. And the -1, -2, -3, -4 are the fields 1 to 4. There is no 002 listing because the label file doesn't have information on Measuring Block 002.
    So after I've checked off the values I want to view, you can save these settings, click on the tiny VCDS icon that the red arrow is pointing to.
    From the drop menu, click on "Save Selection to file..."
    Give the file a name now, "forum_sample" for demo purposes here, then click on [Save].
    Now if at a later date, I wish to view those same cherry picked values, go into [Adv. Meas. Values], click on the tiny VCDS icon, select "Load selection from file..." and locate the profile I created.
    Ross Tech has included several helpful profiles as well.
    Enjoy.
    Jef
    Mar 2014
    Is it possible to create custom measuring block files while not connected to the car? I've only tried working with these while sitting in the car, but it would be advantageous to work on building custom files for later use. Thanks.
  3. Likes aTOMic liked this post
    It is possible, but you have to do it "by hand" (using Notepad).
  5. Likes vwdoc1, El Polaco liked this post
    Jan 2016
    Australia
    Is there any way to log a snapshot in time of every available value when using "Advanced Measuring Values" due to measuring blocks not being available. Doing 12 at a time is a bit much when trying to capture all 1000 in a list (for 7 speed dual clutch gearbox). I know I don't need all the data, but the problem is I don't know what I might need! Thanks
    It would take a considerable time to get all 1000, so even if we did this, it would not constitute a "snapshot".
    Jan 2016
    Australia
    If the vehicle is kept in a constant state (Ignition on, Engine on with vehicle stationary, Engine on with cruise engaged on a flat highway) during the considerable time it would achieve the goal of capturing a snapshot. I can write "send keys" scripts in VBA, however cannot work out how to click and unclick the boxes. Any clues as to the keyboard command to do so? Or other avenues to achieve the goal? Thanks
    Dec 2016
    Greece
    where can i found block 93 in adv meas values? I don't see loc. Maybe these...
    Friday,21,April,2017,19:58:46:43878
    VCDS Version: 17.1.3.0 (x64)
    VIN: WVWZZZ6RZBY077822 License Plate:
    Address 01: Engine (03F 906 070 D)
    19:58:42
    ENG110223-ENG103487 X_Intake_camshaft_signaledge_position_adapted_valu e_Edge2-PSN_EDGE_2_AD_CAM_IN_1 7.6875
    ENG110224-ENG100550 X_Intake_camshaft_signaledge_position_adapted_valu e_Edge3-PSN_EDGE_3_AD_CAM_IN_1 -0.5625
    ENG110225-ENG100831 X_Intake_camshaft_signaledge_position_adapted_valu e_Edge4-PSN_EDGE_4_AD_CAM_IN_1 7.3125
    ENG110226-ENG99342 X_Intake_camshaft_signaledge_position_adapted_valu e_Edge5-PSN_EDGE_5_AD_CAM_IN_1 -0.5625
    ENG110227-ENG100824 X_Intake_camshaft_signaledge_position_adapted_valu e_Edge6-PSN_EDGE_6_AD_CAM_IN_1 9.1875
    ENG110228-ENG102698 X_Intake_camshaft_signaledge_position_adapted_valu e_Edge7-PSN_EDGE_7_AD_CAM_IN_1 0.7500
    ENG110229-ENG102604 X_Intake_camshaft_signaledge_position_adapted_valu e_Edge8-PSN_EDGE_8_AD_CAM_IN_1 7.1875
    i have only adv meas values. My engine is 1.2tsi 8v.
  10. #8
    Quote Originally Posted by christosar View Post
    Your ECU uses UDS protocol. There is no "block 93" and I'm not sure what values would correspond to the data that would be found in block 93 in older ECUs.
  11. #9
    Jun 2017
    I used Advanced Measuring Values when checking whether my fans were coming on ... or not. I could watch the temperatures at the radiator OUTLET, at the radiator INLET ... and the precise temperature at which the fans turned ON ... and OFF.
    What was interesting is ... the fans are variable speed ... so they might only run at 10% speed initially, or they might increase in speed if cooling requirements were greater. That's why I couldn't "hear" the fans running ... I thought they were broken!
    Very useful!
  12. Likes Uwe liked this post
  13. #10
    Jul 2015
    Parameters
    Is there a way to see what the expected "normal" values should be with the uds advanced measuring block. I'm specifically looking to know what "camshaft adjustment intake bank 1 actual" should be at warm idle. This would be on 2012 2.0 tsfi
