Touareg V6 TDI 180 7P upgrade brakes to 18in and ABS coding
prhumphries
C?ID=166080
Hi VCDS world. Has anyone upgraded their front brakes to 18z 6 piston calipers and 18 inch discs and re-coded there ABS controller. Or can someone with a V8 TDI post up there ABS coding.
My current ABS coding is below. This is Standard.
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 41185561296241
Coding: 5B6B13C34B242559DAF4C89CD2D2A470F701
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4C9D2696E78EC92F0B-8018
PetrolDave
Westbury, UK
C?ID=1423
Be helpful if you posted a full unedited VCDS Auto-Scan of your Touareg in it's current state.
BTW are there any fault codes?
I have a fuzzy recollection that this question has come up before and and that the conclusion was: There is no combination of coding that's acceptable to the ABS module when the bigger brakes are used on a vehicle with the smaller engine because that combination was not offered from the factory. IIRC, in the end, that owner decided to leave the original coding and was happy with the performance of his upgrade brakes that way anyway.
prhumphries
C?ID=166080
Saturday,22,February,2020,16:59:34:17886
VCDS Version: 19.6.2.0 (x64)
VIN: WVGZZZ7PZGD006090   License Plate: AHH820
Mileage: 47400km-29452mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 34 42 46 52 53 55 56 5F 62
          69 6C 6D 72
VIN: WVGZZZ7PZGD006090   Mileage: 47400km-29452miles
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P1 907 401 A    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0001
   Revision: 53H41---
   Coding: 292A4012233E01020000
   Shop #: WSC 36612 002 1048576
   ASAM Dataset: EV_ECM30TDI0117P1907401A 001002
   ROD: EV_ECM30TDI0117P1907401A.rod
   VCID: 2E594C1E71529B3F05-807A
5568 - Sensor for Ambient Air Temperature (G17)
          P0073 00 [032] - Signal too High
Address 02: Auto Trans (J217)       Labels: 0C8-927-755.clb
   Part No SW: 0C8 927 755 M    HW: 0C8 927 755
   Component: AL1000 AISIN  130 2879
   Coding: 010100011C008400000000000000000000000000
   ASAM Dataset: EV_TCMAL991031 003118
   ROD: EV_TCMAL991031_003.rod
   VCID: 3B7F754AB2207E97B2-806E
   Part No SW: 4H0 907 064 GM    HW: 4H0 907 064 GM
   Component: BCM2 2.0      H37 0572
   Coding: 01B60010000000000000
   VCID: 7AF1B04EF59A879FE9-802E
   Subsystem 1 - Part No SW: 7P6 959 754 AL    HW: 7P6 959 754 AL
   Component: FBSTOUAREGIDG  H08 0084
   Serial number: 3615000148089008
   Serial number: 3215000107565003
   Part No SW: 7P6 907 040 CK    HW: 7P6 907 040 CK
   Component: Klima 2 Zonen H23 1507
   Coding: 3626200890
   VCID: 7F07415AE6B8A2B7DE-802A
   Part No SW: 4H0 907 063 DA    HW: 4H0 907 063 AA
   Revision: 22020001    Serial number: 00001121580302
   Coding: 26000014D0345D010029400300005D4C431D670827010241000000000040110000000000000000
   VCID: 6AD1800E853A371F19-803E
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    150629  033 0021
   Serial number: 90243401150707131130
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20602726
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 AB    HW: 7P6 941 431 AB
   Component: E1 - LDS  H02 0040
   Serial number: 00000000003006150494
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 D    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0030
   Revision: --------    Serial number: 28231514911578
   Coding: 318504
   ASAM Dataset: EV_VW526ParkiAssis2 001013
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 448D0EB6CFDE016FC3-8010
   Part No SW: 7P0 959 655 F    HW: 7P0 959 655 F
   Component: VW10Airbag00T H10 0044
   Revision: --------    Serial number: 003S8000CMVI
   Coding: 000000000000000000000000000000003054
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   Serial number: 3575LRB404T3COSA78VO
   Serial number: 3585LRB40633AVPA2OVE
   Serial number: 3517ARB405P3DL7CGO6S
   Serial number: 3527ARB405P3DL7CF1PO
   Serial number: 3557BRB40513CGVECOAT
   Serial number: 3567BRB40513CGVE6OCQ
   Part No SW: 4H0 953 568 K    HW: 7P6 953 507 AB
   Revision: --------    Serial number: 01374OG9000E3
   Coding: 000035
   VCID: 3B7F754ABA207E97B2-806E
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0045493 TRW 20140326
   Part No SW: 7P6 920 883 B    HW: 7P6 920 883 B
   Component: Kombi         H13 0515
   Revision: 13240302    Serial number: 658090715592059
   Coding: 332731003A00000800000C
   ASAM Dataset: EV_KombiUDSRBVW526 001022
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 3D7B7B52AC3470A78C-8068
   Part No SW: 7P6 907 530 M    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6042
