Passat B8 doesn't start on the mornings
Amarton
Europe - Hungary
C?ID=338434
There is a Passat B8 with a strange electric problem.
On the mornings the engine not start and there are a lot of warning symbols on the dash.
In ignition and after 10 minutes later the car could start and works all the day until the next morning.
Gateway electronic was replaced but nothing happened.
It looks like the failure is depends on the temperature because if the front of the car get direct sunlight the failure also disappears.
Sunday,09,February,2020,17:31:41:64377
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
Workshop Code: 790 73430 000063
VIN: WVWZZZ3CZFE433115   License Plate: EDJ-725
Mileage: 183453km-113992mi   Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69 6C
VIN: WVWZZZ3CZFE433115   Mileage: 183453km-113992miles
2B-Steer. Col. Lock -- Status: Malfunction 0010
Address 01: Engine (J623-DCXA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 DJ    HW: 04L 907 309 R
   Component: R4 1,6L EDC   H21 1133
   Revision: B5H21---
   Coding: 0119001203541D093000
   Shop #: WSC 52525 001 1048576
   ASAM Dataset: EV_ECM16TDI01104L906026DJ 003002
   ROD: EV_ECM16TDI01104L906026DJ_002_VW48.rod
   VCID: 75B7E2AF054E813FEA1-8021
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [040] - -
          [Diagnostic interface for data busRead out DTC]
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:48:04
                    Engine speed: 1871.00 /min
                    Normed load value: 21.2 %
                    Coolant temperature: 63 °C
                    Intake air temperature: 41 °C
                    Voltage terminal 30: 13.840 V
                    Unlearning counter according OBD: 35
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Acceleration: 0.000 m/s²
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [036] - -
                    Fault Frequency: 8
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:48
                    Coolant temperature: 2 °C
                    Intake air temperature: 2 °C
                    Voltage terminal 30: 11.520 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Drivetrain coordinator: brake function status-Bits 0-7: 4
7158 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [040] - -
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:47:04
                    Engine speed: 979.50 /min
                    Normed load value: 30.6 %
                    Coolant temperature: 62 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 13.780 V
                    Engine control module reset status-Bits 0-7: 2
                    Limitation: torque: 122.2 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 2
                    Accelerator pedal travel: raw value: 0.00 %
                    Engine torque: 37.4 Nm
                    Generator: load signal: 30.00 %
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 63354000002857
   Coding: 0FEC6A8F34230B6F0778060141C849F0562CD0E0608292F11440F078C002
   VCID: 7EA5FD833078C267BBB-802B
17 Faults Found:
8246 - Databus
          [FCAN: Motor_Code_01 message is not received]
                    Fault Frequency: 13
                    Reset counter: 116
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:24
8250 - Databus
          [FCAN: Motor_07 message is not received]
                    Fault Frequency: 13
                    Reset counter: 116
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:24
8252 - Databus
          [FCAN: Motor_11 message is not received]
                    Fault Frequency: 18
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
8254 - Databus
          [FCAN: Motor_12 message is not received]
                    Fault Frequency: 18
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
8256 - Databus
          [FCAN: Motor_14 message is not received]
                    Fault Frequency: 20
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:30
8258 - Databus
          [FCAN: Motor_20 message is not received]
                    Fault Frequency: 18
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
8264 - Databus
          [FCAN: Tsk_06 message is not received]
                    Fault Frequency: 18
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
8351 - Databus
          [FCAN: Motor_17_alt veraltet bit is set]
                    Fault Frequency: 18
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:31
8366 - Databus
          [FCAN: Charisma_01 is not received]
                    Reset counter: 110
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:24
8368 - Databus
          [FCAN: Charisma_07 is not received]
                    Reset counter: 110
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:24
16409 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
                    Fault Frequency: 10
                    Reset counter: 116
                    Mileage: 182952 km
                    Date: 2020.02.03
                    Time: 15:28:10
16410 - Display for Tire Pressure Monitoring
                    Fault Frequency: 10
