Results 1 to 3 of 3
Thread: Audi S4 0B5 transmission adapt clutch slip points
    May 2017
    For a 2012 Audi S4 with the 0B5 S-tronic we have replaced the mechatronic circuit boards. The service manual says that in this case the following must be done (picture):
    https://1drv.ms/u/s!Ap4o2XTLsCbyiNde...yreyg?e=dRi4or
    I saw that there are a few other posts for clutch valve calibration adaptation as well as on the Wiki page for this transmission. Is this the same thing? If not, how can I "adapt clutch slip points" with VCDS? Thanks in advance!
    Saturday,22,February,2020,11:57:26:35753
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    Dealer/Shop Name: Bestiale
    VIN: WAUBGAFL6CA018543   License Plate: INITIAL 2020.02.22
    Mileage: 169870km-105552mi   Repair Order:
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 36 42 46 47 52 53 55 56 5F
              62 72
    VIN: WAUBGAFL6CA018543   Mileage: 169870km-105552miles
    Address 01: Engine (J623-CCBA)       Labels:. 06E-907-551-CAK.clb
       Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
       Component: 3.0T SIMOS84  H08 0003
       Revision: --H08---
       Coding: 0104000A240F0128
       Shop #: WSC 06324 000 00000
       ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
       ROD: EV_ECM30TFS0218K0907551D.rod
       VCID: 3228E95765A4C8DF63-8066
    6506 - MIL Request Signal Active (Check TCM for errors too!)
              P1624 00 [109] - -
                        Mileage: 169848 km
                        Date: 2020.02.15
                        Time: 16:01:28
                        Engine speed: 673.00 /min
                        Normed load value: 14.5 %
                        Coolant temperature: 99 °C
                        Intake air temperature: 54 °C
                        Voltage terminal 30: 12.999 V
                        Engine speed: actual: 672 /min
                        MAF_ENVD: 179.75294 mg/stroke
                        Coolant temperature (unfiltered): 41.3 °C
                        Engine: operating status: IS
                        Engine load: 14.453125 %
                        Vehicle speed: actual: 0 km/h
       Part No SW: 8K2 927 156 S    HW: 0B5 927 156 F
       Component: 0B5 30TFSINAR H10 0001
       Revision: --H10---    Serial number: 0000000139
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ROD: EV_TCMDL501.rod
       VCID: 46C0A587F92C447FDF-8012
    8026 - Valve 1 in Transmission Part 2
              P174C 00 [237] - Electrical malfunction
                        Reset counter: 40
                        Mileage: 169843 km
                        Date: 2020.02.15
                        Time: 15:46:04
                        Engine speed: 2205 /min
                        Transmission input speed: 2205 /min
                        Transmission output speed: 927 /min
                        Engine torque: -44 Nm
                        Transmission fluid temperature: 59 °C
                        Accelerator position: 0.0 %
                        Clutch status: Kupplung 1 kann Moment übertragen
    8093 - Gear Selector 1
              P176A 00 [237] - Cannot be Regulated
                        Reset counter: 40
                        Mileage: 169848 km
                        Date: 2020.02.15
                        Time: 16:15:02
                        Engine speed: 922 /min
                        Transmission input speed: 922 /min
                        Transmission output speed: 0 /min
                        Engine torque: 0 Nm
                        Transmission fluid temperature: 76 °C
                        Clutch status: Beide Kupplungen offen
       Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
       Component: ESP8 quattro  H04 0060
       Coding: 290D1A
       VCID: 024879979D84B85FB3-8056
    02214 - Tire Pressure Warning
                        Reset counter: 166
                        Mileage: 169784 km
                        Date: 2020.02.12
                        Time: 17:16:10
                        Hex Value: 0x2D00
                        Hex Value: 0x4006
                        Hex Value: 0x1237
                        Hex Value: 0x1FB5
                        Hex Value: 0x00FF
                        Fault Status: 00101101
                        Reset counter: 167
                        Mileage: 169843 km
                        Date: 2020.02.15
                        Time: 15:46:03
                        Hex Value: 0x7040
                        Hex Value: 0x4006
                        Hex Value: 0x1227
                        Hex Value: 0x23B5
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 CG    HW: 8K0 907 064 CG
       Component: BCM2 2.0      H05 0435
       Coding: 0D0100
       VCID: 77BE1843C646EDF794-8022
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Serial number: 2311000134454015
    00955 - Key 1
                        Fault Frequency: 14
                        Reset counter: 144
                        Mileage: 169211 km
                        Date: 2019.10.21
