Results 1 to 2 of 2
Thread: The meter not show the fuel in the tank. Golf Mk7 2014.
    Pirate
    Feb 2020
    Hello .
    Sorry for the language but I use a translator (I don't know English very well).
    My problem is that the meter does not indicate the fuel level.
    Wiring - OK (checked transitions to the meter),
    fuel level sensor - OK (removed, measured resistances ),
    meter - OK (VCDS control, fuel clock is working properly),
    Extended VCDS measurements
    1) IDE03473-MAS03798 fuel level sensor - raw value 1832
    2) IDE03473-MAS03799 fuel level sensor - raw value 1949
    3) IDE03474-IDE0034 calculated volume - fuel level 0.0 L
    When I move the connected level sensor - values 1 and 2 change, but the fuel level - NOT.
    Help - what's wrong
    Removed.   Data from a clone/pirate copy of VCDS is not acceptable here.
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#pl
  3. Likes Dana liked this post
