Results 1 to 5 of 5
Thread: 2009 TTRS AWD-22 CODES 01314 AND 01315 (GEN 4 HALDEX)
    Feb 2020
    Hi all,
    Please be gentle this is my first post on here and although I have owned a fully licensed HEX+CAN cable for many years I am still a novice for the most part. Also apologies in advance for the lengthy post, I just feel it helps to add a bit of backstory and include as much detail as possible.
    So the issue I'm having arose shortly after fitting a "Dutchbuild" haldex controller, now this is not a traditional competition haldex controller which would replace the stock module, this actually retains the stock unit and is installed inline between the car and contoller. If I have not explained that clearly enough please visit the link here for more information http://www.vdveer-engineering.nl/ind...dex-controller. Also before installing on the car I updated the firmware to the latest version and downloaded the latest version of the app.
    Anyway moving on to the issue at hand, I installed the inline controller on Monday and drove the car monitoring the haldex bias with the software app on my phone and everything seemed to be working fine. To start with I left it in passthru mode which means the inline controller does not alter the signal going to the haldex module so the haldex will behave as it would completely stock. I also tested the lock function and that seemed to work perfectly well too keeping the bias locked in 30/70, 40/60, 50/50 as I selected.
    Fast forward to Tuesday, driving home from work I thought I'd give the car a bit of a blast and watch the bias as it changed in real time on the app in passthru mode as I wanted to monitor stock haldex bias behavior before creating my own bias maps as it were (for track use mostly). At first no problems but then I started getting a lot of wheel spin in all gears and the esp light was flashing at me, also noticed the bias showing on the app was no more than around 97/3 even at wot in low gears.
    So I scan the car, stupidly I didn't autoscan and save straight away but I had several faults indicated on the ABS, AWD and CAN gateway modules for AWD module, powertrain databus, diagnostic interface for databus, transmission control module (no communication), engine control module (implausible signal). Having done some googling and from talking with dutchbuild themselves it was suggested the CAN gateway needed to re-evalute the network and in order to do this I should recode it with the original coding. I did this and it cleared all the faults bar 2 on the AWD-22 module for transmission control unit and engine control unit. Obviously with the car being a manual the transmission code was odd, so I attempted to recode the AWD module as was suggested in this thread https://forums.ross-tech.com/showthr...t=haldex+01315. Unfortunatley this had no effect even when changing the wsc to non zeros, I also cycled the key after every coding attempt but as soon as I clear the codes on that module they reappear straight away. Here is the autoscan
    VCDS Version: 19.6.2.0 (x64)
    VIN: TRUZZZ8JXA1900307   License Plate: T77RSW
    Mileage: 129140km-80243mi   Repair Order:
    Chassis Type: 8J (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 37 3D 42 44 46 47 52 55 56 77
    VIN: TRUZZZ8JXA1900307   Mileage: 129140km-80243miles
    3D-Special Function -- Status: OK 0000
    Address 01: Engine (CEP)       Labels:. 07K-907-404-CEP.clb
       Part No SW: 8J0 907 404     HW: 8J0 907 404
       Component: 2.5l R5/4V TFSI     0020
       Revision: F4H03---    Serial number: AUX7Z0I3FNS0PS
       Coding: 0113000C180F0160
       Shop #: WSC 01236 785 00200
       VCID: 6ADBCDA045368F1F19-803E
    Readiness: 0000 0001
    Address 03: ABS Brakes        Labels: 8J0-614-517.clb
       Part No SW: 8J0 910 517     HW: 8J0 614 517 C
       Component: ESP MK60E1          0010
       Revision: 00H60001
       Coding: 0610199
       Shop #: WSC 64465 001 1048576
       VCID: 69D9B2AC4030840710-803C
       Part No SW: 8J0 820 043 AQ    HW: 8J0 820 043 AQ
       Component: J255  Klima 1 Zone  0090
       Revision: 00H08006    Serial number: 00000001128652
       Coding: 1573893
       VCID: 75E1EEDC1C8850E784-8020
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
       Component: Bordnetz-SG     H54 2801
       Revision: 00H54000    Serial number: 00000009592348
       Coding: F0061E8380141C80CF18000A1800000000894E875B260A02008000000000
       VCID: 489F57283BFA9D0F2F-801C
       Subsystem 1 - Part No: 8J2 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer AU354   H08 0070
       Coding: 00064784
       Shop #: WSC 01236
       Coding: 00149804
       Shop #: WSC 01236
    Address 15: Airbags        Labels: 8J0-959-655.lbl
       Part No SW: 8J0 959 655     HW: 8J0 959 655
       Component: -r Airbag 9.43  H03 0020
       Revision: 93H03002    Serial number: 0036K003NDK2
       Coding: 0011634
       VCID: 79F9E2EC30903487E0-802C
       Subsystem 1 - Serial number: 6332DRB408DA531BY
       Subsystem 2 - Serial number: 6342DRB408B3CAA3+
       Subsystem 3 - Serial number: 63747RB404CE64A5
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0004041
       VCID: 41894A0C18C0AC47E8-8014
       Component: E0221           H06 0030
    Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
       Part No SW: 8J0 920 980 G    HW: 8J0 920 980 G
       Component: KOMBIINSTR. VDO H02 0480
       Revision: D0H02002    Serial number: 2243I002000032
       Coding: 0037428
       VCID: 35612EDC5C0810E744-8060
       Component: J533__Gateway   H16 0210
       Revision:   H16       Serial number: 3400K094070228
       Coding: E9831F06510602004101
       VCID: 377D24D44604E2F756-8062
       Part No SW: 2K0 907 554     HW: 2K0 907 554
       Component: Haldex 4Motion      5003
