Same erorrs keep coming back
Devilz
Birmingham, England
C?ID=253973
I keep getting error codes on same modules on every scan, I can clear them and rescan to confirm they have been cleared but when scan is done after few days, errors are back. Need advise please. Thanks
Vehicle in question is 2017 Tiguan 2.0 TDi
Thursday,27,February,2020,18:27:18:25423
VCDS Version: 19.6.2.0
Workshop Code: 210 01369 040505
VIN: WVGZZZ5NZHW905957   License Plate:
Chassis Type  5N-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 4B 52 5F A5 BB BC
          CA
VIN: WVGZZZ5NZHW905957   Mileage: 76205km-47351miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 HT    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 3617
   Revision: B4H25---
   Coding: 0125001203661D082000
   ASAM Dataset: EV_ECM20TDI01104L906026HT 004003
   ROD: EV_ECM20TDI01104L906026GP_004.rod
   VCID: 0305DF368A765757BA-8056
28991 - No Communications with NOX Sensor 1
          U029D 00 [032] - -
                    Mileage: 75622 km
                    Date: 2020.02.11
                    Time: 14:02:17
                    Coolant temperature: 55 °C
                    Intake air temperature: 51 °C
                    Voltage terminal 30: 11.860 V
                    Unlearning counter according OBD: 19
                    Cruise Control System (CCS): status-Bits 0-7: 0
                    CAN status - brake control module 1-Bits 0-7: 8
                    selected gear-Bits 0-7: 0
   Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2002
   Revision: 00H06V07
   VCID: 33654FF69A5627D76A-8066
   Revision: 00000000    Serial number: 60477000000313
   Coding: 0AEE929A34200B714780070562CA4950492CD0E2E046927D38625078C22A4200002F641A1B13111435351919323200
   VCID: 77FDBBE6CEAE0BF796-8022
0202 - Reverse Gear Info
          C109E 29 [008] - Implausible Signal
                    Reset counter: 144
                    Mileage: 75893 km
                    Date: 2020.02.18
                    Time: 19:27:12
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000E00420403
   Coding: 0012012420211001110510000010102A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 4A9B3212EDDC461F39-801E
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
263425 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Fault Frequency: 146
                    Reset counter: 114
                    Mileage: 75442 km
                    Date: 2020.02.08
                    Time: 17:46:28
                    Outside air temperature: 10.5 °C
                    Voltage terminal 30: 11.8 V
                    Air quality status: ERROR
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
                    Reset counter: 154
                    Mileage: 75700 km
                    Date: 2020.02.13
                    Time: 08:06:38
                    Voltage terminal 30: 14.3 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 1
                    Auxiliary heater: in stages-Act.val.: 1
                    Auxiliary heater: in stages-Specified value for control: 3
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001704700445
   Shop #: WSC 01369 210 40505
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F0D53C6E69E33B7DE-802A
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 161220  033 0372
   Serial number: 00000001612140479964
   Component: RLHS  042 0105
   Serial number: S3Y17M02D23H21M07S38
   Coding: 06A8DD
   Serial number: 000000000ZY170231E3D
   Serial number: 00000000000068556361
197644 - Control Circuit for Fuel Tank Flap
          B1263 01 [009] - Electrical Failure
                    Reset counter: 83
                    Mileage: 75442 km
                    Date: 2020.02.08
                    Time: 17:47:32
262936 - Sensor for anti-theft alarm system
          B1330 29 [008] - Signal Implausible
                    Reset counter: 143
                    Mileage: 75870 km
                    Date: 2020.02.18
                    Time: 14:01:06
   Part No SW: 3Q0 919 294 A    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H07 0020
   Serial number: 002812167478081
   Coding: 0071451811
   ASAM Dataset: EV_EPHBO18VW3260000 007015
   ROD: EV_EPHBO18VW3260000_007.rod
   VCID: 377D7BE68E2ECBF756-8062
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320147C158FF8728749C8065804085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001.rod
   VCID: 3B7567D6B206EF97B2-806E
1127 - Databus
                    Reset counter: 126
                    Mileage: 75468 km
                    Date: 2020.02.09
                    Time: 22:00:20
                    Voltage terminal 15: 13.1 V
                    Control Module temperature: 16 °C
                    Longitudinal_acceleration_vehicle_reference: 1.25 m/s²
                    Status_ACC_System: ACC_Off_MainSwitch_Off
1218 - Databus
                    Reset counter: 129
                    Mileage: 75468 km
                    Date: 2020.02.09
                    Time: 22:00:20
1219 - Databus
                    Reset counter: 126