                    Reset counter: 116
                    Mileage: 182952 km
                    Date: 2020.02.03
                    Time: 15:28:10
16416 - Display for Tire Pressure Monitoring
                    Fault Frequency: 10
                    Reset counter: 116
                    Mileage: 182952 km
                    Date: 2020.02.03
                    Time: 15:28:10
32865 - Databus
          [IPB_BUS: Motor_12 / MO_Drehzahl_01]
                    Fault Frequency: 16
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:30
32866 - Databus
          [IPB-BUS: Motor_20 / MO_Solldrehz_Leerlauf invalid]
                    Fault Frequency: 16
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:30
32867 - Databus
          [IPB-BUS: Motor_11 / MO_Mom_ist_Summe invalid]
                    Fault Frequency: 16
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:30
32872 - Databus
          [IPB-BUS: Motor_20 / MO_Fahrpedalrohwert_01invalid]
                    Fault Frequency: 16
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:30
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0355060099
   Coding: 000F0F0603
   Shop #: WSC 05311 115 00312
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   VCID: 77ABE8A71F42F32FF8D-8023
12716804 - Databus
          [Message Motor_14 missing]
                    Fault Frequency: 16
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:30
12718343 - Databus
          [Message Motor_07 missing]
                    Fault Frequency: 12
                    Reset counter: 116
                    Mileage: 182952 km
                    Date: 2020.02.03
                    Time: 15:28:04
12718344 - Databus
          [Message Motor_09 missing]
                    Fault Frequency: 12
                    Reset counter: 116
                    Mileage: 182952 km
                    Date: 2020.02.03
                    Time: 15:28:04
12786206 - Databus
          [Message Gateway_73  invalid Qbit received]
                    Fault Frequency: 7
                    Reset counter: 116
                    Date: 2020.02.03
                    Time: 15:27:59
   Part No SW: 5G0 907 044 AH    HW: 5G0 907 044 AH
   Revision: 00001K10
   Coding: 12020104202100012015500000101802
   Shop #: WSC 00015 115 00001
   VCID: 6D87CACF6D1E49FF121-8039
   Air quality sensor:
459525 - Databus
          [Diagnoseinterface für Datenbus - bitte Fehlerspeicher auslesen]
                    Fault Frequency: 15
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:32
459023 - Databus
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Fault Frequency: 15
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:32
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86583011140637
   Coding: 00070C46C24102FF4BE44004001C07081880000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DA7FA8F3D7ED97FA21-8029
   Component: WWS    141121  042 0607
   Serial number:         141128123011
   Component: RLHS  037 0059
   Serial number: S2Y14M12D09H12M43S06
   Coding: 00A8DD
   Serial number: 21 11 2014  00000064
541973 - Databus
                    Fault Frequency: 15
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:32
559125 - Databus
                    Fault Frequency: 11
                    Reset counter: 116
                    Mileage: 182952 km
                    Date: 2020.02.03
                    Time: 15:28:06
555541 - Databus
                    Fault Frequency: 15
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:32
542229 - Databus
                    Fault Frequency: 14
                    Reset counter: 116
                    Mileage: 182952 km
                    Date: 2020.02.03
                    Time: 15:28:02
542485 - Databus
                    Fault Frequency: 11
                    Reset counter: 116
                    Mileage: 182952 km
                    Date: 2020.02.03
                    Time: 15:28:06
   Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0053
   Revision: --------    Serial number: 39391433506963
   Coding: 0071151101
   VCID: 40D9437B0A0C7497897-8015
13637426 - Databus
                    Fault Frequency: 19
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0126
   Coding: 2A40600910FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 33331CB74BBADF0F045-8067
10 Faults Found:
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Fault Frequency: 18
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 13.0 V
0933 - Databus
          [FAULT_MOTOR_AGED_DATA]
                    Fault Frequency: 18
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
1064 - Databus
          [FAULT_TIMEOUT_MOTOR_14]
                    Fault Frequency: 16
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
1065 - Databus
          [FAULT_TIMEOUT_MOTOR_16]
                    Reset counter: 116
                    Mileage: 183430 km
                    Date: 2020.02.09
                    Time: 16:40:49
                    Control Module temperature: 8 °C
                    Voltage terminal 15: 12.1 V
1067 - Databus
          [FAULT_TIMEOUT_MOTOR_20]
