Looking for some assistance tracking down possible causes for the below fault codes. Overall the car has been running well. Occasionally it would studder while driving at low speeds in traffic and occasionally shut off completely. Generally, it would start right back up and I'd go on my merry way. Unfortunately no CEL and no soft codes either. Yesterday the CEL officially came on and threw P2187. Lots of forums say it could be he PCV valve. I had mine replaced around 112k when the RMS blew, that was a fun $1,200 repair. I've also had 3 intake manifolds on this car, the last one most recently replaced under the extended warranty at 119k miles, right before the extended warranty expired. The code P2015 recently appeared along with P119A Fueld Pressure sensor. These might not be true as they are intermittent. I did recently replace the HPFP roughly 5,000 miles ago with the Bosch OE unit and new follower, thinking that would solve the rough idle and intermittent shutoffs...it didn't...I;ve also been smelling a pretty strong fuel smell each morning when I start the car up and let it idle(warm-up).
Anyways, I'd love to get some advice before I start replacing parts...I can easily replace the PCV myself but fear it may be something larger at play, faulty fuel injectors, 02 sensors, etc.?
Thanks!!
Thanks!!
Wednesday,26,February,2020,20:54:54:05814
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 62
65 72 77
VIN: WVGAV7AXXBW513584 Mileage: 288570km-179309miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 997 027 J HW: 06J 907 309 A
Component: MED17.5.2 TFSI 2 01 0393
Revision: P3H06--- Serial number:
Coding: 0423010A19070160
Shop #: WSC 55275 001 1048576
VCID: 3C2135162A6ACC87D5D-8068
008583 - Bank 1; System too Lean at Idle
P2187 - 000 - - Intermittent - MIL ON
Fault Status: 10100000
Mileage: 288450 km
Date: 2014.07.19
Time: 07:57:19
RPM: 766 /min
Load: 29.0 %
Temperature: 93.0°C
Temperature: 10.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - Intermittent
Mileage: 288291 km
Date: 2014.07.16
Time: 15:42:11
RPM: 710 /min
Load: 18.8 %
Temperature: 91.0°C
Temperature: 40.0°C
Voltage: 13.970 V
004506 - Fuel Pressure Sensor (G247)
P119A - 000 - Malfunction
Mileage: 288572 km
Date: 2014.07.19
Time: 20:44:43
RPM: 700 /min
Load: 21.6 %
Temperature: 84.0°C
Temperature: 30.0°C
Voltage: 13.716 V
Part No SW: 09G 927 750 LQ HW: 09G 927 750 LQ
Component: AQ 250 6F 1771
Revision: 00H90000 Serial number:
Coding: 0000840
VCID: 0B43A6CA3F443B3FAC7-805E
Address 03: ABS Brakes Labels: 5N0-614-109-C4.clb
Part No SW: 5N0 614 109 Q HW: 5N0 614 109 Q
Component: J104 C4 450 V2AE 0006
Revision: --H28--- Serial number: 00000003097523
Coding: 0002333
VCID: 392F2C022558F9AFCEB-806C
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: 75B7E03245405DCFEA3-8020
Part No SW: 5K0 937 087 L HW: 5K0 937 087 L
Component: BCM PQ35 H+ 111 0135
Revision: BL111001
Coding: 6D580A1B80232EC4808800851000050440015186524D8D605C8000000040
Shop #: WSC 01035 444 83785
VCID: 3E253F1E3076DE97FB9-806A
Subsystem 1 - Part No: 5N1 955 119 A Labels: 1KX-955-119.CLB
Component: WWS 170810 03 32 0010
Coding: 009795
Part No SW: 5N0 959 655 P HW: 5N0 959 655 P
Component: J234__204 VW10 HI 1918