                    Mileage: 75468 km
                    Date: 2020.02.09
                    Time: 22:00:20
                    Voltage terminal 15: 13.3 V
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Fault Frequency: 7
                    Reset counter: 152
                    Mileage: 75703 km
                    Date: 2020.02.13
                    Time: 13:52:06
                    Voltage terminal 15: 9.5 V
                    Control Module temperature: 10 °C
                    Longitudinal_acceleration_vehicle_reference: 1.72 m/s²
                    Status_ACC_System: ACC_Init
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2MP50/
   Coding: 98CCC0C00C0000005C5400CF008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 102FE07ACB003CCF37-8044
   Belt Pretensioner left:
   Belt Pretensioner right:
   Subsystem 3 - Part No SW: -----------    HW: 480 002 302 17
   Serial number: 3570000000084D9CC12X
   Subsystem 4 - Part No SW: -----------    HW: 480 002 402 17
   Serial number: 35800000000404E48029
   Subsystem 5 - Part No SW: -----------    HW: 480 401 502 17
   Serial number: 3510001C32537332E54U
   Subsystem 6 - Part No SW: -----------    HW: 480 401 702 17
   Serial number: 3520001BB2537335679/
   Subsystem 7 - Part No SW: -----------    HW: 480 401 702 17
   Serial number: 3550001A72537334364S
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 401 702 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001A12537335D27V
   Subsystem 9 - Part No SW: -----------    HW: 480 401 702 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001A12537335825P
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 401 702 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001A32537331C35K
   Subsystem 11 - Part No SW: -----------    HW: 480 001 302 17
   Serial number: I0M00000000C7D5D512C
   Subsystem 12 - Part No SW: -----------    HW: 480 001 302 17
   Serial number: I0N00000000CEB306124
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20170220501272
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 4189153ED0EA8547E8-8014
   Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
   Component: KOMBI         408 2170
   Coding: 27AD00086F84060001887B031401000000000000
          U1110 00 [008] - -
                    Fault Frequency: 29
                    Reset counter: 150
                    Mileage: 75691 km
                    Date: 2020.02.12
                    Time: 16:32:30
   Part No SW: 3Q0 907 530 C    HW: 3Q0 907 530 C
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0005928965
   Coding: 030500045F087300FB07225E1E0F00010001050000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 2F6D4386767E03370E-807A
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0040
   Serial number: 29170000325700107062
   Coding: 2DFFFF
   Serial number: 1158373104
9175296 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
                    Reset counter: 154
                    Mileage: 75482 km
                    Date: 2020.02.09
                    Time: 22:21:05
                    Supply voltage: Terminal 30: 14.4 V
                    Terminal 15: On
   Serial number: HA1-00031.01.17
   Coding: 0101
   Serial number: 310117EAT09337
   Coding: 003F0220D001048000001000
   VCID: 43851F36CAF69757FA-8016
   Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4581012EC4C2A967D4-8010
Address 4B: Multifunc. Module
Interface not compatible.
   Serial number: 040217EB403449
   Coding: 003F0020DE01048000001000
   VCID: 428B1A32D5EC9E5FF1-8016
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0751
   Coding: 02730601FF00000051110101008808001F0106E6012000008F
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 316945FE604A15C718-8064
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL07BSM
   Subsystem 2 - Part No SW: 5NA 919 866 S    HW: -----------
   Component: ECE1 2020  --- 1310
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 21021712K23255
   Coding: 0003070600000401000213448050A90094000E200040
1122664 - Databus
                    Reset counter: 126
                    Mileage: 75468 km
                    Date: 2020.02.09
                    Time: 22:00:20
                    Control Module temperature: 8 °C
                    Outside air temperature: 7.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 37.4 s
                    Voltage terminal 15: 12.8 V
                    mid: 01 F8
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 020217EB129982
   Coding: 002A00200100048000001000
   Serial number: 240117EAN03474
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:30)--------------------------
this scan was done on 8 Feb 2020
Saturday,08,February,2020,17:38:21:25423
          CA
VIN: WVGZZZ5NZHW905957   Mileage: 75442km-46877miles
   Revision: B4H25---
   Revision: 00H06V07
8408 - Implausible Data Received from Driver's Door Control Module
          U049A 00 [008] - -
                    Reset counter: 123
                    Mileage: 75440 km
