Results 1 to 7 of 7
Thread: It took me 4 years but I messed up big time - Please help
    Nov 2014
    San José, Costa Rica
    I noticed my car had its passenger side headlamp not aimed correctly (must've been a fender bender from the GDPO).
    Using my trusty VCDS tool I went into central electronics and used the basic setting to move the lights to their aiming position. Now I have a fault code on the dash referring to dynamic lighting (which my car evidently doesn't have) and I have not been able to find what changed in my car with VCDS. I feel super dumb because all of this wasn't necessary, my car doesn't do the little dance when the headlamps turn on. I just needed to turn the screws.
    Known good scan:
    Friday,21,February,2020,18:00:54:20731
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZF46HA001586   License Plate: RMS313
    Mileage: 46536km-28916mi   Repair Order:
    Chassis Type  F4-AU49 (4M1)
    Scan: 01 02 03 08 09 15 16 17 19 36 42 44 46 52 5F 6C 81 BB BC
    VIN: WAUZZZF46HA001586   Mileage: 46536km-28916miles
    46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-CVNA)       Labels: None
       Part No SW: 04E 906 022     HW: 04E 907 309 R
       Component: R4 1.4l TFS   H21 2848
       Revision: 44H21000
       Coding: 022500324304150834000000000000000000000000000000
       Shop #: WSC 06314 790 00001
       ASAM Dataset: EV_ECM14TFS01104E906022 002006
       ROD: EV_ECM14TFS01104E906022.rod
       VCID: 5CBD891E577B7CAF9B-8008
       Part No SW: 8W0 927 155     HW: 0CK 927 156 S
       Component: 0CK 14TFSIRdW H04 0003
       Revision: --H04---    Serial number: 0000000129
       Coding: 000001
       ASAM Dataset: EV_TCMDL382021 002021
       ROD: EV_TCMDL382021_AU49.rod
       VCID: 7CFDE99EF7BB9CAFFB-8028
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
       Component: V553 MTFP  HB1 0572
       Serial number: 75117051150315000684
    Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
       Part No SW: 8W0 907 379 E    HW: 8W0 907 379 J
       Component: ESP9 Plus     H06 0593
       Coding: 04AA049910A20A9715A3489900835292F6A5C020200850A812004A496FA503
       Shop #: WSC 49917 001 1048576
       ASAM Dataset: EV_ESP9BOSCHAU49X 012014
       ROD: EV_ESP9BOSCHAU49X_012.rod
       VCID: 47974672FEFD0F7726-8012
    327936 - Switch for Electric Parking Brake
              C100C 07 [096] - Mechanical Failure
    420352 - TPMS Warning; Front Left Tire
              C1054 00 [040] - Pressure too Low
                        Mileage: 45682 km
                        Date: 2020.02.09
                        Time: 20:34:48
                        90 00 00 1D 88 24 00 00 70 71
    416768 - TPMS Warning; Front Right Tire
              C1056 00 [040] - Pressure too Low
                        Mileage: 45682 km
                        Date: 2020.02.09
                        Time: 20:34:48
    420096 - TPMS Warning; Rear Left Tire
              C1058 00 [040] - Pressure too Low
                        Mileage: 45682 km
                        Date: 2020.02.09
                        Time: 20:34:48
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 8W0 820 043 F    HW: 8W0 820 043 F
       Component: Klima Zone 3  H32 0052
       Coding: 140801885544000D10000100800000000000000000000000000000000000
       Shop #: WSC 06325 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 36693BB6891786FF4D-8062
       Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000000665832
       Component: AQ_Hum_Sensor  H01 0003
       Serial number: 6DB887D7000000000001
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: Klima Heck  H34 0050
       Part No SW: 8W0 907 063 AC    HW: 8W0 907 063 C
       Component: BCM1 MLBevo   H12 0228
       Coding: 80453942451800CD01045118182C08F911033100000000000000000020001A2000400022025605
       Shop #: WSC 06324 790 00001
       ASAM Dataset: EV_BCM1BOSCHAU736 015005
       ROD: EV_BCM1BOSCHAU736_015.rod
       Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS491 150824  043 0813
       Serial number: 894353?0401523601818
       Coding: 5BC7F7
       Serial number: 60967018
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 N    HW: 4M0 941 531 N
       Component: E1 - LDS  H06 0008
       Serial number: 12 09 2015  00099735
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE119101511910241
       Interior Light Module:
       Subsystem 5 - Part No SW: 8W0 947 135 D    HW: 8W0 947 135
       Component: J528-Dachele  H13 0080
       Serial number: Q00020758
       Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
       Component: SL-B9/Q5NF  H15 0010
       Serial number: 2615000103959007
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       Part No SW: 8W0 959 655     HW: 8W0 959 655
       Component: Airbag10.44   H52 0084
       Serial number: 003M6000MAYB
       Coding: AECCF00000800000580000F3C00C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
       VCID: 06098B76B977D67F9D-8052
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
       Component: BeltPretRevFL  205 2033
       Serial number: 8W0857705A0320P01230
       Coding: 88001B
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
       Component: BeltPretRevFR  205 2033
       Serial number: 8W0857706A0316P00558
       Coding: 88001B
       Subsystem 3 - Part No SW: -----------    HW: 442 060 511 15
       Serial number: 3577Y00B51A87822D251
       Subsystem 4 - Part No SW: -----------    HW: 442 060 511 15
       Serial number: 3587Y009F1AF3CF2502H
       Subsystem 5 - Part No SW: -----------    HW: 442 0B2 010 15
       Serial number: 3517700B91D4A1D261BJ
       Subsystem 6 - Part No SW: -----------    HW: 442 0B2 010 15
       Serial number: 35277009D1D72E53607I
       Subsystem 7 - Part No SW: -----------    HW: 442 0C0 311 15
       Serial number: 3557500BF1C4D03140DG
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 442 0C0 311 15
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500C11C4D033B0BB
       Part No SW: 4M0 907 129 GT    HW: 4M0 907 129 GT
       Component: Lenks.Modul   H11 0008
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 0815854EB363C00FEF-805C
       Part No SW: 8W5 920 700 A    HW: 8W5 920 700 A
       Component: MM--T--BENRW- H11 0267
       Revision: 0226v3      Serial number:    LKLCU03BR
       Coding: 04AD50C02880000805002C001000000000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       VCID: 377736B28E1D7FF756-8062
       Part No SW: 4M1 907 468 A    HW: 4M1 907 468 A
       Component: Gateway       H13 4079
       Revision: 3B030052    Serial number: 5243B03A615A29
       Coding: 0301000100000F402600000000590012CC100000000000000100000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002040
       ROD: EV_GatewCONTIAU736_002_AU49.rod
       VCID: 356B3CBA94118DE744-8060
       Subsystem 1 - Part No SW: 8W0 951 523 A    HW: 8W0 951 523 A
       Component: J453 MFL  H06 0002
       Serial number: 20151102050349 RD259
       Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
       Component: J367-BDMHella  H10 9052
       Serial number: 8976588103
       Part No SW: 4M0 959 760     HW: 4M0 959 760
       Component: MEM-FS        008 0015
       Serial number: 00000176055450
       Coding: 00581B000000B0010000210101010000000000000000000000000000000000
       ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
       VCID: 75EBFCBAD491CDE784-8020
       Part No SW: 8W0 959 593 G    HW: 8W0 959 593
       Component: TSG FS        005 0052
       Serial number: 0000175431241
       Coding: 001D9A205E00008000001082
       VCID: 4E9973561187DE3F65-801A
       Part No SW: 8W0 909 144 D    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0405
       Coding: 09000080008000
       ASAM Dataset: EV_EPSZFAU49X 002015
       ROD: EV_EPSZFAU49X_002.rod
       VCID: 3E792396A1274EBF95-806A
    Address 46: Central Conv.
    Interface not compatible.
