Results 1 to 6 of 6
Thread: Škoda Superb MY20 - Activate high beam assistant
    May 2018
    Israel
    Hello everyone,
    I'm trying to activate high beam assistant,
    But I get different results from what is written in the instructions:
    The instructions I have are:
    Control unit: 09 , Adaptation:
    Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung
    set to: present
    set to: present
    Fernlicht_assistent-Erweiterte_Fernlichtsteuerung
    If the initial value here is:
    "AFS, Fernlicht ueber AFS"
    set to:
    "AFS, FLA, Fernlicht ueber AFS"
    or
    "AFS, BCM-Fernlicht"
    set to:
    "AFS, FLA, BCM-Fernlicht"
    But in my case the value that appears is:
    Basis
    What should I write on this channel?
    or
    Thanks!
    Thursday,27,February,2020,17:04:59:56248
    VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
    VIN: TMBAN7NPXL7031966   License Plate: YAKIR SUPERB
    Mileage: 1123km-697mi   Repair Order:
    Chassis Type: NP-SK48 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 36 3C 42 44 52 5F 6C
              A5 BB BC
    VIN: TMBAN7NPXL7031966   Mileage: 1123km-697miles
    Address 01: Engine (J623-DPCA)       Labels: None
       Part No SW: 05E 906 018 BE    HW: 05E 907 309 H
       Component: R4 1.5l TFS   H20 9598
       Revision: 8AH20000
       Coding: 012500322364050830000000000000000000000000000000
       ASAM Dataset: EV_ECM15TFS01105E906018BE 003003
       ROD: EV_ECM15TFS01105E906018BE_SK48.rod
       VCID: 699A9B2288A25A0712-803C
       Part No SW: 0CW 300 050 A    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1703
       Revision: 00005008    Serial number: CU501910255825
       Shop #: WSC 00033 790 00158
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 3326394A9AEED0D768-8066
       Part No SW: 5Q0 614 517 FA    HW: 5Q0 614 517 BR
       Component: ESC           H82 0190
       Revision: 00000000    Serial number: 62909000000927
       Coding: 1D077A9C31233B6D4780060660C949B85E8CDCE2600692753821F078D2824A0B0003000012121212B835351919323200
       VCID: 75A2C752D41A8EE786-8020
       Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
       Component: VWKESSYMQB    037 1307
       Revision: 00037000    Serial number: 0531581301
       Coding: 0F20000723
       VCID: 45C27792C47A5E67D6-8010
       Part No SW: 3V0 907 044 FJ    HW: 3V0 907 044 FJ
       Component: AC Automat    H34 4803
       Revision: 20K10000    Serial number: 00000B01524887
       Coding: 11010004000110011005000000101026
       ASAM Dataset: EV_ACClimaPrehVW37X 002027
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 014AA38290D2B247AA-8054
       Air quality sensor:
       Subsystem 1 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
       Component: G238 _AQS  H30 0119
       Serial number: 95109976
       Part No SW: 5Q0 937 086 CE    HW: 5Q0 937 086 BQ
       Component: BCM PQ37BOSCH 038 0303
       Revision: --------    Serial number: J53F12101900D5
       ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
       ROD: EV_BCMBOSCH_020_VW27.rod
       VCID: 7F4E257AE626C4B7DC-802A
       Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: 48x LL 041019  032  0121
       Serial number: 00000001910020306562
       Coding: 165DDD
       Component: RLHS  051  0206
       Serial number: S6Y19M10D22H23M51S46
       Coding: 00084D
       Steering Column Switch:
       Subsystem 4 - Part No SW: 5Q1 953 521 CJ    HW: 5Q1 953 569 A
       Component: Lenks.Modul  H13  0170
       Serial number: 0100101020190C203454
    0531 - Footwell Illumination
              B11FF 01 [009] - Electrical Failure
                        Fault Frequency: 161
                        Reset counter: 103
                        Mileage: 145 km
                        Date: 2020.01.12
                        Time: 21:38:25
       Part No SW: 5QA 919 283 E    HW: 5QA 919 283
       Component: PDC 4 Kanal   H08 0061
       Serial number: 000150059319291
       Coding: 0601154011
       Shop #: WSC 00033 790 00120
       ASAM Dataset: EV_EPHVA14AU3700000 009044
       ROD: EV_EPHVA14AU3700000_009.rod