       Coding: 0000005
       VCID: 6BD5C8A44ACC961762-803E
                        Reset counter: 138
                        Mileage: 129140 km
                        Date: 2020.02.26
                        Time: 16:01:28
                        Reset counter: 138
                        Mileage: 129140 km
                        Date: 2020.02.26
                        Time: 16:01:28
       Revision: D0H02002    Serial number: AUX7Z0I3FNS0PS
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8J0 035 193     HW: 8J0 035 193
       Component: RNS-E PU EU     H02 0220
       Revision: 0000001S    Serial number: AUZBZ7J6301194
       Coding: 0619757
       Shop #: WSC 00976 210 67917
       VCID: 67DDB4945624B27706-8032
    02261 - Data Medium
                        Fault Status: 00101110
                        Fault Frequency: 182
                        Reset counter: 171
                        Mileage: 126465 km
                        Date: 2019.11.06
                        Time: 08:03:52
                        Mileage: 129140 km
                        Count: 2602
                        Clock: 13:32
    Address 3D: Special Function        Labels: 8K0-907-440.clb
       Part No SW: 8K0 907 440 A    HW: 8K0 907 440
       Component: STS             H04 0010
       Revision: S0H04000    Serial number: 00000000004331
       Coding: 01010101000000000000000101
       VCID: 2C570BB88F42512F2B-8078
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
       Part No SW: 8J8 959 801 D    HW: 8J8 959 801 D
       Component: Tuer-SG         H03 0080
       Coding: 0004661
       VCID: 3E7331F0693ED3BF95-806A
       Part No: 8J0 909 144 R
       Component: EPS_ZFLS Kl. 239    3501
       Revision: 00H22000
       VCID: 3F8D4CF46E34DAB79E-806A
    Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
       Part No: 8J0 959 433 B
       Component:    KSG          H11 0080
       Coding: 1890300001182D298505489AD637
       Subsystem 2 - Part No: 8J0 951 177
       Component: DWA-Sensor      H03 0020
    Address 47: Sound System        Labels: 8J0-035-223.lbl
       Part No SW: 8J0 035 223 D    HW: 8J0 035 223 D
       Component: J525 Amp High   H04 0160
       Revision: PROD_01     Serial number: 00000000005089
       Coding: 0246317
       VCID: 2541FE9CECA86067F4-8070
    16349 - Control Module - Error in Output Stage
                        Reset counter: 92
                        Mileage: 90376 km
                        Date: 2016.11.22
                        Time: 15:35:09
       Part No SW: 8J8 959 802 D    HW: 8J8 959 802 D
       Coding: 0004660
       Part No SW: 4L0 910 357     HW: 4L0 907 357
       Component: AFS 1           H01 0050
       Coding: 0000024
       Subsystem 1 - Part No: 8E0 941 329 A
       Component: AFS-Modul links H05 0030
       Subsystem 2 - Part No: 8E0 941 329 A
       Component: AFS-Modul rechtsH05 0030
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Coding: 0619757
    02261 - Data Medium
                        Reset counter: 171
                        Mileage: 126465 km
                        Date: 2019.11.06
                        Time: 08:03:52
                        Mileage: 129140 km
                        Count: 2602
                        Clock: 13:32
       Part No SW: 8P0 862 335 S    HW: 8P0 862 335 S
       Component: FSE_256x BT     H34 0550
       Revision: 00000000    Serial number: 00000005086494
       Coding: 0011422
       VCID: 4683591031EE8B7FDD-8012
    End-------------------------(Elapsed Time: 02:05)--------------------------
    So I removed the inline controller and carried out another full scan, this time only 1 fault on AWD-22 for 01315 transmission control module fault but again I am unable to clear it without it immediately reappearing. That scan is here
       Revision: 00H60001
       Coding: 0610199
       Coding: 1573893
       Coding: 00064784
       Shop #: WSC 01236
       Coding: 00149804
       Shop #: WSC 01236
       Coding: 0011634
       Coding: 0004041
       Coding: 0037428
       Coding: 0000005
                        Reset counter: 138
                        Mileage: 129140 km
                        Date: 2020.02.26
                        Time: 12:59:30
       Coding: 0619757
    02261 - Data Medium
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 130
                        Mileage: 126465 km
                        Date: 2019.11.06
                        Time: 08:03:52
                        Mileage: 129140 km
                        Count: 2602
                        Clock: 12:49
       Coding: 0004661
       Revision: 00H22000
       Coding: 0246317
                        Reset counter: 92
                        Mileage: 90376 km
                        Date: 2016.11.22
                        Time: 15:35:09
       Coding: 0004660
       Coding: 0000024
       Coding: 0619757
    02261 - Data Medium
                014 - Defective
                        Reset counter: 130
                        Mileage: 126465 km
                        Date: 2019.11.06
                        Time: 08:03:52
                        Mileage: 129140 km
                        Count: 2602
                        Clock: 12:49
       Coding: 0011422
    End-------------------------(Elapsed Time: 02:09)--------------------------
    Address 19,1K0 907 530 S,recoded (Installation List),from,E9831F06510602004101,to,E9831F06510602004101,,
    Address 19,1K0 907 530 S,recoded (Long Coding),from,E9831F06510602004101,to,E9831F06510602004101,(01236/785/00200),
    Address 22: DTCs cleared
    So the question is why is the haldex still looking for a tcu especially since it is back to stock? I have looked in the CAN gateway installation list and auto trans is not checked. What do I need to do next?