       Part No SW: 8W0 959 592 A    HW: 8W0 959 592
       Component: TSG BFS       005 0039
       Serial number: 0000175446955
       Coding: 001D9A205E00008000001080
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-STD2.clb
       Part No SW: 8W0 035 824     HW: 8W0 035 824
       Component: MU-S--ER      520 0621
       Coding: 01940100FF0A000013220001001A00002F0001C40170010002
       ASAM Dataset: EV_MUStd6C3DELP 001013
       ROD: EV_MUStd6C3DELP_AU37.rod
       Subsystem 1 - Part No SW: 8W0 919 604     HW: 8W0 919 604
       Component: AU49x_DU_STD  H40 0008
       Serial number: AUZ8Z9FBG008AU
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8W0 919 614 M    HW: 8W0 919 614 M
       Component: ControlUnit_B  H22 0134
       Serial number: C1000019091500050027
    0513 - Rear Right Treble Speaker
              B1068 13 [009] - Open Circuit
                        Reset counter: 151
                        Mileage: 46536 km
                        Date: 2020.02.21
                        Time: 17:58:34
                        Voltage terminal 30: 11.9 V
    Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
       Part No SW: 4M0 980 556     HW: 4M0 980 556
       Component: RVC Compact   H08 0130
       Coding: 0294010102002001000040
       ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
       ROD: EV_CamSysRVRVCPANAMLBEv_004_AU49.rod
       VCID: 72E1C7A6A5FFDADFA1-8026
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 8W1 713 041 E    HW: 8W1 713 041 E
       Component: GSM-LL        H07 0068
       Revision: 0L0D5012    Serial number: 20151109000229
       ASAM Dataset: EV_GSMWaehlZFAU736 001013
       ROD: EV_GSMWaehlZFAU736.rod
       Part No SW: 8W0 959 595 A    HW: 8W0 959 595
       Component: TSG HFS       005 0039
       Serial number: 0000175033981
       Coding: 000D98200000008000001080
       VCID: 4A917F46EDEFF21F39-801E
       Component: TSG HBFS      005 0039
       Serial number: 0000175034069
    End-------------------------(Elapsed Time: 04:47)--------------------------
    Scan with issues:
    Wednesday,26,February,2020,20:07:48:20731
    VCDS Version: 19.6.2.2 (x64)
    Mileage: 46918km-29153mi   Repair Order:
    VIN: WAUZZZF46HA001586   Mileage: 46918km-29153miles
    Address 01: Engine (J623-CVNA)       Labels:. 04E-907-309-V1.clb
       Revision: 44H21000
       VCID: 5CBD891E577B7CAF99-8008
       Coding: 000001
       VCID: 7CFDE99EF7BB9CAFF9-8028
       VCID: 47974672FEFD0F7724-8012
       VCID: 36693BB6891786FF4F-8062
       Coding: 5BC7F7
       Coding: 02005D
       Light switch:
    131364 - Headlight
              C107E 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 166
                        Mileage: 46832 km
                        Date: 2020.02.25
                        Time: 19:39:38
                        average_Voltage_terminals: 12.10 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 33.50 °C
                        interior_temperature: 26.00 °C
                        Vehicle speed: 0.00 km/h
       VCID: 06098B76B977D67F9F-8052
       Coding: 88001B
       Coding: 88001B
       VCID: 0815854EB363C00FED-805C
       VCID: 377736B28E1D7FF754-8062
       VCID: 356B3CBA94118DE746-8060
       VCID: 75EBFCBAD491CDE786-8020
       VCID: 4E9973561187DE3F67-801A
    196665 - Switch for Central Locking
              B122D 29 [008] - Signal Implausible
                        Reset counter: 208
                        Mileage: 46872 km
                        Date: 2020.02.26
                        Time: 12:34:19
    196724 - Motors for Central Locking
              B122B 13 [008] - Open Circuit
                        Reset counter: 208
                        Mileage: 46872 km
                        Date: 2020.02.26
                        Time: 12:32:45
       VCID: 3E792396A1274EBF97-806A
                        Reset counter: 166
                        Mileage: 46827 km
                        Date: 2020.02.25
                        Time: 19:15:03
                        Voltage terminal 30: 12.3 V
       VCID: 72E1C7A6A5FFDADFA3-8026
       VCID: 4A917F46EDEFF21F3B-801E
    End-------------------------(Elapsed Time: 04:44)--------------------------
    Address 09,8W0 907 063 AC,recoded (Long Coding),from,80453942451800CD01045118182C08F911033100000000000000000020001A2000400022025605,to,80453942451800CD01045118182C08F911033100000000000000000020001A2000400022025605,(06324/790/00001),
    Address 09-01,8W1 955 119 ,recoded (Long Coding),from,5BC7F7,to,5BC7F7,(06324/790/00001),
    Address 09-04,8W0 857 511 ,recoded (Long Coding),from,010000,to,010000,(06324/790/00001),
    Address 09,8W0 907 063 AC,channel IDE03679-Adaptive light functions,adapted from,not active ,to,active ,
    Address 09,8W0 907 063 AC,channel IDE03641-Presentation run dynamic AFS light,adapted from,active ,to,not active ,
    Address 09: DTCs cleared
    As you can see I tried recoding the modules with no luck.
