Saturday,22,February,2020,16:59:34:17886
VCDS Version: 19.6.2.0 (x64)
VIN: WVGZZZ7PZGD006090 License Plate: AHH820
Mileage: 47400km-29452mi Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 34 42 46 52 53 55 56 5F 62
69 6C 6D 72
VIN: WVGZZZ7PZGD006090 Mileage: 47400km-29452miles
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 A HW: 4G0 907 401
Component: 3.0TDI EDC17 H41 0001
Revision: 53H41---
Coding: 292A4012233E01020000
Shop #: WSC 36612 002 1048576
ASAM Dataset: EV_ECM30TDI0117P1907401A 001002
ROD: EV_ECM30TDI0117P1907401A.rod
VCID: 2E594C1E71529B3F05-807A
5568 - Sensor for Ambient Air Temperature (G17)
P0073 00 [032] - Signal too High
Address 02: Auto Trans (J217) Labels: 0C8-927-755.clb
Part No SW: 0C8 927 755 M HW: 0C8 927 755
Component: AL1000 AISIN 130 2879
Coding: 010100011C008400000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 3B7F754AB2207E97B2-806E
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 41185561296241
Coding: 5B6B13C34B242559DAF4C89CD2D2A470F701
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4C9D2696E78EC92F0B-8018
Part No SW: 4H0 907 064 GM HW: 4H0 907 064 GM
Component: BCM2 2.0 H37 0572
Coding: 01B60010000000000000
VCID: 7AF1B04EF59A879FE9-802E
Subsystem 1 - Part No SW: 7P6 959 754 AL HW: 7P6 959 754 AL
Component: FBSTOUAREGIDG H08 0084
Serial number: 3615000148089008
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 3215000107565003
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CK HW: 7P6 907 040 CK
Component: Klima 2 Zonen H23 1507
Coding: 3626200890
VCID: 7F07415AE6B8A2B7DE-802A
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00001121580302
Coding: 26000014D0345D010029400300005D4C431D670827010241000000000040110000000000000000
VCID: 6AD1800E853A371F19-803E
Subsystem 1 - Part No SW: 7P0 955 120 HW: 7P0 955 120
Component: WWS 150629 033 0021
Serial number: 90243401150707131130
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20602726
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AB HW: 7P6 941 431 AB
Component: E1 - LDS H02 0040
Serial number: 00000000003006150494
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28231514911578
Coding: 318504
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 448D0EB6CFDE016FC3-8010
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 F HW: 7P0 959 655 F
Component: VW10Airbag00T H10 0044
Revision: -------- Serial number: 003S8000CMVI
Coding: 000000000000000000000000000000003054
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
Serial number: 3575LRB404T3COSA78VO
Serial number: 3585LRB40633AVPA2OVE
Serial number: 3517ARB405P3DL7CGO6S
Serial number: 3527ARB405P3DL7CF1PO
Serial number: 3557BRB40513CGVECOAT
Serial number: 3567BRB40513CGVE6OCQ
Part No SW: 4H0 953 568 K HW: 7P6 953 507 AB
Component: Lenks.Modul H06 0005
Revision: -------- Serial number: 01374OG9000E3
Coding: 000035
VCID: 3B7F754ABA207E97B2-806E
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0045493 TRW 20140326
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 883 B HW: 7P6 920 883 B
Component: Kombi H13 0515
Revision: 13240302 Serial number: 658090715592059
Coding: 332731003A00000800000C
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526.rod
VCID: 3D7B7B52AC3470A78C-8068
Part No SW: 7P6 907 530 M HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H13 6042
Revision: -------- Serial number: 00000001911422
Coding: 000D07AD00
Shop #: WSC 12022 002 1048576
ROD: EV_GatewUDS_VW52.rod
VCID: 428108AED5CA0F5FF1-8016
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 42174B10155701315031
Voltage stabilizer:
Subsystem 2 - Part No SW: 7PP 959 663 E HW: 7PP 959 663 E
Serial number: 15188002035021200181
U140B 00 [008] - -
Reset counter: 89
Mileage: 44042 km
Date: 2019.12.25
Time: 17:48:20
Voltage terminal 30: 12.1 V
Voltage terminal 15: 0.0 V
Control Module temperature: 45 ∞C
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status: OFF
Datenfeld: 1
16384 - Function Restriction due to Driver Fatigue Recognition
