Results 1 to 6 of 6
Thread: Error 31: Request out of Range - Engine ECU coding
    Feb 2020
    New Zealand
    Hi Team
    For some reason a car we have here is coded in the engine ECU as NAR, LHD - the BCM etc is all setup as RHD, but throws an error due to the conflict with the engine ECU. (And it definitely is and always has been a RHD car). It brings a headlight error up on the dash which I am trying to fix (Headlight change over active, function restricted)
    When I try to change the coding I keep getting Error 31: Request out of range.
    Any tips?
    Scan as per below for reference
    Friday,28,February,2020,11:09:55:56060
    VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4513.4
    Dealer/Shop Name: Topp Motors
    VIN: WAUZZZ8F7CN011320   License Plate: MJW215
    Mileage: 55570km-34529mi   Repair Order:
    Chassis Type: 8F-AU48 (8R0)
    Scan: 01 02 03 05 06 08 09 14 15 16 17 19 1B 26 2E 36 42 44 46 47
              52 53 56 62 72 77
    VIN: WAUZZZ8F7CN011320   Mileage: 55570km-34529miles
    1B-Active Steering -- Status: Malfunction 0010
    Address 01: Engine (DET-CDNC)       Labels:. 06H-907-115-CDN.clb
       Part No SW: 8K5 907 115     HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 0004
       Revision: ECH09---
       Coding: 22250013242601022000
       ASAM Dataset: EV_ECM20TFS0118K5907115 001006
       ROD: EV_ECM20TFS0118K5907115.rod
       VCID: 6FBBD3626710A3BF20F-803A
              U1113 00 [040] - -
                        Fault Frequency: 10
                        Mileage: 55490 km
                        Date: 2020.02.26
                        Time: 11:08:30
                        Engine speed: 1533.50 /min
                        Normed load value: 6.3 %
                        Vehicle speed: 32 km/h
                        Coolant temperature: 80 °C
                        Intake air temperature: 40 °C
                        Voltage terminal 30: 13.947 V
                        Engine operating condition: Deceleration
                        Engine operating condition-Test_Program_Channel 87: 9
                        Driver-side belt buckle status-Bits 0-7: 61
                        Engine torque: 0.0 Nm
              U1113 00 [040] - -
                        Fault Frequency: 10
                        Mileage: 55490 km
                        Date: 2020.02.26
                        Time: 11:08:30
                        Engine speed: 1550.50 /min
    7150 - Please Check DTC Memory of Steering Wheel Electronics
              P1698 00 [040] - -
                        Fault Frequency: 12
                        Mileage: 55492 km
                        Date: 2020.02.26
                        Time: 11:10:05
                        Engine speed: 1745.50 /min
                        Normed load value: 7.8 %
                        Vehicle speed: 98 km/h
                        Coolant temperature: 84 °C
                        Intake air temperature: 34 °C
                        Voltage terminal 30: 14.135 V
                        Median injection timing: 0.819 ms
                        Engine operating condition: Part. load
                        Engine operating condition-Test_Program_Channel 87: 6
                        Driver-side belt buckle status-Bits 0-7: 166
                        Engine torque: 29.7 Nm
       Part No SW: 8K2 927 143 T    HW: 0B5 927 156 F
       Component: 0B5 20TFSIRdW H10 0099
       Revision: --H10---    Serial number: 0000000293
       Coding: 000001
       ASAM Dataset: EV_TCMDL501 A09699
       ROD: EV_TCMDL501.rod
       VCID: 43D34FD21B1877DF947-8016
       Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
       Coding: 09654C
       Shop #: WSC 02391 823 56573
       VCID: 04518CCE5E16B0E7EDD-8050
                        Fault Status: 00101101
                        Fault Frequency: 10
                        Reset counter: 204
                        Mileage: 55490 km
                        Date: 2020.02.26
                        Time: 11:08:29
                        Hex Value: 0x2040
                        Hex Value: 0x4002
                        Hex Value: 0x122F
                        Hex Value: 0x23B0
                        Hex Value: 0x0000
    03110 - Active Steering Control Module (J792)
                        Fault Frequency: 10
                        Reset counter: 204
                        Mileage: 55490 km
                        Date: 2020.02.26
                        Time: 11:08:29
                        Hex Value: 0x2040
                        Hex Value: 0x4202
                        Hex Value: 0x120F
                        Hex Value: 0x16B1
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 FH    HW: 8K0 907 064 FH
       Component: BCM2 2.0      H10 0602
       Coding: 05B30F00000000000000
       Shop #: WSC 02399 823 56573
       VCID: 7BA3F73223E8CF1F9C7-802E
       Subsystem 1 - Part No SW: 8T0 959 754 K    HW: 8T0 959 754 K
       Component: FBSAUDIB8 IDG  H61 0072
       Serial number: 0812000046360012
       Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
       Component: MEM-BFS       H10 0076
