Error 31: Request out of Range - Engine ECU coding
Rollux
New Zealand
C?ID=380572
Hi Team
For some reason a car we have here is coded in the engine ECU as NAR, LHD - the BCM etc is all setup as RHD, but throws an error due to the conflict with the engine ECU. (And it definitely is and always has been a RHD car). It brings a headlight error up on the dash which I am trying to fix (Headlight change over active, function restricted)
When I try to change the coding I keep getting Error 31: Request out of range.
Any tips?
Scan as per below for reference
Friday,28,February,2020,11:09:55:56060
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4513.4
Dealer/Shop Name: Topp Motors
VIN: WAUZZZ8F7CN011320   License Plate: MJW215
Mileage: 55570km-34529mi   Repair Order:
Chassis Type: 8F-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 14 15 16 17 19 1B 26 2E 36 42 44 46 47
          52 53 56 62 72 77
VIN: WAUZZZ8F7CN011320   Mileage: 55570km-34529miles
1B-Active Steering -- Status: Malfunction 0010
Address 01: Engine (DET-CDNC)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115     HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0004
   Revision: ECH09---
   Coding: 22250013242601022000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TFS0118K5907115 001006
   ROD: EV_ECM20TFS0118K5907115.rod
   VCID: 6FBBD3626710A3BF20F-803A
          U1113 00 [040] - -
                    Fault Frequency: 10
                    Mileage: 55490 km
                    Date: 2020.02.26
                    Time: 11:08:30
                    Engine speed: 1533.50 /min
                    Normed load value: 6.3 %
                    Vehicle speed: 32 km/h
                    Coolant temperature: 80 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 13.947 V
                    Median injection timing: 0.000 ms
                    Engine operating condition: Deceleration
                    Engine operating condition-Test_Program_Channel 87: 9
                    Driver-side belt buckle status-Bits 0-7: 61
                    Engine torque: 0.0 Nm
          U1113 00 [040] - -
                    Fault Frequency: 10
                    Mileage: 55490 km
                    Date: 2020.02.26
                    Time: 11:08:30
                    Engine speed: 1550.50 /min
7150 - Please Check DTC Memory of Steering Wheel Electronics
          P1698 00 [040] - -
                    Fault Frequency: 12
                    Mileage: 55492 km
                    Date: 2020.02.26
                    Time: 11:10:05
                    Engine speed: 1745.50 /min
                    Normed load value: 7.8 %
                    Vehicle speed: 98 km/h
                    Coolant temperature: 84 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 14.135 V
                    Unlearning counter according OBD: 37
                    Median injection timing: 0.819 ms
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
                    Driver-side belt buckle status-Bits 0-7: 166
                    Engine torque: 29.7 Nm
   Part No SW: 8K2 927 143 T    HW: 0B5 927 156 F
   Component: 0B5 20TFSIRdW H10 0099
   Revision: --H10---    Serial number: 0000000293
   ASAM Dataset: EV_TCMDL501 A09699
   ROD: EV_TCMDL501.rod
   VCID: 43D34FD21B1877DF947-8016
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 09654C
   Shop #: WSC 02391 823 56573
   VCID: 04518CCE5E16B0E7EDD-8050
                    Fault Status: 00101101
                    Fault Frequency: 10
                    Reset counter: 204
                    Mileage: 55490 km
                    Date: 2020.02.26
                    Time: 11:08:29
                    Hex Value: 0x2040
                    Hex Value: 0x4002
                    Hex Value: 0x122F
                    Hex Value: 0x23B0
                    Hex Value: 0x0000
03110 - Active Steering Control Module (J792)
                    Fault Frequency: 10
                    Reset counter: 204
                    Mileage: 55490 km
                    Date: 2020.02.26
                    Time: 11:08:29
                    Hex Value: 0x2040
                    Hex Value: 0x4202
                    Hex Value: 0x120F
                    Hex Value: 0x16B1
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 FH    HW: 8K0 907 064 FH
   Component: BCM2 2.0      H10 0602
   Coding: 05B30F00000000000000
   Shop #: WSC 02399 823 56573
   VCID: 7BA3F73223E8CF1F9C7-802E
   Subsystem 1 - Part No SW: 8T0 959 754 K    HW: 8T0 959 754 K
   Component: FBSAUDIB8 IDG  H61 0072
   Serial number: 0812000046360012