                        Time: 23:59:13
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01220620110201
       Coding: 66102000
       VCID: 004C739F9388AA4FA5-8054
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0392
       Revision: 10030001    Serial number: 00000001114465
       Coding: 26001091063CAF212700080300003D0D0F9CD24802010161000000
       VCID: 3C34C76FBFE00EAFB9-8068
       Component: WWS 291112  H07 0080
       Serial number: SWF12110290075
       Coding: 005914
       Component: RLS  H04 0003
       Serial number: 11513354
       Coding: 025028
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001506110531
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
       Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003GLD0NNJ7$
       Coding: 303837354230303030304A55304C384B3053
       VCID: 45C2A28BC42A4F67D6-8010
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R1100004QLS
       Serial number: 6334MSME6134315A6
       Serial number: 6344MSME607208399
       Serial number: 6352QSME6B0C1056I
       Serial number: 6362QSME710C0776I
       Serial number: 63732SME1E0D3172/
       Serial number: 63832SME1E0D344C8
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372KFN000IA
       Coding: 000036
       VCID: 3E30CD67A9FC1CBF97-806A
       Component: E221 - MFL  H02 0010
       Part No SW: 8K0 920 981 Q    HW: 8K0 920 981 Q
       Component: KOMBIINSTR.   H81 0639
       Revision: 00000000    Serial number: JUK42KV6C
       Coding: 8B1709008300D705020000
       VCID: 41CAB69BD8026347EA-8014
       Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0117
       Revision: EC000056    Serial number: 5600E11531021C
       Coding: 00C303
       VCID: 03467C93829EB157B8-8056
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 11024CA2200611
                        Fault Frequency: 40
                        Reset counter: 165
                        Mileage: 167575 km
                        Date: 2019.04.29
                        Time: 08:06:00
                        Bin. Bits:    00000
                        Voltage: 12.20 V
                        Count: 17
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 A    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H12 0025
       Serial number: 003006110001026
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
       VCID: 2E10FD27719CEC3F07-807A
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0074
       Revision: AA000000    Serial number: 00000006310514
       Coding: 00581B00000000000000
       VCID: 3B36C473BAEE0997B0-806E
       Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
       Component: TSG FA        H08 1501
       Coding: 011C13204E00410001
       VCID: 53E68CD3327EE1D748-8006
       Revision: 00002001    Serial number: 0152471459
       Coding: 0106063A00FA440580B0013200000000
       Shop #: WSC 12345 123 61029
       Component: GTO BF  H01 0070
       Serial number: 00000000000000406014
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS045  H07 0041
       Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
       Component: DSP Prem      H10 0190
       Revision: 00010001    Serial number: 34804007383202
       VCID: 7AB80177F554F09FEB-802E
       Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
       Component: TSG BF        H08 1501
       VCID: 52E889D70D64E8DF43-8006
       Revision: 00000003    Serial number: 10000000816220
       VCID: 3424EF4F97B0C6EF71-8060
       Part No: 8K5 907 357 B
       Coding: 0000004
       VCID: 393ADE7B70D23B87A2-806C
       Part No SW: 4G0 035 082 B    HW: 4G0 035 082
       Component: Radio U SIRIU H51 0076
       Revision: AB001007    Serial number: 156FV0B7519112
       Coding: 020007010000000001
       VCID: 1F0E10E30E3675B7BC-804A
       Part No SW: 8T1 035 664 D    HW: 8T1 035 664 B
       Component: H-BN-NA       H52 0165
       Revision: --------    Serial number: 490FU0B7625230
       Coding: 010200000206A1EC45000B0C000000030000
       VCID: 393ADE7BB0D23B87A2-806C
       Component: NAR 2011  0505
       Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
       Component: DU7 High  H43 0084
       Serial number: 9466F-0B0614917
       Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000858985
       Component: CD-Database  2712
       Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
       Component: TSG HL        H06 1501
       Coding: 010C13204000210001
       VCID: 56E075C7218CF4FFAF-8002
       Component: TSG HR        H06 1501
    End----(Elapsed Time: 01:47, VBatt start/end: 11.8V/11.7V. VIgn 11.7V)-----
    Bestiale - incredible quality tuning and full service for Audi, VW and Bentley backed with 101 year labor warranty
    8651 Washington blvd., Culver City, CA 90232
    562-448-2599 or Grigor@bestiale.net, www.bestiale.net
    Given that your scan still shows an "Electrical malfunction" I would guess that you cannot.
    May 2017
    The scan is from before the repair, now the errors are gone. So is what erwin says to do, the same as clutch valve calibration?