       Revision: AA000000    Serial number: 00000024338708
       Coding: 09237025002400001000
       VCID: 45D751CA15AC49EFBA3-8010
       Part No SW: 8K2 820 043 M    HW: 8K2 820 043 M
       Component: KLIMA 3 ZONEN H04 0036
       Revision: D0000000    Serial number: 01230220120709
       Coding: 642762C080
       VCID: 33331F124B38C75F047-8066
    03220 - Stop Valve for Coolant for Climatronic (N422)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 146
                        Mileage: 55202 km
                        Date: 2020.02.18
                        Time: 09:45:12
       Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 AG
       Component: BCM1 1.0      H14 0103
       Revision: 07014001    Serial number: 00000385674902
       Coding: 2600C0108034AFF01981408000001D0D0F1DC38827090201000008000401070100000060000000
       Shop #: WSC 00102 771 06085
       VCID: 77ABEB021FC0EB7FF8F-8022
       Subsystem 1 - Part No SW: 8F2 955 119     HW: 8K2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 030312  H06 0021
       Serial number: SWF12030035284
       Coding: 00FD11
       Serial number: 20179893
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002402120535
       Serial number: 8838C816000000000001
    02988 - Left-Hand/Right-Hand Traffic Switchover Active
                        Reset counter: 146
                        Mileage: 55202 km
                        Date: 2020.02.18
                        Time: 09:45:12
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 8R0 907 364 C    HW: 8K0 907 364
       Component: DAEMPFUNGS-SG H09 0054
       Revision: 00000000    Serial number: 15021200510001
       Coding: 050181
       VCID: 3A2D32366C523617C71-806E
                        Fault Frequency: 137
                        Reset counter: 203
                        Mileage: 55490 km
                        Date: 2020.02.26
                        Time: 11:08:30
                        Bin. Bits: 00000000 00000001
    Address 15: Airbags (J234)       Labels:| 8F0-959-655.clb
       Part No SW: 8F0 959 655 D    HW: 8F0 959 655 D
       Component: AirbagVW-AU10 H12 0430
       Serial number: 003KGD803VAI
       Coding: 30414135353130303030554A305238463053
       Shop #: WSC 02135 785 00200
       ASAM Dataset: EV_AirbaAU10SMEAU485 001004
       ROD: EV_AirbaECUVWAUDI010.rod
       VCID: 392F2D3A69D43D0FCEB-806C
       Serial number: 6334MSME6B431554C
       Serial number: 6344MSME6B362137D
       Serial number: 6352QSME3F0E2268R
       Serial number: 6362QSME400D10400
       Serial number: 63732SME316D0950-
       Serial number: 63832SME490E0254
       Component: Lenks.Modul   H03 0004
       Revision: --------    Serial number: 90372LBO001M4
       Coding: 000036
       VCID: 44D14CCE1E9670E7ADD-8010
       Component: E221 - MFL  H03 0003
                        Fault Frequency: 10
                        Reset counter: 204
                        Mileage: 55490 km
                        Date: 2020.02.26
                        Time: 11:08:30
                        (no units): 38.0
                        Text: 2698005A0158013400
                        Mass Air / Rev.: 0.00 mg/str
                        RPM: 18 /min
                        Text: 239D47011420070800
                        Distance: 18177 cm
                        Lambda: -30.3 %
                        (no units): 0.0
       Part No SW: 8T0 920 930 B    HW: 8T0 920 930 B
       Component: KOMBIINSTR.   H35 0540
       Revision: 00000000    Serial number: NSR75PR2D
       Coding: 3307190032010008010000
       VCID: 3537210A454CD96F2A3-8060
       Part No SW: 8R0 907 468 A    HW: 8R0 907 468 A
       Component: GW-BEM 5CAN   H10 0025
       Revision: 1V040013    Serial number: 1341V1222586C7
       Coding: 00CF07FF00
       VCID: 3D27392A7D7C012FE23-8068
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790210496
       Serial number: 12057000196011200181
                        Fault Frequency: 9
                        Reset counter: 196
                        Mileage: 55283 km
                        Date: 2020.02.19
                        Time: 15:14:26
                        Bin. Bits:    10000
                        Voltage: 11.80 V
                        Count: 12
       Part No SW: 8K0 907 144 H    HW: 8K0 907 144 H
       Component: DYNAMIKLENK.  H06 0680
       Coding: 040100
       Shop #: WSC 05348 000 1048576
       VCID: 34311C0E4E36C0671DD-8060
                        Fault Frequency: 255
                        Reset counter: 203
                        Mileage: 55490 km
                        Date: 2020.02.26
                        Time: 11:08:29
                        Count: 45
                        Count: 1
                        Hex Value: 0x0255
                        Hex Value: 0x8AE8
                        Hex Value: 0x8603
                        Hex Value: 0x2000
                        Reset counter: 203
                        Mileage: 55490 km
                        Date: 2020.02.26
                        Time: 11:08:29
                        Count: 47