       VCID: 4CD442B6E710AF2F09-8018
       Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
       Component: ACC BOSCH MQB H01 0771
       Coding: 3204675111FFC728949C812480400600000000000000000046
       Shop #: WSC 00033 790 00121
       ASAM Dataset: EV_ACCBOSCHVW416 003014
       ROD: EV_ACCBOSCHVW416_003.rod
       VCID: 46C0709EF97C557FDF-8012
    0858 - Databus
              [FAULT_KAMERA_SYSTEMZUSTAND_KAMERA_IM_INIT]
                        Fault Frequency: 38
                        Reset counter: 179
                        Mileage: 792 km
                        Date: 2020.02.03
                        Time: 13:12:45
                        Control Module temperature: 38 °C
                        Voltage terminal 15-Voltage: 14.2 V
                        Vehicle speed: 7.28 m/s
                        Longitudinal acceleration: 0.27 m/s²
                        Adaptive distance regulation: status: ACC_reversible_error
    1232 - Databus
              [FAULT_VIDEO_SIGNAL_LIST]
                        Fault Frequency: 25
                        Reset counter: 218
                        Mileage: 792 km
                        Date: 2020.02.03
                        Time: 13:12:43
                        Voltage terminal 15-Voltage: 14.1 V
                        Vehicle speed: 5.74 m/s
                        Longitudinal acceleration: 1.13 m/s²
                        Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
       Part No SW: 5Q0 959 655 BS    HW: 5Q0 959 655 BS
       Component: AirbagVW21    008 0403
       Serial number: 003FMR5U7Y5J
       Coding: 98CCC0C0000000005C5400CF000800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 12689CCEC5B439DF03-8046
       Subsystem 1 - Part No SW: -----------    HW: 480 001 910 19
       Serial number: 357000000009BB98414T
       Subsystem 2 - Part No SW: -----------    HW: 480 001 810 19
       Serial number: 35800000000828297F3R
       Subsystem 3 - Part No SW: -----------    HW: 480 401 910 19
       Component: SideSensor_Dr  005 6149
       Serial number: 3510001A6F203242D11Q
       Subsystem 4 - Part No SW: -----------    HW: 480 401 410 19
       Component: SideSensor_Pr  004 6149
       Serial number: 35200010C2CA45C3D132
       Subsystem 5 - Part No SW: -----------    HW: 480 401 510 19
       Component: FrontSensor_D  005 6149
       Serial number: 3550001A0F2FD2081396
       Part No SW: 3V0 920 740 E    HW: 3V0 920 740 E
       Component: KOMBI         203 6700
       Coding: 07A5011A6788000801882A0B1001000080000000
       ROD: EV_DashBoardVDDMQBAB_SK48.rod
       VCID: 34243A569FE0D7EF71-8060
       Component: GW MQB High   521 5388
       Serial number: 25101910802820
       Coding: 0B0100047F08570021100250100F00010001070000000000000000000000
       Shop #: WSC 00033 790 00138
       ROD: EV_GatewNF.rod
       VCID: 70ACF646AB78ABCF55-8024
       Component: 5-01-14-01-04
       Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
       Component: E221__MFL-PR6  H03 0180
       Serial number: 000000000D0730211019
       Serial number: 3608302905
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
       Component: U13DCAC  H27 0810
       Serial number: 2175302
    Address 23: Brake Booster (J539)       Labels: None
       Part No SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
       Component: EBKV          H06 0069
       Serial number: BPA085091019013
       Coding: 0102C100340000C618638C31000049922449920400
       ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
       ROD: EV_BrakeBoostG2BoschVW48X_011_VW41.rod
       VCID: 3B36116AB2BE1897B0-806E
       Serial number: 19000278009010
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_AU37.rod
    Address 36: Seat Mem. Drvr (J810)       Labels:* None
       Part No SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
       Component: Sitzmemory    H09 0026
       Serial number: Y0007SIJ30934
       Coding: 0010000000000500018480808080000000008181000000D400
       ASAM Dataset: EV_SeatMemorDriveSide 002022
       VCID: 3FCE657AA6A604B79C-806A
    Address 3C: Lane Change (J1086)       Labels:* None
       Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
       Component: HRE3_Kl15_Mst H06 0149
       Serial number: 00000529260546
       Coding: 52954640
       ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
       ROD: EV_HREntryHellaGen3Kl15.rod
       VCID: 393A0B62B8822A87A2-806C
    Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
       Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
       Component: TSG FS        007 0485
       Serial number: 0000393741661
       Coding: 001D8120DE00020000001100
       VCID: 4DD24FB21C0AA6271E-8018
    Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
       Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
       Component: MQB_VWBS_GEN2 212 2211
       Serial number: 958040 00
       Coding: 0100001100400010
       ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
       ROD: EV_SteerAssisVWBSMQBGen2_VW37.rod
       VCID: 2B16212A42DE881720-807E
    Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
       Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
       Component: TSG BFS       007 0485
       Serial number: 0000394157163
       ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
       Part No SW: 565 035 842     HW: 565 035 842
       Component: MU-S-D-ER     H41 0478
       Serial number: SKZAZ2W1079111
       Coding: 03840100FF0000004111000100810A232F0208C40120050003
       ROD: EV_MUStd4CTSAT_VW41.rod
       VCID: 56E0A0DE29DCE5FFAF-8002
       Subsystem 1 - Part No SW: 3V0 919 605 E    HW: 3V0 919 605 E
       Component: ABT_Std-2  H53 8130
       Serial number: SKZ6ZHW3022798
       Component: RVC Compact   H18 0231
       Coding: 04840101A2002017000040
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 2Q0 980 653     HW: 2Q0 980 653
       Component: MQB MFK 3.0   H11 1027
       Serial number: E33417011192960
       Coding: 0002018800684028B09F00000020000001210000000000000000000000000000
       ASAM Dataset: EV_MFK3ValeoMQB 005035
       ROD: EV_MFK3ValeoMQB_005_AU37.rod
       VCID: 72A8FC4EA57499DFA3-8026
    1124116 - Internal Fault
              B200F F0 [008] - Unknown Error Elaboration
              [SPI_communication_to_EyeQ_timout]
                        Fault Frequency: 10
                        Reset counter: 18
                        Mileage: 1027 km
                        Date: 2020.02.23
                        Time: 16:44:38
    1124105 - Internal Fault
              B200F F4 [008] - Unknown Error Elaboration
              [EyeQ_Init_error]
                        Reset counter: 33
                        Mileage: 982 km
                        Date: 2020.02.17
                        Time: 12:11:11
       Part No SW: 8W0 959 595 M    HW: 8W0 959 595 J
       Component: TSG HFS       010 0384
       Serial number: 0000393979683
       Coding: 001881208000020000001100
       ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod
       Component: TSG HBFS      010 0384
       Serial number: 0000393978899
       ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
    End----------(Elapsed Time: 01:34, VBatt start/end: 12.2V/12.2V)-----------
    Tartu, Estonia
    Where is autoscan?
    Halogen Headlights?
    The world is my oyster...
    May 2018
    Israel
    I added the autoscan,I have LED Headlights.
  4. Likes Uwe liked this post
    Feb 2019
    Australia
    the MY20 Superb, which i believe is the Facelift version, has an entirely different headlight setup altogether - so i would not be surprised at all that the instructions for HBA does not work for you.
    May 2018
    Israel
    Quote Originally Posted by dark5had0w View Post
    it is the Facelift version,
    Another strange thing is that according to the instructions it should look like this:
    Control unit: A5
    Long coding
    Activate byte 21 - bit 5-7
    Change to: (20) Fernlichtassistent/High Beam Assist
    But I found it on:
    byte 15 - bit 5-7
  7. Likes Uwe liked this post
    Dec 2016
    DE
    You have a MFK 3.0, not much is known about it. So it's expected, that bytes have changed. Glad you found it anyway.
  9. Likes Super-VAG, Uwe liked this post
