we are trying to allow the fader option to be adjusted on the composition colour headunit on the transporter t6.1
as standard this vehicle is fitted standard with 2 channel audio
we have fitted rear speakers therefore having 4 channel audio.
i am looking into any information on the coding possibly the same as a normal car with 4 channel audio .
i have attached a autoscan of the vehicle in question.
Friday,28,February,2020,09:44:36:64124
VCDS Version: 19.11.2.1 (x64) HEX-V2 CB: 0.4513.4
Data version: 20200107 DS316.1
VIN: WV1ZZZ7HZLH020226 License Plate:
Mileage: 41km-25mi Repair Order:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 44 55 5F 75 BB BC BE BF D6 D7
VIN: WV1ZZZ7HZLH020226 Mileage: 41km-25miles
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-CXEC) Labels: None
Part No SW: 04L 906 056 RQ HW: 04L 907 445 N
Component: R4 2.0l BTD H01 9970
Revision: 23401001
Coding: 002540144364050800000000000000000000000000000000
Shop #: WSC 00012 790 00030
ASAM Dataset: EV_ECM20BTD03004L906056RQ 004005
ROD: EV_ECM20BTD03004L906056AG.rod
VCID: 0D465F3EDDDEF9A3554-8058
Readiness: N/A
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0BT 300 046 N HW: 0GC 927 711 H
Component: GSG DQ500 H06 3108
Revision: 00H06V09
ROD: EV_TCMDQ500021_VN46.rod
VCID: 41DEB30ED1066DC361C-8014
Part No SW: 7LA 614 517 A HW: 7LA 614 517
Component: ESC_high H01 0700
Serial number: 08510035191122
Coding: 10552452C849E685085624A6136C6706393720B8
Shop #: WSC 00012 790 00049
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 002010
ROD: EV_Brake1ESP90iBOSCHVN46X_002.rod
VCID: 3D26CFFEADFE0923054-8068
Address 08: Auto HVAC (J301) Labels:* None
Part No SW: 7LA 907 426 A HW: 7LA 907 426 A
Component: AC Manuell H01 0502
Coding: B03110000810000001000800504001050000000000011000800000000000
Shop #: WSC 00012 790 00211
ASAM Dataset: EV_AirCondiBHTCT6PA 001004
ROD: EV_AirCondiBHTCT6PA.rod
B10CD 00 [008] - -
[Funktionseinschränkung durch Energiemanagement Ruhestrom]
Reset counter: 43
Mileage: 41 km
Date: 2020.02.27
Time: 16:50:12
Voltage terminal 30: 11.3 V
Blower reduction: No switch-off: no reduction
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 2Q5 937 090 HW: 2Q5 937 090
Component: BCM T6PA Std+ H10 0935
Serial number: 01101932400362
Shop #: WSC 00012 790 00047
ASAM Dataset: EV_BCMA0 205001
ROD: EV_BCMA0_205.rod
VCID: 74B02ADADE34886B3AA-8020
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 050 0105
Serial number: S2Y19M11D15H07M53S27
Coding: 02B8EE
Drivers Door Control Module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000035227908
Coding: 1F0007
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000035233067
Coding: 050007
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY192550XGT
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000047834213
12 Faults Found:
10506 - Bulb for Left Tail Light
B12BE 15 [009] - Open or Short to Plus
Reset counter: 3
Mileage: 41 km
Date: 2020.02.24
Time: 11:12:21
Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: not activated
Zusaetzliche Umgebungsdaten-OFF: not activated
Zusaetzliche Umgebungsdaten-Outside air temperature: -50.0 °C
Zusaetzliche Umgebungsdaten-Automatic high beam assist: not activated
Zusaetzliche Umgebungsdaten-Parking light: not activated
Zusaetzliche Umgebungsdaten-Parking light left: not activated
Zusaetzliche Umgebungsdaten-Parking light right: not activated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 11.8 V
10762 - Bulb for Right Tail Light
B12BF 15 [009] - Open or Short to Plus
Reset counter: 3
Mileage: 41 km
Date: 2020.02.24
Time: 11:12:21
11018 - Bulb for Left Brake Light
B12C2 15 [009] - Open or Short to Plus
Reset counter: 3
Mileage: 41 km
Date: 2020.02.18
Time: 10:13:11
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-voltage measurement: 11.7 V
11530 - Bulb for Right Brake Light
B12C3 15 [009] - Open or Short to Plus
Reset counter: 3
Mileage: 41 km
Date: 2020.02.18