   Revision: --------    Serial number: 00000001911422
   Coding: 000D07AD00
   Shop #: WSC 12022 002 1048576
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 428108AED5CA0F5FF1-8016
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 42174B10155701315031
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 15188002035021200181
          U140B 00 [008] - -
                    Reset counter: 89
                    Mileage: 44042 km
                    Date: 2019.12.25
                    Time: 17:48:20
                    Voltage terminal 30: 12.1 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 45 ∞C
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 1
16384 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
                    Fault Frequency: 238
                    Reset counter: 118
                    Mileage: 35486 km
                    Date: 2019.02.15
                    Time: 19:34:40
                    Voltage terminal 30: 14.6 V
                    Voltage terminal 15: 14.6 V
                    Control Module temperature: 34 ∞C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 AF    HW: 7P0 907 553 AF
   Component: PASM          H05 0750
   Revision: 00000000    Serial number: 00000151880326
   Coding: 14210000
   ASAM Dataset: EV_PASMConti 001005
   ROD: EV_PASMConti.rod
   VCID: 7BFFB54AF2A0BE97F2-802E
0786 - Electical Consumer Cut-Off Active
          U1402 00 [008] - -
                    Fault Frequency: 89
                    Reset counter: 0
                    Mileage: 788992 km
                    Date: 2076.12.13
                    Time: 28:28:59
                    Default: 00
                    Default: 85
                    Default: 00
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000156893297
   Coding: 011D0620D001451005080002
   Revision: 00002001    Serial number: 0372752257
   Coding: 019B1620A8B9108083200624210000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 172
   Component: Sensor, DWA  005 0502
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000157153768
   Coding: 011D0620D001451005080000
   VCID: 48951A86FBF6250F2F-801C
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1563000337
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 3669647E8902A3FF4D-8062
   Slave 3:
12656790 - Databus
                    Reset counter: 23
                    Mileage: 42299 km
                    Date: 2019.09.04
                    Time: 10:16:59
                    Voltage: 13.2 V
   Coding: 01A602000B000200
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3F87015AA63862B79E-806A
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0005
   Coding: B00000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0005
   Coding: B00000
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227G/0F8625532
   Coding: 040005020100000003
   VCID: 2649B43E51A2D37FFD-8072
   Part No SW: 7P6 035 764 K    HW: 7P6 035 764 A
   Component: H-BNT-RW      H41 0934
   Revision: --------    Serial number: 605G.0F7502095
   Coding: 010A01050040C1EF01002B0E00000003F00001030000000000
   VCID: 418307A2D8CC1447E8-8014
   Subsystem 1 - Part No: 8R0 060 884 CL
   Component: ROW 2015  0706
   Subsystem 2 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: DU8 SV Touch  H56 0046
   Serial number: VWZ8Z9RGF003WW
   Subsystem 3 - Part No SW: 7P6 919 603 J    HW: 7P6 919 603 J
   Component: CD-Database  6208
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000157166977
   Coding: 011804200001251005080000
                    Reset counter: 101
                    Mileage: 46277 km
                    Date: 2020.01.14
                    Time: 14:24:15
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4H0 907 383 M    HW: 4H0 907 383 K
   Component: Anhaenger     H14 0137
   Revision: 7C001001    Serial number: 0366813466
   Coding: 0100000202000000
   Shop #: WSC 01286 386 08256
   ROD: EV_TrailFunctGener2Hella_VW52.rod
   VCID: 3777697A8E085AF756-8062
6 Faults Found:
655882 - Bulb for Brake Light on Trailer
          C10F3 15 [008] - Open or Short to Plus
                    Fault Frequency: 116
                    Reset counter: 107
                    Mileage: 38474 km
                    Date: 2019.06.30
                    Time: 09:41:49
655879 - Bulb for Brake Light on Trailer
          C10F3 11 [008] - Short to Ground
                    Reset counter: 40
                    Mileage: 46394 km
                    Date: 2020.01.19
                    Time: 14:39:20
