Results 1 to 5 of 5
Thread: Transport T5 ABS coding problem
    Verified VCDS-User
    Sep 2018
    Turkey
    hi
    i have transporter t5 but giving error wrong coding..
    ESP MK25E1
    LOG is attached thnks for helps
    Friday,28,February,2020,17:53:38:05288
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    VIN: WV1ZZZ7HZ7H138736   License Plate: T5ABSCOD
    Mileage: 586840km-364645mi   Repair Order:
    Chassis Type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
    Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
              57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZ7H138736   Mileage: 586840km-364645miles
    Address 01: Engine        Labels: 038-906-016-AXB.clb
       Part No SW: 038 906 016 N    HW: 028 101 185 5
       Component: R4 1,9L EDC 0000SG  6209
       Revision: 12345678    Serial number: XXXXXXXXXXXXXX
       Coding: 0151031
       Shop #: WSC 02744 790 00000
       VCID: 9F0E61B74FA9F4B73C-5184
    18044 - Powertrain Data Bus
                P1636 - 000 - Missing Message from Airbag Controller
                        Torque: 106.0 Nm
                        Voltage: 12.16 V
                        Bin. Bits: 00000100
                        Torque: 0.0 Nm
                        Torque: 60.0 Nm
    16566 - Fuel Temp. Sensor A (G81)
                P0182 - 000 - Short to GND
                        Torque: 106.0 Nm
                        Voltage: 12.08 V
                        Temperature: 16.2°C
                        Temperature: 31.5°C
                        Temperature: 38.7°C
    Readiness: 0 0 X X X
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
       Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
       Component: ESP MK25E1          0104
       Revision: 00H31001
       Coding: 0000557
       Shop #: WSC 12345 389 45725
       VCID: C4C4CEDB868FF76F41-5160
                003 - Mechanical Failure
                        Fault Status: 01100011
                        Reset counter: 40
                        Mileage: 586844 km
                        Count: 128
                        Count: 4865
                        Count: 199
                        Count: 2049
    Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
       Part No: 7H0 937 049 T
       Component: BORDNETZ SGVER 1.0  2001
       Coding: 0000101
       Shop #: WSC 02736 790 00000
       VCID: C3C6CDC78381F05778-5160
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    00538 - Reference Voltage
                014 - Defective
    Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
       Part No: 7H0 920 861 E
       Component: KOMBI+WEGFAHRSP VDO V02
       Coding: 00103
       Shop #: WSC 00186
       VCID: AE108C7368036D3F87-5160
       WV1ZZZ7HZ7H138736     VWZ7Z0G5298927
                49-00 - No Communications
    01304 - Radio
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 02736
       VCID: F0AC520BB2B73BCFD5-5160
    01304 - Radio
    Address 46: Central Conv.        Labels: 7H0-959-433.lbl
       Part No: 7H0 959 433 B
       Component: C11 Komfortgerát     0004
       Coding: 00025
       Shop #: WSC 02736
       VCID: B22898037C3B49DFE3-4B1E
    End----------(Elapsed Time: 06:23, VBatt start/end: 12.5V/12.3V)-----------
    Mar 2019
    Poland
    And what happened to 15 airbag?
  3. Likes Dana liked this post
    United States
    Providing WV1ZZZ7HZ7H138736 is the correct VIN I believe the 03-ABS coding should be: 0003630
  5. Likes Uwe liked this post
  6. #4
    Verified VCDS-User
    Sep 2018
    Turkey
    Quote Originally Posted by Jacek View Post
    airbag control module hmmm water damaged .. its faulty.. need change..
    gived 0003630 code accepted but giving same error...
    thnks for help.. i will change airbag control module
  7. Likes Uwe, Dana liked this post
  8. #5
    United States
    If it still shows 01044 "Mechanical Failure" after you fix the Airbags please post another scan.
  9. Likes Uwe liked this post