Time: 10:13:11
13322 - Back-Up Light
B12CD 15 [009] - Open or Short to Plus
Reset counter: 3
Mileage: 41 km
Date: 2020.02.18
Time: 10:14:25
Zusaetzliche Umgebungsdaten-voltage measurement: 14.7 V
331786 - Relay Output for Heated Exterior Mirror(s)
B1730 15 [008] - Open or Short to Plus
Reset counter: 43
Mileage: 41 km
Date: 2020.02.17
Time: 13:45:54
Zusaetzliche Umgebungsdaten-Automatic high beam assist: operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 12.2 V
591363 - Motor for External Mirror Folding; Driver Side
B1745 07 [008] - Mechanical Failure
Reset counter: 43
Mileage: 41 km
Date: 2020.02.18
Time: 16:56:53
Zusaetzliche Umgebungsdaten-voltage measurement: 11.6 V
592652 - Dimmer Switch; Driver Side
B1752 01 [008] - Electrical Failure
Fault Frequency: 44
Reset counter: 43
Mileage: 41 km
Date: 2020.02.17
Time: 13:31:57
Zusaetzliche Umgebungsdaten-voltage measurement: 12.1 V
595971 - Motor for External Mirror Folding; Passenger Side
B1755 07 [008] - Mechanical Failure
Reset counter: 43
Mileage: 41 km
Date: 2020.02.18
Time: 16:56:53
608524 - Unknown Error Code
B1A72 F0 [009] - Unknown Error Elaboration
Fault Frequency: 17
Reset counter: 3
Time: 00:00:00
608780 - Unknown Error Code
B1A73 F0 [008] - Unknown Error Elaboration
Reset counter: 43
Time: 00:00:00
919560 - Light Switch
B126A 29 [008] - Signal Implausible
Reset counter: 43
Mileage: 41 km
Date: 2020.02.27
Time: 15:49:56
Part No SW: 5QA 919 294 G HW: 5QA 919 294
Component: PDC 8 Kanal H08 0061
Serial number: 000150058319319
Coding: 0471151811
ASAM Dataset: EV_EPHVA18AU3700000 009046
ROD: EV_EPHVA18AU3700000_009_VW27.rod
VCID: 50F8864A0A6C944BFE2-8004
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [008] - Open Circuit
Fault Frequency: 10
Reset counter: 43
Mileage: 41 km
Date: 2020.02.18
Time: 10:14:12
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 3200670241FF8748949C815580508700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 43D2B906CB1A7FD3730-8016
2172 - Databus
[FAULT_BRAKINGLIGHT_FAIL]
Fault Frequency: 11
Reset counter: 43
Mileage: 41 km
Date: 2020.02.18
Time: 10:13:11
Voltage terminal 15: 11.5 V
Control Module temperature: 13 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.09 m/s²
Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
2095 - Databus
[FAULT_SEATBELT_FAIL]
Fault Frequency: 16
Reset counter: 43
Mileage: 41 km
Date: 2020.02.24
Time: 11:24:57
Voltage terminal 15: 11.4 V
Control Module temperature: 12 °C
Longitudinal acceleration: 0.13 m/s²
1389 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[FAULT_VBAT_BUSMON_LOW]
Reset counter: 43
Mileage: 41 km
Date: 2020.02.28
Time: 08:12:32
Voltage terminal 15: 9.5 V
Control Module temperature: 18 °C
Longitudinal acceleration: 0.31 m/s²
Adaptive distance regulation: status: ACC_reversible_error
Address 15: Airbags (J234) Labels:* None
Part No SW: 2Q0 959 655 AD HW: 2Q0 959 655 AD
Component: VW22Airbag 013 0506
Revision: --------
Coding: 8800C00000000000800000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 7F5AF5F6E772DB33578-802A
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 7LA 920 941 HW: 7LA 920 941
Component: KOMBI 204 6750
Coding: 27A40A0A2580260001886A011401000000600000
ASAM Dataset: EV_DashBoardVDDMQBAB 009069
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 7DA60FFEED7EC923454-8028
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 521 5388
Serial number: 12111910804073
Coding: 030100044F05730001100018100F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW27.rod
VCID: 70B826CAAA2CB44BDE2-8024
Component: 4-00-11-01-04
Subsystem 2 - Part No SW: 3G0 959 442 F HW: 3G0 959 442 F
Component: E221__MFL-PR6 H06 0110
Serial number: PR6-0440066330191227
Coding: 2C1D00
Subsystem 3 - Part No SW: 7E0 915 181 L HW: 7E0 915 181 L
Component: J367-BDMConti H03 1051
Serial number: 77197200001910190077
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
[Globaler Timeout CAN-Infotainment]