656138 - Bulb for Right Tail Light on Trailer
          C10F4 15 [009] - Open or Short to Plus
                    Fault Frequency: 39
                    Reset counter: 67
                    Mileage: 35741 km
                    Time: 00:00:00
656135 - Bulb for Right Tail Light on Trailer
          C10F4 11 [008] - Short to Ground
                    Reset counter: 40
                    Mileage: 46430 km
                    Date: 2020.01.19
                    Time: 15:26:25
656650 - Bulb for Right Turn Signal on Trailer
          C10F6 15 [008] - Open or Short to Plus
                    Reset counter: 97
                    Mileage: 43863 km
                    Time: 00:00:00
656906 - Bulb for Left Turn Signal on Trailer
          C10F7 15 [008] - Open or Short to Plus
                    Reset counter: 100
                    Mileage: 44062 km
                    Date: 2019.12.28
                    Time: 10:49:15
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H08000    Serial number: 525 PA8JA61595
   Coding: 0030001
   VCID: 3777697A46085AF756-8062
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 183500907
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000156921511
End-------------------------(Elapsed Time: 05:06)--------------------------
prhumphries
C?ID=166080
          69 6C 6D 72
   Revision: 53H41---
   Coding: 3626200890
   Coding: 004DBD
   Coding: 025223
   Coding: 318504
   Coding: 000035
   Coding: 000D07AD00
   Voltage stabilizer:
          U140B 00 [008] - -
                    Reset counter: 89
                    Mileage: 44042 km
                    Date: 2019.12.25
                    Time: 17:48:20
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
          B130E 00 [008] - -
                    Reset counter: 118
                    Mileage: 35486 km
                    Date: 2019.02.15
                    Time: 19:34:40
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Coding: 14210000
          U1402 00 [008] - -
                    Fault Frequency: 89
                    Reset counter: 0
                    Mileage: 788992 km
                    Date: 2076.12.13
                    Time: 28:28:59
                    Default: 00
                    Default: 85
                    Default: 00
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   Slave 3:
12656790 - Databus
                    Reset counter: 23
                    Mileage: 42299 km
                    Date: 2019.09.04
                    Time: 10:16:59
                    Voltage: 13.2 V
   Coding: B00000
   Coding: B00000
                    Reset counter: 101
                    Mileage: 46277 km
                    Date: 2020.01.14
                    Time: 14:24:15
6 Faults Found:
                    Reset counter: 107
                    Mileage: 38474 km
                    Date: 2019.06.30
                    Time: 09:41:49
                    Reset counter: 40
                    Mileage: 46394 km
                    Date: 2020.01.19
                    Time: 14:39:20
                    Fault Frequency: 39
                    Reset counter: 67
                    Mileage: 35741 km
                    Time: 00:00:00
                    Reset counter: 40
                    Mileage: 46430 km
                    Date: 2020.01.19
                    Time: 15:26:25
                    Reset counter: 97
                    Mileage: 43863 km
                    Time: 00:00:00
                    Reset counter: 100
                    Mileage: 44062 km
                    Date: 2019.12.28
                    Time: 10:49:15
   Coding: 0030001
   Coding: 0533314003
prhumphries
C?ID=166080
Thanks for the response - was wondering if recoding will actually make any noticeable affect anyway.
darkchina811
ITALY
C?ID=333184
while my Car is a Golf and not a Touareg, let me say this...
I installed larger brake discs and recoded my ABS accordingly. not only I did not notice any difference after the software change, to me there was no difference from the start, after the bigger discs. maybe I am just not a race driver :)
NSTouaregTDI
Canada
C?ID=313957
I just made a new post about this, and discovered this thread afterwards while just scrolling. My concern here would be making sure the ABS and traction control systems work properly after upgrading, not just under normal driving. Would the computer be expecting less braking power from it's input in an emergency, and possible overbrake the front wheels, causing loss of control? Or does it not really operate that way?