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000024338708
   Coding: 09237025002400001000
   VCID: 45D751CA15AC49EFBA3-8010
   Part No SW: 8K2 820 043 M    HW: 8K2 820 043 M
   Component: KLIMA 3 ZONEN H04 0036
   Revision: D0000000    Serial number: 01230220120709
   Coding: 642762C080
   VCID: 33331F124B38C75F047-8066
03220 - Stop Valve for Coolant for Climatronic (N422)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 146
                    Mileage: 55202 km
                    Date: 2020.02.18
                    Time: 09:45:12
   Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 AG
   Component: BCM1 1.0      H14 0103
   Revision: 07014001    Serial number: 00000385674902
   Coding: 2600C0108034AFF01981408000001D0D0F1DC38827090201000008000401070100000060000000
   Shop #: WSC 00102 771 06085
   VCID: 77ABEB021FC0EB7FF8F-8022
   Subsystem 1 - Part No SW: 8F2 955 119     HW: 8K2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 030312  H06 0021
   Serial number: SWF12030035284
   Coding: 00FD11
   Serial number: 20179893
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002402120535
   Serial number: 8838C816000000000001
02988 - Left-Hand/Right-Hand Traffic Switchover Active
                    Reset counter: 146
                    Mileage: 55202 km
                    Date: 2020.02.18
                    Time: 09:45:12
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 15021200510001
   Coding: 050181
   VCID: 3A2D32366C523617C71-806E
                    Fault Frequency: 137
                    Reset counter: 203
                    Mileage: 55490 km
                    Date: 2020.02.26
                    Time: 11:08:30
                    Bin. Bits: 00000000 00000001
Address 15: Airbags (J234)       Labels:| 8F0-959-655.clb
   Part No SW: 8F0 959 655 D    HW: 8F0 959 655 D
   Component: AirbagVW-AU10 H12 0430
   Serial number: 003KGD803VAI
   Coding: 30414135353130303030554A305238463053
   Shop #: WSC 02135 785 00200
   ASAM Dataset: EV_AirbaAU10SMEAU485 001004
   ROD: EV_AirbaECUVWAUDI010.rod
   VCID: 392F2D3A69D43D0FCEB-806C
   Serial number: 6334MSME6B431554C
   Serial number: 6344MSME6B362137D
   Serial number: 6352QSME3F0E2268R
   Serial number: 6362QSME400D10400
   Serial number: 63732SME316D0950-
   Serial number: 63832SME490E0254
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Component: Lenks.Modul   H03 0004
   Revision: --------    Serial number: 90372LBO001M4
   Coding: 000036
   VCID: 44D14CCE1E9670E7ADD-8010
                    Fault Frequency: 10
                    Reset counter: 204
                    Mileage: 55490 km
                    Date: 2020.02.26
                    Time: 11:08:30
                    (no units): 38.0
                    Text: 2698005A0158013400
                    Mass Air / Rev.: 0.00 mg/str
                    RPM: 18 /min
                    Text: 239D47011420070800
                    Distance: 18177 cm
                    Lambda: -30.3 %
                    (no units): 0.0
   Part No SW: 8T0 920 930 B    HW: 8T0 920 930 B
   Component: KOMBIINSTR.   H35 0540
   Revision: 00000000    Serial number: NSR75PR2D
   Coding: 3307190032010008010000
   VCID: 3537210A454CD96F2A3-8060
   Part No SW: 8R0 907 468 A    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H10 0025
   Revision: 1V040013    Serial number: 1341V1222586C7
   Coding: 00CF07FF00
   VCID: 3D27392A7D7C012FE23-8068
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790210496
   Serial number: 12057000196011200181
                    Fault Frequency: 9
                    Reset counter: 196
                    Mileage: 55283 km
                    Date: 2020.02.19
                    Time: 15:14:26
                    Bin. Bits:    10000
                    Voltage: 11.80 V
                    Count: 12
   Part No SW: 8K0 907 144 H    HW: 8K0 907 144 H
   Component: DYNAMIKLENK.  H06 0680
   Coding: 040100
   Shop #: WSC 05348 000 1048576
   VCID: 34311C0E4E36C0671DD-8060
                    Fault Frequency: 255
                    Reset counter: 203
                    Mileage: 55490 km
                    Date: 2020.02.26
                    Time: 11:08:29
                    Count: 45
                    Count: 1
                    Hex Value: 0x0255
                    Hex Value: 0x8AE8
                    Hex Value: 0x8603
                    Hex Value: 0x2000
                    Reset counter: 203
                    Mileage: 55490 km
                    Date: 2020.02.26
                    Time: 11:08:29
                    Count: 47