Reset counter: 43
Mileage: 41 km
Date: 2020.02.27
Time: 16:26:14
Supply voltage: Terminal 30: 11.5 V
Terminal 15: OFF
8526361 - LV Energy Management
B1802 F1 [008] - Warning Triggered
Reset counter: 43
Mileage: 41 km
Date: 2020.02.28
Time: 08:09:41
Terminal 15: On
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 7LA 909 144 F HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7150
Coding: 0106
ASAM Dataset: EV_SteerAssisMNB 002012
ROD: EV_SteerAssisMNB_VN46.rod
VCID: 45D6A71EC52E41E35D4-8010
Part No SW: 7P6 907 357 E HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 0C8E020009200003
ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
ROD: EV_HeadlRegulAFSMQBMAX_VN46.rod
13706005 - Databus
[Empfangener Fehlerwert im Signal BCM1_LDS_Stellung: CAN Message Gateway_72]
Reset counter: 43
Mileage: 41 km
Date: 2020.02.27
Time: 16:32:12
Part No SW: 3G5 035 820 HW: 3G5 035 820
Component: MU-O-ND-EU H12 0156
Serial number: VWZAZ2W1189797
Coding: 64600008000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_SE27.rod
VCID: 619E538E71C60DC341C-8034
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 284 HW: 5WA 035 284
Component: OCUGen3High H20 0083
Serial number: 0000000908VICL9
Coding: 06462000196898209005460160000607
ASAM Dataset: EV_OCUGen3High 002115
ROD: EV_OCUGen3High_002_VW27.rod
VCID: 035279068B9ABFD3330-8056
6 Faults Found:
1190912 - Ethernet Databus Branch 1
U122C 00 [008] - No Communication
Reset counter: 40
Mileage: 41 km
Date: 2020.02.27
Time: 14:43:08
Ethernet counter checksum error: branch 1: 0
Ethernet counter connection interruptions: branch 1: 0
7170 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
Reset counter: 40
Mileage: 41 km
Date: 2020.02.27
Time: 16:32:13
0081 - Databus
[Ethernet Databus missing message - Infotainment Unit]
Reset counter: 40
Mileage: 31 km
Date: 2020.01.13
Time: 14:30:02
Voltage terminal 30: 12.5 V
9457171 - Audio signal output 1
B14F1 13 [008] - Open Circuit
Reset counter: 40
Mileage: 41 km
Date: 2020.02.27
Time: 16:19:55
Voltage terminal 30: 11.6 V
2566 - GPS Antenna
B1054 13 [008] - Open Circuit
[GPS-Antenna - Interruption]
Reset counter: 40
Time: 00:00:00
Voltage terminal 30: 12.3 V
12866049 - Databus
[Airbag: Error value received]
Reset counter: 40
Mileage: 41 km
Date: 2020.02.24
Time: 11:24:57
Voltage terminal 30: 11.4 V
Address BB: Door Rear Drv (J1093) Labels: None
Part No SW: 7LA 035 593 A HW: 7LA 035 593 A
Component: SLD_Rx-Unit_d H07 0031
Serial number: 19001E7C
Coding: 00
ASAM Dataset: EV_ReceiRearDriveSideHuf 002002
ROD: EV_ReceiRearDriveSideHuf.rod
VCID: 3E24C8F2A0F8123B1CE-806A
Address BC: Door Rear Pass (J1094) Labels: None
Component: SLD_Rx-Unit_p H07 0031
Serial number: 19002168
Coding: 00
ASAM Dataset: EV_ReceiRearPasseSideHuf 002002
73750 - Supply voltage
U1011 00 [108] - Voltage too Low
Reset counter: 36
Mileage: 41 km
Date: 2020.02.28
Time: 08:12:31
Address BE: Slid. Door Rear Left (J926) Labels:* None
Part No SW: 7LA 959 244 C HW: 7LA 959 244 C
Component: Slidingdoor_d H09 0033
Serial number: 180022A5
Coding: 10
ASAM Dataset: EV_SlideDoorDriveHufT6PA 001010
ROD: EV_SlideDoorDriveHufT6PA_VN46.rod
VCID: 48C8AE2AF23C5C8BA62-801C
12313 - Motor for Sliding Door Opening
B115A 19 [040] - Current Too High
Reset counter: 15
Mileage: 41 km
Date: 2020.02.17
Time: 15:54:08
Address BF: Slid. Door Rear Right (J927) Labels:* None
Component: Slidingdoor_p H09 0033
Serial number: 18001BA2
Coding: 10
ASAM Dataset: EV_SlideDoorPasseHufT6PA 001010
ROD: EV_SlideDoorPasseHufT6PA_VN46.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 992 941 571 AA HW: 992 941 571 A
Component: LED1L H08 9002
ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
ROD: EV_LLPGen3LKEBODPO68X_VW48.rod
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H08 9002
ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
End----------(Elapsed Time: 01:34, VBatt start/end: 14.5V/14.5V)-----------