    For reference here is an old auto scan from prior to fitting the inline controller
    VCDS Version: 18.9.0.2 (x64)
    Mileage: 117660km-73110mi   Repair Order:
    VIN: TRUZZZ8JXA1900307   Mileage: 117660km-73110miles
       VCID: 6ADBCDA045368F1A6B-803E
    001089 - EVAP Emission Control Sys
                   P0441 - 002 - Incorrect Flow - Intermittent
                        Mileage: 117657 km
                        Date: 2018.11.30
                        Time: 12:44:49
                        RPM: 705 /min
                        Load: 5.5 %
                        Temperature: 96.0įC
                        Temperature: 29.0įC
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.351 V
       Revision: 00H60001
       Coding: 0610199
       VCID: 69D9B2AC4030840262-803C
       Coding: 1573893
       VCID: 75E1EEDC1C8850E2F6-8020
       VCID: 489F57283BFA9D0A5D-801C
       Coding: 00064784
       Shop #: WSC 01236
       Coding: 00149804
       Shop #: WSC 01236
       Coding: 0011634
       VCID: 79F9E2EC3090348292-802C
       Coding: 0004041
       VCID: 41894A0C18C0AC429A-8014
       Coding: 0037428
       VCID: 35612EDC5C0810E236-8060
       VCID: 377D24D44604E2F224-8062
       Coding: 0000005
       VCID: 6BD5C8A44ACC961210-803E
       Coding: 0619757
       VCID: 67DDB4945624B27274-8032
    02261 - Data Medium
                014 - Defective
                        Fault Frequency: 95
                        Reset counter: 253
                        Mileage: 111543 km
                        Date: 2018.03.25
                        Time: 20:32:07
                        Mileage: 117660 km
                        Count: 212
                        Clock: 16:33
       VCID: 2C570BB88F42512A59-8078
       Coding: 0004661
       VCID: 3E7331F0693ED3BAE7-806A
       Revision: 00H22000
       VCID: 3F8D4CF46E34DAB2EC-806A
       Coding: 0246317
       VCID: 2541FE9CECA8606286-8070
                        Reset counter: 92
                        Mileage: 90376 km
                        Date: 2016.11.22
                        Time: 15:35:09
       Coding: 0004660
       Coding: 0000024
       Coding: 0619757
    02261 - Data Medium
                014 - Defective
                        Fault Frequency: 95
                        Reset counter: 253
                        Mileage: 111543 km
                        Date: 2018.03.25
                        Time: 20:32:07
                        Mileage: 117660 km
                        Count: 212
                        Clock: 16:33
       Coding: 0011422
       VCID: 4683591031EE8B7AAF-8012
    End-------------------------(Elapsed Time: 02:10)--------------------------
    Feb 2020
    Anyone have any pointers at all as to what I need to do next? To simplify I have put the car back to stock so all I really need to understand is why the awd module is still looking for a tcm which doesnít exist. Should I try recoding the abs module also as that originally had some faults stored which have now cleared? If so do I need a login to do that? Left scratching my head for now
    Quote Originally Posted by Heelandtoe77 View Post
    You're not the only one. The Haldex doesn't seem to have an explicit means of telling it whether there's an automatic trans or not.
    If it were mine, the first thing I would try is a cold-boot of the entire car. I.e. disconnect the battery for a while. I don't have high hopes for that, but it doesn't cost much to try.
    Feb 2020
    Thanks Uwe, I will try that. Iím just wondering if the abs has anything to do with it but Iím dubious to start fiddling around with the coding in there
    Feb 2020
    Unfortunately the hard reset didnít work as the code is still present. Anyone have any other ideas? 😅