Revision: 22014000 Serial number: 003GJPGLU9FP
Coding: 0012340
VCID: 4ACD63CE70BE6237571-801E
Subsystem 1 - Part No: 5N0 959 339 A
Component: BF-Gewichtsens. 001 0004
Subsystem 2 - Serial number: 00000000007WVZ
Subsystem 3 - Serial number: 0007.07.000000100000650007ÿ†63
Subsystem 4 - Serial number: 650007ÿ†6332MTS677742090 ÿ†63
Subsystem 5 - Serial number: 42090 ÿ†6342MTS617133065 ÿ†63
Subsystem 6 - Serial number: 33065 ÿ†6351HTS6PT7ED9KR ÿ†63
Subsystem 7 - Serial number: ED9KR ÿ†6361HTS6DBTOVVNR ÿ†63
Subsystem 8 - Serial number: OVVNR ÿ†63727TS61JVDD6KJ ÿ†63
Subsystem 9 - Serial number: DD6KJ ÿ†63827TS69HVDD6KJ ÿ
Subsystem 10 - Serial number: DD6KJ ÿ
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0140
Revision: --X01--- Serial number: 20140321101201
Coding: 198A140000
Shop #: WSC 43852 001 1048576
VCID: 025D8BEE048E7A77DF1-8056
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 820000
Part No SW: 5N0 920 972 B HW: 5N0 920 972 B
Component: KOMBI H03 0406
Coding: 210F00
VCID: 323D1B2EF4AE0AF70F1-8066
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 060810F2002468
Coding: FD807F0740061300006002
VCID: 2E050F5EEC162E176B9-807A
Component: IMMO H03 0406
VCID: 6A8DC34E1CFE8237771-803E
Part No SW: 5N0 035 342 C HW: 5N0 035 342 C
Revision: A1001003 Serial number: 7668529761
Coding: 020000
VCID: 270BFA7ACFEC7F5FA8F-8072
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 HW: 1K0 035 274
Component: RNS315-NAR H04 0007
Serial number: VWZAZ2K8409372
Coding: 040004210400000000001000
ASAM Dataset: EV_RNS315VWNARV1UDS A01005
ROD: EV_RNS315VWNARV1UDS.rod
VCID: 619FA462E1C8C16FA6B-8034
1048669 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Reset counter: 48
Mileage: 248085 km
Date: 2018.09.29
Time: 13:37:23
Part No SW: 5N0 959 701 D HW: 5N0 959 701 D
Component: Tuer-SG 009 2101
Coding: 0001205
VCID: 3635273E144616D7239-8062
Part No SW: 5N1 909 144 S HW: 5N1 909 148 K
Component: J500__APA-BS KL.285 1501
Revision: 1BH04843 Serial number: 00180380006301
Coding: 0000258
VCID: 42DD4BEE488EBA779F1-8016
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H25 5603
Coding: 050B0500
VCID: 6FBBD25A279C671F20F-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
02071 - Local Databus
Fault Status: 00101100
Reset counter: 213
Mileage: 287576 km
Date: 2014.07.09
Time: 11:20:27
Part No SW: 5N0 959 702 D HW: 5N0 959 702 D
Coding: 0001204
VCID: 372B2A3A134CEFDF38F-8062
Part No SW: 3AA 907 801 D HW: 3AA 907 801 D
Component: J540 EPB4 VW-53083 0006
Revision: H18 Serial number: 00000000066657
Coding: 0023057
VCID: 323D1B2EF82E0AF70F1-8066
Part No SW: 5N0 959 703 E HW: 5N0 959 703 E
Component: Tuer-SG 007 2102
Coding: 0001168
Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018704
Shop #: WSC 01035 444 12611
02801 - Hard Warning
Mileage: 281614 km
Date: 2014.03.13
Time: 09:48:28
Text: 3454295283
Pressure: 1.90 bar
Pressure: 2.40 bar
Temperature: 23.2°C
Text: C0
Speed: 29.0 km/h
Part No SW: 5N0 959 704 E HW: 5N0 959 704 E
Coding: 0001168
VCID: 3A2D330E205EF2B7C71-806E
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668349831
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
End----(Elapsed Time: 01:27, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