B130E 00 [008] - -
Fault Frequency: 238
Reset counter: 118
Mileage: 35486 km
Date: 2019.02.15
Time: 19:34:40
Voltage terminal 30: 14.6 V
Voltage terminal 15: 14.6 V
Control Module temperature: 34 ∞C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Address 34: Level Control (J197) Labels:. 7P0-907-553.clb
Part No SW: 7P0 907 553 AF HW: 7P0 907 553 AF
Component: PASM H05 0750
Revision: 00000000 Serial number: 00000151880326
Coding: 14210000
ASAM Dataset: EV_PASMConti 001005
ROD: EV_PASMConti.rod
VCID: 7BFFB54AF2A0BE97F2-802E
0786 - Electical Consumer Cut-Off Active
U1402 00 [008] - -
Fault Frequency: 89
Reset counter: 0
Mileage: 788992 km
Date: 2076.12.13
Time: 28:28:59
Default: 00
Default: 85
Default: 00
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000156893297
Coding: 011D0620D001451005080002
Revision: 00002001 Serial number: 0372752257
Coding: 019B1620A8B9108083200624210000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 172
Component: Sensor, DWA 005 0502
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000157153768
Coding: 011D0620D001451005080000
VCID: 48951A86FBF6250F2F-801C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1563000337
Coding: 01040100
ROD: EV_ParkbA7.rod
VCID: 3669647E8902A3FF4D-8062
Slave 3:
12656790 - Databus
Reset counter: 23
Mileage: 42299 km
Date: 2019.09.04
Time: 10:16:59
Voltage: 13.2 V
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 01A602000B000200
VCID: 3F87015AA63862B79E-806A
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: B00000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: B00000
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 227G/0F8625532
Coding: 040005020100000003
VCID: 2649B43E51A2D37FFD-8072
Part No SW: 7P6 035 764 K HW: 7P6 035 764 A
Component: H-BNT-RW H41 0934
Revision: -------- Serial number: 605G.0F7502095
Coding: 010A01050040C1EF01002B0E00000003F00001030000000000
VCID: 418307A2D8CC1447E8-8014
Subsystem 1 - Part No: 8R0 060 884 CL
Component: ROW 2015 0706
Subsystem 2 - Part No SW: 7P6 919 603 J HW: 7P6 919 603 J
Component: DU8 SV Touch H56 0046
Serial number: VWZ8Z9RGF003WW
Subsystem 3 - Part No SW: 7P6 919 603 J HW: 7P6 919 603 J
Component: CD-Database 6208
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000157166977
Coding: 011804200001251005080000
Reset counter: 101
Mileage: 46277 km
Date: 2020.01.14
Time: 14:24:15
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H14 0137
Revision: 7C001001 Serial number: 0366813466
Coding: 0100000202000000
Shop #: WSC 01286 386 08256
ROD: EV_TrailFunctGener2Hella_VW52.rod
VCID: 3777697A8E085AF756-8062
655882 - Bulb for Brake Light on Trailer
C10F3 15 [008] - Open or Short to Plus
Fault Frequency: 116
Reset counter: 107
Mileage: 38474 km
Date: 2019.06.30
Time: 09:41:49
655879 - Bulb for Brake Light on Trailer
C10F3 11 [008] - Short to Ground
Reset counter: 40
Mileage: 46394 km
Date: 2020.01.19
Time: 14:39:20
656138 - Bulb for Right Tail Light on Trailer
C10F4 15 [009] - Open or Short to Plus
Fault Frequency: 39
Reset counter: 67
Mileage: 35741 km
Time: 00:00:00
656135 - Bulb for Right Tail Light on Trailer
C10F4 11 [008] - Short to Ground
Reset counter: 40
Mileage: 46430 km
Date: 2020.01.19
Time: 15:26:25
656650 - Bulb for Right Turn Signal on Trailer
C10F6 15 [008] - Open or Short to Plus
Fault Frequency: 6
Reset counter: 97
Mileage: 43863 km
Time: 00:00:00
656906 - Bulb for Left Turn Signal on Trailer
C10F7 15 [008] - Open or Short to Plus
Fault Frequency: 6
Reset counter: 100
Mileage: 44062 km
Date: 2019.12.28
Time: 10:49:15
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 7P6 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0020
Revision: 00H08000 Serial number: 525 PA8JA61595
Coding: 0030001
VCID: 3777697A46085AF756-8062
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 183500907
Coding: 0533314003
ROD: EV_HeckkTouar.rod
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000156921511
End-------------------------(Elapsed Time: 05:06)--------------------------