                    Fault Frequency: 18
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
                    Control Module temperature: 26 °C
                    Status_ACC_System: ACC_Init
1126 - Databus
          [FAULT_TIMEOUT_MOTOR_35]
                    Fault Frequency: 16
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
1133 - Databus
          [FAULT_TIMEOUT_MOTOR_CODE_01]
                    Fault Frequency: 12
                    Reset counter: 116
                    Mileage: 182952 km
                    Date: 2020.02.03
                    Time: 15:28:04
                    Control Module temperature: 20 °C
                    Voltage terminal 15: 12.7 V
1088 - Databus
          [FAULT_TIMEOUT_TSK_06]
                    Fault Frequency: 18
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
1085 - Databus
          [FAULT_TIMEOUT_TSK_08]
                    Fault Frequency: 15
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
1139 - Databus
          [FAULT_TIMEOUT_TSK_Ausrollkurve_01]
                    Fault Frequency: 16
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
   Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R2PRAZDR/
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 025D89734480A687DF3-8057
   Subsystem 1 - Part No SW: -----------    HW: 454 002 911 14
   Serial number: 3576U0000002C96CE11M
   Subsystem 2 - Part No SW: -----------    HW: 454 002 911 14
   Serial number: 3586U0000002BC6CE11P
   Subsystem 3 - Part No SW: -----------    HW: 454 800 312 14
   Serial number: 3516RBD254D050000009
   Subsystem 4 - Part No SW: -----------    HW: 454 800 512 14
   Serial number: 3526R19CA64050000004
   Subsystem 5 - Part No SW: -----------    HW: 454 800 512 14
   Serial number: 3556V476B42050000003
1053952 - Databus
          [NWD: 0x121 Motor_20 Timeout]
                    Fault Frequency: 20
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:28
1054720 - Databus
          [NWD: 0x385 Charisma_01 Timeout]
                    Reset counter: 110
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:22
1056000 - Databus
          [NWD: 0x3BE Motor_14 Timeout]
                    Fault Frequency: 20
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
1057792 - Databus
          [NWD: 0x0A8 Motor_12 Timeout]
                    Fault Frequency: 20
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:28
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141128400492
   Coding: 0400
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D273A8F7DFE197FE21-8069
   Part No SW: 3G0 920 751     HW: 3G0 920 751
   Component: KOMBI         306 5305
   Coding: 03A40A102F80000800886A001000000000000000
   Shop #: WSC 12345 233 12345
   ASAM Dataset: EV_DashBoardJCIMQBAB 009003
   ROD: EV_DashBoardJCIMQBAB_009_VW48.rod
   VCID: 629DA9F3A4C00687BF3-8037
16776971 - Databus
          [Motor_04 keine Kommunikation]
                    Fault Frequency: 19
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
16776988 - Databus
          [TSK_07 keine Kommunikation]
                    Fault Frequency: 19
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:29
16777024 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_BCME_0x23 keine Kommunikation]
                    Reset counter: 110
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:52
   Revision: --------    Serial number: 26111410802289
   Coding: 030300344F085900EF00025A080F00010001070000000000000000000000
   Shop #: WSC 03009 041 08297
   ROD: EV_GatewConti_011.rod
   VCID: 72BDD9B374209607CF3-8027
   Component: E221__MFL-DC1  H16 0038
   Serial number: 27140003038130034487
   Coding: 2CFFFF
   Analog clock:
   Subsystem 3 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 0412201400010287
131668 - Headlight Range Control Module
          U101E 00 [008] - No Communication
          [Timeout Knoten 0x54 / 55 - Steuergerät für Leuchtweitenregelung]
                    Reset counter: 113
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:29
                    Supply voltage: Terminal 30: 12.6 V
                    Terminal 15: On
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [008] - -
          [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
                    Reset counter: 113
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:29
                    Terminal 15: On
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
          [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                    Fault Frequency: 42
                    Reset counter: 116
                    Mileage: 182952 km
                    Date: 2020.02.03
                    Time: 15:28:02
                    Supply voltage: Terminal 30: 12.7 V
                    Terminal 15: On
66567 - Local Databus
          U1030 00 [008] - Electrical Malfunction
          [LIN#1 (LIN-Energie) elektrischer Fehler]
                    Fault Frequency: 25
                    Reset counter: 110
                    Mileage: 182954 km
                    Date: 2020.02.03
                    Time: 19:33:41