                    Date: 2020.02.08
                    Time: 17:17:14
                    Reset counter: 83
                    Mileage: 71442 km
                    Date: 2019.12.22
                    Time: 14:35:56
                    Outside air temperature: 7.0 °C
                    Voltage terminal 30: 13.2 V
                    System run time-Engine running time: 253 s
   Coding: 06A8DD
                    Reset counter: 78
                    Mileage: 71442 km
                    Date: 2019.12.22
                    Time: 15:28:19
   Coding: 0071451811
1113328 - Parking Sensor(s); Front
          B10FC F0 [008] - Function Limitation due to External Factors
                    Reset counter: 117
                    Mileage: 75378 km
                    Date: 2020.02.06
                    Time: 12:27:44
2091 - Databus
                    Reset counter: 123
                    Mileage: 75440 km
                    Date: 2020.02.08
                    Time: 17:17:15
                    Voltage terminal 15: 12.2 V
                    Control Module temperature: 14 °C
                    Longitudinal_acceleration_vehicle_reference: -0.16 m/s²
          U1400 00 [008] - -
                    Reset counter: 121
                    Mileage: 75422 km
                    Date: 2020.02.08
                    Time: 14:17:47
                    Voltage terminal 15: 9.6 V
                    Longitudinal_acceleration_vehicle_reference: 1.81 m/s²
   Serial number: 5NC857705C0044R01024
   Coding: 80000D
   Serial number: 5NC857706C0044R00588
   Coding: 80000D
   Coding: 0C10
   ROD: EV_GatewNF.rod
   Coding: 2DFFFF
          B130E 00 [008] - -
                    Fault Frequency: 66
                    Reset counter: 117
                    Mileage: 71541 km
                    Date: 2019.12.26
                    Time: 20:32:10
                    Supply voltage: Terminal 30: 14.3 V
                    Terminal 15: On
   Coding: 0101
65656 - Response Closing Status of Drivers Door
          B1468 F0 [008] - Implausible
                    Reset counter: 123
                    Mileage: 75440 km
                    Date: 2020.02.08
                    Time: 17:00:27
   Coding: 9107
1275 - Unknown Error Code
          B182E F0 [024] - Unknown Error Elaboration
                    Reset counter: 48
                    Mileage: 71950 km
                    Date: 2019.12.30
                    Time: 18:15:56
                    Control Module temperature: 25 °C
                    Vehicle speed: 48.28 km/h
                    System run time: 305.1 s
                    Voltage terminal 15: 13.9 V
                    mid: 01 62
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:37)--------------------------
this was done in December 2019
Sunday,22,December,2019,13:44:29:25423
          CA
VIN: WVGZZZ5NZHW905957   Mileage: 71440km-44390miles
   Revision: B4H25---
          U029D 00 [032] - -
                    Mileage: 70931 km
                    Date: 2019.12.13
                    Time: 10:55:16
                    Coolant temperature: 10 °C
                    Intake air temperature: 10 °C
                    Ambient air pressure: 960 mbar
                    Voltage terminal 30: 11.280 V
   Revision: 00H06V07
16401 - Tire Pressure Warning
          C102D 00 [137] - -
                    Reset counter: 226
                    Mileage: 71427 km
                    Date: 2019.12.21
                    Time: 19:55:02
                    Fault Frequency: 99
                    Reset counter: 226
                    Mileage: 70896 km
                    Date: 2019.12.11
                    Time: 17:02:57
                    Outside air temperature: 4.0 °C
                    Voltage terminal 30: 12.1 V
                    System run time-Terminal 15 on: 123 s
          P1719 00 [008] - -
                    Reset counter: 1
                    Mileage: 70906 km
                    Date: 2019.12.12
                    Time: 10:56:09
                    Voltage terminal 30: 14.5 V
                    Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 2
                    Auxiliary heater: in stages-Act.val.: 2
   Coding: 00A8DD
                    Reset counter: 203
                    Mileage: 70896 km
                    Date: 2019.12.11
                    Time: 17:16:21
   Coding: 0071451811
   Coding: 80000D
   Coding: 80000D
   Coding: 0C10
   Coding: 27A400086F84060001887B031401000000000000
   ROD: EV_GatewNF.rod
   Coding: 2DFFFF
          B130E 00 [008] - -
                    Fault Frequency: 6
                    Reset counter: 8
                    Mileage: 71100 km
                    Date: 2019.12.16
                    Time: 20:49:16
                    Supply voltage: Terminal 30: 14.1 V
                    Terminal 15: On
   Coding: 0101
   Coding: 9107
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:25)--------------------------
When the a condition that sets a fault code has not been corrected, the fault code will come back.