                        Count: 52
                        Hex Value: 0x0255
                        Hex Value: 0x8A6B
                        Hex Value: 0x0001
                        Hex Value: 0x0800
    Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
       Part No SW: 8F0 959 255     HW: 8F0 959 255
       Component: VSG-AUDI-B8   H12 0190
       ASAM Dataset: EV_ElectRoofContr 001008
       ROD: EV_ElectRoofContr.rod
       VCID: 71BFD51A7124B54F36B-8024
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020202
       VCID: 392F2D3A69543D0FCEB-806C
       Component: MEM-FS        H10 0076
       Revision: AA000000    Serial number: 00000024338740
       Coding: 093B7B25002400001000
       Part No SW: 8T0 959 793 G    HW: 8T0 959 793 G
       Component: TSG FA        H09 0302
       Coding: 011C52725E09330C03
       VCID: 4DC769EACDDCB1AF723-8018
       Component: RCEPS         H36 0507
       Revision: 00001000    Serial number: 0023327995
       Coding: 010000010001
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 34311C0E4EB6C0671DD-8060
    5242881 - Regulation Limit Exceeded
              C10F2 F0 [008] - Unknown Error Elaboration
              [Detektierung "yellow error" durch Lenkfunktions-Überwachung-Software]
                        Reset counter: 203
                        Mileage: 55540 km
                        Date: 2020.02.27
                        Time: 09:41:07
                        Write only channel
    4207936 - Steering Angle Value
              C10C9 29 [008] - Signal Implausible
              [Unzulässige Differenz zwischen internen Lenkwinkel und dem vom Bussystem (Gleichlauf-Überwachung)]
                        Reset counter: 203
                        Mileage: 55540 km
                        Date: 2020.02.27
                        Time: 09:41:07
                        Write only channel
    4215044 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Fehlerwert "Lenkradwinkel"]
                        Fault Frequency: 12
                        Reset counter: 202
                        Mileage: 55492 km
                        Date: 2020.02.26
                        Time: 11:10:04
                        Write only channel
       Revision: 00002001    Serial number: 0172023872
       Coding: 01000EA000B900A18030033680000000
    00165 - Switch for Transmission Position P/N
                        Reset counter: 198
                        Mileage: 55441 km
                        Date: 2020.02.23
                        Time: 17:27:26
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
       Component: DSP STD       H07 0230
       Revision: S2500000
       Coding: 0203010102
       VCID: 74B1DC0E0EB68067DDD-8020
       Part No SW: 8T0 959 792 G    HW: 8T0 959 792 G
       Component: TSG BF        H09 0302
       Coding: 011C52325E09330C03
       VCID: 4CC164EE36C6B8A765D-8018
       Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
       Component: EPB-4         H01 0001
       Revision: --------    Serial number: 10000000021554
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3635260658CAD277239-8062
       Part No SW: 8R2 035 195     HW: 8R2 035 195
       Component: Symphony3     H04 0440
       Revision: 00000005    Serial number: AUZ5Z4L1454108
       Coding: 0402008201030D0003DB070800
       VCID: 73B3DF120BB8875FC47-8026
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
       Part No SW: 8T0 959 795 F    HW: 8T0 959 795 F
       Component: TSG HL        H08 0302
       Coding: 010C12304009370C03
       VCID: 4EC56EE6C0DA8AB70B9-801A
       Component: TSG HR        H08 0302
       Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005477166
       Coding: 0010300
       Shop #: WSC 02335 785 00200
       VCID: 3D27392A717C012FE23-8068
    End----------(Elapsed Time: 01:43, VBatt start/end: 13.9V/14.2V)-----------
    PS, I know we have a steering angle sensor fault in this scan due to low batt voltage
    Cheers
    Dan
    As a general rule, ECU software will not accept a coding change between NAR and RoW.
    My guess: This car has the wrong ECU (or wrong ECU software) in it.
  3. Likes Rollux liked this post
    Feb 2020
    New Zealand
    Thanks for the reply - it also wouldn’t accept just the RHD change.
    I wonder if it’s had a second hand ecu put in it sometime that was sourced from eBay
    I have looked through about 50 scan's I have with this controller, I guess there is a little problem with label file.
    I think it should be like this, so you should not change coding.
    For BCM DTC, try and look in MMI menus, eg. CAR > Outside light (or others).
    Also Adaptation Channel 045, what is the value ?
  6. Likes Uwe liked this post
    Feb 2020
    New Zealand
    No, my screens look different on the first screen you have shown bit 0-2 says Audi: North America. There is no bit 6-7. Byte 6(?) has bit 0 RHD vehicle unchecked.
    Quote Originally Posted by Rollux View Post
    Yes I know that, that is defined that way, right now in our label files.
    But right now I think it is wrong and should be showed as in #4.
  9. Likes Uwe liked this post