                    Supply voltage: Terminal 30: 14.1 V
                    Terminal 15: On
197175 - Control unit for battery monitoring
          U1050 00 [009] - No Communication
          [BDM (LIN#1) Timeout]
                    Fault Frequency: 154
                    Reset counter: 77
                    Mileage: 182954 km
                    Date: 2020.02.03
                    Time: 19:26:40
                    Supply voltage: Terminal 30: 12.9 V
                    Terminal 15: OFF
8526353 - Generator
          P1B00 00 [008] - Mechanical Malfunction
                    Reset counter: 116
                    Mileage: 183430 km
                    Date: 2020.02.09
                    Time: 16:49:42
                    Supply voltage: Terminal 30: 12.3 V
                    Terminal 15: OFF
   Serial number: 14000306549003
   Coding: 0000000000000000
   Shop #: WSC 00015 115 08193
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD6BF7126AD1F369-8025
12666369 - Databus
          [Timeout Message Motor_14]
                    Fault Frequency: 16
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:30
                    Result lock conditions: invalid
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Lock sensor: not activated
                    Unlock sensor: operated
                    Error mode 1: not active
                    Error mode 2: not active
                    Clamp S: On
                    Clamp 15: On
                    Clamp 15 Status: valid
                    Remote Start: not active
                    Driver door: closed
                    Central locking locked external: unlocked
                    Central locking safed external: Vehicle not secured
                    Clamp Request: No
                    Request highside lock: No
                    HW highside lock: OFF
                    Highside unlock: No
                    Motor break: not active
                    Activation lowside unlock: OFF
                    Activation lowside lock: OFF
                    I2C overflow: No
                    I2C error pathflags: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C length failure: No
                    I2C error sda: No
                    I2C communication failure: i2c no comm failure
                    I2C state esp 10: i2c cnd true
                    I2C cnd haco message: valid
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: Yes
                    Signature IMS OK: Yes
                    IMS responded: Yes
                    Positive authentification in current KL15 cycle: No
                    Lifestate: Immobilizer download obtained
                    Authentication valid (T1): No
                    State of authentication state machine: WFS_AUTH_INIT_e
                    Vehicle speed: 0.00 km/h
                    UBat internal: 12.4 V
                    UMotorBridge: 6.7 V
                    Lock condition engine speed: Condition met
                    Lock condition clamp S: Condition not met
                    Lock condition clamp 15: Condition not met
                    Lock condition E2E clamp status: Condition not met
                    Lock condition timeout clamp status: Condition met
                    Lock condition vehicle speed: Condition met
                    Lock condition E2E vehicle speed: Condition met
                    Lock condition timeout vehicle speed: Condition met
                    Lock condition Mode1: Condition met
                    Lock condition drive readiness: Condition met
                    Lock condition selector lever position parking: Condition met
                    Clamp enable ESCL: not enabled
                    Lock condition timeout distance pulse: Condition met
                    Lock condition E2E distance pulse: Condition met
                    Lock condition difference distance pulse: Condition met
   Serial number: 041214BL405129
   Coding: 00350B20D000020000001000
   VCID: 42DD4973040066879F3-8017
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000536947
458803 - Databus
          [Motor_14 Datenbus fehlende Botschaft]
                    Fault Frequency: 16
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:30
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000094302
   Coding: 01000010005000
   Shop #: WSC 00015 115 00312
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
   VCID: 3B23349763EA174FDC5-806F
3158274 - Databus
          [Ausfall der CAN-Botschaft "Motor_12" des Motor-SG (über GW)]
                    Fault Frequency: 19
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:31
                    Write only channel
3161872 - Databus
          [Ausfall der CAN-Botschaft "Motor_Code_01" des Motor-SG (über GW)]
                    Fault Frequency: 15
                    Reset counter: 116
                    Mileage: 182952 km
                    Date: 2020.02.03
                    Time: 15:28:04
                    Write only channel
3161888 - Databus
          [Ausfall der CAN-Botschaft "Motor_11" des Motor-SG (über GW)]
                    Fault Frequency: 19