                    Count: 52
                    Hex Value: 0x0255
                    Hex Value: 0x8A6B
                    Hex Value: 0x0001
                    Hex Value: 0x0800
Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
   Part No SW: 8F0 959 255     HW: 8F0 959 255
   Component: VSG-AUDI-B8   H12 0190
   ASAM Dataset: EV_ElectRoofContr 001008
   ROD: EV_ElectRoofContr.rod
   VCID: 71BFD51A7124B54F36B-8024
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020202
   VCID: 392F2D3A69543D0FCEB-806C
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000024338740
   Coding: 093B7B25002400001000
   Part No SW: 8T0 959 793 G    HW: 8T0 959 793 G
   Component: TSG FA        H09 0302
   Coding: 011C52725E09330C03
   VCID: 4DC769EACDDCB1AF723-8018
   Revision: 00001000    Serial number: 0023327995
   Coding: 010000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34311C0E4EB6C0671DD-8060
5242881 - Regulation Limit Exceeded
          C10F2 F0 [008] - Unknown Error Elaboration
          [Detektierung "yellow error" durch Lenkfunktions-Überwachung-Software]
                    Reset counter: 203
                    Mileage: 55540 km
                    Date: 2020.02.27
                    Time: 09:41:07
                    Write only channel
4207936 - Steering Angle Value
          C10C9 29 [008] - Signal Implausible
          [Unzulässige Differenz zwischen internen Lenkwinkel und dem vom Bussystem (Gleichlauf-Überwachung)]
                    Reset counter: 203
                    Mileage: 55540 km
                    Date: 2020.02.27
                    Time: 09:41:07
                    Write only channel
4215044 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Fehlerwert "Lenkradwinkel"]
                    Fault Frequency: 12
                    Reset counter: 202
                    Mileage: 55492 km
                    Date: 2020.02.26
                    Time: 11:10:04
                    Write only channel
   Revision: 00002001    Serial number: 0172023872
   Coding: 01000EA000B900A18030033680000000
00165 - Switch for Transmission Position P/N
                    Reset counter: 198
                    Mileage: 55441 km
                    Date: 2020.02.23
                    Time: 17:27:26
   Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
   Component: DSP STD       H07 0230
   Revision: S2500000
   Coding: 0203010102
   VCID: 74B1DC0E0EB68067DDD-8020
   Part No SW: 8T0 959 792 G    HW: 8T0 959 792 G
   Component: TSG BF        H09 0302
   Coding: 011C52325E09330C03
   VCID: 4CC164EE36C6B8A765D-8018
   Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
   Component: EPB-4         H01 0001
   Revision: --------    Serial number: 10000000021554
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3635260658CAD277239-8062
   Part No SW: 8R2 035 195     HW: 8R2 035 195
   Component: Symphony3     H04 0440
   Revision: 00000005    Serial number: AUZ5Z4L1454108
   Coding: 0402008201030D0003DB070800
   VCID: 73B3DF120BB8875FC47-8026
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
   Part No SW: 8T0 959 795 F    HW: 8T0 959 795 F
   Component: TSG HL        H08 0302
   Coding: 010C12304009370C03
   VCID: 4EC56EE6C0DA8AB70B9-801A
   Component: TSG HR        H08 0302
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005477166
   Coding: 0010300
   Shop #: WSC 02335 785 00200
   VCID: 3D27392A717C012FE23-8068
End----------(Elapsed Time: 01:43, VBatt start/end: 13.9V/14.2V)-----------
PS, I know we have a steering angle sensor fault in this scan due to low batt voltage
Cheers
Dan
As a general rule, ECU software will not accept a coding change between NAR and RoW.
My guess: This car has the wrong ECU (or wrong ECU software) in it.
Rollux
New Zealand
C?ID=380572
Thanks for the reply - it also wouldn’t accept just the RHD change.
I wonder if it’s had a second hand ecu put in it sometime that was sourced from eBay
NEtech
C?ID=56995
I have looked through about 50 scan's I have with this controller, I guess there is a little problem with label file.
I think it should be like this, so you should not change coding.
For BCM DTC, try and look in MMI menus, eg. CAR > Outside light (or others).
Also Adaptation Channel 045, what is the value ?
Rollux
New Zealand
C?ID=380572
No, my screens look different on the first screen you have shown bit 0-2 says Audi: North America. There is no bit 6-7. Byte 6(?) has bit 0 RHD vehicle unchecked.
NEtech
C?ID=56995
Yes I know that, that is defined that way, right now in our label files.
But right now I think it is wrong and should be showed as in #4.