    In case I changed something without running a log:
    Address 09,8W0 907 063 AC,channel IDE03679-Adaptive light functions,adapted from,active ,to,not active ,Tuesday,25,February,2020,19:14:43:20731
    Address 09,8W0 907 063 AC,channel IDE03679-Adaptive light functions,adapted from,not active ,to,active ,Tuesday,25,February,2020,19:15:09:20731
    Address 09,8W0 907 063 AC,channel IDE03679-Adaptive light functions,adapted from,active ,to,not active ,Tuesday,25,February,2020,19:15:23:20731
    Address 09,8W0 907 063 AC,channel IDE03679-Adaptive light functions,adapted from,not active ,to,active ,Wednesday,26,February,2020,20:31:12:20731
    Address 09,8W0 907 063 AC,channel IDE03641-Presentation run dynamic AFS light,adapted from,active ,to,not active ,Wednesday,26,February,2020,20:32:00:20731
    Address 09,8W0 907 063 AC,recoded (Long Coding),from,80453942451800CD01045118182C08F911033100000000000000000020001A2000400022025605,to,80453942451800CD01045118182C08F911033100000000000000000020001A2000400022025605,(06324/790/00001),Wednesday,26,February,2020,20:08:33:20731
    Address 09-01,8W1 955 119 ,recoded (Long Coding),from,5BC7F7,to,5BC7F7,(06324/790/00001),Wednesday,26,February,2020,20:08:57:20731
    Address 09-04,8W0 857 511 ,recoded (Long Coding),from,010000,to,010000,(06324/790/00001),Wednesday,26,February,2020,20:09:20:20731
    Address 09,8W0 907 063 AC,recoded (Long Coding),from,80453942451800CD01045118182C08F911033100000000000000000020001A2000400022025605,to,80453942451800CD01045118182C08F911033100000000000000000020001A2000400022025605,(06324/790/00001),Wednesday,26,February,2020,20:14:53:20731
    Feb 2020
    New Zealand
    At the bottom of your second scan - you have changed the Adaptive light function from not active to active - Address 09,8W0 907 063 AC,channel IDE03679-Adaptive light functions,adapted from,not active ,to,active ,
    Nov 2014
    Quote Originally Posted by Rollux View Post
    Yes. I was trying to see if that helped. It didn’t. I get the error message at either setting.
    Quote Originally Posted by m_bolc View Post
    I assume you did this via the Basic Setting?
    IDE03675 -- Basic headlamp setting
    After you made adjustments, did you then also do the following?
    IDE03676 -- Acknowledge basic setting
  5. Likes Eric liked this post
    Nov 2014
    I didn’t do the second step. Should I run it by itself or do I run the basic headlamp setting again?
    Apr 2018
    ITALY
    they need to be run in sequence. in between is when you turn the screws on the headlights.
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
  8. Likes Uwe liked this post
    Nov 2014
    All fixed now. Thanks all
  10. Likes Uwe, Eric, jyoung8607 liked this post