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:31
                    Write only channel
3161920 - Databus
          [Ausfall der CAN-Botschaft "Motor_14" des Motor-SG (über GW)]
                    Fault Frequency: 19
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:31
                    Write only channel
3161984 - Databus
          [Ausfall der CAN-Botschaft "Motor_20" des Motor-SG (über GW)]
                    Fault Frequency: 19
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:31
                    Write only channel
   Serial number: 011214BKU14434
   Coding: 00350120D000020000001000
   VCID: 41DF467F01067D9F869-8015
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000528304
   Coding: 090000
458803 - Databus
                    Fault Frequency: 16
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:30
   Coding: 039A00000F200200
   VCID: 3FDB408777F20B6FF0D-806B
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Coding: E02400
   Component: LeiMo rechts  H02 0003
   Coding: E02400
13705484 - Databus
          [Charisma_01 Datenbus fehlende Botschaft]
                    Reset counter: 110
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:22
13705475 - Databus
          [Motor_20 Datenbus fehlende Botschaft]
                    Fault Frequency: 15
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:30
   Part No SW: 3Q0 035 864     HW: 3Q0 035 864
   Component: MU-S-N-ER     H10 0138
   Serial number: VWZAZ2P4650762
   Coding: 02840201FF00000011110001000808001F0100C401200100CC
   Shop #: WSC 05311 115 00091
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW48.rod
   VCID: 6E85CDC36018B2E72BB-803B
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H42 1017
   Serial number: VWZ8Z9PD800JUK
   Subsystem 2 - Part No SW: 3G0 919 866 E    HW: -----------
   Component: ECE 2015  --- 0335
6708 - Databus
          [Engine: no communication]
                    Fault Frequency: 12
                    Reset counter: 116
                    Mileage: 182952 km
                    Date: 2020.02.03
                    Time: 15:28:04
                    Voltage terminal 30: 12.8 V
                    Network diagnosis-Status: Enabled
7202 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Driver alert system (0x22) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 110
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:20
                    Voltage terminal 30: 12.6 V
                    BAP-BAP_Function_ID: 02
7203 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Efficiency program (0x23) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 110
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:20
7207 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Start/stop reasons (0x27) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 110
                    Mileage: 182953 km
                    Date: 2020.02.03
                    Time: 16:44:20
   Part No SW: 5Q0 907 383 J    HW: 5Q0 907 383 B
   Component: Anhaenger     H21 0203
   Revision: 8C001003    Serial number: 0379949714
   Coding: 0100000202000000
   VCID: 3E253D8370F80267FBB-806B
336388 - Databus
          [Engine electronics - no signal/communication]
                    Fault Frequency: 36
                    Reset counter: 116
                    Mileage: 182944 km
                    Date: 2020.02.03
                    Time: 14:38:30
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 0184020143002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
End----------(Elapsed Time: 02:02, VBatt start/end: 14.5V/14.5V)-----------
downtime
C?ID=280813
Wiring issue most likely. Either can wires, power supply or grounding issue.
EDIT:
After more examination, all the errors seem to be to modules that are in engine bay. Check the wiring that goes from inside to engine bay. There's a passthrough for those cables behind the pedals. The passthrough is just above the rest pedal.
Also check the visible grounding bolts on the engine bay if the wires attached to those are damaged.
Amarton
Europe - Hungary
C?ID=338434
EDIT:
Thanks.
Which modules do you think of.
If this is a wiring problem, why not appear while driving? While driving, the wire moves everywhere.
downtime
C?ID=280813
The modules generating errors are motor, abs system, generator LIN, battery LIN and headlight range control. The latter is not in the engine bay but AFS light modules are and my guess is that this error is actually generated from there.
And yes, you have a good point there. But what you wrote that if the sun is shining on the car for some time it starts just fine. That would indicate a wiring or similar issue as there's heat related expansion happening in the materials.
Check the grounding points in the engine bay. I would start from there before jumping to pass through wiring.
Temporary ground enhanced with set of jumper cables to chassis and battery direct plus block tried yet?
Battery specific gravity bad cold or has it been checked yet?
Amarton
Europe - Hungary
C?ID=338434
There is a brand new battery and coded well.
